[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Soweit ich gelesen habe soll der Kühler der KFA nicht so dolle sein und die Lüfter wohl recht laut aber ich werde mir selber davon erst ein Bild machen.
Es ging nur um das Feedback da die Frage aufkam ob Neuware oder ausgenudelte Retoure.
Also ich hab mir grad diverse Tests zur Kfa2 durchgelesen und da wird überall die gute Kühlleistung und die Leise der Karte gelobt und die Karte bekommt überall awards, also lass dich da nicht negativ beeinflussen, wer weiß wie schlecht die Cases der User sind die die Karte negativ bewerten^^
Auch diese Zeit haben wir zum Abwarten.
Weiß nicht ob das so klug gewählt ist von AMD… bis dahin ist auch die 4080er draußen und Treiber sind dann auch weiter optimiert etc.
Und wie du ja hier siehst sind viele extrem ungeduldig, noch mal 5-7 Wochen warten (ab heute gezählt und wer weiß wann die genau im Dezember erst erscheinen) ist schon ne Hausnummer wenn der „Gegner“ bereits vorgelegt hat 😏
Im Schnitt packen die Karten wohl
3GHZ + 1000-1500 Mhz Vram .
Perlen wären die Karten die da deutlich darüber wären . 3,1-3,3GHZ + über 1500 MHZ Vram .
Was ist denn per Definition eine "Perle"
Vielleicht liege ich auch falsch und die Leute posten einfach nicht , weil die Karte keine 3GHZ timespy Extreme oder Port royal schafft und der Vram nicht einmal + 1000 macht . Finde einfach interessant mal zu erfahren wie die Karten so liegen .
Es könnte auch sein das es einfach keine "Perlen" gibt weil alle Karten round about das gleiche machen. Mal mehr und mal weniger.
Wundert mich das so wenige Leute darüber teilen wie ihre Karte läuft . Was die OC packt .
Kommen meistens nur paar wenige mit einer Perle um die Ecke .
Ich warte damit, bis die Karte unter Wasser ist. Dann werde ich versuchen, mit so wenig Spannung/Verbrauch wie möglich die 3GHz als 24/7-Setting zu erreichen.
Hier jetzt länger mit dem Luftkühler zu hantieren hab ich keine große Lust zu, da ich unter Wasser sowieso (leicht) andere Resultate haben werde.
Es könnte auch einfach sein, dass die Leute wegen der Brandbeschleunigernummer erstmal keinen Bock darauf haben, unendlich Watt und dadurch Hitze da rein zu pumpen, um irgendwelche Benchmark Contests zu gewinnen, sondern vorsichtiger unterwegs sind^^
gibt Karten die machen bei 2.900 Core dicht und welche die laufen bis fast 3200. Da sind schon dicke Unterwchiede
Selbst im UV Thread ist absolut gähnende Leere angesagt, außer dem Startpost gibts da gar nichts!
Das war fast klar, das Thema UV ist nicht so interessant bei den Karten. Viele machen einfach Blind was vorgelebt wird und setzen das PT kleiner.
Es könnte auch einfach sein, dass die Leute wegen der Brandbeschleunigernummer erstmal keinen Bock darauf haben, unendlich Watt und dadurch Hitze da rein zu pumpen, um irgendwelche Benchmark Contets zu gewinnen, sondern vorsichtiger unterwegs sind^^
Habe mich schon gefragt wo du bleibst und diese Antwort schreibst. Bist du denn inzwischen bei Reddit weg oder immer noch auf Abo ?
Hast du denn mal eine seriöse seite?
Woher wissen denn alle, dass der 3d so schnell ist?
Je nach Spiel und Auflösung spielt der 5800X3D ganz vorne mit. Wer bereits AM4 hat und den Rechner nur zum Spielen verwendet, kann damit ggf. Ryzen 7000 auch überspringen
Joa, zumindest mal ein Spiel und in Full HD. Man nimmt halt immer die Benchmarks die passen^^
in jeder auflösung
Gab diese Nacht wieder einige Fälle^^
Einen fand ich besonders beunruhigend, weil dort ein User einen Pre-Built PC gekauft - diesen nie angemacht (laut eigener Aussage) - und dort das Kabel überprüft hat. Und siehe da... Hitzeschaden. Das heißt, dieser ist beim Testen von dem Zusammenbauer entstanden. Der "defekte" Adapter wurde also an den Kunden verkauft, verschifft und hätte auf kurze bis mittelfristige Sicht katastrohpale Schäden angerichtet.
Da werden potentielle Brandherde an Menschen verkauft, die sowas nie nachkontrollieren würden...
Leute, die ihre Grakas selbst einbauen und ggf. Fehler machen können, das ist die eine Sache... aber wenn die Teile so empfindlich sind, dass professionelle Pre-Builts auch Risiko laufen, abzufackeln... oh my.
Der 5800x3d ist ein Einhorn. Manchmal ganz vorn dabei wenn der L3 Cache zieht. Mal ganz hinten dabei wenn der L3 Cache nicht zieht und dafür der niedrige Takt.
