[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du musst es auch in der relation der Größe sehen. Die FE ist knapp 15% kleiner. Aber die Zotac kühlt nur 2% besser.
Deine Aussage war "krasse Kühlung". Und das ist halt so nicht richtig, wenn du das nicht genauer beschreibst was du eigentlich meinst. Eine FE kann man aus optischen Gründen kaufen, aber sicher nicht wegen der "krassen Kühlung" :)
Valider Punkt :)
Interessanter wäre bei der FE ob sie durch die hybride Bauart eine geringere case Innentemperatur hinbekommt
Wie hast du bezahlt? Siehst du eine Abbuchung bei PP, KK oder Amazon?
Bei Paypal steht nur dass die Zahlung erst erfolgt nachdem NBB den Auftrag bearbeitet hat
Wie bei mir zum Release. Deine Bestellung wurde nicht an das Warenwirtschaftssystem weitergereicht.
Du wirst nun also den Support von NBB anschreiben und die werden dir antworten dass es nicht geklappt hat mit deiner Bestellung. 😐
Dann kann ich mir das anschreiben wohl ersparen :-)
Hier im Test bei Hardwareluxx im Test schneidet die FE ja im Vergleich zu den Customs sowohl Temperatur als auch Geräuschmäßig sehr gut ab. Bei anderen Seiten ja eher schlechter. Evtl. andere TRest Setups, z.B. Gehäuse.
Aber hier hatten ja glaube ich auch schein einige die FE wie auch andere Karten, Wie sind denn eure Erfahrungen damit?
Sie kühlt ausreichend.. hab nen bequiet dark base 900. Viele Lüfter. Die FE bleibt stock immer unter 67 grad. Die BananenGamerock blieb bei leicht höherem Watt verbrauch etwas Kühler 65 grad. Aber ich finde die FE einfach schöner. :) Wie schon meine 3090FE zuvor, mag ich die einfach.
Also meine Paypal Zahlung hat irgendwie einen neuen Account angelegt (meine alten Bestellungen waren da nicht drin), in dem hab ich die Bestellung direkt gesehen, jetzt nach der automatischen Abmeldung, kann ich mich nur in den bestehenden Account einloggen und sehe den Status und die Bestellung nicht mehr :d
Wow, so viele neue Seiten in grad mal 2 Stunden. Ich rate einfach mal, es gab einen FE Drop und es werden wieder Bestellnummern vergleichen und gepokert wer eine bekommt und wer nicht ?
So war es bei mir beim letzten Drop. Da wurde auch ein neuer Acount angelegt. In dem war auch meine Bestelluzng die storniert wurde.
In meinen alten acount kann ich mich dennoch einloggen.
Nur dieses mal wurde gar kein acount angelegt und die bestellung ist niergends.
Bei EK gibt es wieder frische Ware. Zwischen 2400-2800€ alles dabei:devilish:
Also meiner Meinung nach sind die Karten schon weg bevor sie zum verkauf für das fussvolk angezeigt werden. da werden einige nbb mitarbeiter richtig kohle machen.
Dafür mit Abstand optisch die schönste Karte 😉
Ich weiß Geschmäcker sind verschieden, aber viele andere Karten haben komische Farbakzente und unnötigstes RGB Gedöns.
Ich kann nur wiederholt sagen, dass im Vergleich zu meiner 3090 Strix mit P-Bios Mode die 4090 FE deutlich kühler, effizienter, laufruhiger, weniger Spulensurren, wertiger und schöner ist. Ich könnte einfach nur den ganzen Tag schwärmen. 🥰 Ich hatte Glück eine zu bekommen und bin absolut happy damit und möchte sie nicht mehr missen. Die Temps sind btw. absolut super, auch wenn die ein oder andere Custom Karte kühler ist.
Und leider immer nur Software Lösungen um das RGB Gedöns abzuschalten. Macht einen Schiebeschalter für den optischen Schmutz, dann kann man von Kirmes auf Ruhe umschalten.
Ja wenn man gut drankommt. Wenn man dafür den Kühler zerlegen muss isses schon wieder blöd.
Ja wenn man gut drankommt. Wenn man dafür den Kühler zerlegen muss isses schon wieder blöd.Bisher habe ich bei vielen modellen den stecker am rand der platine gesehen.
Bei den meißten modellen habe ich den stecker außen am platinenrand gesehen.
Beim letzten Drop hatte man doch über 2 min Zeit oder? Man und da war ich noch am Überlegen, ob ich mir die hol ...
War dieses mal auch so. Hatte das verfolgt. Aber keine bestellt, da ich schon eine habe.
Und wen es interessiert: Es sind vermutlich ca. 200 Stück jeweils immer.
Auf dem Karton steht dann drauf "Package 170 von 200", auf dem Label von Foxconn. Produziert im September^^
Habe doch eine Bestellmail von NBB bekommen. War im Spamordner.
Da ich nur per pp bezahlt habe ist es einem gastkonto zugeordnet.
Dieses kann ich jetzt in ein Kundenkonto umwandeln.
Genau das hatte ich aber schon beim letzten mal gemacht.
Was passiert wenn ich nun unter dieser mailadresse erneut ein kundenkonto eröffne?
Soll ich das machen oder nicht?
geht nicht, hab das versucht, aber mein PP Acc. und der bestehende NBB Acc. haben die gleiche E-Mail Adresse, daher gibt's einen Fehler beim umwandeln :d
Direkt nach der Bestellung war der Gast Account aber angemeldet xD
Ähnliche Themen
Antworten
6K
Aufrufe
389K
