[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Stell dir einfach nicht so einen hohen Ton vor
Die Karte wirkt geradezu winzig :) Hängt aber ganz schon durch.. Machst du da noch ne Stütze oder nen Bracket hin?
Ähm das ist der Winkel vom Foto das Bracked ist schon dran die Karte ist Bomben fest!
Das Bracked ist cool gelöst!
Meine Suprim X ist auch heute angekommen. Und meine Messungen waren fehlerfrei, sie passt wie ein Handschuh in mein Gehäuse. Nix gequetscht, nix gebogen, nichts unter Stress. Karte selbst sieht einwandfrei aus, keine verbogenen Fins, edler Look und bisher keine Probleme.
Wer ein paar Bilder sehen will, findet welche hier.
Mit dem Corsair 600W Anschlusskabel bin ich auch sehr glücklich, das machte die Verkabelung doch bedeutend einfacher. Mein AX1600i hat ganze 10 (in Worten "zehn") 8-pin Anschlüsse, ich habe das Kabel daher an 1 und 3 angeschlossen stzatt 1 und zwei, sollte doch mal was warm werden, dann hat die Wärme mehr Platz sich zu verteilen. Und ein Lüfter pustet auch auf die Anschlussbuchsen, das sieht alles sehr solide aus und die Adern des Corsairkabels sind auch massiv, das ist gute Arbeit die Corsair da meiner Meinung nach abgeliefert hat.
So, jetzt werde ich ein paar echte Tests machen und auch schauen wie das mit dem Spulenfiepen bei meiner aussieht auch wenn das für mich wier gesagt eigentlich kein Thema ist. Bisher war wirklich alles perfekt, fast zu schön um wahr zu sein.
Frage an die Suprim X Besitzer: war euer Karton von aussen mit einem Aufkleber o.ä. versiegelt? Oder konntet ihr ihn direkt nach oben aufklappen ohne einen Aufkleber zu entfernen?
Nein, kein Aufleber auf der Packung. Aber die Karte selbst war mit Folie ohne Ende versorgt, sogar auf den Lüfteranrben waren welche, hatte ich fast übersehen. Hat ewig gedauert die ganzen Foilen abzubekommen und keine zu übersehen.
Moin
hab jetzt das Problem, dass die Karte im Idle nicht mehr runter taktet, Speicher und Chip bleiben auf vollem Takt.
Woran könnte das liegen und wie kann man das am besten lösen?
DU hast es ja mittlerweile gelöst wie ich sehe, im Zweifelsfall aber immer auch mal nach einem BIOS Update fürs Mainbaord schauen, es gab ein Problem mit den 4090ern und Runtertakten glaube ich das bei einiggen Boards per BIOS Update behoben wurde. Nur der Vollstädnigkeit halber.
Gleiches Spiel selbe Stadt, hatte ich gestern. Die 4090 Suprim X kam an, mein Wakü Zeug ist liegen geblieben und kommt heute. Beides am selben Tag bestellt.
DHL halt :fresse2:
Bei mir hat DHL echt ein halbes Wunder vollbracht. Gestern 15:30 noch im Startzentrum in Bremen und heute schon bei mir, gute 500km weiter südlich. Ich bin begeistert, hatte eigentlich mit Montag gerechnet :)
Das gehört zwar hier nicht rein.. aber wie kann man Gehäuselüfter im Windows regeln? Da mein Mainboard nur 2 Lüfter Anschlüsse hat. Musste ich alles über das Hub steuern. Die 2x180 vorne und die 3x140 unten. Mir sind sie im Idle etwas zu laut. Geht das nur übers Bios oder kann man da ne Windows Software nutzen?
@SH
Du brauchst zum Benchen dringend einen schnelleren Prozessor^^
Ich muss PBO mal aktivieren^^
Ich habe noch alles Stock laufen auf CPU. 7200er Ram kommt heute und dann die CPU auf 5,3-5,4 GHz hoch prügeln.
Ich warte aber noch, bis es halt draußen ist und ich den Rechner draußen hinstellen kann fürs Benchen.
Donnerstag Nacht sollen 6 Grad werden in Frankfurt. Vielleicht dann dort :)
da hängt nix.
da hat gigabyte beim "kühler" mehr plastik vorne gemacht als hinten und somit sieht das so aus.
er hat sogar ne stütze montiert
Der Kühler ist in einem Bereich etwas abgerundet da her wirk es dünner wird aber etwas weiter innen wieder genau so dick.
