[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Omg das könnte die Preise deutlich ansteigen lassen/:
Hi, hat da bei dir geklappt mit dem Sharkoon Silent Storm und der RTX 4090? hab die 4090 suprim x und auch das 850 von sharkoon. Hatte schon mal den support angeschrieben aber bislang kein Antwort. Hab mich noch nicht getraut die karte anzuschließen.
Ja, funktioniert einwandfrei. Einfach mit den Zwei Y Kabeln angeschlossen. Lasse die Karte zwar auf 70% PL laufen, aber funktioniert auch mit 100%PL. Kabel werden auch nach längerer Last nicht warm oder so, da passiert nix. Hole mir trotzdem ein 1200W ATX 3.0 Netzteil sobald verfügbar, weil ich bei meinem Gehäuse die Tür nicht zu kriege mit dem ollen Adapter und der dazu echt kacke aussieht. Bzw. die Tür geht sogar zu, aber ich habe genau 3,5cm Platz und Nvidia sagt, man braucht mindestens 3,6cm Platz. Traue mich nicht den Adapter so zu biegen. Die Kabel haben quasi 90 Grad ab der Sleeve, wenn ich die Tür zu mache, das ich mir dann doch zu heikel.
Karte ist bereits im PC, aber laut DHL noch unterwegs. :fresse:
Danke für die schnelle Antwort, hab mir vorgestern auch das thermaltake toughpower gf3 1350w bestellt, dauert aber noch zwei wochen bis das lieferbar ist. Aber dann kann ich heute schon mal n bissel testen. Viele Grüße und danke nochmal.
Das 1600W TT Netzteil ist in Dortmund lagernd, damit kann man sogar zwei 4090er betreiben :eek:
So ich glaube das wars mit Untervolting.
Mein Persönliches Ergebnis mit dem ich zufrieden bin : 965mv Takt gleich bei 2775MHZ sowie Speichertakt + 1000MHZ
Durchschnitt 359Watt Verbrauch
Jo genau das habe ich auch bestellt, nur halt 1200W.
Erster Volt-Mod?
Edit: Mal zu Ende angesehen...Er kriegt auch nur die 1,1V raus, allerdings ist ja die Spannung in seiner Afterburner Version noch gelockt...
Ist bisher nur die FE unlocked?
Wird sich sicherlich noch ändern. Rockstable kann man sowas erst nach Wochen des Spielens beurteilen...
ja kann klar sein, habe aber gestern bestimmt 5 std getestet.....10x Port royal und Speedway und 3 Std cyberpunk gespielt...wird sich zeigen.
Wenn nicht bekommt es noch leichtes Feintuning sollte kein Problem sein wie bei meiner alten 3080 Ti.
Sollte man für die FE bei NBB schauen, oder eher bei Nvidia bis der Kaufen Button grün wird? Meine 3080 FE habe ich bei Nvidia direkt bekommen.
naja ist ja der gleiche laden. der link bei nv geht zu nbb. bleibt nur ein verfügbarkeitsbot denn die verfügbarkeitsanzeige benachrichtigung von nvidia wird langsamer sein
Hast du die letzten 2 Jahre im Winterschlaf verbracht? 🤣🤣🤣
Ich wollte heute bei der Cashback Aktion von Gigabyte mit machen aber leider kann ich keine Bewertung abgeben da die Karte im Shop nicht mehr gelistet ist.
Komische Aktion wenn das nicht funktioniert. Oder es war so geplant :d
ne das ist die blödheit der shops alternate mf und co schmeißen die karten raus wenn nicht lieferbar. warum auch immer
Hat einer mit der 4090 PUBG getestet ?
Sobald ich in das Game gehe und schon im Menü wo ein FPS Limit 60 ist bekomme ich
einen Neustart vom System. Kernel 41
BF2042, Cyberpunk 2077 , Dying Light , Left 4 Dead 2 , Time Spy Extreme, Heaven 4.0 , Port Royal ,PCI E Benchmark , EZ Bench ,Hitman 3, Ready or Not läuft alles .
Nur PUBG will irgendwie garnicht . Wäre nett , wenn einer das Game mal testen könnte .
Habe jetzt ein Dark Power Pro 12 1200 Watt neu vom Schwager geliehen.
Fehler bei PUBG bleibt . Bin irgendwie ratlos.
Hab die neuste Windows 11 version drauf Windows 11 Insider Preview 25217.1010.
Neuste Treiber und neuste Bios ist drauf .
wie bereits gesagt wurde, die fe gibt es ausschliesslich bei notebooksbilliger.
die seite von nvidia verlinkt bei verfügbarkeit dorthin.
Noch besser ist ein Bot, der dann sofort den Checkout erledigt. 🤡
Also ich hab das gestern ausprobiert 60FPS Limit im Menü keine Probleme ingame auch nicht, bin aber bei 0.9v und 2600 MHz gewesen Power Draw war im Menü aber auch nicht hoch achso Win11 Pro aktuell.
Bei Ampere war Metro Exodus Enhanced mit RT und DLSS in 4K für mich der Goldstandard.
Mal mit der 22H2 versucht anstatt der Preview?
Was ich persönlich als eine schlechte Entscheidung empfinde...
Grundsätzlich eigentlich nicht aber es ist schon traurig, dass im Jahr 2022 die Systeme noch immer nicht in der Lage sind sowas fair und der Reihe nach abzuwickeln. Evtl. hätte es Amazon besser können... ähm nein auch nicht :d
Werde wohl mal ne Windows neu Installation machen . Graka selber denke ich nicht . Wenn ich mal denke was CP zieht und dann PUBG Menü . Finde das sehr merkwürdig.
Wie kommst du da drauf das ek Blöcke besser sind als die von Deutschen Herstellern?
Aus Erfahrung, ich habe ca. 10 Blöcke insgesamt schon montiert und getestet von aquacomputer, watercool und EK
Im Ergebnis hat der EK Kühler den Speicher (Mem Junction Temp) immer am besten gekühlt. Die GPU selber wurde zwar vergleichbar gut gekühlt, aber nur EK hat den Speicher auf max. 70 Grad gebracht, die Konkurrenz war da mehr als 10 Grad höher
Ähnliche Themen
Antworten
6K
Aufrufe
402K
