[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Warum manuell und so hoch?
War nur für Tests.
Bei der FE fällt mir auf das der hintere Lüfter echt sehr unangenehm "rauscht". Das hatte die 3090 FE nicht. Es scheint aber iwie am Design zu liegen den dass da etw. schleift scheint mir nicht der Fall zu sein.
I.d.R dreht der Lüfter nicht so hoch.. icht teste noch weiter wie relevant das ganze ist (Sommer?) oder obs vernachlässigt werden kann
Das mit dem möglichen Jubiläumsrelease, hatte ich so nicht auf dem Schirm. Würde auch Sinn machen, dass sie nun schon Chips dafür selektieren. Februar wäre ja auch nicht so weit entfernt und bis dahin haben alle ihre 4090 und wie beim 3090Ti Release wäre die Nachfrage geringer und man könnte seine Wunschkarte direkt bekommen. Was mache ich nun 🤔, schade, dass es noch keine offizielle News dazu gibt bzw. geben wird.
Ja die Lüfter drehen sich nicht destopbetrieb. Was ist denn jetzt schonender für die Karte?
Also ich persönlich ziehe da immer niedrigere Temperaturen vor, vor allem auch in Bezug auf die allgemeine Gehäusetemperatur. Bei solchen Karten ist das zwar schön ein SilentBios zu haben aber wer kauft denn so eine Karte, um sie dann in einem Silent-PC nur für den Desktopbetrieb einzusetzen. Beim Hochfahren der Leistung hat man zudem in Bezug auf die Lüfterleistung dann auch wieder mit höherer Geräuschkulisse zu tun, denn die Ausgangstemp im Idle ist mit 50 Grad im Desktopbetrieb schon sehr hoch. Das ist übrigens eine Temperatur, die ich mit der Lüftereinstellung bei meiner Karte NUR unter absoluter Vollast sehe. ;)
Ich glaube das passt nicht - im "P"ower und "Q"uiet Mode sind es 2610 MHz und nicht 2640 MHz. Oder ist das bei Euch anders?
38K ist bestimmt auch noch drin.
Um paar Plätze verbessert.
Nun wieder 8ter in der Hall of Fame :)
Ah du hast beim Unigine die Shaders auf 4k optimized gelassen. Da hatte ich Extreme. Krass wie viel das ausmacht.
Hast du einen Benchmark Thread hier schon gestartet? Bei der 3090 FE gabs das meine ich mal mit ner Ranking Liste. Da konnte man dann schauen was die Karten in dem Benchmark so erreichten^^
Also Division 2 3GHz 1,1 V +1000 Ram da kann man schon mal die 565 W sehen vielleicht auch an manchen Orten mehr!
leider ist nur der Screen mit 2900 was geworden beim 3GHZ hab ich mich verdrückt.
Bisher das Spiel mit höchstem Powerlimit was ich gefunden habe.
Metro habe ich noch nicht rein geschaut!
Meeehr! :)
Absolut. Die Karten sind wirkliche Monster mit rund 2,5 kg und ich habe gleich zur Sicherheit mal drei Stands am "ackern". 😅 Ich bin übrigens der Meinung, dass hier jetzt auch wirklich Schluss sein sollte mit den Ausmaßen von Karten. Ich dachte meine Strix 3090 wäre schon groß aber meine Suprim X (und bei anderen Modellen ähnlich) toppt das nochmal und zwar vor allem von der Dicke und dem Gewicht her. "Godzilla-Klasse" 😱
Ich habe mir ebenfalls die Suprim 4090 bestellt… Liefertermin aber bestimmt erst in 1-3? Wochen 😅
Ich überlege mir, ob ich die vertikal einbaue. Muss da aber noch nach einem passenden PCIe 4 Riser Kabel recherchieren…
Mal ne Info aus dem OC Forum zu den einzelnen PCBs:
1. MSI SUPRIM X (LIQUID) - Vcore: 26x70A MPS mem:4x70A MPS
2. ASUS STRIX - Vcore 24x70A Onsemi, mem 4x70A Onsemi
3. FOUNDERS EDITION - Vcore: 20x70A MPS mem:3x70A MPS
4. Colorful Vulcan OC-V - Vcore: 24x55A Alpha&Omega, mem 4x55A
5. GB MASTER (WATERFORCE) - Vishay 24x50A, mem: 4x50A Vishay
6. MSI TRIO X - Vcore: 18x70A MPS mem:4x70A MPS
7. ASUS TUF Vcore: 18x70A Infineon, mem: 4x50A Vishay
8. GB GAMING OC Vcore: 20x50A Vishay, mem 4x50A Vishay
Hast zufällig den Link dort hin?
