[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Grüße 🖖
Würde mich gerne an das Thema Undervolting heranwagen und wollte mal in Erfahrung bringen, ob es bei Ada eine grobe Richtlinie gibt an der man sich orientieren kann?
Besitze die Gaming Trio und würde gerne, dass die Karte auf 350 Watt. Wäre für mein Gehäuse auch deutlich komfortabler da ich das Lancool Mesh II besitze
Hat auch ausreichend Airflow denn das Teil hat meine Aorus Xtreme 3080 auf 69 Grad gehalten
War glaube ich auch ihre Thermische Grenze
Gibt es lehrreiche Videos die man mir freundlicherweise verlinken könnte ?
Liebe Grüße
Gibt's nen Test zum Spulenfiepen ich höre nämlich absolut 0 bei meiner ZOTAC Amp Extreme Airo.
high load + mehr fps.
Grüße 🖖
Liebe Grüße
einfach das pt runter ist wohl die einfachste methode
Hier auch nur FPS Limiter und Powerlimit - fertig. (Bzw. lass einfach den Afterburner mit OSD laufen -z.B. bei meinen Racing Games brauch ich nicht mal das Powerlimit runtersetzen, die Karte braucht nicht über 380 Watt im Peak😂)
Nachdem diese Karte die hohen Spulen analog zu den Karten mit 100% Ref hat, stehen die Chancen sehr gut, das sie tatsächlich so leise sind.
Zusätzlich zu den schon genannten Testmöglichkeiten: Meiner Erfahrung nach ist der Superposition-Benchmark (zb 4k-Preset) ein Worst-Case-Szenario in Sachen Spulengeräusche.
So bei 60-70% laut derBauer.
Also einfach straight das Power Limit MSI Afterburner runtersetzen ?
Ist ein richtiges Untertakten nicht sinnvoller per Volt als das ? ^^
Mit Ada klappt die Verbrauchsreduzierung durch herabsetzen des PL fast genauso gut wie klassisches UV. Wurde hier im Forum auch schon getestet. Nur minimale Unterschiede bei der selben Leistungsaufnahme.
Normalerweise dauert es nicht 1,5 Tage von Regensburg bis nach Wien, das sind 400km. Eigentlich hätte die Shice letzte N8 in Wien ankommen sollen, normalerweise schafft DHL ca 600km pro Tag (wie alle anderen auch per Landweg), oder zumindest in nem Zwischenlager, ev in Linz, hätte das Teil landen können, warum auch immer. (y)
Also ich habe schon Pakete die 200km entfernt sind erst nach 2 Tagen erhalten oder sogar 3 Tage. Ich hatte sogar schon Pakete die wurden im Zustellzentrum zur Beladung ins Fahrzeug gescannt und lagen dort 3 Tage. Aktuell ist vieles möglich aufgrund der schwierigen Lage.
Hier direkt eine Unterstellung zu machen das einer die Karte eingesteckt hat, ist falsch denke ich. Denn alle anderen bekommen ja ihre Karten auch.
Diese Aussage hält sich irgendwie hartnäckig obwohl die nur von einem Influencer stammt. Offensichtlich glauben das viele. In verschiedenen Foren liest man aber durchaus das mit UV bessere Werte erzielt werden von der Community.
Bin bei mir mit PWT Limit und OC besser gefahren als UV per volt limit. Mehr Leistung bei identischem Verbrauch.. sind aber nur ein paar FPS.
@pajonk hat ein paar gute Tests dazu gemacht ein paar Seiten zuvor.
Alles Quark was du erzählst. Bei Auslandssendungen kommt es immer wieder zu Verzögerungen und Tagen, an denen sich das Paket nicht bewegt. Einfach mal locker bleiben. Kann man außerdem den Medien entnehmen, dass es aktuell zu Verzögerungen aufgrund des hohen Krankenstandes kommen kann.
