[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Versuche meine suprim liquid x zu übertakten, aber bei knapp 2970 MHz ist Schluss (1,1v und 600w/125% pt). Kann mir nicht vorstellen, dass sie keine 3ghz packt.
Hat noch jemand Ideen, woran es liegen kann? Gibt es irgendwo nen Vergleich, was andere hier so geschafft haben, bei welchen settings? (thread habe ich bereits durchsucht, das ist leider nicht so zielführend)
Igor hat 3075 bei 1,05 und 3150 bei 1,1 gepackt . Kannst bei igorslab seinen Test dazu lesen .
Auch, wenn das Jeder schon x-mal irgendwo gelesen hat...
76,3 Mrd. Transis auf einem so "kleinen" Die, ist absolut geisteskrank (y)
Fast 3x mal (2,7x) mehr, als bei der 3090...
In meiner Stadt gibt es sehr großes Computermuseum und eine recht neue Ausstellung über Mikroelektronik. Die Kuratorin Frau Dr. Hartmann sprach letztes Jahr noch über den großen Ampere Chip. Ich stimmt dir aber absolut zu, ein faszinierendes Thema mit unglaublichen Dimensionen.
Bevor ich das Strix-BIOS flashe, probiere ich es erstmal mit automatisierten AB-Profilen. Hast bisher immer super geklappt
Denk aber dran...Strix Bios Du hast eine aio Variante.
Geht darum das Du die Pumpe auf volle Drehzahl bekommst.
Wenn Du schon das 600 Watt BIOS drauf hast dann wirds mit dem Asus BIOS nicht besser.
Wie schaltet man denn in Afterburner die Spannungserhöhung in mV frei? Bei mir steht da nur eine Erhöhung in Prozent.
Ihr Abschluss klingt irgendwie lustig...
Nach dem Motto "esst mehr Transistoren, statt Reis" :fresse:
AiO?
Hab eine normale TUF Non-OC...
Der einzige Unterschied zur Strix OC ist, dass der Default- und der Boosttakt +90MHz höher ist
Viele OC Werte aus dem Netz werden teilweise auf Benchtables, unter Wasserkühlung und/oder mit LN2 produziert (wird nicht zugegeben). Mal abgesehen von Chiplotterie und Gehäuseunterschiede... (= Airflow) - nicht alle 4090 schaffen mit Garantie 3GHz.
Reviewers kriegen häufig Golden Samples von Herstellern, um ihre Produkte besonders gut zu vermarkten (= von Hand ausgewählte "super"/optimale Chips).
Nur Reviews von privat gekauften Produkten sollte man vertrauen in Bezug auf Leistungserbringung.
D.h. dass 99% der Reviews zu Release in die Tonne gehören, weil sie häufigst ein unrealistisches Bild erschaffen.
Wichtig ist auch, dass Reviewer diese Bestellungen nicht direkt bei Herstellern unter Klarnamen erbringen (sonst könnten trotzdem Golden Samples verschickt werden, bei gewiefter Marketingabteilung), sondern immer über Drittpersonen bestellt werden und/oder bei Dritthändlern wie MM bestellen.
Es gibt Reviewer, die machen das genau so - und deren Werten kann man vertrauen.
Preise purzeln bei EBK. Stellenweise Karten für um die 2K.
Selbstverständlich aufpassen vor potentiellen Scams.
Regel Nummer 1 bei EBK: Wenn die Preise zu gut erscheinen, sind sie es auch. PP Käuferschutz ist ebenfalls nichts Wert. Aber alles schon durchgekaut.
Die Reviewer bekommen aber golden samples. Daraus kann man nicht auf den Durchschnitt schliessen.
Passt schon. Meine FE braucht 1,1V für 2880MHz. Völlig normal also bei deiner Karte, da kannst du nicht mehr viel machen.
Auf meine ASUS TUF werde ich wohl 1-2 Wochen verzichten müssen.
Ich habe die Bestätigung das meine TUF am Alphacool Send it in and get one cooler for free Programm teilnimmt. Die geht also morgen in den Versand nach Braunschweig, wird dort vermessen und auf dem 3D Abdruck meiner Karte wird eine Wasserkühler-Line für alle ASUS 4090 TUF und Strix produziert.
