[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab vorhin mal Undervolting ausprobiert: Respektables Ergebnis
875 mV bei 2600 Mhz PT unverändert
Cyperpunk
Bild1- 3440*1440p gelockt auf 100 FPS, Alles maxx out, DLSS Qualität, GPU Stock ~ 352 Watt
Bild 2 mit UV
Praktisch kein Leistungsverlust, dafür aber nur 248 Watt Verbrauch, dass ist schon enorm :eek:
Meine Karte schafft in UV bis 865 mv und 2600 Watt, mehr geht auch nicht, ist sogar die Idle Spannung xD
So, meine Suprim ist nun auch verbaut. Für den Übergang muss es so gehen, bis dann Wasserkühler zu kaufen sind. ;)
Und Fiepen tut sie auch. Ein bisschen mehr als meine alte EVGA 3080Ti und ungefähr auf dem gleichen Level der alten AMD 6900XT.
Mit Gehäuse zu und Kopfhörer auf geht es dann aber wohl.
Ich habe jetzt knapp zwei Stunden Spiderman getestet und bin jetzt schon extrem begeistert von DLSS3. Selbst wenn man bei einer geringen Grund Framerate von 45-65FPS darauf die Frame Generation klatscht, sieht das trotzdem super aus. Daraus werden dann ungefähr 65-85FPS. Mein Ryzen 3900X limiert in diesem Spiel allerdings heftig. Bei einer besseren CPU dürfte da vielleicht noch mehr draus werden.
Ich tu mich hier verdammt schwer, überhaupt irgendwelche Artefakte ausmachen zu können. Das offensichtlichste ist der Missionsmarker, der ein halt ein bisschen "flackert". Wichtig ist, wie Alex von DF in seinem Video erklärt hat, nicht VSYNC zu triggern. In meinem Fall darf ich also keine 120Hz bzw. FPS auf meinem OLED erreichen, andernfalls gibt es eine spürbare Erhöhung des input lags (49ms vs 110ms wie im Video erwähnt).
Bewegt man sich aber innerhalb seiner VRR/GSYNC-Range ist das alles super fluffig spielbar. Dafür musste ich allerdings auf 5120*2880 ohne DLSS2 oder auf 5760*3240 mit DLSS2 quality gehen um sicher zu sein, stets unter 120FPS mit DLSS3 zu bleiben. Wohlgemerkt mit allen Settings + RT auf Anschlag und das bei 60% Power Target XD
Ich habe bei dem Spiel allerdings auch beobachtet, dass es ohne DLSS3 bei mir nicht smooth aussieht (mit DLSS3 wesentlich besser, aber auch nicht 100% perfekt). Spiele ich z.B. in 4K ohne DLSS3, habe ich trotz dreistelligen FPS starke frame pacing Probleme. Drehe ich die Kamera sieht man deutliches stuttering. Habe innerhalb der zwei Stunden auch nichts gefunden, was dagegen hilft. Meine einzige Vermutung ist, dass mein 3900X jetzt zu einem üblen Flaschenhals geworden ist und besonders bei diesem Spiel mit der 4090 nicht ansatzweise mithalten kann.
Bin mal gespannt ob der 5800X3D da was ändern wird.
Zudem wäre es sinnvoller mehre Undervolt Profile zu haben. So kannst Du die Karte auch noch drosseln um unter VSYNC zu bleiben und sparst ne Menge Strom und Hitze.
Will keiner,liegt wie Blei...
Ich finde die Zotac eigentlich sehr schick ehrlich gesagt. Mag dieses rundliche Design. Aber der Preis ist übel. Für 2K würde ich mal gucken wie die so ist.
