[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Danke!
Ich glaube gar nicht, dass die droppen. Die Links aus den Invites sind bis Montag 15 Uhr gültig. Ich denke eher es wie neue Invites geben.
Das haut hinten und vorne nicht hin.
Als nicht PC-Nutzer oder ohne eine Nvidia Grafikkarte im PC, hat man keine möglichkeit die fe zu ordern? Damit schießt sich nvidia glatt ins eigene Knie! Ich meine es gibt soviele kaufinteressenten die a) vielleicht keinen pc haben und b) bisher amd nutzer waren. Will man diese Gruppe außen vor lassen? wollen die jetzt ernsthaft diese politik bei der 4080,4070,4060 weiterführen?
Also wenn die so weiter machen, wird amd mit dem normalen drop viel mehr Abnehmer finden... Aber hauptsache mal alle Interessenten an ein komisches invite binden, wo man eine Grafikkarte aktiv vom hersteller im system haben muss um mitzumachen und man so die käuferschicht radikal selektiert!
Wow! Das ist schon kurz. Meine gehen Stock bei 66°C an im Silent Bios aber dann schon höher vom drehen.
Hab jetzt ab 50°C-70°C nur 50-55°C Lüfter. Da sind sie schön leise und das reicht eigentlich auch. Sonst würde die immer an und aus gehen und das ist bei der Karte mit das lauteste. Da sie immer ein Brumm machen und dann anlaufen.
OC Bios mal getestet?
Vielleicht hilft das jemanden.
Hab hier ein Video 20cm vom geschlossenen Gehäuse meine RTX 4090 in Doom Eternal mit 118FPS Cap aufgenommen. Habe auch ein zweites Video mit Uncapped 290FPS.
Am Iphone höre ich das Coil Whine etwas auf Youtube irgendwie nicht mehr.
Ich hab jetzt die Lüfter Manuell fest gelegt bei 800 RPM Bios Switch auf OC.
und bei mir Sprangen die Lüfter auch bei 66 Grad an das hat aber genervt weil die dan kurz auf ca 1450 hochdrehen.
Bei 800 RPM hört man die Karte gar nicht!
Bei BF hatte ich jetzt in 4K DLSS Qualität alles max bis auf RT um die 320 W bei 2805mhz 0,97V 58C
Hatte hier im Forum bisher stumm mitgelesen, mir nun aber wegen der Palit Gamerock Theamtik doch mal einen Account gemacht. :d
Meine Karte hat ab der niedrigsten Lüfterstufe (30%) schon so ein Motorengeräusch, das ich bisher von keiner Grafikkarte oder anderen Lüftern kannte. Durch das geschlossene Gehäuse ists nicht so extrem, aber bei niedrigen Drehzahlen schon nervig. Trotzdem bin ich unsicher ob das der Defekt ist von dem ich hier immer las.
Habe mal ein kurzes Video gemacht. Leider etwas rauschig durch die Luftzirkulation.
Wäre mega wenn jemand bestätigen kann ob sich das für die Karte normal anhört oder wirklich defekt ist. Würde mich dann Montag mal bei Mindfactory melden.
Ansonsten ist die 4090 von der Leistung echt heftig:d
Hey !
Leider, würde ich sagen hört sich das nicht normal an, oder so wie es sollte.
Ich würde sie eintauschen, hatte ähnliches auch mal mit einer RTX 2080Ti und wollte und konnte damit dann auch nicht leben.
Ausserdem weiß man ja nicht, in wie weit mit so einem schleifenden Lager/Moter etc. mit der Langlebigkeit aussieht.
Mit freundlichen grüßen
Tim
das haut hinten und vorne nicht hin.
