[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Will hier nicht jemand ne Spendenaktion für mich starten dass ich mir doch schon vor Dezember ne Karte holen kann? Das mitlesen hier killt mich 🤣🤣🤣
Hab das Video bis zu erstem Vergleich geschaut und direkt da aufgehört weiter zu schauen. ~70watt (in diesem Vergleich ~20%) weniger Verbrauch und dafür nur 2-3% weniger Leistung und der sagt UV ist schlecht??? 🤔
Der zahlt auch keinen Strom in DE :d
Geht mehr darum das im Hintergrund der Video- und Effective Clock mit UV sinkt. War bei Ampere nicht so.
Also kann man jetzt mehr GPU Clock bei weniger Volt als Stock haben, aber dadurch das die anderen Parameter sinken, bekommst du trotzdem weniger Leistung bei mehr Clock.
weiß jemand ob es für die 4090 aussreicht wenn man sich ein Pcie Kabel bei Cablemod bestellt und zwar den 16Pin auf 3x8Pin?
Habe nicht vor das Powerlimit auf 600W zu erhöhen, möchte es max auf 450 laufen, eher sogar weniger.
Funktioniert das ?
Undervolting mit Voltage/Frequency Curve scheint dieses mal anders zu sein. Sehr interessantes Video.
Was hat er denn geraucht? Sein Test ist zwar Interessant aber seine Rückschlüsse daraus sind ja echt lustig. 100W weniger Verbrauch an der Steckdose bei 3-5% FPS Verlust lohnt sich nicht? Das muss ein Ami sein, der zahlt bestimmt 10cent für die KWh. Lautstärke und Temperaturen sind ihm wohl egal. Klar mit einer fetten Klimaanlage im Sommer irgendwo in Texas lebend wäre mir das eventuell auch wurscht. Yikes.
Hatte derBauer im Gigabyte Video auch schon festgestellt. Aussage war keine Kurve basteln und lieber PT senken.
Einfuhrumsatzsteuer sind doch auch nur die 19% oder?
Richtig.
Dann würde man sich doch bei einem US-Import einiges sparen und könnte evtl. einfacher an eine FE kommen ?
Die FEs sind dort auch gefragt, außerdem wird dich Bestbuy nicht direkt beliefern, selbst Paketforwarding wird da geblockt.
Vergiss es einfach, bei den Abmessungen/dem Gewicht ist der Versand teuer, es lohnt sich nicht.
Eben. Hierzulande mit den schweren Steinhäusern wird es schon bei ner 250 Watt Karte schwierig, Räume im Sommer kühl zu halten - selbst wenn ne (kleinere) Klimaanlage nebenan läuft.
wo ist denn das ASUS Lager?
Die haben kein eigenes Lager. Die arbeiten mit einem Großhändler hier zusammen. Meine Asus-Karten, die ich vor 2 Jahren im Webshop gekauft hatte, kamen von API.
Eilmeldung:
:d
Ich flipp aus... als GE Hater dann wohl auch keine Chance daran zu kommen...
Eilmeldung:
:d
Na super... und ich hab bei Mindfactory ne Gamerock jetzt bestellt... weil ich ... einfach dumm bin. :d Aber wer weiss ob ich je eine Einladung erhalten würd. Mal sehen.
Hab ich schon verstanden. Bei meinen Turing und Ampere Karten hab ich Teilweise (2080 ti) 25% weniger Verbrauch und gleichzeitig 6-7% (mit ram oc) mehr Leistung erreicht. Scheint dann mit lovelace nicht mehr möglich zu sein, imho trotzdem kein Grund kein UV zu betreiben da die immense Verbrauchseinsparung größerer Gewinn als 2% Leistungseinbuß ist.
Nvidia geht wohl den Intel weg und nimmt die letzten 5% Mehrleistung mit, auch wenn dabei der Verbrauch um knapp 100 Watt steigt. Hauptsache man hat den längsten Balken o_O
Ich biete sie dann bald hier im Marktplatz an. EK natürlich.
eine sehr feine sache!
und nochmal als erinnerung:
handeln ist im luxx ausschließlich im marktplatz erlaubt, siehe unsere forenregeln, bitte beherzigen, danke!
Seid der 1000er Serie, kaufe ich immer 2-5 GPUs am Releasetag und teste sie alle. Den besten Chip im OC behalte ich. Alle anderen verkaufe ich.
Puh, gut das ich für sowas nicht genug Zeit habe, mein Urlaub demnächst wieder endet und ich dann wieder nur unterwegs bin.
Sonst würde ich auch noch auf solch "Dumme" Gedanken kommen.
Nein Spass bei Seite, viel Spass beim testen :-)
Funktioniert das ?
Warum nimmst Du nicht das passende Adapterkabel?
Die haben es auch immernoch nicht für nötig gehalten mir eine Mail bezüglich ihrer Stornierung zu schicken...
Hätte ich nicht auf der Amazon-Pay seite geschaut, wüsste ich davon bis jetzt noch nichts
Machen sie auch nicht, niemand hat eine bekommen. Als gestern hier massenhaft von Stornos berichtet wurde habe ich auch direkt meinen Kundenbereich gecheckt und da war das Storno sichtbar. Mich ärgert auch daß man die Kunden da nicht informiert, damit man sich anderweitig umschauen kann. Gerade leute wie ich, die aus Prinzip nicht mehr als eine Bestellung für eine Karte gleichzeitg aufgeben, ist das unnötig verlorene Zeit.
So meine Karte ist Endlich da. Alter Schwede ist das ein Trümmer
Der Zustellversuch konnte nicht abgeschlossen werden.
Dass es heute ausgerechnet DHL Express versaut :d Obwohl zu dieser Zeit mehrere Leute im Haus waren, DHL hatte wohl einfach keinen bock.
Liegt vermutlich daran, das Du und nur Du eine Unterschrift geben musst oder?
Da sieht sogar mein Tower mickrig aus
Ähnliche Themen
Antworten
6K
Aufrufe
392K