Gibt es großartig Unterschiede zur Non X Variante ? 🤔 Im Netz finde ich bisher kaum Antwortmöglichkeiten ^^
Denke die gaming trio wird es nicht lange geben. Baugleich mit der X 20 Watt niedrigeres Powerlimit . X 50 MHz mehr beim Boost
Bin ein User der Wert auf die Optik legt und wollte eine Karte der neuen Generation unter Wasser legen deswegen sind mir die OC Variante ja auch egal. Der Preis ist für mich entscheiden denn am Ende sehen die Karten unter Wasser alle gleich aus.
Habe hier nur die Wahl zwischen einer Gaming Trio, Suprim X, Asus TUF und der Zotac Extreme AMP Airo und bisher ist die Gaming Trio auch attraktiv für 2036€ (gut, Preislich sind die alle fett!) deswegen wollte ich einigermaßen Erfahrungswerte Sammeln bis ein passender Block für die jeweilige Karte erscheint…
In der Zeit sind halt die Karten als Luft Varianten im Gehäuse ….
Ja ich weiß auch nicht ^^“
Mein Sternzeichen ist Waage und ich bin relativ unausgeglichen 💁🏽
Dann nimm die TUF Gaming, die wird mit dem EK Waterblock kompatibel sein
Cyperpunk
Bild 2 mit UV
Hab mal 0.925 mit 2750 gemacht sofort Crash im Port Royal. Werde wieder Metro Exodus Benchmark installieren und dann langsam nach unten tasten.
Mit einer TUF macht man wohl nichts falsch , weil AC und WC jeweils einen Block bringen und EKWB sowieso.
Da hat man schon Auswahl .
Dazu finde ich den Luftkühler echt schon Top. Absolut begeistert wie kühl und leise die von Haus aus schon ist.
Da kann ich mich entspannt zurück lehnen und zur not auch bis Januar/Februar warten bis die besten Blöcke kommen.
Hauptsache zum Sommer ist alles wieder unter Wasser :)
Beneide bisschen die TUF Leute die eine Non OC Variante für 1950 € bei Asus bekommen habe.
Das die echt 300€ mehr verlangt haben wegen 45 MHZ mehr Boost takt ist schon hart :d.
Naja 2250 € am Release Tag ist noch zu verschmerzen für eine TUF .
Hätte ich das mit der Non OC gesehen , dann hätte ich die auch bestellt , aber als die Bestellung durch war wollte ich bloß
nichts ändern , damit die Karte auch kommt .
Nachdem ich hier im Forum fast 15 Jahre lang nur mitgelesen habe und diesmal tatsächlich beim ersten Drop eine Karte erwischen konnte, wollte ich euch einmal an meinem Glück teilhaben lassen. :d
Ich hätte gerne wieder eine Strix gehabt aber jetzt ist es erstmal die Suprim geworden.
Da hier jetzt schon öfter das Thema Spulenfiepen aufkam, habe ich mal einen kleinen vorher/nachher Vergleich mit der Strix 3080 Ti gemacht. Die Tonqualität ist mangels Aufnahmeequipment nicht toll, aber die Charakteristik lässt sich trotzdem ganz gut heraushören. Hier liegt zumindest mein Exemplar der Suprim deutlich vor der Strix, die hatte bei Stock Settings ohne UV wirklich Fiepen aus der Hölle.
Aufgenommen in MSFS 2020, jeweils ohne Framecap erst im Hauptmenü und dann in Game.
Na gut die 20 Watt sind ja auch nicht so der unterschied bis hin zur 50Mhz
Die könnte man zur Not noch selber kitzeln.
Interessant wäre noch zu wissen, wann ein Block kommt 😅
Glaube Bykski war letzte Generation einer der wenigen, die einen MSI Block bereitgestellt haben
Also man muss schon sagen die Effizienz der 4090 ist beeindruckend zb. in WQHD ist der Verbrauch halb so hoch wie mit der 3090 bei gleichen Settings.
Ich habe noch alles Stock laufen auf CPU. 7200er Ram kommt heute und dann die CPU auf 5,3-5,4 GHz hoch prügeln.
