[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also in meinem Define 7 habe ich massig Platz, simd ja von den Proportionen gleich glaub ich.
Aber nur ohne HDD Gerüst, oder? Also nur mit dem "Open Internal Layout". Was macht man dann mit seiner einen übriggebliebenen HD? :-/
EDIT: Geht anscheinend auch im Standard Layout, aber kA wie er sie da reinbekommen hat! Mit meiner 3080 ist es schon relativ eng, zumindest von der Vorderseite kommend. Vermutlich von der Hinterseite dann.
https://www.hardwareluxx.de/community/attachments/20221014_174120-jpg.802451/
Bei mir wird es langsam echt wild :stupid:
Es fing eines Tages alles mit der RTX 4090 TUF an. 1949€ konnte ich nicht widerstehen. Fuck. Naja was soll's ist einfach zu gut. Hm scheiße der dumme nividia Adapter wird im O11D XL zu stark geknickt -> Lian Li 4.0 Riser Card + PCI-Slot-Blende bevor die Bude abfackelt :fire:-> hm CPU Limit in CP 2077 -> Mist. :poop: Okay neuer Unterbau, Wie ersetzt man ein Z490 Formula standesgemäß? Bingo Z690 Formula :shot:, nice endlich ein PCI4.0 Board, muss man ja irgendwie ausnutzen. 2TB Seagate Firecuda 530. Nice. :love:Aber DDR5 nun Pflicht, ah Speicherpreise sind stark gefallen, da kann man ja auch gleich zu 32GB 6000 mit CL30 greifen :cool: Neue intel Gen geht ja ab. Okay 13700kf soll es sein, bisschen was einsparen, muss ja nicht gleich Flagship sein.. Hm aber neuer Sockel, AIO passt nicht. Mountig Kit für die AIO, was sind schon 13€. :rolleyes: Ach da war noch was... Contact Frame ist ja auch Pflicht. OKAY. Das wars aber jetzt. Nope... der nvidia Adapter ist immer noch Müll... 12VHPWR Cable direkt zur PSU von bequiet muss sein, bestellt ... wird einfach nicht geliefert. :wut: Puuuuuh, was macht cablemod? Nice endlich be quiet Kabel im Angebot. Haben muss. Der Preis gesalzen.
Okay, das wars jetzt oder oder? Nope AW3423DW bei Dell im Angebot für 1099€ ......... sheesh
Wenn ich mal denke das 3 mm gefehlt haben in meinem Phanteks Enthoo Primo für die TUF unter zu kriegen ^^ . Es hat mich aber dann dazu bewegt mir ein neues Case zu kaufen , weil das Primo langsam etwas zu oldschool war und ich mich all die Zeit davon gedrückt habe , weil ich zu faul war alles umzubauen . Am Ende ist man dann froh , wenn das alles dann mal so ist wie man es möchte .
- Amstrad CPC 464: CRTC 0 : HD6845 (Hitachi); CRTC 1 : UM6845R (UMC); CRTC 2 : UM6845S (UMC) oder MC6845 (Motorola); CRTC 3 : CPC+ ASIC; CRTC 4 : ASIC der kostenreduzierten klassischen CPCs
- Cirrus Logic 1MB
- Hercules Terminator 3D mit einer S3-GPU, 4MB
- Voodoo 1 3dfx 4MB
- Voodoo 2 3dfx 12MB
- 2te Voodoo 2 3dfx 12MB für SLI-Betrieb
- ASUS V7100 GeFoce 2 MX
- ATI 9500@Pro
- GeForce 7800GTX
- GeForce 8800GTX
- 2te GeForce 8800GTX wegen SLI
- GeForce 280GTX Dual SLI
- GeForce 580GTX + 280GTX@Physx
- EVGA GeForce GTX 980 Ti FTW ACX 2.0+, 6GB GDDR5, DVI, HDMI, 3x DisplayPort, @1500MHz
- Palit GamingPro OC RTX 2080 Ti, @2100MHz
- RTX 4090 FE
(y)
ziemlich begeistert vom EKWB FE block. wahnsinnstemps. kein grund die stock pads gegen 12 w/mk pads zu tauschen wenn max memory temp 36c ist :d
11c delta auf stock, 17c delta auf OC, max PT, max voltage, 250+gpu, 1400+ memory
10 minuten bright infinity benchmark
5120x1440p
rtx: very high
dlss: quality
stock:
OC:
Da wirst DU keine Lösung bekommen. Da ist dann irgendeine Inkompatibilität zwischen MB Bios und Graka Bios.