Da hilft nur: Anforderungen definieren, schauen ob der 5800x3d diese Anforderung erfüllt, oder ob man besser eine andere CPU nimmt.
Kann man auch auf Grafikkarten und Monitore anwenden.
Da draußen gibts Leute die sowas testen. Die ihre Testszenarien veröffentlichen. Da kann man sowas nachlesen. Schocker!
...immer das gleiche.
Bisher hieß es laut Testern würde es reichen das Power Limit zu beschränken . Vielleicht fehlt dahingehend eher die Motivation da noch zu optimieren . Persönlich habe ich getestet was nach oben geht . Sonst im Alltag läuft die Karte @ Stock bei mir .
Mal ganz abgesehen davon, dass Kabel sich bekanntermaßen verschieben/leicht lösen beim Transport von Pre-Builts (in diesem Fall natürlich irrelevant, weil der Schaden in einem "an" Zustand entstanden sein muss).
Das heißt, weil die Adapter anscheinend so empfindlich sind, dass wenige millimeter Spiel zu Problemen führen werden, müsste jeder Pre-Built PC mit diesem neuen Kabel nach Lieferung erstmal "profesionell" nachgezogen/kontrolliert werden (wenige Pre-Built Käufer würden das tun, und noch weniger würden so wenige millimeter Spiel überhaupt bemerken). Ansonsten herrscht Brandgefahr...
Diese ganze Geschichte nimmt immer üblere Ausmaße an, wenn man darüber länger nachdenkt...
Produkte für den Heimanwendermarkt müssen idiotensicher sein. Das hier ist aber ein hochempfindliches Kabelchen, dass bei leichtesten Anwenderfehlern zu BRANDProblemen führt... absolut bescheuert von NVIDIA, sowas zu veröffentlichen. Wobei hier auch noch der Verdacht im Raum steht, dass die Adapter auch bei korrekter Anwendung wegen Herstellungsfehlern Probleme machen können. In letzterem Fall hat der Endverbraucher natürlich überhaupt keine Chance.
Seit ca. 1 Jahr bin ich eh nur mit dem FS unterwegs, daher vom 5950x auf den 5800X3D gewechielt. Zum Arbeiten (Videoschnitt) hab ich eh den Mac, der PC ist nur zum Spielen (FS). :-)
Meine TUF läuft 24/7 momentan mit
+220 MHz core
+1500 MHz Vram
bei PT 80%.
Das macht in games
1,05v 2920 MHz
PT 350 Watt
Das ist auch wirklich stable, time spy etc geht auch mit +250 core +1600 Vram durch, aber crash irgendwann.
Max gehen 3040 Mhz wenn ich den Vcore auf +100 stelle.
Die Gainward Phantom hatte augenscheinlich den besseren Chip, weil mit ihr auch bei 1,05v 2970 gingen. Doch in deahtloop gab es damit schnell Artefakte, welche ich bei der TUF nie provozieren konnte. Da gab es dann entweder crash oder stable. Das zeigt scheinbar, dass die bessere Spannungsversorgung der TUF dem Chip zugute kommt. Auch der Vram der Phantom ging auf +1100 MHz. Danach gab es Artefakte. In Timespy kam ich aber auf die selbe Punktzahl mit den Karten. Nur ist die TUF die eindeutig stabilere Karte.
Gestern konnte ich noch etwas interessantes beobachten. Mein bequiet DPP10 750W läuft bisher einwandfrei mit der 4090+5900x. Auch volle Pulle OC ging bisher ohne Auffälligkeiten. Doch als ich Star citizen testen wollte, ist das Netzteil in die Knie gegangen und das reproduzierbar. Egal auch wie ich das PT Limit eingestellt habe. Von 60% bis oben gab es immer nach ein paar Sekunden die Schutzschaltung. Einzig allein UV bei 0,875v und 2540 MHZ liefen, wo normalerweise die Karte bei voller Auslastung ca 260 Watt zieht, sind es in Star citizen 340 Watt. Scheinbar wird die Karte hier um ein vielfaches mehr ausgelastet und sobald spannungsspitzen auftreten, macht mein Netzteil die Grätsche. Puhh länger text... Jetzt warte ich auf ATX 3.0 Netzteile.
+220 MHz core
+1500 MHz Vram
bei PT 80%.
Das macht in games
1,05v 2920 MHz
PT 350 Watt
Nicht vergessen, dass auch Ryzen CPUs Spannungsspitzen haben. Ggf. solltest Du hier im BIOS mal mit PPT Limits u. verändertem TDC/EDC arbeiten, um zu schauen, ob Du so der GPU mehr Luft geben kannst.
Ich denke hier möchte aktuell niemand mehr zu viele positive Wörter finden… dann kommt nämlich oft nur ein „warte nur bis deine abraucht…“
Da ist ein Beitrag zur kfa
@4090 Besitzer mit NV Adapter, wie macht ihr das denn, einfach unbeschwert weiter zocken und davon ausgehen, dass nichts passiert oder habt ihr aufgehört, die Karte mit Last zu nutzen bzw das Nutzungsverhalten irgendwie eingeschränkt?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
