[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat jemand schon mit der Voltage getestet, ob es mehr Punkte gibt?
Und gerade kam neues Spielzeug 😃
Ist das die TUF non-oc? Interessante Karte wenn man die für UVP bei Asus einkauft. Läuft hier gut, aber brauch bei mir auch 1.1v ffür 3 Ghz. Voltage limitiert hier halt, wie bei allen 4090ern. Schau dir aber bitte die Einsteiger-TUF genauer an, viele hier nutzen das Modell. Dank Kompatibilität mit der Strix, wird es bald wohl auch mehrere Wasserkühler zur Auswahl geben.
So mal Unigine laufen lassen
Default ohne OC 4090 FE:
WO bekommt man TimeSpy here (keine Kaufversion). Steam?
Hab den schon ewig nimmer benutzt und kaufe will den auch nicht kaufen^^
@dnnsh Das Video klingt nicht so gut. Das ungleiche Wummern würde mich persönlich stören. Du kannst über das Wochende mal länger die Lüfter auf 100% laufen lassen und einen Spaziergang machen. Es kann sein das es noch ein paar Stunden Vollast ruhiger wird. Wenn nicht würde ich mich Montag auch bei MF melden. Kannst denen auch gern das Video verlinken.
An die Gainward Besitzer mit Lüfter Problematik: Versucht mal das Silent BIOS über den Schalter zu aktivieren und Lüfter Kurve in Afterburner auf automatisch. Das beseitigt das Problem komplett bei mir, da die Karte dann im Idle 0rpm hat und bei mir ist es eh nur im Idle hörbar. Performancetechnisch macht es keine Unterschiede, habe fast dieselbe Punktzahl im 3D Mark wie mit dem Performance BIOS. Ist natürlich trotzdem nicht optimal, aber ich persönlich würde die so behalten bis die 5090 oder 5080 drin ist und mache dann ein RMA damit es für den Weiterverkauf gefixt ist.
Das ändert bei mir nichts das Geräusch bleibt. Und im idle sind die Lüfter bei immer aus egal ob das P oder S Bios
Wenn der WB kommt, schau ich nochmal was geht. Aber 210/1600 ist für mich ein Träumchen. Werde morgen so alle 3dmarks mit den Settings durchnudeln, danach geht's ans UV.
Das WaKü Thema habe ich erst mal weiter weg geschoben. Aktuell sehe ich den Nutzen für mich persönlich einfach nicht. Ich bin kein Silent Freak der den Lärmvorteil der WaKü braucht, die Karte erreicht schon unter Luft keine Temperaturen die sie nennenswert einbremsen und die Lüfter sind unglaublich leise im Vergleich zu dem was ich vorher hatte.
Bevor die ersten Infos zur 4090 kamen wollte ich sie auf jedenfall umbauen, weil ich einen Hitzealbtraum erwartet hatte und dadurch blockierte Leistung aber was dann kam war ja das genaue Gegenteil. Jetzt fehlt ihr Spielraum bei der Spannung, man bekommt sie eh kaum ins Powerlimit und die erreichbaren OC Taktraten sind aufgrund der starken Kühler schon unter Luft kaum vom Normalzustand zu unterscheiden.
WaKü ist für mich persönlich kein Prinzip mehr wie es noch vor ein paar Jahren war, so wie die Karte aktuell läuft sehe ich nicht, warum ich irgendein Risiko durch Kühlerwechsel eingehen und mir die Extramühe machen sollte. Ich warte wahrscheinlich mal bis zum Sommer wenn es wieder heiß wird, vielleicht die Sache ja dann anders aus.
Nicht übel, danke dafür. Das wird mein Richtwert sein. Teste auch gerade OC/UV aus. Stellst du das über die AB Curve ein? Selbe Prozedur wie bei der 3090?
Genau dieselbe Prozedur, sieht dann so aus
2022-10-16 00_20_37-(7) [Sammelthread] - NVIDIA GeForce RTX 4090 + FAQ (KEIN MARKTPLATZ! HANDE...png
Das gleiche haben wir mit der Gainward Phantom auch. Kurz gesagt es liegt vielleicht an Lüfter/Resonanz Igor hat Palit angeschrieben in der Hoffnung das man es per Bios fixen kann
Aber abwarten ob es wirklich daran liegt und nicht vielleicht doch ein Defekt an denn Lüfter/Motor liegt
Das ist meine Karte.
