[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, und was ist jetzt? Haben die deshalb einfach storniert?
Mich würde interessieren, wie die anderen beiden FEs bezahlt wurden. Gab ja nur Amazon-Pay und KK, richtig?
Also ich wurde auch stumpf mit KK storniert.
Nochmal Bild mit Lineal. Unten gerade, oben weg verbogen.
Es sieht für mich so aus als wäre der hintere Teil dea Kühlers verbogen, Heatpipe und Backplate. Aber das PCB sieht auf dem Foto gut aus. Weswegen Du wahrscheinlich auch keine Probleme hast (bisher).
Ich würde sie sofort zurückschicken. Da braucht nur ein einzige, winzige Lötperle wegknacken - dann wars das
Das kann heute, nächste Woche oder kurz nach der Garantie passieren. Vielleicht aber auch nie. Das Risiko würde ich aber nicht eingehen
Das PCB ist deutlich kürzer, verbogen scheint nur der hintere Teil zu sein, Heatpipes und Backplate. Das PCB siehgt aber gerade aus und steht möglicherweise sogar nicht mal unter Spannung. Es kann also auch gut sein, daß diese Karte viele Kahre völlig anstandslos laufen wird.
Trotzdem stimme ich Dir aber insgesamt zu, das Risiko, daß sich Probleme erst später zeigen ist durchaus da und bei dem Preis kann das weh tun. Deswegen ist wie gesagt Minimum mit dem Händler umgehend darüber zu sprechen. Am besten wäre natürlich ein Austausch, aber ich kann echt verstehen daß man das aktuell irgendwie nicht möchte, es könnte dauern bis Ersatz da ist und das hat dann vielleicht deutlich ärgerlichere aber weniger sichtbare Mängel. Bei optischen Mängeln war ich in der Vergangenheit auch immer sehr zurückhaltend mit Reklamationen. Aber vielleicht kann man mit dem Händler ja auch vereinbaren, daß man den Austausch zu einem späteren Zeitpunkt vornimmt wenn sich die Liefersituation bessert. Ich kann so oder so nur die Daumen drücken.
hab sie direkt am 12.10.22 um 15.00uhr bei nbb abgeholt.
wollen ist etwas weit hergeholt - ich kaufe nur aus gewohnheit, weil ich es schon immer tue..
auf spielchen habe ich allerdings selten bis nie bock. geht nur ums haben u. das ist besser als brauchen.
tobi
Hast du einen Zwillingsbruder...?
Ich kenne einen User, dessen Nick genauso heißt. Der war vor dem Release nicht so begeistert von der 4090 :fresse:
bei NBB konnte man am 12.10. zuschauen, wie die karten im shopsystem weniger wurden.. bis der verkäufer im laden ne strix soweit hatte, sie im system zu finden, anzuklicken und aufs kundenkonto zu buchen, war sie schon weg.. mir wurden drei direkt als barverkauf vor der nase weggekauft.. gut dass die TUF OC keiner wollte.. und sie war sogar einen hunderter billiger.
andere karten hätte ich nicht haben wollen, denn ich brauche explizit 2x HDMI_2.1 am slotblech. dp1.4->hdmi2.1-adapter funktionen bei mir nicht.
tobi
ich habe eine ZOTAC GeForce RTX 4090 Trinity, im warenkorb bei alternate, kann dies frei machen wenn jemand es haben möchte. PM me
Ich frage hier auch mal nach, bis ich das 12VHPWR Kabel von BQ habe, denkt ihr ich sollte die Karte wie folgt an den Adapter anschließen:
2 Y-Kabel, jeweils eins an 12V3 und eines an 12V4 vom BQ Straight Power 11 1200 W
Bin da gerade echt überfragt, man soll die Rails ja laut Handbuch gleichmäßig belasten. Ich kann 3 PCIe Kabel ans Netzteil anschließen, das heißt ein Kabel muss mindestens gesplittet werden.
Die Verteilung ist wie folgt:
PCIe1: nutzt nur 12V3 Rail
PCIe2: nutzt 12V3 und 12V4 Rail gelichzeitig
PCIe3: nutzt nur 12V4 Rail
Mann könnte auch 3 Kabel nehmen:
PCIe 1+3 ohne Split und PCIe2 dann splitten, dann hätte man ja auch eine gleichmäßige Auslastung, aber was ist besser?
herzlichen Dank, dass Sie mit dem be quiet! Service Kontakt aufgenommen haben.
Die „Y-Kabel“ des Straight Power 11 sind grundsätzlich vollwertige Kabel. Jede Phase hat eine durchgehende Verbindung von Netzteilbuchse zu PCIe-Anschluss. Es reicht also zwei Doppelkabel zu verwenden.
Beachten Sie, dass Sie beim Anschluss ans Netzteil die Last auf beide Rails verteilen. Verwenden Sie dazu bitte PCIe1 und PCIe3. Lassen Sie den PCIe2** Anschluss einfach frei.
