[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Temps von der Waterforce sind ja mal richtig geil. 48 Grad Peak bei 80% Lüfter.
Noch die master dazu und du hast das legendäre trio bisaflor, turtok und glurak
Ich gestehe ich war kurz davor aber bin echt kein FAN von Gigabyte war jedes Mal irgendwie enttäuscht … muss nicht an Gigabyte liegen ist eine nicht Objektive Glaubensfrage ;-)
Ich frage hier auch mal nach, bis ich das 12VHPWR Kabel von BQ habe, denkt ihr ich sollte die Karte wie folgt an den Adapter anschließen:
2 Y-Kabel, jeweils eins an 12V3 und eines an 12V4 vom BQ Straight Power 11 1200 W
Bin da gerade echt überfragt, man soll die Rails ja laut Handbuch gleichmäßig belasten. Ich kann 3 PCIe Kabel ans Netzteil anschließen, das heißt ein Kabel muss mindestens gesplittet werden.
Die Verteilung ist wie folgt:
PCIe1: nutzt nur 12V3 Rail
PCIe2: nutzt 12V3 und 12V4 Rail gelichzeitig
PCIe3: nutzt nur 12V4 Rail
Mann könnte auch 3 Kabel nehmen:
PCIe 1+3 ohne Split und PCIe2 dann splitten, dann hätte man ja auch eine gleichmäßige Auslastung, aber was ist besser?
Ich werde gleich auch meine Gainward Karte einbauen :) Ein neues Netzteil werde ich ebenfalls einbauen.. kann mir jemand mit Gewissheit beantworten ob ich die Kabel von meinem alten Corsair RM650X auch bei meinem Corsair RM850X verwenden kannn? Oder doch lieber alle Kabel wechseln?
Warum schwören hier eigtl so viele auf Seasonic? Hatte mir ein DP Pro 1500 geholt fürn komplett neuen Rechner, aber irgendwie sehe ich hier fast nur Seasonic Anhänger :fresse:
Vielleicht ähnliche Erfahrungen wie ich, ich habe soviele Be Quiet aus unterschiedlichen Serien sterben sehen, das erste Dark Power, Straight Power aus unterschiedlichen Serien, das ganze gewürzt mit kurzen Garantiezeiten, nein danke, mit Be Quiet bin ich durch.
Mittlerweile haben sie ja die Garantie verlängert aber in mein Gehäuse kommt sowas nicht mehr.
So Strix ist auch angekommen.
Bzgl. Spulenfiepen hatte eine TUF ganz am Anfang ohne fiepen dann eine Strix 3090 die ging auch garnicht noch schlimmer war aber die 6900XT ;-)
Netzteil tauschen hilft meist nicht… was ich aber schon hatte das es mit der Zeit Verschwunden ist.
Wenn die Asus das Problem wieder hat geht sie zurück. Die Suprim X 3090Ti unter Wasser hat auch Spulenfiepen.
Also in das Gehäuse würden fast 2 passen ;-)
Beim TX-1300 ist das passende Kabel mit dabei.
Was ist das rechts unten für eine Einsteiger-GPU? :d
Achso, das Case ist so riesig :fresse:
Was hast du da alles drin?
also ist doch wurst mit den kabeln ...2 kabel reichen doch volkommen aus ...die rails sind auch schnuppe .... fragt mal die 3090 nutzer die das teil am billo 750 betreiben ..wie sacht der rheinländer ....et is noch alles jut gejange .....
Na ja … wenn Wasser dann richtig … 48 Grad zu wieviel 52Grad bei 100% unter Luft?
Wieviel mehr Takt ist drin? Viel leiser?
Aber bin gespannt auf die erste echt Blöcke und Ergebnisse…
Endlich da :d. Werde jetzt erstmal benchen. Spulenfiepen des todes bei der Karte.
ich weiß, Einhorn und so, aber vielleicht doch interessant für den ein oder anderen:
Großer Schritt in die richtige Richtung! Gefällt mir wie simpel das geht.
Konnte einfach nicht anders.
Corsair 7000d kommt erst am Dienstag .
TUF non OC von CU gerade eingebaut. Der beiliegende Adapter ist ja mal richtig kacke. Viel zu steif und klobig. Mein Evolve X ist kein kleines Case und trotzdem müsste ich den extrem biegen um die Tür schließen zu können. Das fühlt sich überhaupt nicht gut an und werde ich daher auch nicht machen. Ich bin froh, dass ich noch den passenden Adapter von Be Quiet bestellen konnte, der hoffentlich Morgen eintrudelt.
Wo hast du den Adapter bestellt?
Wenn die 80% aber hörbar sind dann isses halt wenig sinnvoll außer fürs bemühen 😁
Benchen
In Gesprächen mit Händlern hat Golem.de erfahren, dass die Liefermengen der Nvidia Geforce RTX 4090 (Test) deutlich höher sind, als es beim Start der Ampere-Generation der Fall war. Es waren zum Start bis zu viermal so viele Karten verfügbar wie vor zwei Jahren. Die hohen Preise der Wiederverkäufer sind damit vermutlich nicht lange zu halten.
Sicher gehst du mit "Zange" oder Elmor´s "PMD-USB" (nur mit beigelegtem Adapter-Kabel möglich)
Trotzdem ausverkauft. Und nun
Dear xxxxx,​
Your request for a 12VHPWR Cable has been approved. Once your parcel is shipped, we will provide you a tracking number. Meanwhile, if you have any questions, please contact support@seasonic.com
Thank you,
Seasonic
Mal gespannt wie lange das dauert :)
Mit welchem Programm testet ihr denn überhaupt dieses Spulenfiepen?
Ich hatte bisher damit noch nie Stress. *kopfaufholz* Palit 1080Ti und Suprim 3080
Ähnliche Themen
Antworten
6K
Aufrufe
392K
