[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
geht nicht, hab das versucht, aber mein PP Acc. und der bestehende NBB Acc. haben die gleiche E-Mail Adresse, daher gibt's einen Fehler beim umwandeln :d
Direkt nach der Bestellung war der Gast Account aber angemeldet xD
Was bei mir nach der >Bestellung angemeldet war weiß ich leider nicht?
Finde jetzt nix auf der nbb seite zu meiner gastbestellung.
bekommt man denn ohne konto eine mail mit storno oder wird die paypalbuchung einbfach kommentarlos storniert?
War dieses mal auch so. Hatte das verfolgt. Aber keine bestellt, da ich schon eine habe.
Und wen es interessiert: Es sind vermutlich ca. 200 Stück jeweils immer.
Auf dem Karton steht dann drauf "Package 170 von 200", auf dem Label von Foxconn. Produziert im September^^
Das wird eher von einer Palette sein, die haben sicher mehr als 200^^
NBB verschickt keine Storno Mails :) Wenn du bis morgen keine AB bekommst ist relativ sicher storniert worden.
Vielleicht auch 200 für ganz Europa oder Welt??? Bei insgesamt 100000 ausgelieferten 4090er wären 200 pro Drop und pro Land wöchentlich schon viel.
Kurze Info für alle, die das be quiet! Adapterkabel bei Reichelt bestellt haben. Die Auslieferung verzögert sich wohl bis zum 18.11.2022. Habe gerade mit dem Kundenservice telefoniert.
Seasonic Kabel 😁
Soll am Dienstag ankommen
Kann man gut zu einem 40. Geburtstag verschenken
Finde terminals hinten auch am besten. Hat leider kaum ein Block.
Die Preise für Wasserkühlungen sind einfach nur der Wahnsinn. 350 Öcken, nur für den Block. Bescheuert. Die Granzon Teile gab es letztes Jahr noch als Gesamtpaket inkl. Radiatoren+Lüftern+Tubes+Pumpe für 300. .
Das ist eine sehr trotzige Reaktion seitens Nvidia. /:
Die Frage ist ob es überhaupt rechtens ist.
Darf dann jedes Elektrogerät nur mit dem mitgelieferten Netzkabel betrieben werden da ansonsten die Garantie erlischt?
naja, letztendlich kann es eh nicht überprüft werden.
Aber die Reaktion ist nvidia typisch überheblich.
schade das amd nichts zu bieten hat. Ich hasse Jensen.
Bei Apple erkennt das Gerät, ob das Ladekabel Original ist oder nicht . Man weiß nie, ob NVIDIA das auch mit eingebaut hat. Würde mich aber wundern, wenn es so wäre :)
Nein, aber die Problematik liegt hier auch eher auf dem Thema Adapter.
Die Karte ist für ein 12VHPWR Kabel spezifiziert, das setzt aber eben ein natives ATX 3.0 PSU voraus.
Jeder Adapter und das sind auch alle aktuellen Kabel der PSU Hersteller die nicht nativ ATX 3.0 sind, ist ein Betrieb außerhalb der Spezifikation. Ein Betrieb außerhalb der Spezifikation ist durch die Garantie nicht abgedeckt.
Bei dem Adapter der beiliegt ist es etwas anderes, da dieser ja explizit von der Garantie erfasst wird/zum Betrieb offiziell empfohlen wird.
Wie bereits beschrieben hat auch bei mir Nvidia sofort gesagt ich darf mein BeQuiet Kabel nicht benutzen.
Die sind da aktuell sehr vorsichtig.
Spannend wenn jemand ein ATX 3.0 Netzteil hat braucht der dann einen Adapter für den Adapter ;-)
Hier muss man erstmal wieder differenzieren...
Garantie ("Hilfe ohne Diskussion") ist eine freiwillige Leistung des Herstellers/Händlers und darf an Bedingungen geknüpft werden (zB Verbot von Drittanbieter Zubehör bei sicherheitsrelevanten Bereichen wie Stromversorgung; Beispiel auch ähnlich wie bei Autos regelmäßige Inspektionen für die Herstellergarantie nötig sind). Wenn NVIDIA also sagt: Nur Originalteil - dann ist das so.
Gewährleistung (gesetzlich)... da schaut es wieder anders aus. Da wird es am Ende darauf ankommen, ob das Drittanbieter Produkt sich an die Spezifikationen gehalten hat, CE Zeichen/ andere EU-weite Vorschriften eingehalten wurden /ordentlich nach gängiger Industriepraxis und -erfahrung hergestellt wurde usw. Wenn sich hier der Händler/Hersteller querstellt, müsste man das per Gericht und Sachverständigengutachten klären lassen (Vorschusskosten mehrere tausend Euro). Wer das möchte... macht das. Der Rest wird das nicht tun.
Klingt schlüssig...
Selbstimport von Bykski über AliExpress für ca. 80€ ist der Weg.
Boah... wieder knapp an der Strix vorbei.
Das Kabel Thema ist echt dermaßen...wie kann man nur so eine Panik schieben? Ist hier der Anonyme Club an Hypochonder?
Zudem: Wen interessiert was nVidia sagt was man für Kabel nutzen darf? Was ich nicht weiß, macht mich nicht heiß. Wie sollen die das jemals nachprüfen.
Einfach bisschen den eigenen Verstand benutzen.
Strix OC wieder verfügbar! Go, go, go!!!
Ähnliche Themen