Mittwoch um 15:35 Uhr bestellt, dort stand Lieferzeit 2-4 Tage. Gestern mal ne support Anfrage über das Kontaktformular gemacht.
Jetzt voraussichtlich verfügbar 06.01.23 :d
Same, hatte es damals auch bei der 3090 dort versucht. Es kam dann in regelmäßigen Abständen ne Nachricht dass der Liefertermin noch unbekannt ist.
Damals war man froh wenns nicht storniert wurde da die Preise schnell anzogen. Allerding scheint Cyberport echt seeeeehr schlecht beliefert zu werden oder deren ihr System ist so schlecht dass die für die nächsten Jahrzehnte überbestellt waren.
War nur für Tests.
Hmm hört sich nicht gut an, bestätigt aber die selbe Auffälligkeiten wie vom 8auer und Computerbase. In anderen Reviews wurde nichts dazu erwähnt. Wird scheinbar meistens nicht mit bewertet, da so Dinge eher subjektiv sind?
Wo hast Du denn bestellt? Und ja, der beigelegte "Vierzack" ist ja Standard bei allen Karten dabei afaik. Der Adapter ist natürlich sehr "semi" wegen der Kürze der Kabel. Ich musste bei meinem Meshi 2 auch die größere der beiden vorderen Bodenplatten rausnehmen um die Kabel von da zur Karte führen zu können. Der dritte Stand steht dann quasi direkt auf dem Gehäuseboden. Da kommen aber garantiert noch bessere Kabellösungen, um dann wieder die Kabel ""gepflegt" verlegen zu können.
Ich hab noch eine Frage wegen UV! Bei der 3080 hat das immer gut geklappt. Bei der 4090 hebt er am Ende die Kurve immer wieder etwas an nach den Windows neu geladen hat.
Hatte das Problem nie bei der 3080. Woran liegt das? Er verschiebt die ganze kurve immer. Und nicht nur um die 15Mhz sondern manchmal 45Mhz vorne und hinten dafür 15Mhz höher.
Klar :)
Ja, ich suche auch gerade nach anderen Quellen die davon berichten. Ich würde mal behaupten Nvidia hat nochmal die Kosten optimiert bei dem Preis o_O :(
Kommt wohl noch ne neue ab version.
Bald werden im Ebay und EKA die Invite Links zum Bestellen einer FE gehandelt :haha:
NBB hat es Samstag nicht mehr geschafft ne AB rauszuschicken, vermutlich kommt die dann am Montag :drool:
Schlägst Du zu, wenn die Benachrichtigung kommen sollte?
ich werde wohl kurz überlegen müssen aber eventuell schon. warte ich länger, könnten mehr karten released werden (auch amd) und meine ti wird nix mehr wert sein.
wenn natürlich nvidia den preis senkt wenn ampere ausverkauft ist, was ich aber nicht glaube, hab ich pech gehabt :d
Da muss noch ein stärkeres BIOS kommen... :)
Die Bauteile machen sonst keinen Sinn :fresse:
Hat hier schon wer den verfügbaren Wasserblock von ALC und kann paar Bildchen posten?
hätten mal lieber noch mehr anti coilwhine zylinder installieren sollen.
Ähnliche Themen
