[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hier der Status bei Cyberport von einer Bestellung von gestern:
Da denk ich mir: Ja was denn nun? Habt ihr die Karte oder nicht? :d
Naja, im besten Fall ist das so eine Außenlagergeschichte und das Teil muss noch an einen Ort gebracht werden, wo es dann für den Versand verpackt werden kann.
Ich bin gespannt. Wäre meine erste Grafikkarte von Cyberport seit über 2 Jahren.:ROFLMAO:
Woher weißt Du das?
Siehe hier Post 10
Hatte ich damals bei meinem dort bestellten 3700X auch angezeigt bekommen. Ergebnis der Nachfrage war, dass sie gerade nichts vorrätig haben und ich den 3700X daraufhin storniert habe.
Macht ja auch irgendwie Sinn. Der Block erscheint bald erst und dann muss der noch montiert werden. Plus Lieferzeiten.
Der Block kommt nächste Woche in den Verkauf, sprich er kommt aus China an ;). Und die Karte wird doch auch in China gemacht, da montierst du das Zeug ja nicht in der EU, sondern vor Ort. Von daher nicht ganz nachvollziehbar, warum sie später kommt.....
Gibt es hier User die Erfahrungen mit MSI und der Gaming Trio Serie gemacht haben?
Ich konnte eine eine Gaming Trio erwerben und die Jahre davor war ich stets bei Gigabyte Aorus.
Kann man da was zur Kühlung und deren Lautstärke schreiben ?
Hat jemand übrigens schon Versandbestätigungen aus dem Asus Shop? Meine hängt noch bei "bezahlt" und Versand "offen".....
Hatte nur eine RTX2080 Super Gaming X und RTX3080TI Gaming X. Beides super Karten und extrem leise. Denke das wird bei der 4090 nicht anders sein
Computeruniverse hat gerade "Ware bereit zur Auslieferung" Mail an mich geschickt, Asus TUF non OC :-) Muss ich die Tuf vom Asusshop wieder stornieren.
EDIT: Wie kontaktiert man beim ASUS shop den Support um die Bestellung zu stornieren? Das ist ja mal komplett unübersichtlich dort...
Habe für die TUF (non OC) eine Bestätigung und DHL Tracking. Wurde jedoch gestern nicht mehr losgeschickt.
Bei mir das gleiche. Hatte von denen meine 3090strix
Welche Uhrzeit bestellt? Ich hatte sie erst nach 20:00 Uhr gekauft....
Annahme Deinerseits oder konkretes Wissen?
So eine wassergekühlte Karte ist in der Handhabung ja doch etwas aufwändiger als eine luftgekühlte Karte. Da würde es mich nicht überraschen, wenn so eine Karte erstmal regular mit Luftkühler aufgebaut und getestet wird. Ist dabei alles ok, dann übernimmt jemand anderes abseits des normalen Ablaufs den Umbau.
Das ist wie mit gewissen Sonderausstattungen für Autos, die man auch nicht ab Werk bekommt. Das passt dann dort nicht in die üblichen Abläufte/Taktzeiten und muss daher nachträglich vom Händler erledigt werden.
Wenn man dann diesen Zusatzaufwand berücksichtigt + den Luftkühler, der erstmal montiert wird (und dann in die Tonne wandert?), dann wundert es einen auch vielleicht nicht mehr, wenn so eine Karte mindestens so viel kostet wie die luftgekühlte Version + der separat gekaufte Wasserkühler.
Das sind aber auch alles nur Überlegungen meinerseits auf der Basis von Beobachtunen, die ich in anderen industriellen Fertigungsumfeldern gemacht habe.
Edit
Imho vielleicht ganz gut vergleichbar zu der Geschichte mit den Wasserkühlern bei einer sonst luftgekühlten Grafikkarte:
Da werden Fahrzeuge bei VW erstmal mit einem Verbrennungsmotor komplett zusammengebaut.
Bei Abt kommt der Verbrenner dann wieder raus, weil nun auf E-Antrieb umgebaut wird.
Bei der 4090 werden halt zum ersten mal die zusätzlichen 4 'Data' (Sense) Pins verwendet.
