[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ist aber kein ATX 3.0 Netzteil .
Denke mit einem guten 1000watt kommt man locker klar . Also im Härtefall 600 GPU + 250 CPU und Board + schnick schnack 50-60 Watt . Das sollte gehen . Im Gaming ist das alles wesentlich weniger . Glaube auch garnicht , dass die 4090er 600 Watt schlucken .
Laut Hersteller Corsair ist es Voraussetzung 1200 bei einer GPU mit bis zu 600w zu betreiben
Lg
Ja nun, Corsair würde dir auch gern 1600W verkaufen :d
Hast Du Erfahrungen mit Pfändungen @MADman :-)
Ich selbst zum Glück nicht, ich lebe nie über meine Verhältnisse und habe immer ausreichende Reserven bevor ich mir irgend etwas anschaffe, ich plane und bugettiere viel. Aber ich hatte schon Berührung im Bekanntenkreis mit dem Thema ALG2 und Pfändung, daher weiss ich das ein oder andere noch ;) Was auch der Grund ist warum meine alte Hardware nie auf ebay oder auch sonst wo selten verkauft wird, ich verteile daher lieber u.a. in diese Richtungen oder im Bekanntenkreis wenn es geht. Und es trägt auch dazu bei, das ich immer wachsam bleibe was meine eigenen Finanzen angeht. Weil man ohne Geld in unserer Gesellschaft relativ am Arsch ist.
Daher bin ich froh das ich mir guten Gewissens eine 4090 leisten kann wenn ich eine haben will, weil ich das Geld dafür schon lange in einem Budget zurückgelegt habe, weil es mein Hobby ist und meine mentale Gesundheit aufrecht erhält. Ok, mehr oder weniger :d
Wenn Du es zusammen mit einem Threadripper und der 4090 betreibst: Ja.
hihi, kann ich bestätigen, bis letzte Woche hatte ich einen Threadripper und zusammen mit der 3090 hat mein Rechner in manchen Games über 1000W verbraucht. 1000W wäre da zu eng gewesen :)
According to these results, the RTX 4090 is at least 82% faster than RTX 3090.
Die 4090 wirkt von der Perf. eher wie eine Gen weiter. Wenn das alles stimmt, heftig.
Beim Einbau der 4090 gelten zusätzliche Sicherheitsregeln
Viele Karten lassen sich über Geizhals jetzt aufrufen und können in österreichischen Shops in den Warenkorb gelegt werden. Ob sie kaufbar sind kann ich aber nicht sagen.
Die haben bei meinem HX750i in Verbindung mit der 3090 schon gesagt, dass das nicht ausreicht. Hat gereicht, gut für Ada OC no way...
Auf meinem Rm750x läuft meine 3090 @400W ohne Probleme über einen 8- Pin Anschluss am Netzteil. Denke die 4090 wird auch kein Problem werden.
Ergibt nur den Shice:
Auch OC meinst du? Hmm wenn ich das so summiere, dann raucht das Netzteil ab. 600W Graka +150W Board etc. +100W CPU= 850W 💥
Also laut dem Test hier kann mein Netzteil über 900W sogar ausspucken. Die Dinger von Corsair verkraften schon einiges. Aber ich will auch keine 600W PT verbraten. Die 450-500W reichen mir total.
Top. Alles ohne OC der GPU und Speicher. Bestimmt so um die 28-29K möglich bei guter Kühlung und OC.
Moore‘s Law is dead sagt sehr gute Verfügbarkeit für den Launch vorraus (in US)
Klingt super! Aufgrund der Größe werden viele wahrscheinlich zur Founders greifen. Und nur wenige zur Master. Auch die Wakü Fans werden wahrscheinlich nur zur FE oder Strix greifen
Spricht alles für eine gute Verfügbarkeit.
Ich würde jedem raten auf keinen Fall direkt beim Launch in Euphorie zu verfallen und wenigstens ein paar Tage zu warten.
Die paar hundert Euro, sitzen nicht nur mehr in eurer Brieftasche, auch die Händler passen relativ rasch die anfänglichen Scalper-Preise an.
