[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab ich mit der 4090 und dem 13900k tatsächlich auch gerade ne neue Runde angefangen, weil die Schatten so dermaßen auf die CPU gehen, dass die Graka alleine das gar nicht richtig rausgezogen hat auf meinem alten Ryzen. Jetzt ist es perfekt.
Kommt wie üblich darauf an, wie man "maxed out" definiert, und wie schnell der Prozessor ist, der die Schatten berechnet. Bringt ja nix wenn Du wegen der "maxed out" Schatten ständig 20 Min-FPS hast.
Man findet aber bestimmt einen guten Kompromiss.
Wie hoch ist die Auslastung der 4090 bei dir mit „Kingdom Come“? Mit dem 5950X ist die nicht sehr hoch
Die weiße 4090 gibt’s noch nicht 😕
Wie du ran kommst, ist dein Problem :d
Woran könnte es wohl liegen, dass du von dem neuen Adapter mehr mitbekommst?
Könnte es vielleicht sein, dass sich zuvor schon alle über den Adapter beschwert haben, er jetzt ein gefundes fressen ist und jeder einzelne Fall von Usern wie Stagefire in mehreren Foren protokolliert werden?
Was eine Filterblase ist, weißt du aber schon?
Ein Klickbait folgt dem anderen und alle steigen auf den Zug auf.
Ein Problem ist da keine Frage, aber es definitiv nicht so groß wie alle behaupten. Bisher keine Probleme mit einer Strix oder FE und auch andere Hersteller.
"Besonders" betroffen scheinen die Asus TUF, MSI Gaming X Trio, Gigabyte Gaming OC und MSI Suprim X/Liquid.
Die Zotac scheinen z.b. sicher.
Das is zu Off Topic :d ... aber zumindest noch unter 60 aber über 39 :whistle:
Aber damit dieser Post nich zu Off Topic is hab ich noch was schönes für euch ... den Power Adapter Fall Nr. 29
Ist aber kein schmelzen, das wurde zu den unbekannten gepackt. Schmelzen passiert von innen nach außen und nicht umgekehrt.
Da hat sich meine 3090 die zähne ausgebissen. Wie läuft es mit der 4090? Geht maxed out 4k?
Abgesehen von der moderaten GPU-Auslastung ganz ok (fps stehen oben links). Mein 5950X kann nicht schnell genug Daten nachschieben in bestimmten Szenen :cry:
Zockt jmd „Kingdom Come“ mit 4090 + 5800X3D?
Der Mark is noch lange nich gesättigt du siehst doch was da los is man hat immer nur so 1 min zeit um zu bestellen danach is dann wieder alles leer ... Heute gabs doch wieder einige Dropps und alles is wieder weg aber die 2 Karten bei Mindfactory sind immernoch drinn .. das dürften nun schon gut 20 Std sein die die beiden karten bei Mindfactory verfügbar sind .. das is einnfach nur ein Shop Fehler .. die Karten sind eigentlich schon weg aber das System checks noch nich und führt die noch als verfügbar
sind bei beiden immernoch 5 lieferbar wie gestern Abend auch schon ... das is einnfach nur ein Shop fehler und das hat weder mit den Preisen was zu tun die Minndfactory dafür will
noch damit das der Markt deiner Meinung nach nun gesättigt währe und kaum noch leute ne 4090 wollen :
Denke mal es hat sich rumgesprochen, dass man diese beiden Modelle sofern möglich meiden sollte, wenn man schon 2K investiert. Der Preis mit 300-400€ über UVP tut sein übriges
@Stagefire
Wieso möchtest du eigentlich ne 4090 Strix haben?
Du bist doch eh nur in Foren unterwegs, sei es OLED oder der Nvidia Stecker, kommst du da überhaupt noch zum zocken?
:d
ehrlicherweise hab ich schon seit 4 Wochen nich mehr gezockt .. weil halt Arbeit ( wird zur Weihnachtszeit bei uns mehr und stressiger ) und dann nach der Artbeit nach der 4090 Strix verfügbarkeit schauen da muss man ja aufpassen wie ein Fuchs aber man verpasst den dropp ja eh weil man zu langsam is oder grad aufn Klo is oder auf der Arbeit oder inn der Küche und wenn man sie erwischt ( was bei der Strix ja grad eh nich vorkommt weil so gut wie nie ein dropp kommt seit 2 Wochen ) nur max 1 min zeit hat oder man schaut in dem mom grad n Youtube Video... ich hoffe ja mal das es nun bald auch mal so ein 20 Std auf Lager Dropp der 4090 Strix gibt wie es grad mit den Gainward und Palit Karten bei Mindfactory der Fall is .. wird zeit dass das auch mal bei der Strix passiert das die auch mal schöne 20 std auf Lager is.
