[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So meine Gainward GS, ist jetzt auch angekommen. Die GS hat im Gegensatz zur non GS einen Adapter mit 4 Anschlüssen. Läuft bisher sehr gut, extrem leise. Hab aber aktuell auch noch das Case offen, weil es leider nicht zu geht mit dem Adapter. Mit einem nativen Kabel sollte es gehen, es fehlen so ca. 1 - 1,5cm. Case ist ein NZXT H510 Elite. Angeschlossen an dem Sharkoon Netzteil, was ja heute für ein bisschen Gesprächsstoff gesorgt hat. Läuft ohne Probleme mit den 2 Splitterkabeln bei 100% PL und die Kabel werden auch nicht warm oder so, scheint alles ok zu sein.
Auch mal ein Bild zum Größenvergleich mit der Gainward Phoenix GS 3090, ist schon ein Klopper :ROFLMAO:
Das heißt, wer eine NON GS hat bekommt keinen Adapter und kann die Karte gar nicht nutzen???
Woher isn das? Bin eher davon ausgegangen ASUS wäre da eine der besseren Marken. 🤔
Von hier. Da muss sich jeder sein eigenes Bild machen
die TUF non-OC hat einen BIOS Switch & 4x8 PIN & 600PT
Komisch, dass davon nichts auf dem Karten oder bei ASUS steht
Meine TUF (non OC) hat einen Bios Switch auf der Rückseite links neben dem Power Anschluss ( Performance Mode | Quiet Mode)
Im Afterburner lässt sich 133% als Power Target einstellen. Hab random einfach mal auf 3000 Mhz getaktet. Lief ohne Probleme.
Wieviel PL hat die TUF Non-OC nochmal?
Momentan ist nur die Strix hier vertreten
Nochmal Bild mit Lineal. Unten gerade, oben weg verbogen.
Ja Adapter ist kacke aber passt erstmal 😅
Da bin ich ja mal morgen auf meine Suprim gespannt, wenn ich sie eingebaut habe.
Vorfreude wurde ein bisschen genommen, aber meine 6900XT und auch die EVGA 3080Ti fiepen haben gefiept.
Zum kotzen, da die FE ja nun nicht lieferbar ist dachte ich nehm ma halt ne TUF. Nur geht selbst die nicht in mein Case. Baaah.
Wie bei mir auch...habe jetzt ne Antwort von NBB..die schieben das wie bei einigen anderen hier auf Amazon-Pay.
Komisch, weil ich schon 2 mal mit Amazon-Pay 3000FEs bestellt habe...
Dann muss ich da noch mal schauen.
Beste Grüße
So wie ich das sehe ist der Bios switch da wo ich blau eingeringelt habe, also auf der Backplate, kannst du mal checken ob du den hast? :)
Gerade Mail von MF erhalten, dass die Gamerock nicht mehr nachgeliefert wird und sie mir dafür die
OC Variante dann für 1979,- anbieten. Der Deal ist super, mich wundert nur die Aussage, dass sie die Non OC nicht mehr nachgeliefert bekommen.
Gib dann bitte Bescheid :)
Beste Grüße
Also, ich nehme meine Aussage zurück und behaupte das Gegenteil. Beide haben einen Bios Switch, nur etwas kleiner als ich erwartet hatte 😜
Beste Grüße
Willst Du nun doch eine 4090?
Letztens war in Hannover noch eine zu haben...:wayne:
hab sie direkt am 12.10.22 um 15.00uhr bei nbb abgeholt.
wollen ist etwas weit hergeholt - ich kaufe nur aus gewohnheit, weil ich es schon immer tue..
auf spielchen habe ich allerdings selten bis nie bock. geht nur ums haben u. das ist besser als brauchen.
tobi
Die war schon so verbogen, bevor ich sie eingebaut hab. Die lief jetzt zum Test vielleicht 1 Stunde.
Ich würde sie sofort zurückschicken. Da braucht nur ein einzige, winzige Lötperle wegknacken - dann wars das
Das kann heute, nächste Woche oder kurz nach der Garantie passieren. Vielleicht aber auch nie. Das Risiko würde ich aber nicht eingehen
Da lobe ich Hersteller, die am PCB einen stabilen Metallrahmen haben. Hier ich scheinbar keiner vorhanden...!?
In Amerika geht das Scalpen los, schon 3 Angebote auf Ebay mit +1000$
Was denn nun los? Die Inno3d X3 OC ist immer noch verfügbar und für die ist bei ALC sogar der Block lieferbar. Wo sind die ganzen Enthusiasten?
Enthusiasten kaufen kein Inno, ganz einfach
So ich sach ma, sitzt passt und hat Luft :d :d
Praktisch, dass das provisorische 90 Grad fitting gleich als GPU Stütze eingesetzt werden kann :d
Naja, hoffentlich kommen die Wasserblöcke bald.....
Ja, und was ist jetzt? Haben die deshalb einfach storniert?
Mich würde interessieren, wie die anderen beiden FEs bezahlt wurden. Gab ja nur Amazon-Pay und KK, richtig?
Meine TUF läuft jetzt nach Bios zurücksetzen. Kein Spulenfiepen 👍Karte ist allerdings mit 3x8 angeschlossen, warte quf das Bequiet Kabel
Ähnliche Themen
Antworten
6K
Aufrufe
392K