Als nicht PC Nutzer und vorallem ohne eine nvidia grafikkarte im pc, har man keine möglichkeit die fe zu odern. schießt sich nvidia nicht ins eigene Knie? ich meine es gibt soviele kaufinteressenten die a) vielleicht keinen pc hat und b) bisher amd nutzer war. Will man diese Gruppe außen vor lassen? wollen die jetzt ernsthaft diese politik bei der 4080,4070,4060 weiterführen?
also wenn die so weiter machen, wird amd mit dem normalen drop viel mehr abnehmer finden, aber hauptsache alle an ein komisches invite binden wo man eine grafikkarte vom hersteller haben muss und man so die käuferschicht radikal selektiert
Zudem das alle potentiellen käufer, wie amd karten besitzer, ausschliesst. Das wirkt ja als wollten sie keine verkaufen... 😃
hab meine auf die 50% jetzt gesehen das es auch 823 u/min sind :d haben also ähnlichen Geschmack bei der Lautstärke
Zudem alle potentiellen käufer welche eine amd karte haben ausschliesst. Das wirkt ja als wollten sie keine verkaufen... 😃
Genau so ist es. Ich sage es hier und jetzt. Nvidia wird so auf die fresse fliegen, sobald amd die eigene gpu auf den Markt wirft. Das ist nur eine Frage der Zeit. Erst mal die Nutzer mit einer fake 4080 verarschen, nur um dann zurück zu rudern und es doch nicht releasen. Das wird einfach umgelabelt und als 4070 ti releast. der preis bleibt selbstverständlich gleich oder steigt sogar. Die 4090 Interessenten mit komischen invites selektieren. Das einzige wo Nvidia einen Vorteil gegenüber am hat ist, dass sie im highend gpu-markt dominieren. Aber das ist wie gesagt nicht Speerspitze was Verkaufszahlen angeht. Mit günstigen Preisen sowie weniger Verbrauch wird amd die Verkäufe dominieren.
das sage ich als 4090 Nutzer...
Mal nen Update. Meine 4090 FE hat leichtes Spulenfiepen
Der Lüfter hört sich bei 100% ebenfalls definitiv anders an als der Lüfter meiner 3090 FE
.. Ich teste weiter
Das MSI Center geht mir sowas von auf den Sack :(
Kennt jemand ne andere Möglichkeit wie ich die RGB Beleuchtung meiner Suprim X ändern kann ?
Mit der Version 4.6.5 Beta 2 vom 15. September ist dann der "Core Voltage"-Regler nicht mehr ausgegraut.
Bei Port Royal musste ich bei meinen Tests am Donnerstag etwas runter gehen bei den Offsets (Core: +180 VRam +300) im Vergleich zu vielen anderen Benchmarks (Core: +200 +300), damit es stabil durchlief.
Heute mit erhöhter Spannung lief dann auch Port Royal mit +200 +300.
Für 3,5% mehr Takt (laut 3dmark-Log) gabs aber nur 0,8% mehr fps.
Ich hab dann noch 3dmark Speed Way gebencht. Hier hat sich das Ergebnis sogar leicht verschlechtert.
Ich habe mir dann die effektiven Taktraten in Relation zur angezeigten Taktrate angeschaut:
Mit erhöhter Spannung ist der angezeigte Takt um 60MHz hochgegangen, während der effektive Takt nur um 18MHz gestiegen ist.
Und das sind jetzt nur die Max-Werte vom Benchmarklauf.
Wenn man sich über ein Logging alle Werte während des Zeitraums, in dem Last an gelegen hat (im Screenshot ist auch der Zeitraum dabei, bei dem der Benchmark nur geladen hat), auswertet, schauts vielleicht noch ungünstiger für die Spannungserhöhung aus.
Was ein starker Report!! Ich danke dir dafür. Das sind Informationen, die man so glaube ich noch nicht findet.
Hey !
Tim
Danke. Hatte überlegt damit einfach zu leben, nur bei dem stolzen Preis sehe ich das nicht ein. Fragt sich ob zurückschicken und Abstand von Palit Karten nehmen oder nach Ersatzkarte von Palit fragen.