Und nunja schaue mom viele Serien und Filme .. .. aber Guardians of the Galaxy , ELEX 2 , Cyberpunk und Spiderman warten grad auf mich
aber die wollen mit der 4090 gezockt werden da meine 3080 Strix ( 10 GB ) da so langsam an die grenzen kommt und ich ungern zuviel runterstellen möchte in den Settings bzw bei DLSS.
Und nunja die 4080 liefert mir zuwenig drauf auf meine 3080 daher dann die 4090 und die bleibt dann für 4 Jahre in meiner Kiste... normalerweise bin ich aber der 80 TI oder 80 Käufer
aber 2022 hat Nvidia das schon geschickt gemacht
Wenn ich meine 4090 Strix hab und dann entweder Dezember oder Januar entlich mein Urlaub nehmen kann werd ich aber hier in diesem Thread eher seltener bzw dann garnich mehr zu finden sein weil dann
einige Games auf mich warten .. und im OLED Thread wenn dann in der Zeit nur wenns neue News zu QD-OLED gibt oder einem Hilfesuchenden dort wiedermal nich geholfen wird.
Hat jemand eine Idee, warum der Speedway Benchmark immer abbricht? :(
Was für eine Karte ist das?
Nich das dort die Boosttaktraten nicht stabil sind ...
Vielleicht die Boostrate 15-30 MHz niedriger stellen...oder irgendwas störendes läuft im Hintergrund mit...gehen andere Benches...
Cyberpunk läuft, TimeSpy… TimeSpy Extreme hat er aber auch schon abgebrochen…
3DMark braucht stellenweise 1-2 mins um mein System zu scannen, dann laggt in der Zeit alles.
hatte bei meiner 4090 strix stock das problem das mehrer spiele und auch timespy abgstürtzt sind. Konnte aber nacht 30stunden testzeit nicht reproduzieren woran es lag hab die grafikarte in zwei pc getestet. Karte ging jetzt erst mal zurück aber noch keine rückmeldung.Schätze das was mit last und takt zu tun hat.
Was soll mir jetzt die Mail von Reichelt sagen?
Habe dort das Bequiet Kabel bestellt.
Kündigen die schon an, dass nicht ausreichend Ware für die Bestellungen da ist???
"Sehr geehrter Kunde,
aus o.a. Auftrag stehen noch folgende Positionen zur Lieferung aus:
InetNr.: xxxxx
Ihre Bestell-Nr.: xxxxxxxxxxxxx
Auftrag vom : 07.11.2022
Artikel Menge Offen vorausstl. Termin
BQT BC072 1 1 09.11.2022
Die noch offenen Positionen werden unter vorbehaltlicher Selbstbelieferung zum angegebenen Termin zum Versand gebracht.
Für eine eventuelle Ersatzlieferung bei nicht mehr lieferbaren Artikeln setzen Sie sich bitte mit unserer Bestellhotline in Verbindung.
Damit ist gemeint das die Ware sofern die rechtzeitig bei Reichelt ankommt zum geplanten Termin versendet wird.
Der Lieferant der Reichelt beliefert hat nur einen Liefertermin ohne Garantie angegeben.
Yo, nach dem Energiesparmodus des Monitors kommt kein Bild mehr. Das Bild bleibt einfach schwarz.
PC ist nicht eingefroren.
Monitor von Graka abstecken und wieder anstecken bringt nichts.
Monitor vom Stromnetz abstecken und wieder anstecken bringt nichts.
STRG+WIN+Shift+B für nen Treiberreset bringt nichts.
Muss dann immer umständlich über den zweiten Monitor den PC noi starten, dann läuft alles wie vorher.
Kann natürlich am Monitor liegen, aber vllt auch am Treiber. Ist dafür eine Lösung bekannt?
Ähnliche Themen
Antworten
6K
Aufrufe
395K
