[Sammelthread] Mining Hardware und Software Smalltalk-Thread (Kein Handel oder Fragen zum Steuerrecht!)
lolminer-equihash 1.46 updated!
- Changelog -
Significantly improved the Ton performance in Eth+Ton dual mining for all supported GPUs. Gain is 15-20% over the old implementation at same Eth reward - combined with new tuning some cards can be much higher
(e.g. RX 580) while others optimize for more Eth hash rate (e.g. RX 5700)
Changed the Eth+Ton and Eth+Alephium tuning functions on AMD and all Nvidia non-LHR cards. Tuning now uses a scoring function to score resulting Eth and dual coin rewards and try to optimize this. Note that with --maxdualimpact you still can just define the max % of Eth hashrate to give away. This will overwrite the scoring function.
Added experimental Eth+Alephium dual mining kernels for Pascal GPUs.
API now also gives the worker name on Ethash, Ton and Alephium mining.
Ton stratum: https://next.ton-pool.com now using mode 2 automatically again. New whalespool server wss://stratum.whalestonpool.com/stratum now using mode 6 automatically.
Fixed a bug causing connection time out (for a retry) not working properly
Fixed a bug in Alephium stratum: miner did not check fail-over when primary worker name was not accepted by the pool
Fixed a crash when trying to specify more fail-over pools for dual algorithm then for the primary connection
Windows: fixed a bug causing dual mining (especially Eth+Alephium) freeze the card & driver on startup
Fixed some minor glitches
- Changelog -
mmpOS EU hat es schon. Mein zweiter Rig mit hive nicht. Ich werd gleich berichten!
mmpos - notifications, [21.02.2022 19:50]
[Worker002] Miner software stopped (BitCoin_TonPool)
[Worker002] Miner software updated (BitCoin_TonPool)
[Worker002] Miner software started (BitCoin_TonPool)
von 8,44 GH/s auf 10,24 GH/s 8-)
Nice, unter win 10 +250mhs bei einer 3080.
Du sollst deine 6700 nicht drosseln :whistle:
Habe keine Drossel drin??
So hive Rig mal manuell umgegradet.
mmpOS Rig 8.5GH/s --> 9.8GH/s
hiveOS Rig 7.4GH/s --> 8.8GH/s
Insgesamt also +2.7GH/s!
Ich habe 2 Sensecap in Betrieb. Laufen in gewisser Weise "wartungsfrei"
Überlegt ihr bei dem Antennenthema wirklich so lange? Die Stock Antenne kann man meist wirklich vergessen.
A New Hope (?)
A New Hope (?)
NICE
A New Hope (?)
Holy shit, da ist soviel BS dabei.
Das schreit ja nach Scam.
Da lasse ich erstmal andere testen.
Tickende Zeitbombe in beide Richtungen.
Wenn kein Fake -> difficulty wird rasant steigen
Fake -> könnte einigen Usern coins kosten
Mit lolMiner 1.46 Update:
Von 31GHs auf 37,5GHs, an der Wand ist der Stromverbrauch nahezu identisch.
Man könnte jetzt einen neuen Sweetspot suchen.
Welche Pool-Adresse für ton-pool verwendet ihr jetzt mit 1.46?
Die alte (https://next.ton-pool.com) oder die neue (wss://eu1.stratum.ton-pool.com/stratum)?
Ich habe die alte drinnen und bis jetzt keine Probleme.
Sensecap hat mir gerade angeboten anstatt im März den 8GB Miner zu bekommen, jetzt auf das gleiche Model mit 4GB zu wechseln, da es verfügbar ist.
Habe ebenfalls die alte TON-Pool adresse drin. Bin von 39,5 auf 48,5 hoch mit gleichen energieverbrauch. sieht nice aus (y)
Wenn er für Dich ist, würde ich auf 8 GB Version warten, da man nicht weiß ab wann die 8 GB gebraucht werden. Wenn Du aber kurzfristig unterwegs bist 4GB und los.
Seit dem ich wss://eu1.stratum.ton-pool.com/stratum nutze, sind bei mir die Probleme mit dem AMD Rig weg.
Ist für mich und ich warte, glaube der Merry hat doch schon nur 4GB, da reicht mir der eine zum testen.
Wie habt ihr eure Außenantennen ans Dach gemacht? Ich schau gerade bei SAT Befestigungen. Jemand ne bessere Idee?
Ich habe zwar mit Lolminer 1.46 auch die erwarteten 20% Steigerung bei TON, aber immer noch deutlich niedrigere Werte als oben gezeigt.
@dau0815 , würdest du deine Settings noch mal mit uns teilen?