Tendierte dazu die wieder wegzuschicken aber andere Hersteller haben ja anscheinend mit Coil Whine Probleme. Mal von der unerreichbaren FE abgesehen :d
Ich konnte sie damit gar nicht ändern.
Er zeigt mir da nur das Mainboard und den Arbeitsspeicher an.
Im OC Forum schreiben sie davon, dass Asus derzeit wohl Karten binned und eine eigene "Kingpin" Karte releasen wird!
Sie binnen 4 verschiedene Qualitätsstufen und nur die letzten Beiden werden wohl für die Strix OC/non OC verwendet. Das würde die ähnliche Leistung der TUF/Strix erklären.
@dante`afk
Sagte bereits was Ähnliches.
Da aber auch andere Karten bislang nicht wesentlich höher Takten, wird die Kingpin Version, nur mit Anpassungen (Volt) viel höher Takten im aktuellen Rahmen sind alle Karten sehr nah zusammen.
Wie schon gesagt das binnen so früh nach dem Release ist, afaik, für Hersteller auch ein bißchen „geraten“ und wird im laufe der Produktion meist nochmal angepasst. Zumindest war das früher so.
Tip von mir, weiß nicht ob es daran gelegen hat aber ich habe im MSI Center noch das Graphic Fan Tool Instaliert hab dann mal Cooler Booster gestartet, danach war die Graka in Mystic Light zu sehen :)
Bei Computer Base haben wir mal bei Igor nachgefragt und seine GS hat mal nix. Das wird halt ne Charge von Lüftern sein die halt bescheiden sind. Irgendwann wird dann evtl. ein Lagerschaden daraus usw. Nur welche Karte dann nehmen...das ist hier die Frage oder doch austauschen...
Update. also der Lüfter beim Auslass der 4090 FE macht sehr komische "Kratzgeräusche". Erst dachte ich das da etwas am Lager schleift aber das scheint es nicht zu sein. Es scheint iwie die Elektronik des Lüftermotors zu sein die dieses Schleifen/Zirpen verursacht. Hält man den Lüfter an hört man dieses Zirmen alle X Sekunden wenn die Karte versucht den Lüfter wider anzudrehen. XD Spulenfiepen in den Motorspulen oder wie?
Der andere Lüfter der Karte wird ab 50% hochfrequent. Ich denke nicht das das ein lagerschaden ist aber iwie by Design ist der einfach unangenehm hochfrequent.
Als ich die FE ausgepackt habe dachte ich noch dass sich im Vergleich zu meine 2 Jahre alten 3090 FE iwie etwas an der Qualität getan hat. Die Lüfter kamen mir leichter bzw weniger massiv vor. Dürfte das womöglich erklären dass Nvidia da gespart hat?
Generell denke ich macht es aber nichts aus. Man muss sich halt ggf damit abfinden das die Karte bei 70-100% etwas anders klingt als ggf die Customs (falls das bei jeder FE ist)
Das Zirpen denke ich wird ggf wirklich in richtung Spulenzirpen gehen und ist womöglich wie Spulenfiepen nicht weiter schlimm... wenn man mal versucht alles positiv zu sehen.
Jetzt ein bisschen OC...
Aso. Hat noch wer ne FE und kann mal die Lüfter testen? Also tatsächlich mal mit dem Ohr neben der Karte hören.
Der beim Auslass hat ein Zirpen und ab 50% kommt ein eher hochfrequentes Rauschen zustande (beim hinteren hört man das zumindest deutlich)
Als Nicht-PC Besitzer wird man sich bestimmt keine 2000€ GPU mit dem "ersten" PC kaufen. Und als AMD-Nutzer ist man auch keine 2000€ GPUs gewöhnt, eher für 1000€. :d
Es geht ja NUR um die FEs, die übrigend AIB Karten gibt es doch überall.
Hattest du schon mal eine GPU mit richtig heftigem Coil Whine? Da spielen Ton und Kopfhörer keine Rolle, das ist so ein penetrant nerviger Ton, dass man wahnsinnig wird.