Deine Karte klingt genau wie meine. Wäre optimal wenn sich das so einfach per BIOS fixen ließe. Auch wenn mir nicht ganz klar ist wieso die Lüfter bei manchen Probleme machen und bei anderen nicht wenn das per Software gelöst werden kann. Dann werde ich wohl doch noch ein paar Tage warten bis von Igor was von denen hört.
@Youngtimer Danke für den Tipp. Werde später mal testen ob die Lüfter nach einiger Zeit auf 100% ruhiger sind.
Müssen wir abwarten ob man es so fixen kann. Ich habe eine Video gesehen wo ein user meinte er hat das problem nicht aber im video hört man es deutlich. Manche scheinen es nicht zuhören
Hat noch eine außer ich bei Cyberport bestellt und wie sieht bei euch der Versandstatus aus Stand der Dinge jetzt.
Lg
Ich habe am Donnerstag angerufen und nach den Lagerstand der TUF OC gefragt - keine Karte da und dann direkt storniert und nun ist schon eine Karte von MF verbaut, die ich am Donnerstag vormittag bestellt habe.
Haben wohl mehrere schon wieder storniert und von einer Person habe ich hier im Thread gelesen, der eine Karte bekommen hat.
@Felix the Cat Wenn das mal probiert hast und geklappt hat. Sag mal bitte bescheid
Tatsache, das hat funktioniert. :)
Danke dir :bigok:
Im OC Forum schreiben sie davon, dass Asus derzeit wohl Karten binned und eine eigene "Kingpin" Karte releasen wird!
Sie binnen 4 verschiedene Qualitätsstufen und nur die letzten Beiden werden wohl für die Strix OC/non OC verwendet. Das würde die ähnliche Leistung der TUF/Strix erklären.
Interessant. Ich habe hier nur zwei Beispiele, Kumpel mit Strix oc und ich mit TUF non-oc. Die Karten laufen beide gleich. Knapp über 3 Ghz aber auch unter Last stabil mit 1.1v.
Wo EVGA jetzt weg ist, gibt es sicher einen Markt für diese "Kingpin" Karten. Galax wird da bestimmt eine HOF bringen, aber die sind ja bisher hier noch nicht so etabliert am Markt. Könnte ich mir also schon vorstellen das ASUS was bringt. Dann aber bitte auch ein Modell in Kooperation mit deutschen Wakü-Herstellern wie Watercool oder Aqua-Computer. *träum*
Danke dir :bigok:
Ich habe jetzt sowas obwohl Versand vorbereitet. Ist es jetzt ein Server Problem oder wurde bei mir storniert E-Mails habe ich bis jetzt keine bekommen ..?
Lg
Nochmal was zu den roten LEDs der Asus GPUs. Wenn man es loswerden will: ERP Power Saving im BIOS aktivieren.
Ansonsten wird es auch in diesem Video (und den Kommentaren) diskutiert:
Die bessere Lösung ist wohl einfach eines der Adapterkabel zu besorgen. Müsste damit wohl auch verschwinden.
Wenn nur 2 oder 3 stecker an der tuf sind leuchtet sie auch rot. Ich denke die karte wird noch mit strom über den pcie slot versorgt aber bekommt kein strom mehr über die pcie kabel wenn der rechner aus ist. Deshalb leuchtet sie rot um strommangel zu signalisieren. Denke das können nur atx 3 netzteile beheben oder erp im bios aktivieren. Dann ist aber auch wakeup on lan oder usb oder standby nicht mehr nutzbar. Mich störts aber auch nicht.
Lg
Ich hatte per Paypal Express bestellt und konnte in meinen Kundenkonto gar nichts sehen. Denke mal, dass es bei dir nur ein Serverfehler ist, wenn der Versand schon vorbereitet wurde.
ich habe auch per Paypal Express bestellt konnte in meinen Kundenkonto Alles Sehn.
Lg
38K ist bestimmt auch noch drin.
Um paar Plätze verbessert.
Nun wieder 8ter in der Hall of Fame :)
Gibt es innerhalb der RTX 4090 Custom-Modelle wieder Referenz-Designs, sodass WaKü-Blöcke für mehrere Modelle infrage kommen? Ich frage wegen der Gainward Phantom GS.