Evtl. gibts noch einstellungen die du noch nicht probiert hast.
Fullsreenbootlogo usw aktivieren.
Finde aber auch, dass es kein Problem ist was Nvidia lösen muss. Eher Dein MB Hersteller. Was er aber auch nicht tun wird.
Da hilft Dir nur eine andere 4090 ztu testen um zu wissen woran es liegt.
Ich hatte von seinem "Problem" mit dem fehlenden BIOS-Screen gelesen und hatte dabei an meinen ARC-1261ML gedacht, der genau das Gleiche hatte
Daraufhin hatte ich ihm das mit CSM geschrieben. Seine FE ist zu 100% ok. Ich würde die FE behalten. Denn andere FEs werden genau das gleiche "Problem" aufzeigen, welches nie eins gewesen ist :d
Eco-Mode ist wieder was anderes. Eco-Mode ist ein Power-Limiter.
Und dieser ist tödlich für einen 5950X. Eco ist bei meinem Board 86W.
Der 5Ghz@1,5V Boost braucht aber nur ~80W. Heißt der boostet auch so hoch trotz Eco-Mode, aber wenn man viele Kerne nutzen will, braucht der 5950X Strom.
Bei mir kann der normal 142W ziehen und wird auch bei Vollast nur 65°C warm.
NUR der Single-Core Boost ist das Problem, mit biszu 95°C in Prime 95.
Quasi dasselbe "Problem" das Ryzen 7000 auch hat, nur ist es da noch schlimmer. Da das Spannungslimit (1,5V beim 5950X) bei Zen4 nicht erreicht wird, sondern das Templimit.
Ich will halt aus Prinzip keine ZU heißen Komponenten haben. >80°C wäre mir zu hoch. Deswegen tat mir die 3090 auch immer weh, weil dessen VRAM über 95°C war... :d
Für die Enthusiasten:
Setz doch ein Temp-Limit...
Hat bei mir auf´s Grad genau funktioniert und den 5950X im Zaum gehalten
Das macht ja mal Hoffnung ...
Werde auch mal bei Asus ein Ticket aufmachen ...
Allerdings könnte ich schwören, das es ein paar Mal funktioniert hat und irgendwann plötzlich nicht mehr.
Evtl. hattest du CSM ON mit der neuen FE eine Weile laufen und hast UEFI auf default gestellt?
Dann ist CSM nämlich standardmäßig OFF (bei mir zumindest). Das kann Manche nachdenklich machen, wenn auf einmal Dinge anders laufen (zb anderes Logo, langsames booten etc) ;)
Wie beschrieben ist das Problem ohne BIOS Update plötzlich aufgetaucht bei unterschiedlichen Motherboards Z690 und Z790 Unterschiedlichster Marken.
Wie beschrieben hat es ja anfangs funktioniert.
Den Ratschlag mit Fullscreenlogo und CSM habe ich ja bereits getestet auch wenn es plötzlich nichtmehr funktioniert hat.
Eine Inkompatibilität des BIOS habe ich selbst ergoogled leider steht da aber genau so oft das die GraKa defekt war.
Da wirst DU leider keine Ahnung haben und nicht recht behalten das es dafür keine Lösung gibt.
bitte erst alle Fakten kennen bevor man urteilt 😂
Der hat schon mehr als genug 4090 getest. Keine war für ihn zufrieden stellend sollte es jetzt mal lassen
Das hättest du dir sparen können es war die einzigste FE … einfach nur Gelaber (ohne drüber mal nachzudenken) weil die Enttäuschung selbst keine bekommen zu haben, oder erst spät, zu tief sitzt. Tut mir leid langsam nervt es nur noch!
„Nicht zufriedenstellend“ wenn ich das schon lese … keiner von euch hatte die Karten vor sich aber alle meinen drüber urteilen zu können absolut Top! Sind genau die Leute die später die Karte irgend einem auf EKA verkaufen und meinen soll er sich doch um das Problem kümmern und damit rumärgern!
