[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie beurteilt ihr die Chancen auf Amazon eine 4090 zu bekommen?
Wenn du den richtigen Link hast, geht das prima. Ein Freund hat damals sehr früh zwei Asus Karten gekauft, musste aber lange warten. Wenn man aber überlegt für das die ein halbes Jahr später gehandelt wurden...
Schon krasser Kühler aber auch einen Stolzen Preis
Hatten wir das Unboxing hier schon???
@Thunderburne Nachdem die riesigen M2 Kühler in Mode gekommen sind, kollidiert eine aktive Backplate auf vielen neuen Mainboards. Gerade im high-end wie z.B. dem Asus Crosshair.
Danke für das Video. Es wird verkündet das die OC Modelle vorselektiert sind. Aber ein richtiges binning kann ich mir eigentlich nicht vorstellen. Wie seht ihr das?
Mich würde mal interessieren, wer sich welche Karte holt…? Msi - Gigabyte - Palit- Asus….zb
Lg
Lg
Da meine Lieblingsmarke leider keine Grafikkarten mehr baut wird es eine Msi.
Gigabyte zu viel Plastik und mit Asus habe ich nur schlechte Erfahrungen gesammelt.
Lg
Lg
SUPREME X // Strix // TUF // Aorus Master
In der Reihenfolge wie ich was bekommen kann
Ist die Frostbite immer noch nur bei proshop und nbb gelistet? Wer verkauft sonst noch normalerweise Inno3d?
Bin gespannt was die Tests zeigen wenn ich alle Karten so ansehe glaube ich das Gigabyte die meiste Kühlfläche bietet und könnte so einen der vorderen Ränge erreichen es sei den sie versauen es wieder mit der LüfterKurve. Die wir natürlich anpassen aber so die Wertung negativ beeinflusst.
Frostbite/Suprime/Strix/Tuf
Frostbite x Liquid oder die normale x sind meine Favoriten
Suprim X 😁
Kühler ist mir eigentlich Wurscht, wird eh gleich auf Wakü umgebaut.
Gibt es denn schon einen Kühler für die Suprim?
@Ronchan411 Ich hatte mal eine 3080 Frostbite bei equippr.de reserviert die konnte aber nicht geliefert werden.
Vielleicht kann @INNO3DStephan sagen welche Händler was von euch bekommen?
Ich weis, NDA und so aber viele Enthusiasten hier fragen sich ob die neue Frostbite ein hartes Powerlimit bei 450 Watt oder wie offenbar alle anderen Karten inkl. der Founders Edition bei 600 Watt hat. Bevor wir jetzt alle die Frostbite kaufen und frustriert zurückgehen lassen weil sie doch nicht so "brutal by nature" ist, wäre die Info zum Powerlimit sicher in beiderlei Interesse.
Hatte ich ihn schon gefragt im inno Support Bereich, konnte er leider nichts zu sagen.
Wen die 600W liefert dann wäre es auch mein Favorit weil nach Dualbios sieht es ja nicht aus bei der Karte sonst könnte man da auch eventuell sorgenfrei Flashen.
Aber ist die Suprim Referenz Design? Ich glaube eher nicht, dann nützt mir der Block j auch nichts,
Meine nämlich, dass es noch keinen konkreten Block gibt. Auch wenn von ALC und Bykski bestimmt was kommt.
Aber trotz großem Gehäuse, passt die Karte mit Luftkühler für den Übergang nicht in mein System, da ich intern noch Pumpe, AGB und einen 480er habe.
Deswegen abwarten bevor man irgendwas kauft wo nicht wirklich passt😉
Die Karten laufen ja nicht weg😄
Oder den AGB einfach an den Mora ran. :)
Hab kein AGB verbaut, nur Distroplate vorne.
Corsair könnte auch was bringen.
Yep, auf dem ROG Strix X670E-E war für den zweiten und dritten m.2. Slot auch extra ein "massiver" Heatsink beigelegt, den man alternativ zu dem normalen montieren kann. Ich habe ihn nicht verwendet, weil mir gleich aufgefallen ist, daß es da mit einer 4090 eng werden würde. Vielleicht mache ich das dann wenn ich sie man auf Wasser umgebaut habe, dann passt es.
Hatte schon mal gefragt leider keine Antwort bekommen.
Mal ne blöde fragen. Ich kann ja zwecks mein Tower die Karte "NUR" Vertikal ( bis der WB da ist ) einbauen. Meint ihr es gibt hier Gewichtprobleme ? Und könnte hier mir irgendwas an mein MB schrotten ?
Das ganze sieht ja bei mir so aus ( mom bilder folgen)
Wüsste nicht was da passieren sollte, die Karte ist doch verschraubt
Naja ich weiß nicht aber von Bykski Kühlern hört man eigentlich wenig Beschwerden hier, naja...
Ähnliche Themen
