[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Klingt komisch aber nach 7 Tagen dauerzocken macht meine Asus TUF non OC keine Fiep oder Rattergeräusche mehr mit Ausnahme wenn es an die 200,300 fps geht . Aber selbst dann ist es ein leises rasseln/fiepen.
Bim echt glücklich mit dieser GPU. Dank Metallgehäuse sehr hochwertig und stabil. Konnte die für UVP 1949,- ergattern.
Weiß jemand wieso dieses TUF non OC Modell nur bei Asus Eshop zu finden ist und nicht bei anderen Händlern?
Geht mir bei meiner Suprim X ähnlich.
Die lief letzte Woche auch mal 48h im MSI Kombustor und beim Dauerzocken von Kingdome Come Deliverance kann ich es mittlerweile auch nicht mehr hören.
Wenn ich die Seitenscheibe abmache und Ohr ranhalte höre ich es zwar noch, aber nicht mehr so extrem wie letzte Woche, wo es mit geschlossenem Gehäuse und ca. 1m Abstand, noch deutlich lauter und hochfrequenter war.
Meine Gigabyte 4090 produziert ein seltsamen Fehler. Wenn ich im Idle bin im NoFan Modus und plötzlich der Lüfter anspringt zum nachkühlen, gibts ab und an ein Treiberreset/paar Sekunden Blackscreen mit folgender Meldung:
Eventuell ist das Lüfter anspringen auch Resultat des Treiber Resets. Es passiert nur im Idle. Jemand schon was ähnliches gehabt?
Das tönt für mich nach einem Bug im VBios, GPU bekommt zu wenig Saft, Treiberreset.
Silent Bios 95.02.18.00.BC ?
Wieso nur 3 ? Hättest doch jedes Modell nehmen können so wie andere hier. Habe gehört man verkauft die ganz gut gebraucht zum Kaufpreis.
Da mit man sich dann mit irgendwelchen Leuten rum schlagen muss.
Ab Donnerstag kann ich endlich testen, welche 4090 es bei mir wird. Habe 3 Karten zur Auswahl und mache es rein von der Geräuschkulisse abhängig.
Könnt ihr mir einen Ratschlag geben, welches Spiel / welche Anwendung ich am besten nutzen soll? Habe leider die Woche nicht viel Zeit und möchte möglichst effektiv und schnell testen.
Da ich auf einem OLED spiele, der max. 120 Hz darstellen kann, überlege ich, ob ich einfach auf 120 fps begrenzen soll.
Division 2 4K Max out bring die Karte an ihr Limit Wen man Takt und Spannung ausfährt.
Man sollte immer unterhalb der maximalen Aktualisierungsrate des Monitors bleiben, sofern man denn Gsync nutzen will, was auf jeden Fall zu empfehlen ist. Oberhalb von den 120fps funktioniert das nämlich nicht mehr. Für die perfekte Erfahrung auf dem OLED macht man folgendes:
Gsync- Ein
Vsync - Ein
Max FPS im Treiber: 117 oder 118 fps
Grafikeinstellungen im Spiel an dieses FPS Ziel anpassen, sofern möglich/nötig
Hmmm warum?
Ich dachte G-Sync sei dafür da um bei zu wenig FPS (weniger als der Monitor Herz hat) das Tearing am Monitor zu verhindern.
Bringt es noch andere Vorteile wenn man die 120FPS zwar hat und G-Sync aktiviert?
jo bei mir das Gleiche, kann da auch nichts hören und die Lüfter haben noch massiv reserven. Hab jetzt zum testen mal ein bisschen rum gespielt und gut 3Ghz sind für die Karte wirklich gar kein Problem. Weder wird sie zu laut noch zu warm. Cyberpunk 2077 und Modern Warfare 2 laufen damit ohne Probleme. 3d Mark habe ich mit diesen "Alltagssettings" auch nochmal laufen lassen...
Die normale zotac trinity oder ? Feeue mich auch meine verbauen zu können bisher wirklich nichts bezüglich spulenfiepen gehört :)
@SaiBot62
Kenne das nur mit Vsync aus und Gsync an .
  • Sad
Reaktionen: gjn
Ich nutze G-Sync immer, weil die Vertikale Synchronisation sollte ja trotzdem da sein. Kann ja bei 144 HZ von Monitor, meist keine 144 FPS in 4 K von der Graka bekommen, also passt G-Sync die Hz an die FPS an.
unterhalb von der G-Sync (Compatible) Range von 48 HZ, meist schon bei 50 HZ/FPS, macht der Treiber Frame Doubling, hab dann 100 FPS/HZ, dafür steigt natürlich die Frametime, was man schon merkt zum Teil,
Hmmm warum?
damit gsync funktioniert müssen die fps innerhalb der range bleiben. limit auf 120 wäre zu knapp
limit per RTSS auf 118 und dann gsync + vsync an.
mit zu wenig fps hat gsync nichts am hut
Ja genau die Version ist aktiv. Ist das bekannt?