Für weitere Fragen stehen wir natürlich gerne zur Verfügung.
Mit freundlichen Grüßen
Florian Stegemeier
Bitte senden Sie beim Antworten immer den kompletten Emailverlauf, da wir ihre Nachricht sonst nicht zuordnen können.
be quiet! - Service
After Sales
_________________________
Listan GmbH
Wilhelm-Bergner-Str. 11C
21509 Glinde
Deutschland
Fon: +49 40 736 76 86 44
Fax: +49 40 736 76 86 - 69
E-Mail: service@bequiet.com
So, Suprim X heute angekommen und eingebaut. Du meine Fresse......was sind das für "Monsterkarten"! Da braucht man ja nen "Hebekran". Also im Ernst, von den Ausmaßen ist hier aber echt mal ne Grenze erreicht. 😱
Aus dem Stand dann timespy (normal) stock 37.523 Graphic Score und rund 76% schneller als die 3090er Strix OC mit moderatem OC. Schon der Hammer. Temps bei lauwarmen 51 Grad. MSI Afterbuner sagt Powertarget max 108%.:unsure:
die frostbite passt halt auch in kleinere gehäuse mit custom-loop.. das wäre dann auch schon der ganze vorteil dieser innogurke.
btw,
ich hatte das leistungsmessgerät gestern auf über 900W peak beim hardware grillen.
tobi
So Suprim X ist eingebaut und läuft einwandfrei. (y) Läuft mit dem mitgelieferten Adapter am Dark Power Pro 12 mit 2 Kabeln.
Diesen "Suprim Stand" find ich aber eine bastellösung. Ist sicher nicht einfach eine stütze zu bauen die für viele Gehäuse funktioniert aber bei mir z.b. sind am boden 3 lüfter und somit ist es nur sehr schwierig den ordentlich zu installieren da keine abstellfläche vorhanden ist.
@kampi71
Und jetzt DAS noch größer
Die TUF hat ca. 0,3Liter mehr und die Aorus Master 0,66Liter mehr Volumen als die Suprim :haha:
Absolut gestört die Gigabyte :fresse:
haben die 4090er das gleiche ding mit vram oc wenn man es übertreibt das ne fehlerkorrektur reinballert und die punkte drückt? nur als abfrage wenn ich gleich mal memory max austesten möchte ^^
Storniert, Wie denn? Die haben ja angeblich nicht mal ne Bestellung von mir. Nur Amazon-Pay sagt ich hätte eine Bestellung. Dort steht auch In Bearbeitung, aber von deren Seite machen die nix.
Paypal gab es auch.
Mich nervt es, weil es mal wieder ein Kampf wird überhaupt eine FE zu bekommen. Keiner weiß wann die nächste Fuhre kommt. Warscheinlich wenn die 4080er kauskommen, soll ich aber jetzt mind nen Monat wieder mit blanken Nerven rumsitzen, nur weil NBB es WIEDER nicht gebacken bekommt NACH 2 JAHREN!!!
war mal, funktionierte aber zuletzt wieder
"War mal"? Bei welchem Shop?
Also wenn man von einer "sauberen" KK ausgeht, sollte es immer klappen
Die hätten das ruhig weiterlaufen lassen können. Dein Geld hatten sie ja schon
Und bei der nächsten Welle wird sie zugeschickt
Wie es jetzt und vor 2 Jahren lief, ist absolute Scheisse
Daher bin ich froh, wenn sie in Zukunft so verfahren, wie EVGA
Den Suprim Stand habe ich kurz probiert. Taugt nix und stattdessen benutze ich drei (ja, 3 lol) Stands von uphere. Die haben wenigstens nen Magneten und stehen nicht so wackelig im Gehäuse.. Der "Vierzack" war auch nervig und ich musste bei meinem Fractal Meshify die vorderen Platten rausnehmen um die Kabel besser führen zu können. Na ja, da kommen bestimmt noch bessere Kabellösungen in Kürze.
witcher mit DSR auf 8K und mit 80fps und natürlich alle games, die den speicher gut füllen und idealerweise modern genug sind auch RT mit ins spiel zu bringen.
benchmarken ist eher für'n popo.. was im speedway funzt, steigt mitunter im port royale direkt aus.
tobi
bQ hat auch nur die Kabel mit 2x 8Pin-Steckern (jeweils 300W)?
Guck mal bitte, wie hoch du die Suprim auslasten kannst
wirklich, 37000 graphics score? Meine hat da 30.500, online findet man für timespy aber noch nicht viel. Port Royale gibts einige Daten online, da kommt sie so auf 26k meine hat mit nem harten OC an 27 gekratzt. Deswegen glaube ich eig. nicht dass meine hier underperformed?
Bei mir ist die Suprime X ins Corsair 680X eingezogen, es mussten wie erwartet zwei Frontlüfter dran glauben ;)
Lets go
Nvidia Adapter Kabel wird gegen ein weißes ausgetauscht!
Ähnliche Themen