Ich warte aber noch, bis es halt draußen ist und ich den Rechner draußen hinstellen kann fürs Benchen.
Donnerstag Nacht sollen 6 Grad werden in Frankfurt. Vielleicht dann dort :)
7200er Ram? Läuft der überhaupt mit nem 12900k? Sind die nicht für 13900k?
Mit dem Corsair 600W Anschlusskabel bin ich auch sehr glücklich, das machte die Verkabelung doch bedeutend einfacher. Mein AX1600i hat ganze 10 (in Worten "zehn") 8-pin Anschlüsse, ich habe das Kabel daher an 1 und 3 angeschlossen stzatt 1 und zwei, sollte doch mal was warm werden, dann hat die Wärme mehr Platz sich zu verteilen. Und ein Lüfter pustet auch auf die Anschlussbuchsen, das sieht alles sehr solide aus und die Adern des Corsairkabels sind auch massiv, das ist gute Arbeit die Corsair da meiner Meinung nach abgeliefert hat.
Darf man fragen woher du das Corsair Kabel hast?
Also ich spiele das Game native in UHD mit 80-120 FPS. Wozu brauchst Du da noch DLSS oder FG?
Weil ich nur mit DLSS3 eine wesentlich smoothere Performance habe. Keine Ahnung wieso. Ohne DLSS3 fühle und sehe ich praktisch dauernd stuttering, trotz VRR.
Oh ich habe Straight Power 850W und PCI-E 1 / PCI-2 / PCI-3 alle angeschlossen einmal Y Kabel und 2x einfaches Kabel. Werde aber wenn das neue Kabel kommt extra wie du es sagst anschließen.
Du kannst auch nur drei am Adapter nutzen, dann aber nur bis max 450Watt. Nutze die Karte auch so ohne Probleme
Das Feature werde ich aufgrund von fehlendem V-Sync niemals nutzen. Mein Motto lautet seid über 20 Jahren gib tearing keine Chance. ;) Und bzgl. Inputlag hast du Reflex laufen?
ich habe noch eine gigabyte rtx 4090 windforce (für 1949€) bei computeruniverse zur vorkasse. habe echt kein plan ob ich die nehmen soll oder nächste woche auf eine asus rtx 4090 tuf non oc fokussieren sollte... könnt ihr mir da tipps geben? die windforce hat ja einen powerlimit von 520W oder? definitiv nicht 600W wie bei der tuf non oc. kann man diesen wert unterschied einfach ignorieren, da man sowieso keine rtx 4090 auf 600W bekommt?
Bist du auf Rekorde aus oder willst du einfach eine schnelle Karte zum spielen? Sollte zweites zutreffen kannst die behalten. Die ist vermutlich paar (vernachlässigbare fps) langsamer als Strix, Suprim, Master.
Ich bin mit der Windforce aktuell sehr zufrieden! Wollte auch der ASUS TUF non OC aber wenn ich sehe das alle bzw. Viele lautes Fiepen haben und meine eigentlich noch recht angenehm ist. Die Idle Temperaturen auch gleich sind. Weis ich nicht ob sich das lohnt. Bin auch eher der UV Typ und möchte nicht jedes letzte Rest an Leistung raus holen. Einzig die Lüfter gehen im Silent Bios bei so 65°C doch bisschen lauter an und die Karte kriegt dann auch ab und zu 70°C Trotz 350W. Vielleicht werde ich die Kurve noch etwas ändern für die Lüfter.
Was sollte die GPU den Maximal an Temp bekommen bevor es kritisch wird? Wenn ich die Lüfter leiser mache?
Jemand Erfahrungen mit Computeruniverse? Versenden die Samstags nicht? Nur Support ?
ne der warenkorb button geht nicht. seite kaputt.
eher holt dhl samstag nichts ab. das wird der grund sein :d
Ähnliche Themen
Antworten
6K
Aufrufe
381K