Klar habe ich jetzt etwas Aufwand mit Verzicht der Grafikkarte, aber dafür die ungewöhnliche Chance einen wirklich perfekt passenden Kühler für meine ASUS Karte zu bekommen.
Bei Kameraobjektiven ist es wirklich so mit dem Golden Sample - ist auch bekannt und manche YouTuber weisen daraufhin, dass es sich um ein Presse-Sample handelt.
Aber bei Grafikkarten? Nee... die Karten werden nur halbherzig getestet. Vergleiche das mit dem Herrn, der seine angebliche Perle anbietet. Diese Karte wurde 10mins getestet und für 3 GHz stable erklärt - natürlich ohne Garantie auf's OC :)
Es ist in der Elektronikindustrie mehr als nur üblich, dass Golden Samples an Testunternehmen verschickt werden - das hört nicht bei Grafikkarten auf. Im Netz gibt es tausende Berichte über das Thema... mal ganz abgesehen davon, dass jede drittklassige Marketingagentur Golden Sampling empfiehlt. (= LMGTFY = golden samples)
Insbesondere bei GPUs, bei denen es fast ausschließlich um Balkenlängen bei Reviewern geht (=Verkaufszahlen) haben die Hersteller mehr als nur bedingtes Interesse daran, dass die Karten herausragend gut funktionieren.
Das ist auch kein Geheimnis in der Branche, da darüber - über die Jahre - häufig gesprochen wurde, in diversen Videos, Interviews... Intel hat das sogar selbst zugegeben.
Keine Ahnung also, warum dieser "Quasi-Fakt" hier im Forum in Zweifel gezogen wird. Hersteller verlieren nichts, wenn sie ein paar hundert Karten händisch nachkontrollieren, außer ein wenig Arbeitskraft/-zeit - auf der Habenseite stehen aber Milliarden an Gewinnen durch potentieller Kundenfang durch fette Balken.
Hersteller wären ziemlich blöde, wenn sie kein Golden Sampling betreiben würden. Ich verstehe jeden Hersteller, der das macht - als Kunde sehe ich das aber bedingt als Verarsche, dementsprechend darf man sich hier nicht von guten Benchergebnissen blenden lassen. Es gibt genug Reviewer, die haben ihre privat gekauften Karten gegen ihre Golden Samples vom Hersteller verglichen - teilweise mit frappierenden Differenzen (bis zu 13% Unterschiede in Ergebnissen - bei selbem Wattverbrauch!). Einfach mal nachschlagen und sich selbst bilden über diese Thematik...
Auf meine ASUS TUF werde wohl 1-2 Wochen verzichten müssen.
Congrats Youngtimer :)
Neptun wäre stolz auf Dich!
Das Programm hört sich toll an, auch wenn ich es etwas albern finde, dass am Ende der originale Kühler wieder draufgeschraubt wird, der "neue" Wasserkühler separat verschickt und der Kunde/Tester/Programmteilnehmer/whatever dann am Ende die Selbstmontage durchführen soll.
Wenn die schon die Karte demontiert und den neuen Kühler für die Auslieferung fertig haben, könnten die einem auch direkt das fertige Produkt zuschicken..
Wie sieht’s denn aus, wenn die Karte bei denen kaputt gehen würde . Ist man da denn abgesichert bei denen ?
Und wie lange willst Du auf die Karte warten? Das ist so schon völlig ok.
Wenn viele 4090 Karten nicht 3Ghz schaffen . Dann frage ich doch mal so in die runde was so geht bei Normalen OC ?
Liegen sie so bei + 100 bis +200 Mhz oder eher mehr was dann vieleicht 2800 bis 2900 Mhz entspricht .
Dachte jetzt an einen Durchschnit was meistens geht ?
Ich hab genau 1 bestellt, erhalten und fertig.
Alphacool kriegt es nicht selbst hin eine Karte zu organisieren? Gut für dich aber schon strange😆
Ähnliche Themen
Antworten
6K
Aufrufe
389K