Ich hatte sowas ehrlich gesagt noch nicht. Und auch meine Suprim fällt für mich in die Kategorie "leise". Aber wie Du schon gesagt hast, es ist subjektiv, allgemeione Ratschläge helfen da nicht, ich bin nur froh das ich das Problem nicht habe.
Jeder Mensch ist da auch individuell empfindlich. Was für die eine Person störend ist, macht der anderen Person garnix oder nimmt es gar nicht erst wahr.
Deshalb ist einzig und alleine das eigene Gehör entscheidend und weniger die Eindrücke von anderen Personen.
Ich will nicht wissen, bei wievielen die meinen ihre wäre leise, es für andere Leute aber störend hörbar ist. Deshalb stößt das Thema bei vielen auch auf Unverständnis.
Yep, deswegen hatte ich auch kürzlich schon gesagt das diese Coilwhine Reports, wenig nützen, weil es nicht umgangen werden kann indem man ein bestimmtes Modell wählt. Sobald nur einer berichtet das ein Modell bei ihm Coilwhine hat, kann man es von der Liste streichen wenn man weiss das man darauf empfindlich reagiert. Man ist dann fast komplett auf Glück angewiesen eine Karte zu bekommen die da nicht anfällig für ist.
@Felix the Cat Wenn das mal probiert hast und geklappt hat. Sag mal bitte bescheid
Wenn alles gut geht habe ich ab Mittwoch auch meine FE kann dann was dazu sagen.
Frage an die fe user.
Bläst die fe hinten viel luft raus oder bleibt das meißte im gehäuse?
Auf 70% gehen die lüfter?
Meine tuf dümpelt bei vollast bei 1000rpm rum und ist unhörbar. Sind dann etwa 30--40%. Vielleicht ist dein geräusch die pwm steuerung?
Meine tuf dümpelt bei 1009rpm rum und ist unhörbar. Sind dann etwa 30--40%. Vielleicht ist dein geräusch die pwm steuerung?
Auf 100% spürt man da schon was rauskommen. Also ein Großteil des Lüfters vom Auslass müsste auch nach draußen gelangen
Aso ne. Die FE habe ich manuell auf 70% gestellt
An die Gainward Besitzer mit Lüfter Problematik: Versucht mal das Silent BIOS über den Schalter zu aktivieren und Lüfter Kurve in Afterburner auf automatisch. Das beseitigt das Problem komplett bei mir, da die Karte dann im Idle 0rpm hat und bei mir ist es eh nur im Idle hörbar. Performancetechnisch macht es keine Unterschiede, habe fast dieselbe Punktzahl im 3D Mark wie mit dem Performance BIOS. Ist natürlich trotzdem nicht optimal, aber ich persönlich würde die so behalten bis die 5090 oder 5080 drin ist und mache dann ein RMA damit es für den Weiterverkauf gefixt ist.
Hey, also das musst du entscheiden.
Allerdings kann ich auch nicht genau sagen, ob es sich vllt auf der Aufnahme schlimmer anhört, als es ist.
Vielleicht mal auf youtube suchen, wie die Lüfter sich anhören (bei verschiedenen Drehzahlen)
Oder, wenn es das halt noch nicht wirklich gibt, vllt mit anderen Usern vergleichen.
Nochmal was zu den roten LEDs der Asus GPUs. Wenn man es loswerden will: ERP Power Saving im BIOS aktivieren.
Ansonsten wird es auch in diesem Video (und den Kommentaren) diskutiert:
Die bessere Lösung ist wohl einfach eines der Adapterkabel zu besorgen. Müsste damit wohl auch verschwinden.
Damit hab ich ja jetzt nicht mit gerechnet.
Ich habe mir jetzt das bestellt Corsair hx1500i dann bin ich beruhigt.
Lg
Ähnliche Themen
Antworten
6K
Aufrufe
381K
