[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich finde es gut, wie ASUS die recommendation für das Netzteil bei der 4090 Strix macht:
Recommended PSU = 1000W
Note: * Our wattage recommendation is based on a fully overclocked GPU and CPU system configuration.
Wird sicherlich Thema sein!
Falls möglich wäre auch echt gut wenn ihr die Idle Stromaufnahme mit reinnehmen könntet, die RTX3000ér liegt ja so bei ca. 35W und springt bis 90W+ hoch für den reinen Desktopbetrieb, was ich irgendwie schon echt viel finde für Idle.
ATX 3.0 SFX-L-Netzteil von ASUS ab dem 05.10. verfügbar, falls jemand sein SFF-Case mit Ada aufheizen möchte. :d
Gibt es keine 1200W Netzteile? Nur bis 1000? :)
Puh, das wird nochmal echt teuer bis Ende des Jahres. Neue GPU, neues NT, neue CPU, neues Board, neuer Ram und evtl. neues Gehäuse 😔.
Edit: Anfang kommenden Jahres dann noch die Pcie 5.0 nvmes.
Was hast du denn für ein Board? Kein Z690?
Gerade mal die coverage auf YouTube gecheckt. Gerade mal 6 Videos in den letzten 24 Stunden weltweit über die RTX 4090. Keine Sau interessiert sich für die Karte. Außer die 10 hier im Forum :P
Von dem Modell soll es auch eine 1200W-Variante geben. Die ist aber bislang nicht gelistet. Generell leider sehr mau momentan die Situation mit den ATX 3.0-Netzteilen. Ich hoffe da kommt noch was bis zum 12.10.
Ich warte da noch zwei Jahre mit dem NT´s.
Mir kommt erstmal die 4090 an die Adapter .
Corsair wollte da noch was machen und mal schauen ob da noch was kommt für die alten Nt´s.
Für den Microfit kam ja auch erstmal ein seperates Kabel produziert und angeboten.
Fände es aktuell zu schaden das gute AX1000 Titan einfach raus zu schmeißen.
@Brandur : Musst ja eigentlich nichts schwer aufrüsten. 3090 TI raus und 4090 rein ,wenn du mehr Leistung brauchst.
CPU kannst du ja auch tauschen auf deinem Z690 Board wobei das wenig bringt, wenn du überwiegend zockst.
Alles andere ist eigentlich quatsch , außer hast absolut bock drauf , aber dann darf man auch nicht jammern :d
Zu schön um wahr zu sein. Am 12.10 gibts dann trotzdem nix zu holen es sei denn man ist sehr versiert oder hat glück...
Weiss man denn inzwischen ob's über Nvidia direkt geht oder NBB?
Fände es aktuell zu schaden das gute AX1000 Platin einfach raus zu schmeißen.
Ich hab hier auch ein Corsair HX1200i Platinum wäre cool wen Corsair da noch was nach Liefert!
Customspreise sind bisher in Ordnung. Hoffen wir mal, dass es auch so in Europa ist.
Ich wüsste jetzt aber nicht, dass z.B. die EK Kühler auf den Asus Karten qualitativ schlechter sind als die auf der Hydrocopper.
Ne, aber dafür das PCB/VRM und die Anzahl der Anschlüsse.
Denn Asus hat für die Karten mit dem EKWB nicht etwa das PCB der Strix mit 3x 8-Pin PCIe genommen sondern halt ein billigeres.
Die perforierte Backplate bei der letzten HC fand ich aber auch eher dämlich bzw. weniger gelungen.
Die haben einfach die Referenzplatine von Nvidia genutzt. Ansonsten wäre es ja auch keine Singleslot Karte geworden.
Interessant fand ich ja auch die 3070 EK mit 12 Pin Anschluss, verstehe nicht wieso der nur bei der 70er genutzt wurde.
Da es von beQuiet keine Infos über ein passenden Kabel zu finden gibt, war ich mal so frech und hab deren Kontaktformular genutzt. Sobald ich eine Rückmeldung habe, poste ich es hier rein. :)
Falles es jemanden interessiert, die Rückmeldung von beQuiet kam schon:
Sehr geehrter Herr …,
herzlichen Dank, dass Sie mit dem be quiet! Service Kontakt aufgenommen haben.
Bedauerlicherweise können wir Ihnen aktuell noch nicht mitteilen, mit welchen Karten der 4000er Serie dieses 12 Pin Dual-Rail Kabel kompatibel ist.
Die technischen Spezifikationen der Karten wurden zwar bereits bekannt gegeben, allerdings haben wir die Karten physisch noch nicht vorliegen um zu prüfen, welche Serie der Karten mit dem Kabel nutzbar ist.
Wir werden allerdings ein Kabel in absehbarer Zeit anbieten können, was alle Serien der 4000er Serie unterstützen wird.
Wir bitten Sie daher noch um etwas Geduld, da dieses Thema noch etwas frisch ist.
Vielen Dank.
Mit freundlichen Grüßen
Ja Gott sei dank ist ein Kabel wohl da.
Passt auf dein HX Platin und auf mein AX Titan (hatte irgendwie Platin im Kopf)^^
ist schon etwas von Seasonic bekannt? Idealerweise fürs Prime TX1000 ?
Naja die Kabel zumindest beim AX Titan sind auch immer 2x8 PIN pro Strang . Habe selber mir zwar Einzelstränge dazu gekauft , aber denke bei dem Kabel wird schon der Querschnitt schon passen , damit das geht .
Im Single Rail sollte es ja egal sein .
Ist mir so immernoch lieber als ein Adapter wo man mit 4x 8Pin dran geht .
Es gibt aber keine ATX 3.0 Netzteile oder kaum und dazu wenig Erfahrung.
Daher ist ein neues dafür entwickeltes Kabel vom Netzteilhersteller mir lieber.
Adapter ist immer kacke.
Denke von Bequiet und Seasonic kommt sicher auch noch was , aber denke ein gutes 1000 Watt Single Rail Netzteil sollte es dann schon sein
für eine RTX 4090. Sicherlich hören wir von Igorslab dazu noch etwas.
Werde sobald verfügbar mir das Kabel von Corsair ordern, weil habe ein gutes NT wo ich weiß das es was taugt.
Wenigstens eins mit passendem Kabel sollte es schon sein.
Mein (fast/ungefähr) 10 Jahre altes 1.2kW Corsair jedenfalls hat jetzt ausgedient.
Ich schieb mir ein Asus Thor in den Rechner. (Perlen für die Säue, sieht sowieso niemand, weil in verschlossener Kammer^^).
Ja bei dem alter kann man ruhig mal tauschen , wenn man so dicke Hardware verbaut .
Meines ist gerade mal 2 Jahre alt . Kann noch ein bisschen weiter laufen .
Ähnliche Themen
Antworten
6K
Aufrufe
392K
