[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Moin,
ich hab eine Gainward Phantom GS ergattern können. Aber anscheinend habe ich das glück das meine Lüfter einfach mega laut gieren... Hat jemand dasselbe Model & vll denselben struggle ?
Ja ich hab sie grad eingebaut. So ist sie super. Mega leise und etwas zirpen also kein Vergleich zur Asus aber dieses Geräusch kenne ich so auch noch nicht😂mal schauen ob es sich einläuft. Die Karte sieht in live wertiger aus als auf den Photos. Nur ich muss mir auch nen Netzteil Adapter holen. Ist ja übel mit diesem 4 Zack😂
TUF aus dem Asus Shop gerade angekommen und ins O11 Dynamix XL eingebaut. Ohne 90 Grad Adapter für den Stromanschluss bekommt man nicht wirklich die Seite zu.
Ganz schöner Backstein. Aber Verarbeitung ist sehr gut.
Okay dann hast du mir gerade Arbeit erspart. Meine TUF kam auch gerade an, dann kommt die vertikal rein.
für mich ein extrem unangenehmes nebengeräusch!
Für mich persönlich eine Bestätigung daß ich völlig nutzlos bin bei der Bewertung dieser Art von Problemen. Ich finde das Geräusch hat einen gewissen Style. Und das Hochdrehen der Lüfter, wie ein startendes Triebwerk in Mini-Format :) Aber leise ist es natürlich nicht, würde mich aber nicht so stören. Verstehe aber deinen Punkt, ich bin zumindest auch nicht sicher ob das so sein soll.
Stop mal hier gibt es noch mehr Leute mit dem Problem der Gainward? Also dann möchte ich auch keine Ersatzkarte haben ...
18% von der max. Bandbreite von PCI e 3.0
Wenn ich mir das so anschaue kann man eigentlich auf wakü Block verzichten 😊
Bisschen CPU Limit habe ich aber auch festgestellt , aber die Frames sind ok . Hier BF2042 .Also 120-140 FPS packt ein 10900k auch noch .
Okay, das reicht mir vollkommen, ich habe im Treiber eh ein FPS-Limit mit 140 FPS eingestellt und das kommt ja gut hin. :)
TUF non OC von CU gerade eingebaut. Der beiliegende Adapter ist ja mal richtig kacke. Viel zu steif und klobig. Mein Evolve X ist kein kleines Case und trotzdem müsste ich den extrem biegen um die Tür schließen zu können. Das fühlt sich überhaupt nicht gut an und werde ich daher auch nicht machen. Ich bin froh, dass ich noch den passenden Adapter von Be Quiet bestellen konnte, der hoffentlich Morgen eintrudelt.
Spulenfiepen?
Der ausländische Support von Asus ist auch wieder zum Haare raufen. Was die für Vorschläge machen... Wie ich mein Glück kenne ist die Karte ein Montagsmodell und ich kann jetzt erstmal warten.
Gesehen...?
Bin froh, dass ich die TUF bei CU und nicht direkt bei ASUS kaufen konnte
Das Spulenfiepen meiner Suprim ist ja brutal. Evtl fällts mir erst recht auf weil die Lüfter kaum drehen.
Bei ner Karte für den Preis darf da gar nichts fiepen.
Bin echt gespannt wie meine TUF heute Abend abschneidet.
Vielen Dank :) wirst du dir das Bios von der Gamerock Oc draufflashen?
Die non OC hat kein BIOS Switch und man müsste auch noch das 4x8PIN besorgen. Oder halt das Cotsair Kabel. Aber mir reicht die Power so.
Beste Grüße
Absolut... als ich die Karte eingebaut habe ist mir das Grinsen vergangen... So habe ich eigentlich kaum Coil Whine. Die Karte sieht super aus... bin sehr zufrieden, aber dieses Sägen geht mir richtig auf den Sack! Hast du bei Alternate gekauft?
auch das korrekt. ich denke charge fehler hab dir ne pn geschrieben wegen SN nummer weil ich email an gainward fertig machen AUCH ruf bitte im support an und melde deine karte ebenfalls mit dem lüfter defekt! nur das auch alternate das problem aufzeichnen kann wäre nett von dir.
fiepen kannst du NICHT verhindern das liegt einfach and er sache selbst das einzige mit dem man gegenwirken kannst ist qualität der bauteile und ob man die noch etwas einpackt und das wars JEDE karte wird aber fps XXXX fiepen. die frage ist auch bis wohin du das wahrnehmen kannst (frequenz bereich)
wenn es die TUF OC ist, dann mit etwas über 1500MHz auf dem RAM und 3.1GHz auf der GPU.
tobi
Also, meine Gamerock ist angekommen. Läuft soweit. Ich hab aber echt ne Bananenkarte erhalten. Der hintere Teil des Kühlers, ab dem Board ist nach hinten hoch gebogen. Die Temps bei Stock Einstellungen, 62-64 grad. Echt nice. Wegen dem gebogenen Kühler mach ich mir noch Gedanken. Ich mach mal gleich nen Bild. Das PCB sieht aber von der Seite voll ok aus.