Nope, hatte nur geschaut ob es eventuell schon was neueres gibt, unverified Uploads in der Techpowerup VBIOS DB immer mal wieder prüfen, oder mal Gigabyte Support anschreiben.
Edit: So wie es aussieht wurden alle RTX 4090 VBIOS aus den unverified Uploads entfernt. :LOL:
Limit 3-4 fps drunter damit kein vsync inputlag bei 120 reinkickt. Gsync verhindert tearing und macht das Bild bei Bewegung geschmeidiger. Tearing wird aber nicht komplett verhindert (oben und unten im Bild teart es auch mit gsync) nur wenn man vsync zusätzlich aktiviert ist es komplett fein.
Hmmm warum?
Das ist ein Irrglaube. Leider verstehen die wenigsten die Technik die sie nutzen. Liegt in diesem Fall aber auch am Marketing...
Ja, richtig. Vsync aus und gsync an geht auch, aber Bild ist deutlich unruhiger. Vsync an und gsync an bringt die besten Ergebnisse, natürlich mit Framelimit.
Mit DLSS 3 muss man dann mal gucken was am meisten Sinn macht, damit ändert sich ja einiges. Da muss man dann möglichst unterhalb von dem Framelimit bleiben um hohe Latenz zu verhindern. Da die 4090 so performant ist, könnte das aber je nach Spiel schwierig sein. Evtl. Mit Supersampling und falls vorhanden, wird dann Raytracing zum must have :d. Z.B. bei Plague Tale schafft man es aktuell ohne Raytracing gar nicht unterhalb von 120fps zu bleiben in 4K mit DLSS 3. Daher ist da DLSS 2 noch sinnvoller, da RT ja irgendwie immer noch nicht verfügbar ist. Wobei die Latenz bei so einem recht behäbigen Story Spiel vllt. Auch gar nicht so schlimm ist... Aber da ich in der Bildqualität keinen Unterschied zu DLSS 2 Quality sehe und auch damit die 117 fps konstant kriege, lasse ich DLSS 3 einfach aus
Ja da hatte ich zumindest Tearing mit DLSS 3.0 bei Spiderman Framelimit hat nich funktioniert und Vsync erhöht den Inputlag .
Ich hoffe das ich kommende Woche eine Strixx abgreifen kann .
Kann mir bitte mal jemand erklären, ob es einen Leistungsunterschied zwischen der Gigabyte Windforce und der Gigabyte Gaming OC gibt oder liegt der Unterschied nur im Lüfter/Kühler?
da die karten wohl alle richtung 3ghz und über 1000mhz im ram mehr gehen kannst du nach geschmack wählen. finde die windforce schicker. das geflicker von den leds bei gigabyte ist ne katastrophe
Ich auch, da man ja durch die Framebegrenzung stets in der Gsync-Range bleibt. Zumindest hatte ich es so verstanden.
Vsync war noch irgendwas mit dem Inputlag meine ich mich zu erinnern.
Meine Master lief nur +900mhz stable im RAM
Hab auch schon wen gesehen bei dem war bei +650 Schluss!
Also man kann schon Pech haben.
Auch Leute gesehen die mit 1.1V gerade so die 2900 schaffen.
Jemand ne kurze Anleitung wie ich Voltage auf 1.1 erhöhen kann?
Ich habe trotzdem immer vsync Off. Merke da kein tearing oder frame pacing problem…
Viel Lesestoff auf den folgenden Seiten in dem Artikel…aber das wichtigste ist bei GSync ON die Frame Rate Cap auf -2/3fps vom Monitor. Vsync in Cyberpunk zb ist total laggy…
Ja, der ist höher mit Vsync. Ist also meistens die Qual der Wahl zwischen Tearing oder höherem Inputlag. Wobei ich letzteres immer bevorzuge ;)
Ich hab kein Tearing mit Gsync -VRR auf meinem 77C1 LG Oled.
V Sync immer aus Limit 117 FPS.
Genauso ist es bei mir. In dem Artikel den ich von blurbuster gelinkt habe, steht allerdings, dass es trotzdem zu einem „tearing“ beim Scan out kommen kann…aber glaube das kommt so selten vor, dass man es nicht merkt.
Ähnliche Themen
Antworten
6K
Aufrufe
399K
