[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gut das die Tests einen Tag vor Verkaufs Start kommen hoffe das dann keine Fragen Ofen bleiben im Bezug auf Powerlimit usw.
Bin auch gespannt welche die beste Luftgekühlte sein wird.
Man die Strixx finde ich schon sehr lecker.
Ja die strix macht wie immer nen guten Eindruck…. Aber der preis 😂. Ich hoffe dass dann auch bald ein wb für die suprim x raus kommt. 😅
@Marius250 Wenn du eh auf Wasser umbauen willst, kannst du auch ne TUF für 2050€ nehmen. Die PCB bzw. Wasserblöcke sind gleich.
Umbau richtig erlaubt glaube ich niemand mehr. Aber statt eine Strixx zu strippen tuts ja auch eine TUF. Wenn die Blöcke eh die gleichen sind.
nvidia verweigert explizit die Garantie bei Kühlerdemontage. Ich hatte nach knapp 2 Jahren nun 3 defekte 3090FE die auf Wasser umgebaut waren und in einem Server liefen. Bei 2 wurde die Garantie verweigert, 1 ist durchgegangen. Eine gute Quote sieht anders aus.
Oha! :S woran haben die es gemerkt? Andere Pads? Und was war der Defekt?
Das sieht ja nicht sonderlich rosig aus bez. Lieferbarkeit. Bin mal gespannt ob ich eine kriege. Tendiere zur Aorus da Kühler am größten :)
Warum steckt in deinen Beiträgen eigentlich oft so viel Frust, fast schon Hass? Du wirkst auf mich ziemlich verbittert.
Ja der ist nice. Aber warum habe die die Backplate nicht stabiler gemacht? Ich verstehe das nicht. Das ist doch so offensichtlich dass man bei dem Preis und der Wucht auch für ordentlich Stabilität sorgen sollte. KP wer da im HomeOffice ein bissel in Blender rumgespielt hat und sowas bei rausgekommen ist :(
@Marius250 Ich habe hier eine 3080 Suprim mit Alphacool Block die wirklich klasse ist. Kein Spulenfiepen usw. Aber eigentlich möchte ich den großen Umbau inkl. Wegwerfen des Luftkühlers nicht mehr. Das Konzept der Inno3D mit Reference PCB, ALC Block und schneller Verfügbarkeit zum Launch finde ich daher interessant. 450W Bios eher nicht so. Wahrscheinlich werden wir es hier einfach ausprobieren müssen.
Genauso die msi …. Nur anderes bios. Aber durch biosflash ist die Garantie weg
Ich hatte ne rtx 3090 ichill x4 mit Alphacool wb und shuntmod….. die hat gefiept wie ein Weltmeister 😂. Daher dieses mal ne custom mit hochwertigen Drosseln. Msi soll dieses mal wert auf leise Drosseln gelegt haben
Wie gesagt, ein Techniker mit etwas Ahnung sieht das, egal was du machst. War alles im einwandfreien Ursprungszustand.
Kaputt war bei allen 3 Karten der GDDR6X Speicher. An den Temperaturen kanns übrigens nicht gelegen haben.
Ich kenn proshop nicht direkt. Versenden die aus DE ?
Hab da mal bestellt, musste leider beim DDR5 auch lange warten obwohl lieferbar war. Ansonsten netter Service und lief alles gut. Einziges Mako, der Shop scheint bei keinen Aktionen wie Cashbacks usw mitzumachen. Zumindest letztes Jahr konnte ich deswegen kein 30€ Steamgutschein holen :/
Also von der Ampere Suprim kann ich nur Gutes berichten. Wenn zum Launch verfügbar, werde ich wohl erst die Frostbite testen und halt bei nicht-gefallen zur Not wieder problemlos zurückgeben.
@****** Einfach Standard Ware, ref-pcb, ALC Block inkl. Garantie und zum Launch lieferbar. Das Paket hat halt sonst niemand für die Wakü-Jünger zu bieten. Es kann natürlich sein das sie es verkacken, aber dann sind alle Karten mit ref-pcb Mist.
Hmm damn. So kaputt dass die nichtmal mehr angingen oder wurden iwelche Fragmente usw. angezeigt? Womit hast das getestet?
Würde ansonsten meine auch mal testen. Noch habe ich 1 Jahr Garantie.
Wenn die Kühler so überdimensioniert sind wie ja aktuell behauptet wird stellt sich halt die Frage ob sich ein Wakü Umbau unbedingt lohnt.
Hier gibt es halt gravierende Abweichungen bei dem Gewicht von Hersteller zu Hersteller von 2KG bis 2,5KG ist alles dabei .
Wie gesagt erstmal schauen was die Tests zeigen werden wo die Temps bei OC liegen sowie Lautstärke Takt und so weiter!
Mit Inno habe ich wenig am Hut, aber das Referenz Design kommt von Nvidia und war in der Vergangenheit nicht besser oder schlechter als die Platinen der FE. Da diese ja bereits 600W bestätigt haben würde mich das doch sehr wundern, aber bei Nvidia kann man nie wissen.
@Thunderburne Meine Wakü ist etwas anders aufgebaut als meist üblich. Kompromisslose 0-db und auch die Abwärme wird aus dem Raum geführt. Aber ich möchte hier nicht zu off-topic werden. Wenn sich jemand für den Aufbau interessiert, Link ist in der Signatur.
Achso dann hab ich da was verwechselt gestern, finde die TUF dann aber immerhin vom Äußeren schöner :>
Ähnliche Themen
Antworten
6K
Aufrufe
389K