Und wenn die beim Adapter nicht belegt sind startet die Karte überhaupt nicht.
Zum Starten der Karte muß Psense#1 auf Masse liegen und damit statt 450Watt 600 Watt freigegegen werden muß zusätzlich noch PSense#0 auf Masse.
Igor beschreib das hier incl. wie das Nvidia mit den Stomadaper gelöst hat:
Also ganz einfach alte Adapter funktionieren nicht mehr.
D.h. wenn man eine 4090 mit "nur" 3 Pins belegen will, muss auf jedenfall #1, #2 und #3 genutzt werden und nicht #4, #3, #2? Sind die Pins am offiziellen NVIDIA Adapter nummeriert?
Die 3080 Trio war sehr gut von der Lüftung her, hat man auch sehr leise laufen lassen können, mit Powerlimit. Vergleichbar mit TUF, vllt minimal ineffizienter.
Hoffe für dich, dass das schneller, wie bei mir läuft. CP lies mich ganze 4 Monate auf die Strix OC warten :rolleyes2:
(wollte die wahrscheinlich nicht sofort rausrücken, weil sie sie billig verschleudert hatten :d)
Hab zumindest die Lieferansagen aus dem AC Forum dahingehend gedeutet, dass die Ware per Schiff von irgendwo kommt, muss natürlich nicht China sein ;). Müsste man die Karte nicht vielmehr mit dem Wasserblock durchtesten, ob alle Temps stimmen, keine Leaks und nicht auf dem Luftkühler? So oder so, testen muss man sie wohl ;). Mein Traum wäre immer noch ne nackte Karte - nur PCB - kaufen zu dürfen, aber das wird wohl nie passieren ;).
Hi, sehr interessanter Thread hier, hab mir mal die letzten paar Seiten durchgelesen. Gibt es eine Übersicht welches powerlimit die einzelnen custom Modelle erlauben ? Habe hier eins gefunden, aber da waren fast nur die high end Modelle der Hersteller aufgeführt. Mich würde das maximale powerlimit auch der günstigeren Modelle wie Gigabyte windforce etc. Interessieren.
Niedriger aber so wie sie das hier anhört ist mehr auch gar nicht nötig.da die Karte mit weniger als stock deutlich effizienter läuft
Gib die Andere du einem Bedürftigen hier :-)
btw:
Die TUF wurde ja um 20€ erhöht. Die Strix OC nur um 1-2€
Hab versucht beim Asusshop anzurufen, alle Leitungen belegt. Habe auf AB gesprochen mit Bitte um Storno. Falls die Karte doch geschickt wird, gebe ich sie natürlich gerne hier an einen Interessenten weiter.
Sehr nette Ergebnisse.
Meine Gamerock OC geht jetzt doch an einen Kumpel, der hängt noch auf einer 1060 3GB rum und wollte jetzt komplett upgraden.
Hatte auch ne Storno von NBB, hatte sich so gefreut vor der Schicht noch eine zu kaufen und nach der Schicht den Storno gesehen.
Bei mir drückt es nicht mit der 4090 und er freut sich so, gute Tat für dieses Jahr erledigt :d
Beste Grüße und viel Spaß mit den 4090, vielleicht darf ich die Gamerock mal kurz bei mir rein bauen :d
PS: Und nein, ich schlage nix auf :d
So, jetzt hab ich ne 2te Gamerock, die ist dann dieses mal für mich
:d
Ist aber die nonOC, OC brauch ich nicht, mir reicht die Renderleistung stock schon aus.
Beste Grüße
Das kann dann ja immer noch bei dieser Sonderbehandlung passieren, die ich genannt habe.
Tatsächlich habe ich bei den paar wenigen ab Werk wassergekühlten Karten (eVGA, Zotac und Gigabyte), die ich hatte, noch nie auch irgendeinen Tropfen Flüssigkeit im Kühler gesehen.
Also entweder gibts da dann beim Hersteller Prozesse, die das restlos entfernen, oder die Kühler der betreffenden Karten hatten vorher noch nie einen Tropfen Kühlmedium von Innen gesehen.
Ähnliche Themen