Bonus. Bestätigt alles aus der Vergangenheit.
80% schneller in Games average ohne DLSS und RT und fast doppelt so schnell in RT Games.
Über die Leistung sollte eigentlich keiner meckern können. :)
Jo. Das ganze Video ist sehr interessant. Kann man sich komplett geben.
  • Danke
Reaktionen: SH
Gibt es Infos, was bei der TUF auf dem PCB anders sein soll? (Angeblich ist nur das PCB das Gleiche, wie bei der Strix)
Das PCB von Strix und TUF ist nicht 100% identisch. Zum Beispiel ist der Switch vom dual Bios mal hinten, auf der andern Karte vorne.
Ich hatte in den letzten Tagen aber ganz freundlichen Schriftverkehr mit Firma Optimus aus Chicago und laut deren Aussage ist der 4090 Wasserkühler kompatibel sowohl mit Strix als auch TUF. Es wird auch einen Vertrieb über einen deutschen Händler geben. Jetzt bin ich schon ernsthaft getriggert :unsure:
Mich wundert das EK noch keine Blöcke fürs Ref-Design vorgestellt hat. Hat das bei den 30er Karten auch länger gedauert?
Hier übrigens nochmal die Info von Bequiet zu dem neuen Kabel:
@be quiet Support Kann ich das PCIe 12-Pin Dual-Rail (EBN016) Kabel auch für die RTX 4090 verwenden, welches schon im Shop bestellt werden kann?
Technisch möglich ja. Dafür freigegeben ist es nicht.
Das neue 12VHPWR Kabel hat einen anderen Querschnitt und daher empfehlen wir nur die Nutzung dieses Kabels.
Daher bitte lieber auf das Kabel warten....
Richtig interessant wird erst ob DLSS 3 funktioniert wie angepriesen. Mit einem vertretbaren Kompromiss aus Latenz und Bildqualität könnten sich die FPS dadurch nochmal verdoppeln.
Die FPS verdoppeln sich nicht so wie wir es kennen.
Der Visuelle Fluss wird verbessert ja!
Aber die erzeugten FPS werden nicht wirklich an die HZ des Bildschirm gekoppelt .
Bei echten120FPS 120HZ hast du ja einen Inputlag von glaube 8,3ms bei DLSS 3.0 + Frame Generation 120FPS jedoch ehr um die 16ms weil das 60HZ entspricht!
Bei NV auf der Seite siehst du die ganze Geräte Kette bei 62 FPS Mit DLSS 2.0 hast du 58 ms mit dem 3.0 100FPS auch um die 55-60ms mit aktiviertem Frame Generation +aktiviertem Reflex dieser Wert entspricht einem 60HZ Monitor jedoch müssten es 100HZ glaub ca 10ms sein damit man von verdoppelten FPS sprechen kann.
Das ist ein super Feature für Single Player wenn in einem Spiel nur noch 40-60FPS drin sind um den visuellen Bildverlauf zu verbessern .
@Thunderburne So ähnlich habe ich es auch verstanden und darum bewusst auch von einem Kompromiss gesprochen. Wenn ich die Wahl zwischen 60FPS mit 8ms Inputlag oder 120FPS mit 10ms Inputlag wüsste ich glaube ich wie ich mich entscheide. Ist aber ein super interessantes Thema und das wird man noch ausführlich testen müssen.
Da gefühlt die halbe Ada GPU aus künstlicher Intelligenz bzw. Tensor Cores (hellgrün) besteht glaube ich schon das ist keine simpler Software Trick wie Zwischenbildberechnung am Fernseher. Ob und wie das alles funktioniert bleibt natürlich spannend.
Finde ich auch !
Nur wir sollten nicht von doppelter FPS sprechen weil das Trift es ja nicht!
Wen dann von einem verbesserten Bewegt Bild!
Den das diese Form von Zwischenbild Berechnung alle anderen Methoden in den Schatten stellen wird Zweifel ich nicht an .
Das wird ein cooles Feature .
Ähnliche Themen
