[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nachricht gelöscht
Mich wundert das EK noch keine Blöcke fürs Ref-Design vorgestellt hat. Hat das bei den 30er Karten auch länger gedauert?
Vielleicht nicht and Lay-out gekommen vor Launch? Alphacool hat ja den Frostbite Block gemacht daher hatten sie sich alle Daten so früh vor Launch….
Ich will hier niemandem auf die Füße treten, und auch sicher keine Rechtsberatung abgeben, aber den Unterschied zwischen Garantie und Gewährleistung scheinen einige zu verwechseln. Die Gewährleistung hat mit dem Hersteller nichts zu tun; sondern nur mit dem Händler. Gewährleistung heißt auch nur, dass die gekaufte Sache zum Übergabezeitpunkt (Gefahrenübergang) frei von Mängeln war. Ein Defekt zu einem späteren Zeitpunkt ist nicht automatisch ein Fall für die Gewährleistung. Garantie dagegen ist vom Hersteller, und da kann der Hersteller nach eigenem Ermessen Regeln und Bedingungen aufstellen. Miteinander zu tun haben die beiden Dinge aber nichts. Unabhängig davon kann man davon ausgehen, dass ein Händler sich querstellen wird, wenn nach einem Umbau auf Wakü ein Defekt auftritt und das als Gewährleistungsanspruch geltend gemacht wird. Eine umgebaute Karte entspricht halt leider nicht dem gekauften Produkt; es sei denn, man kauft bereits eine Karte mit Wakü-Block vom Händler.
Wird viele nicht interessieren. Sie werden es trotzdem versuchen. :hust: Bin aber ganz deiner Meinung. Hoffe alle werden abgelehnt so wie es sein sollte.
So ist es. Der Händler oder Hersteller versucht im besten Fall dann nur ein Garantiefall abzuwickeln der aber völlig auf Kulanz basiert. Ein Anspruch besteht nicht. Es sei denn in den Garantiebestimmungen ist eben definiert, dass eine Kühlerdemontage von der Garantie abgedeckt wird. Außer bei EVGA hab ich sowas allerdings noch bei keinem anderen gesehen.
Werde meine Karte so oder so erstmal unter Luft verbauen und ausreichend testen bevor die auf Wasser umgebaut wird . Habe ich mit der Gainward auch gemacht , weil die geben auch keine Garantie bei Kühlerumbau .
Das ist halt so und wenn die Karte dann doch irgendwie stirbt , dann ist es halt so . Die Hersteller machen ja auch Garantie Siegel drauf und die Pads von denen fallen ja auch auseinander . Man kann natürlich mit viel Feingefühl arbeiten und in Falle einer Garantie versuchen dennoch die Karte zu tauschen .
Wenn das Kind eh in den Brunnen gefallen ist könnte man es trotzdem probieren und hoffen der Bearbeiter hat einen guten Tag .
Wie ich schon mal geschrieben habe, bei Hardwareluxx ist MSI-Support dabei, falls Probleme geben sollte. Meine 2080TI von MSI wurde repariert, obwohl ich den Sigel entfernt habe und extra darauf hin gewiesen habe, dass sie unter Wasser lief. Der Siegel auf der Schraube bei MSI ist nicht für Deutschland gedacht hat der nette Kollege gesagt. Ich teile nur meine Erfragung, meine nächste wird wieder MSI werden, da ich selbst gerne umbaue.
Von Reddit:
Ich bin stiller mitleser, ich bin dieses Mal auch echt am überlegen was ich mache. Habe sonst auch immer auf Wasserkühlung umgebaut aber ist es das jetzt wirklich noch wert ? Ich habe mal eine 980 zerstört weil der Block nicht passte aber dank EVGA kein Problem wurde ohne Murren getauscht. Habe dann bei dem Wasserblock eine Aussparung gefräst und alles war gut.
Diesen Stress will ich auf keinen Fall mehr haben. Ich versuche eine Frostbite zu bekommen sollte das nicht klappen wird es in der Reihenfolge eine Suprime,Tuf oder am Ende eine Strix die ich dann auf Luft belasse.
Am Ende will ich das Ding sowieso Untervolten da sollte Luft ausreichend sein. Ich zocke viel mit VR, viele Stunden Assetto Corsa mit Mod das heizt extrem ein. Und ich bin sehr gespannt ob ich mit der 4090 in Hunt Showdown endlich in 4K mit stabilen 90FPS zocken kann.
Zur Verfügbarkeit denke ich das der erste Rutsch sehr schnell vergriffen sein wird, ich würde gerne Wissen wieviele Leute hier mitlesen und sich niemals anmelden.
wakü hat wohl bei der 4090 wohl den vorteil dass die karten wieder ins case passen :d
ansonsten solange die karte unter last fiept, hab ich von einer wakü relativ wenig
Ich denke auch das am Anfang wahrscheinlich alles vergriffen sein wird.
Ordentlich Mehrleistung scheint ja dazusein und bestimmt wird auch nicht so viel geliefert um die 3xxx noch wegzubekommen.
Die Suprime Liquid lacht mich ja auch an wenn da ein 360 Radi dran wäre würde ich die auch kaufen aber der 240 ist Lachhaft wird nicht ausreichen.
EVGA hinterlässt diesbezüglich eine Große Lücke!
  • Danke
Reaktionen: A6
Bin mal gespannt ob AC diesmal was für die MSI Suprim X rausbringt, wie gesagt ich werde erstmal abwarten, auch wenn es mir schwerfällt, will nicht wieder alles 5x kaufen😅
Ich vermute mal eher nicht.
Mit der 3090 hatten die sich schon so angestellt :sleep:
Befürchte ich auch, sonst wird es wieder Bykski oder Corsair, ich denke da kommt bestimmt was.
Ich vermute mal mitte oder ende November wird es so weit sein.
Unfair, dass man schon in Österreich vorbestellen kann :)
Ach zu den Preisen die e-tec verlangt vollkommen uninteressant, die bekommen die Ware von Ingram Micro, die Zotac Amp kostet im Einkauf 1660 netto sind unter 2k VK Brutto, E-tec verlangt viel mehr
Bei den Tests werde ich diesmal auch mehr auf die Lukü Temps schauen .
Die Strixx ist mit 2,5 KG ein Schwergewicht mal schauen ob die auch so Performen tut .
Die Colerful war bisher die 2t schwerste mit über 2,4 kg .
Die Master sieht auch interessant aus da kenne ich das Gewicht noch nicht !
Die restlichen Karten lagen alle er bei um die 2KG mal sehen wie das bei den Temps aussieht!
Die Suprim war top bei der 3090 Ti und eventuell ist die Tuf da auch sehr gut.
Bin echt gespannt auf die Tests hoffe am 11 erfährt man was zum. Powerlimit der Frostbite.
Joa dann verdient CK an so einer AMP ca. 375 € , wenn die Zotac ca. 1975€ mit Mehrwegsteuer kostet.
Wenn ich mal denke , dass damals vor Ampere der kleine Händler um die Ecke garkeine Karte verkauft hat , weil der Gewinn zu gering war.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