Ich habe damals DDR5 RAM an alle möglichen Leute hier verkauft als keiner welchen angeboten hat oder nur zu Scalperpreisen. Aber diese Karten waren so schlecht das ich einen weiterverkauf nicht mit meinem Gewissen hätte vereinbaren können, ist euch das Bewusst?!
Das ich versucht habe eine Strix zu finden die funktioniert wie eine FE oder eine Gigabyte die ich behalten habe und werde das ist keinem in den Sinn gekommen.
Ich habe nicht 8 bestellt um zu binnen wie andere sondern eine nach der anderen!!!!
5120x1440p
rtx: very high
dlss: quality
stock:
OC:
Anhang anzeigen 812283Anhang anzeigen 812284Anhang anzeigen 812285Anhang anzeigen 812286
Lecker !
Hast du The Division 2 ? da würden mich mal die Temps nach einer Stunde mit OC interessieren da kommt man wenn man die 3GHZ angeht deutlich über 500W.
Bei meinem Z690 Dark hatte ich auch kein Boot Logo und kam auch nicht ins BIOS - erst nachdem Windows vollumfänglich geladen wurde, war das Bild da.
EVGA hat dafür ein Beta Bios rausgebracht und nun passt es wieder.
Ticket bei Asus läuft sollte es daran liegen leider habe ich es auch mit dem neusten BIOS auf dem Dark und dem ASRock Taichi X670E
5120x1440p
rtx: very high
dlss: quality
stock:
OC:
wieso hast Du nur 408W bei max Powertarget von 133 erreicht ich mit der FE 486W Leistung !
da stimmt was nicht, hast Du nur 100 als Powertarget eingestellt, anders kann ich mir das nicht ganz erklären.
250l/h Durchfluss schaffe mein Pumpe nicht hab aber mit 190l/h den gleichen Benchmark damit mal durchgeführt.
21c delta bei OC, max PT, max voltage, 150+gpu, 1000+ memory
5120x1440p
rtx: very high
dlss: quality
die active Backplate scheint also bessere Temps zu bringen.
vermutlich tragen die 60l/h mehr Durchfluss auch dazu bei.
Yes - die 4090 ist...
:d
Top @dante`afk
5120x1440p
rtx: very high
dlss: quality
Am Durchfluss liegt es nur wenn die GraKa direkt nach der CPU gekühlt wird ansonsten verteilt sich die Wärme im Kreislauf was bei ~120l/h kaum noch Unterschiede macht ab 200-250l/h ist es quasi nichtmehr vorhanden. Mir war von Anfang an klar das die ABP was bringt, warum auch nicht?! Die Hitze verteilt sich immer in der Platine und bei dem Hotspot … na ja kannst du sicher nachrüsten.
:ROFLMAO:
Nicht falsch verstehen jetzt kannst du ja überall schreiben ich war der ERSTE ohne ABP …
:ROFLMAO:
5120x1440p
rtx: very high
dlss: quality
Bei dir sieht das ordentlich aus. Vorallem die Vram Temps sind sehr nice (y)
Jap, kanns kaum erwarten aber vor allem kann ich es kaum erwarten mal einen Winkeladapter am liebsten mit 180 Grad zu kaufen!!! 😂
180 Grad Bogenmaß oder Temperatur? :haha:
Das würde mich auch interessieren (nicht, daß Jura nicht auch interessant wäre 🙄)!
Das war bei meiner Zotac und jetzt auch bei der FE so. Ebenfalls nur 3x8 Pins dran. Kann das sein, dass wir die Sense-Leitung "versehentlich" nicht angeschlossen haben? Soweit ich das interpretiere für nur eines der vier Kabel die Sense-Leitung, oder habe ich das falsch verstanden?
Ich sag nur "Zange" und/oder Leistungsmesser (Steckdose) ;)
Also CSM ist OFF by Default genau wie du gesagt hast.