Ich zieh gerade erstmal Win Updates spiele updates erstmal was futtern!
Also ich habe ja vor dem Release über die Optik des Corsair-Kabels gelästert, aber es sieht trotzdem um Welten besser aus als der Adapter. Wenn es jetzt auch noch mal wieder verfügbar wäre... :cry:
Bios oder
Oder kombinieren :fresse:
Fan Control ist phantastisch, super Software!
bin ich noch nicht ganz drinnen. Werd mich aber rein fuchsen :) überschreibt das dann die Bios werte?
Du meinst, es sind ausschließlich alle Boardpartner Karten Sau gut unterwegs und unterscheiden am Ende nur in Sachen Kühlung ect. ?
Gibt ja durchaus Karten die eine Vapor Chamber haben und einige nicht ….
Ich weiß ja nicht was für ein User die Frage stellt.
Mir persönlich sind +/- 100 Mhz völlig egal, und so wie es bis jetzt aussieht laufen alle Karten kühl.
Am Ende ist es wieder Chip-Lotterie.
Aber wenn ich der Mega-OC-Junkie bin, dann kauf ich mir keine Tuf Non-OC. Oder doch?
Hi, hast du für die MSI bei Cyberport bis jetzt eine Versandbenachrichtigung bekommen? :unsure:
Ich habe am gleichen Tag noch eine Asus Tuf non OC bekommen und die MSI wieder storniert. Am besten dort anrufen und fragen, wann deine Karte in den Versand geht. Wenn ich mich richtig erinnere, sollte die Karte laut Angabe mitte Ende nächster Woche bei mir kommen.
So Umbau fertig. Hat sich gelohnt.
@cHio
Was für Karten hattest du bislang? Ist die suprim die schlechteste bez. Spulenkrach?
Eben kam noch eine TUF non OC. Die teste ich im laufe des Tages. Sonst hab ich keine weitere bisher. Vielleicht probier ich auch noch eine Zotac aus.
@Brainscan1979 einfach viel cleaner, sieht nice aus! Lies sich das Kabel halbwegs biegen oder sehr steif?
Das sieht ganz schön kurz aus.
Undervolting ist immer besser als PL. Beim Powerlimit rennt die karte permanent da rein und taktet hin und her. Bei UV hast Du eine konstante Taktrate und es läuft smoother. Versuch mal 0,95V bei 2760.
Ja gibt mit und ohne Vaper Ch...
60cm lang reicht locker
An die die schon eine Karte haben was für Netzteile nutzt ihr wie viel Watt und läuft es perfekt gibt es Probleme?
Lg
Das Master hat seinen Meister gefunden 1000D
Gratulation, die Master war ja auch mein Favorit, das Display ist nämlich sehr cool, aber diese offene Sicht auf die Finnen ist in natura dann doch nicht sooo schön...wenn das wenigstens schwarz wäre.
Bin mal gespannt wie gleich meine Zotac AMP Extreme Airo aussieht, sie war ja meine Nummer 2, das Surfboard. "Like ice in the sunshine"
Also das Lüfter Tool ist ja Hammer! Jetzt kann ich die Gehäuselüfter nach der GPU Temp steuern und nicht wenn der CPU Kurz mal hochdreht. Sehr nice!!!
Komplett aus kann man die Lüfter nicht lassen oder?
Meine 4090 Gaming X Trio läuft mit dem Dark Power 11 1200 Watt mit dem Adapter stabil. Wobei ich mir das Bequiet Kabel noch holen werde.
Mein Be Quiet Kabel kam auch grade. Das ist allerdings steifer als ein geiler Opa im Freibad. Da hat man für 20€ ein bisschen mehr erwarten können. Biegeradius nicht vorhanden am kleinen Stecker.
Hoffentlich kommt am Montag das 12VHPWR Kabel von BeQuiet. Das sieht ja verboten aus :(
Es handelt sich um die Zotac 4090 AMP Extreme Airo.
Erinnernt mich irgendwie an an das Raumschiff Orville ;-)
Kaum Spulenfiepen, dafür sind die Lüfterlager leider nicht die leisesten und geben ein leises "brummen" von sich.
Bei den ersten OC versuchen hat die Karte 3050 mhz durchgängig geschafft und bleibt mit knapp 65 Grad relativ kühl.
Leute versteh ich richtig das bei der 40er gen bei 4k 120hz schluss ist wegen DP 1.4? Ausser mit DSC dann 144?
Ähnliche Themen
Antworten
6K
Aufrufe
381K
