[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Soviel zu dem Thema das der 3-fach Adapter der den niederen 4090er beiliegt nicht betroffen ist
jepp somit sind dann zumindest 450 Watt auch nich Save ... ob 400 oder 350 oder 300 Watt Save sind wissen wir auch noch nich
Schon krass viele Fälle in so kurzer Zeit :rolleyes2:
Jepp ... war auch interessant zu beobachten wie die Sache hier im thread anfangs bzw sogar bis vor kurzem noch klein geredet wurde.
Ich Finde selbst 1 Fall is schon Grund zur besorgniss .. nich unbedingt Grund zur Panik .. aber eben zur Besorgniss und dafür das man das Problem ernst nehmen sollte
und nich noch spässe darüber macht.... bei sowas weiss man nie was da sonst noch so passieren kann wenn man eben grade mal nich direkt am PC is sondern aufm Klo
oder in der Küche oder so.
Bin mal gespannt wie Nvidia damit nun umgeht und wie das nun auf Kurzer Sicht weiter geht und da wird auch sicher jemand hinterher derbe Ärger bekommen denn sowas hätte in der Entwicklungsphase eigentlich
schon auffallen müssen das dieser Aufbau so nich grad so idial is.
Hmm, da standen auf jeden Fall 4090 im Regal vllt. waren das drunter 3000er founders? Na zumindest bei der Inno3D hab ich gut genug hingeschaut, sorry :censored:
Ja das sind alte FE Kartons :)
So, mein Video zu DLSS3 / Gsync, LG Oled ist nun raus. Leider nicht in der Qualität die ich erhofft hatte.
Das einzige Problem in MW2 war dieses tolle weiße Flackern bisher :d
120 und 144 sind schon sehr nah beinander. das ist nicht die welt.
Manche merken auch keinen zwischen 60 und 120 hz, andere angeblich zwischen 144 und 280 hz.
Kann ich mir nach wie vor nicht vorstellen wie das gehen soll, das merkt sogar mein Dad mit Mitte 70 noch sofort :eek:
144 und 280 Hz ist auch easy zu unterscheiden. 144 auf 280 Hz nicht so sehr, wenn man nur 144 gewöhnt ist. Aber wenn man von 280 auf 144 Hz zurück muss kriegt man aktuen Brechreiz.
Musste auch vom neuen Treiber ein Rollback machen (das erste mal in Jahren mal wieder).
Die Lüfter wollten nicht mehr in den Zero Fan Modus bei der Phantom... sobald der alte Treiber drauf war, voila: instant wieder auf 0% wie es sein soll. :asthanos:
Aber auch ganz allgemein kommt der MSI AB noch nicht ganz zurecht mit meiner 4090 und insbesondere der Lüftersteuerung... da muss noch bissel Feintuning her.
Einzige was mich bei der Strix stört ist der RGB Ring am ende des Kühlers.
Finde die TUF auf Kühlerseite schöner , aber bei der Strix gefällt mir das design der Backplate .
Hätte auch die Strix genommen , wenn verfügbar gewesen , aber man kann mit der TUF auch gut leben.
Hat das schon wer mit dem Bios Flash gestest? Also zb.B von TUF non-oc auf Strix OC.
Also habe bei meiner TUF OC erstmal das neue Bios von Asus drauf geschmissen .
Bisher alles ohne Probleme . Mit dem neuen Nvidia Treiber hatte ich jetzt auch keine Probleme,
aber bisher nur PUBG , BF2042 und Dying Light gespielt.
Das Adpater Kabel habe ich eben aus interesse mal auseinander genommen.
Sah bei mir alles noch gut aus , aber besser ist es und ist somit in den Müll gelandet ^^
Die meisten undervolten ihre Karte aus Angst, dass der Stecker schmort und @Holzmann so: "1000W BIOS?! WO?! Need moar powa!!!"
Wenn er alles im Blick hat, ok
Hat man keine WB-Cam (oder IR-Cam), kann man auch einen Temp-Sensor am Stecker befestigen und sich per Software benachrichtigen lassen (ein Aquaero wäre ideal - da er völlig autark arbeiten kann)
Ist besser, als Nichts und der Stecker wird durchgehend "überwacht"...
Hat man einen Aquaero oder was Vergleichbares, kann man die Kiste worst case auch hart abschalten lassen, bevor es anfängt zu rauchen und zu stinken
Hast die Schaltung gesucht? :d
Geht mir genauso. 👍
Wenn man den Unterschied zw. 60 und 120Hz nicht merkt, stimmt was nicht :d
Ich persönlich merke zw. 120 und 144Hz keinen mehr
Ist für mich auch absolut unverständlich.
Die Art des Panels spielt hier eine Rolle, und die (Software)Technik, die zum Tragen kommt.
Beispiel: 120hz auf einem OLED fühlt sich wie 200 hz auf einem nicht OLED an. 120 Hz auf einem Oled mit VRR (GSync) fühlt sich wie 300 Hz auf einem "normalen" Panel an. Nur mal soviel dazu.
Selbst bei einem einfachen Panel - VA, LED - spürt man einen gewaltigen Unterschied zwischen 60 und 120 Hz.
Vielleicht, wenn das Augenlicht schon etwas nachgelassen hat und die Reaktionsfreudigkeit des Benutzers nicht mehr so sehr gegeben ist (Alter?), spürt man keinen großen Unterschied. Das ist dann aber eher anwendergeschuldet, als dass die Technik keinen Unterschied schaffen würde.
Wie ist das eigentlich bei den aktuellen Treibern, bei mir steht in der NV -Sys-Steuerung nur Normal oder Höchstleistung zur Auswahl, gab es da nicht auch mal optimale Leistung? Wenn ja, seit wann ist das weg oder liegt das an der 4090?
Die Leute würde ich gerne mal persönlich kennenlernen, die eine Diff. von 3,37ms spüren :d
Die High-Speed-Zocker kaufen insgesamt HW mit möglichst geringem Lag, da der ganze Kram sich sonst schnell, ungünstig aufsummiert in 20 und mehr ms
Vielleicht hast du die Möglichkeit die beide hinzustellen. Kann mir gut vorstellen, dass du dann den LG nehmen wirst ;)
Lieber jetzt noch einen abgreifen. Ab nächstes Jahr soll es keine OLEDs mehr in DE geben :cry:
Ähnliche Themen
Antworten
6K
Aufrufe
350K