Ein Thumbnail hätte es übrigens auch getan, bekomme das einfach nicht in den Kopf, warum man immer die Screenshots in voller Auflösung postet? Davon ab gehört der Beitrag sowieso in den Smalltalk Thread, hat nichts mit der FAQ zu einer 4090 zu tun. 🤦‍♂️
Ich habe das nicht aufgrund des einen Videos gesagt, sondern weil es selbst hier im Forum sowie bei mir zu ähnlichen Ergebnissen geführt hat. Es gibt sich einfach nicht viel.
Bei mir ist es aktuell auch ein klassisches UV Profil, weil ich damit ein besseres Gefühl habe :)
Einigen wir uns darauf, man macht mit beiden Vorgehensweisen zumindest bei Ada nichts verkehrt.
Und genau das möchte ich erreichen deshalb die Frage, ob es eine grobe Richtlinie gibt was Ada betrifft
0.95 oder 0.9 und schauen was geht. 0.8x war glaube ich schon nicht mehr gut für die GPU. Ich fahre aktuell 0.95 bei 2700.
Ah super, danke! Ist es eigentlich okay, das Powertarget instant auf 70 dann zu setzen, oder sollte man auch hier, ähnlich wie beim OC, schrittweise runtersetzen und Systemstabilität prüfen?
Einer der Gründe wieso die Reduzierung des PL etwas einfacher ist bzw. schneller von der Hand geht. Dein System wird stabil laufen, du brauchst es nicht erst zu testen, was bei UV im Grenzbereich notwendig ist.
Danke dir 👍
Was konntest du dadurch an Temperaturen verbessern ?
Wie ist dein FPS Verlust …
Hatte es zwar schon mal gepostet aber das Video ist zu diesem Thema ziemlich aufschlussreich.
Da jede 4090 anders ist, muss man sich halt rantasten.
Ich hatte bei meiner unter Luft 850 mv @ 2650 glaube ich. Das war soweit stabil. Den FPS Verlust konnte ich nicht sehen, da ohne UV direkt das Netzteil ausging. Das Enermax Revolution 750W kam damit nicht klar ohne UV. Heute im Hauptrechner beim 750 E11 Platinum wird das anders laufen.
Wir müssen uns auf nichts einigen. Du hast deine Meinung geschrieben und ich meine. Nichts weiter. Hier wird ja öfter dieser Influenver erwähnt. Es ist nicht falsch das man dazu sagt das es nicht unbedingt so sein muss. Meine Aussage war kein Vorwurf.
Ich werde es bei meiner auch testen mit dem
Spuhlenfiepen dann, wobei man auch ehrlich sein muss wenn man es erst extrem bei 200+ FPS hört kann es mir egal sein. Hab generell ein cap auf 141 FPS da mein UWQHD Monitor eh nur 144 kann.
Muss man mal schauen. Kp wann ich die abholbestätigung bekomme (nervt mich das ich kein versand zu mir gemacht habe^^) aber wollte/will die strix eigentlich wobei die msi Suprim auch gut aussieht und von den maßen auch „kleiner“ im vergleich.
für itx builds quasi pflicht ne wakü zu nutzen wobei dannn die radifläche zum problem wird :d
Mini-ITX macht man eh nur mit Mora! 8-)
Aloha zusammen. Ich habe mir eine Zotac 4090 sichern können. Nun habe ich noch ein 1000w Netzteil liegen, welches ich gern für die Karte verwenden möchte. Dieses NT hat allerdings nur 3x PCI-E Kabel beiliegen. Der Anschluss der Zotac Karte benötigt allerdings, im Gegensatz zu anderen Karten, nicht 3, sondern 4 8Pin Anschlüsse. Glaubt ihr, ich kann eines der Doppelkabel, also 1 PCI-E Kabel mit zwei 8 Pin Anschlüssen verwenden, oder sollte ich mir ein viertes Kabel nachbestellen?
Nachricht gelöscht
Ähnliche Themen