Ich bin mir sicher das sich das Fiepen vermeiden lassen würde wenn höherwertige Bauteile verbaut werden, oder es eine Qualitätskontrolle geben würde.
Eine Karte für 2000€ muss stock laufen ohne zu nerven.
So, habe meine Asus TUF non-OC auch bekommen (von Asus direkt), eingebaut und getestet, bin soweit begeistert :-)
Spulenfiepen habe ich beim ersten Hochtakten ein wenig gehört, jetztn ichts mehr, ist aber auch ein geschlossenes Case. Die Karte ist superleise, ich höre sie gar nicht.
Erster Run Timespy normal (CPU ist Ryzen 5900x, nichts übertaktet): 29.129 Punkte; Grafikscore: 36.284 :-)
Timespy Extreme: 15.624 Punkte; Grafikscore: 19.393 --> GPU Temp max: 68,4° Hotspot: 79,3°; max Takt 2805 MHz; Power consumption: 428W max
Dann hab ich mal Powerlimit auf 70% gesetzt undCore Clock um 100 erhöht:
Timespy Extreme: 15.170 Punkte; Grafikscore: 18.535 --> GPU Temp max: 60,9° Hotspot: 70,3°; max Takt 2895 MHz; Power consumption: 331W max
Also jetzt auf Timespy bezogen, 4,4% weniger Leistung bei fast 100 Watt weniger Verbrauch, und Temperatur um 7-8° runter.
Ich bin begeistert :-)
Bin aber auch absolut kein Experte im Undervolting oder Übertakten, bin für Tipps dankbar was ich noch testen/ändern könnte
Achso, Seasonic Kabel wurde mir auch bestätigt per Mail, super Service, obwohl das Netzteil von 2020 ist (habe aber 2022 angegeben in der Maske, danke für den Tipp)!
Dear xxxxx,​
Your request for a 12VHPWR Cable has been approved. Once your parcel is shipped, we will provide you a tracking number. Meanwhile, if you have any questions, please contact support@seasonic.com
Thank you,
Seasonic
Mal gespannt wie lange das dauert :)
Ich war mal so frei und hab angefragt wie es mit dem Verkauf dieses Kabels aussieht für alle die wie ich schon ein älteres Seasonic haben, in meinem Fall ein 5 Jahre altes Prime Titanium SSR-850TD.
Antwort:
Dear xxxxx
Thank you for contacting Seasonic.
For now, we do not have yet any stock of 12VHPWR cables for sale. We will have some at a later time (hopefully end of this year) and we recommend to contact us by December about it.
Thank you for your understanding.
Das ist schon eher schwach muss ich sagen.
Bananenkarte….So, bitte geschockt sein. :d und nein, das liegt nicht an der Stütze. Die Karte ist auch so fest und stabil ansich, das man nix verbiegt. Ich warte mal paar Tage ab. Solang die nicht verfügbar sind, wird nen Austausch ja auch nix bringen. Ich hab bei mindfactory den Gold Service. K.a. Ob das was helfen würde.
Klingt ja echt super. Kann es kaum erwarten. 🤓 muss noch essen gehen denke so 21 Uhr kann ich meine mal testen.
Sieht ja spannend aus. Muss mal bei meiner schauen
Beste Grüße
Der Gold Service dient nur zur Persönlichen Bereicherung dieses As.... schuppens sonst nix Mindfactory ist der Letzte Händler wo ich bestellen würde. Wenn du die zurück schickst wirst du gesperrt als Kunde, Sie ist ja nicht defekt nur optisch. Jeder händler klar tauschen wir um MF sagt dir genau das.
Beste Grüße
Jop, hinter dem Board, fängt die Karte an sich weg zu biegen. Der Karton war auch nicht kaputt oder sonst was. Scheint wirklich so vom Werk zu sein hinten verbogen. Lüfter drehen frei und sind auch leise
was ist den damit passiert, das sieht nicht gesund aus
Gut zu wissen. Na, ansich läuft die ja auch super. Nur bissle verbogen. :d viel macht mir das nicht aus. Rechner steht im Nebenraum. Ist mir eigentlich Wurscht
Ka was du für Probs mit MF hast, aber ich konnte da bisher alles Retounieren, sogar nach der 14 tägigen Frist auf Kulanz, ohne das ich gesperrt bin - seit vielen Jahren. Und wenn man sich dein salziges Geschreibe so anguckt.. wirds wohl andere Gründe haben für deine Sperre.
Ähnliche Themen
Antworten
6K
Aufrufe
313K