Zumindest beim Z690 Apex sowie Extreme Z690 und Z790 und den von mir verwendeten BIOS Versionen. Ich habe CSM niemals auf ON gestellt warum auch. Wie beschrieben ohne Veränderung Plötzlich. Ich hatte zunächst einen Bildfehler beim AI OC Splash von Asus festgestellt. Nach dem ich Ai OC aus und wieder ein geschaltet habe wurde nun auf der FE nichts mehr angezeigt.
Jetzt zeigt die FE auf keinem Board mehr einen BIOS Splash … wenn’s am Board liegt hätten andere User das „Problem“ auch mit der FE … @UdoG hatte es ja auch beim Dark…daher habe ich es auf dem Dark und auf dem Taichi getestet und alle haben das „Problem“ leider auch mit dem neusten BIOS.
Das ist falsch :) um genau zu sein hatte ich bisher 8 Karten.
3x Strix
2x KFA2
1x Suprim X
1x Suprim Luquid
Und morgen/Montag kommt die Frostbite
Das sind 7 zuviel... :d
Ich bin für Regeln, wie bei der Formel 1 - d.h. beim HWluxx-Benchmarking darfst du nicht mehr mitmachen :fresse:
Stark! Meine erste Karte war eine GeForce 2 MX440. Meine erste selbst erkaufte Karte durch Zeitungsausteilen, war eine GeForce 3 TI 500. Nur um Operation Flashpoint zu zocken :)
Meine Erste war eine ELSA Erazor 2 + Voodoo 2 (3D-Beschleuniger-Karte), um NFS 2 zocken zu können :oops:
(CPU weiß ich grad nicht mehr, aber Arbeitsspeicher waren "gigantische" 64MB :fresse: )
Erste Grafikkarte müsste eine Cirrus Logic im Highscreen 486 DX 33 gewesen sein. Erster 3D Beschleuniger war eine Elsa mit S3 Virge. Weil die so schlecht war gab's dann eine Voodoo2. Dann Riva TNT2, GeForce 3, ATI 9700 pro, 6800 GT, 3870er ATI als "SLI", x1950 pro, GTX 280, GTX 580, 7970, 290x, Vega 64 LC, 3080, 4090.
Reihenfolge ist bestimmt durcheinander und evtl hab ich irgendwas vergessen. Zuviel Geld für zuviel Blödsinn
Was ein Luxus Nvidia Riva TNT plus Voodoo 2
Müsste schon Pentium 2 oder 3 gewesen sein. Da war der beste RAM noch von Infineon ☺️
Ja die Elsa mit S3 Virge war die Victory glaub ich
;-) die 3D Beschleunigung funktionierte fast nur in wenigen Benchmarks
Dazu hatte ich dann zuerst ne ORCHID RIGHTEOUS 3dfx Voodoo 4MB oh man
Ähm hier mal ne Info zum VBios Update für TUF/Strix.
Hier scheint es bei manchen auf diverse Plattformen probleme mit dem Tool gegeben zu haben .
Daher haben die das Tool von der Website entfernt um es zu überprüfen.
Also denke ich mit dem VBios ist an für sich kein Problem vorhanden und wenn das Tool angepasst wurde wird es auch wieder hochgeladen.
Das Vbios update ist anscheinend dafür gedacht da es auf manchen Asus z690 Boards zu reboots kam im Idle oder surfen .
Hatte ich in einem anderen Thread rausgelesen.
Hatte selber sowohl mit dem release als auch mit dem V1 Bios keine Probleme.
gruß
Hast Du das 2.03 Beta für die 4090 FE installiert? Es gibt zwei verschiedene Versionen vom 2.03 - falls Du es nicht gesehen hast.
bist glaub ich nicht der einzigste :d aber es ist geil das fette teil abrufbereit zu haben :hmm:
Erster Platz Galax RTX 4090 HOF
Name Galax RTX 4090 HOF
Beschreibung Quick test of the upcoming RTX 4090 Hall of Fame by Galax.
Benutzer OGS
Core-Takt 3.570 MHz
Durchschnittliche Taktfrequenz 3.570 MHz
Speichertakt 1.469 MHz
Durchschnittliche Speichertaktfrequenz 1.469 MHz
Durchschnittliche Temperatur -35 C
Test gleich nochmal und sag Bescheid
Ähnliche Themen