Für die Gainward Phantom GS ist noch kein WaKü-Block angekündigt. Von EKWB sind ja neben der 4090 FE auch bereits Blöcke für die ASUS Strix + TUF sowie die Gigabyte Aorus und Gaming OC angekündigt.
der von alphacool ist fürs referenz design, aber auf deren seite sind bisher nur folgende modelle als referenz bestätigt:
Kompatibilität:
- Nvidia Geforce RTX 4090 Reference Design
- INNO3D GeForce RTX 4090 iCHILL X3 OC, 24GB GDDR6X, HDMI, 3x DP (N40903-246XX-18332989)
- INNO3D GeForce RTX 4090 iCHILL X3, 24GB GDDR6X, HDMI, 3x DP (C40903-246XX-1833VA47)
- INNO3D GeForce RTX 4090 iCHILL Frostbite, 24GB GDDR6X, HDMI, 3x DP (C4090-246XX-1833FB)
- INNO3D GeForce RTX 4090 iCHILL Black, 24GB GDDR6X, HDMI, 3x DP (C4090-246XX-18330005)
gibt sicher noch mehr mit referenz design aber keine ahnung welche
Ich hab auch im Perf. BIOS Zero Fan im Idle. Mhm komische warum hast du das nicht?!?
Habe rausgefunden woran es liegt. Es scheint die benutzerdefinierte Lüfterkurve im Afterburner zu sein. Wenn ich die deaktiviere geht auch Zero Fan Mode. Werde aber trotzdem wohl im Silent bleiben, da es keine Leistung kostet und allgemein ein bisschen ruhiger ist.
Afterburner ist noch nicht angepasst für die neuen Karten das hatte ich schon mal mit der 3080ti was ihr die ganze Zeit schreibt an Problemen
Lg
MSI 4090 Suprim X Bios update kommt hat er in den Kommentaren geschrieben.
Lg
Kannst Du mal bitte den Tipp mit dem Silent Bios ausprobieren und nochmal aufnehmen. Du hast das Problem gut eingefangen und wäre interessant ob es dann echt weg ist. Wenn das via Bios Fix zu lösen ist, wäre das extrem bequem.
Ich gratuliere jedem, der eine 4090FE bekommen hat...aber ich will auch eine. :(
Wieso ruft Nvidia mich nicht an...
:d
Bin auch noch wegen Mittwoch angepisst :cry:
Ist jedenfalls interessant mit dieser Priorisierung
Denkt ihr, es spielt auch eine Rolle, wie lange schon GE installiert war?
Denn dann könnte NV den Scalpern einen Strich durch die Rechnung machen, die Dutzende VMs am Laufen haben - zu Recht! ;)
Also Division 2 3GHz 1,1 V +1000 Ram da kann man schon mal die 565 W sehen vielleicht auch an manchen Orten mehr!
leider ist nur der Screen mit 2900 was geworden beim 3GHZ hab ich mich verdrückt.
Bisher das Spiel mit höchstem Powerlimit was ich gefunden habe.
Metro habe ich noch nicht rein geschaut!
Weiß nicht wie lange es her ist als man von den Kingpin Karten noch ein echten Performance Vorteil hatte...aber es ist lange her.
Bei den letzten Kingpins hat man genau der gleichen Chip Lotterie unterlegen wie bei jeder anderen billo Karte auch. Wenn du Pech hattest hat die günstige Palit deine Kingpin komplett zersägt. Da haben dann auch eine Mio Phasen nix dran geändert.
Selbst wenn ASUS, anders als EVGA zuletzt, starkes Binning betreibt, von was sprechen wir da? 50-100Mhz mehr als der Durchschnitt? Die Karten werden nur interessant sein wenn sie das Voltage Limit von 1.1V überbieten können und man ein externen Power Mod fährt.
Die Serie hat nämlich sonst nurnoch einen Zweck, den dummen Leuten noch mehr Geld aus der Tasche zu ziehen.
@Matadil kam Heute noch nicht dazu.
Die Kingpin soll ja nicht den Normalo ansprechen. Wer diese Karte normal betreibt, hat zuviel Geld ;)
Ähnliche Themen
Antworten
6K
Aufrufe
314K
