[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Werde wohl mal ne Windows neu Installation machen . Graka selber denke ich nicht . Wenn ich mal denke was CP zieht und dann PUBG Menü . Finde das sehr merkwürdig.
Hast mal probiert im nvcp auf Leistung -> Performance zu stellen? Statt normal.
Hatte da damals bei Elden Ring Probleme
Hab meine Gainward Phantom GS mal undervoltet und dabei sind 2715 MHz bei 0.925 Volt rausgekommen denke damit kann ich zufrieden sein.
Sollte man für die FE bei NBB schauen, oder eher bei Nvidia bis der Kaufen Button grün wird? Meine 3080 FE habe ich bei Nvidia direkt bekommen.
Nur wegen deinem posts vor 2 Jahren, sehr früh am Morgen, konnte ich mir damals auch die 3080FE direkt über NV sichern. 😅
Ja habe ich im PUBG Profil eingestellt gehabt.Nichts geändert . Windows GPU hardwarebeschleunigung deaktiviert.
VRR deaktiviert und HDR deaktiviert .
Windows Energie Einstellung Höchstleistung .
CPU um 200 MHZ runter getaktet.
Ram runter getaktet.
Hat alles nichts gebracht .
Nachdem ich heute öfter mit PT 70% und manuelen UV getestet habe.
Sind bei mir die min. FPS deutlich besser mit UV.
Und ich bekomme mit 0,900V auch nochmal knapp 10-20W unterhalb der 70%.
Für mich ist jetzt alles erstmal perfekt eingestellt und ich werde die Spiele damit geniesen.
Wieviel Mhz?
Meine Gainward Phantom GS RTX 4090 macht Geräusche. Das bekommt man also für 2 Scheine. Geht sofort zurück die Karte.
Die brutale Effizienz von ADA wird vor allem im Notebook Bereich Anfang nächstes Jahr zeigen was geht.
Gerade Notebooks werden richtig derb einen Sprung machen was entweder Leistung oder Laufruhe angeht.
Wenn ich mir vorstelle was eine 150W mobile GPU bald zu leisten im Stande ist…
ne das ist die blödheit der shops alternate mf und co schmeißen die karten raus wenn nicht lieferbar. warum auch immer
Hmm muss man Gigabyte melden. Sollen sie halt ohne Bewertung das Cashback geben oder mit den Shops reden. Ehrlichgesagt gehören diese Bewertungen eigentlich nicht dazu. Finde das von GB nicht gerade ne feine Art sich so die guten Bewertungen zu ermogeln.
Das tun ASUS und MSI doch genauso. Von daher auch die Lobhudeleien auf geizhals, amazon und Co, mit meistens 0% Mehrwert für denjenigen, der die Bewertung liest. Die Verfasser haben meist einfach keine Ahnung, wie man eine hilfreiche Bewertung schreibt oder sind halt auf das schnelle Geld aus. ;)
Hi, Leute
Postet mal bitte eure TimeSpy Extreme-Ergebnisse?
Bitte per Link, damit man vergleichen kann - danke ;)
Du bist aber auch nicht gezwungen eine gute Bewertung abzugeben wenn du nicht zufrieden bist. Habe denen damals beim Master Board 1 Stern gegeben weil ich total unzufrieden mit dem Board war.
Steam Gutscheine gabs trotzdem. Die Bewertung ist jetzt aber lustigerweise gelöscht lul
Gibt es schon so einen mittel Wert was man so+ fahren kann bei Ram über den AB?
Hab mir das hier nicht so genau angesehen weil Benche nur ingame :-) Ram habe ich aktuell nur auf+500 laufen und nicht weiter probiert!
Zum Glück sind die Ram Temps bei der 4000ner Serie kein Thema mehr!
Nicht viel! Hab alles sehr auf Stabilität ausgelegt. 20 Runs Metro Benchmark, Stresstest Port Royal, Cyberpunk usw.
0,900V 2575Mhz +500Mhz auf Speicher.
Ist meine alltags Einstellung.
Bei Resi 7 in 4K alles max. und Ray Tracing (ist ja nicht viel drin). Braucht die Karte mit 118FPS ca. 180W. So macht es Spaß.
Also die sieht doch einfach nur geil aus
Ich kann die Memory Temps nicht sehen in GPU-Z wo sieht man die?
Hwmonitor zb.
Glaub die meisten haben +1500 auf dem Speicher
Muss ich gleich mal schauen! Danke!
Nicht das bei +500Mhz der Speicher immer zu heiß wird.
Meine Asus 4090 tuf non oc läuft aktuell daily bei -25% PT +150 Mhz Core Clock + 900 Mhz Mem Clock, hat damit in allem, was ich getestet habe etwas mehr Leistung (1-2%) als Stock bei Peak 360 Watt statt vorher Stock 443 Watt. Läuft super stabil, da würde sicherlich noch etwas gehen, aber mir ist die Systemstabilität in jeder Situation wichtiger als die 1-2 % Mehrleistung. Natürlich profitieren auch die Temperatur und die Lüftergeschwindigkeit ein wenig, allerdings sind die beiden Punkte sowieso kein Problem. Wie optimiert ihr eure Karte? Lieber UV statt PT runterdrehen? Meiner Erfahrung nach bringt UV wenig, vor allem ist das Verhalten der Karte komplett anders als man es von Ampere kennt.
Grundsätzlich eigentlich nicht aber es ist schon traurig, dass im Jahr 2022 die Systeme noch immer nicht in der Lage sind sowas fair und der Reihe nach abzuwickeln. Evtl. hätte es Amazon besser können... ähm nein auch nicht :d
Sorry aber da grätsche ich mal rein, auch wenn ich gesteinigt werde. Es kann einfach nicht sein das du hier solche Spräche klopfst obwohl du dazu keinerlei Infos oder Hintergrundwissen hast. Du sagst einfach es ist nur fair weil du noch keine Einladung erhalten hast. Aber weist halt nicht wie das System läuft. Du sagstest ja selbst du hast GFE erst installiert als du erfahren hast das es diese Einladungen gibt, vielleicht haben das andere schon Jahrelang oder gar immer intalliert. Du denkst nur weil du jetzt GFE installierst hast und ne handvoll spiele im Account, muss man dir direkt die Chance geben eine FE zu kaufen. Denn alles andere ist ja unfair.
Sorry, verstehe ich nicht.
Ähnliche Themen
Antworten
6K
Aufrufe
314K
