[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe meine Trio X mal ein Stündchen laufen lassen. Die Spulen haben zum Schluß genauso geschrien, wie zu Beginn.
Lass ich jetzt tauschen. Wenn nichts besser wird, wandert die in die Bucht.
Ich habe die letzten 3 Seiten gelernt, dass ich kotzen will, wenn ich Nachrichten von speziellen Usern hier lese. Das Wort „Shice“ belastet meinen Glauben an die kommunikative Intelligenz am meisten.
die ganzen "8" hast du auch gesehen? :d
ne weiße FE hui.
leider nur ne ampere :d
Die Tipps mit Spulen Einbrennen mit speziellen Spielen oder Benchmarks. Spezielle Settings zum einlaufen lassen der Spulen. Anderes Netzteil. Anderes Kabel. Dickere, dünnere, härtere, weichere Wärmeleitpads, mehr weniger Wärmeleitpads. Dem ganzen länger Zeit geben. Hab ich alles bei der 3090 Strix gemacht hat alles nichts gebracht die Karte schreit nach 2 Jahren noch genau so wie vorher. Hat nun meine Frau da sie nur mit Kopfhörer spielt und es da sobald das Spiel und Ton drauf ist erträglich ist. Aber wenn ich wenn sie spielt in die Nähe von ihrem Rechner komme denk ich immer zuerst oh schreck da ist irgendwas kaputt schnell PC ausmachen bis mir einfällt das dieses KRRRRRRÄRÄÄSÄZZZZZRTZTTZTZTZTTZZTZTZTZ ja nur die Strix ist :d
Also wenn man Geräusche hat und damit nicht leben kann würd ich es innerhalb der 14 Tage zurückschicken und nicht drauf spekulieren das es vielleicht in ein paar Wochen aufeinmal besser wird oder gar verschwindet weil das wirds wahrscheinlich nicht. Was noch am besten gewirkt hat ich aber nur an einer günstigeren Karte getestet habe ist die Spulen mit Epoxy fluten und keine Wärmeleitpads auf den Spulen zu haben diese also quasi von jeglichem Kontakt abschirmen und mit dem Epoxy möglichst ersticken. Aber das mach ich ja nicht bei ner neuen teuren 3090, 4090 etc. wo dann die Garantie sofort futsch ist.
Auch wenn ich eher Mitleser bin und es OT ist, aber DANKE. Jedes Mal wenn ich etwas vom Betreffenden gelesen habe, hatte ich das bedürfnis mich fast zu übergeben bei der Verge**tigung der Sprache.
Also mir stach ja "hoite" direkt ins Auge ... das von dir erwähnte ist einfach die übliche gossensprache.
Muss nicht bedeuten das es für gamer teurer wird, wenn die Menge immer noch ausreichend bleibt da passt man eher an die aktuelle Nachfrage an aber mal sehen ....
Ich weiß wen du meinst. Die Ignorierliste hilft 😉
kann ich eigentlich nen 3000 fe kabel an jeder 4090 benutzen? die pins sehen gleich aus
Immer locker bleiben, der wird schon noch auseinandergenommen werden für solche Aktionen. Alles halb so wild.
Meine Gigabyte 4090 produziert ein seltsamen Fehler. Wenn ich im Idle bin im NoFan Modus und plötzlich der Lüfter anspringt zum nachkühlen, gibts ab und an ein Treiberreset/paar Sekunden Blackscreen mit folgender Meldung:
Der Anzeigetreiber "nvlddmkm" reagiert nicht mehr und wurde wiederhergestellt.
Die Beschreibung für die Ereignis-ID "0" aus der Quelle "nvlddmkm" wurde nicht gefunden. Entweder ist die Komponente, die dieses Ereignis auslöst, nicht auf dem lokalen Computer installiert, oder die Installation ist beschädigt. Sie können die Komponente auf dem lokalen Computer installieren oder reparieren.
Falls das Ereignis auf einem anderen Computer aufgetreten ist, mussten die Anzeigeinformationen mit dem Ereignis gespeichert werden.
Die folgenden Informationen wurden mit dem Ereignis gespeichert:
\Device\Video3
Error occurred on GPUID: 100
Die Nachrichtenressource ist vorhanden, die Nachricht wurde in der Nachrichtentabelle jedoch nicht gefunden
Eventuell ist das Lüfter anspringen auch Resultat des Treiber Resets. Es passiert nur im Idle. Jemand schon was ähnliches gehabt?
Gibt es Leute hier die eine 4090 trinity haben? Und Erfahrungen dazu? Habe eine 4090 trinity geschossen kann sie jedoch erst Donnerstag verbauen wenn der Rest da ist. Viele Grüße
Die Halterung ist auch perfekt umgesetzt. Diese wird am rechten Teil vom Mainboard befestigt.
Bei meinem Mainbord lässt sich diese Halterung leider nicht passend anbringen. Bei mir sitzt der PCI-E-Slot höher auf dem Mainboard als es normalerweise sein sollte. Der Slot liegt auf gleicher Höhe mit der rechtseitigen Mainboardbefestigungsschraube. Dabei sollte der ein bis zwei Zentimeter tiefer liegen als diese. Hab mir nun eine alternative GPU-Halterung bestellt.
Das kann eigentlich nicht sein, da die Slots genormt sind. Es kann allerdings sein, das Slot 1 übersprungen wird und der PCI-E 16x Slot bei Slot 2 ist.
Man muss nicht die Schrauben am Mainboard nutzen wen das Gehäuse noch größere Mainboards fasst dann kann man ein Stück nach rechts gehen und die anderen Aufnahmen verwenden!
Der Halter war das beste an der Karte!
ein tamagotchi
die gibts? oO
evtl zu stark undervoltig eingestellt?
Meine RTX 4090 Phantom wurde gestern versendet. Ich freue mich auf die Karte! :)
Wie handhabt ihr es eigentlich mit euren alten Karten (Turing/Ampere)? Hebt ihr die als Backup-Karten auf oder verkauft ihr die direkt? Bin mir nicht ganz sicher, wie ich es am besten machen werde. Der Wert der Karten könnte nach RTX 4080 bzw. RDNA3 Reveal noch einmal steigen (Wenn man sieht, was das für "Krücken" sind)...
Habe hier etwas mitgelesen bez. spulengeräusche. Ich habe eine Supreme X und die macht so geräusche wie ein rasierer, wenn ich spiele.
Ist das dieses störgeräusch?
habe auch noch eine ungeöffnete strix. sind die besser?
Damit liegst du richtig.
Bei der Strix hilft auch nur testen, würde aber nicht zuviel erwarten. Meine Strix war noch schlimmer als die Suprims.
Ähnliche Themen
