[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Irgendwie ist vorfreude doch das schönste. Jetzt bekomme ich die fe und überlege ob ich nicht doch besser die tuf behalte. Passt optisch besser zu meinem pc. 2×hdmi und die leiseste karte von allen und ne bessere kühlung als die fe... hm. Ich werde es wohl entscheiden wenn ich sie mal getestet habe. Hat sonst jemand von fe zu aib gewechselt? Wenn ja... warum?
Ich hatte vor der TUF die FE, die wegen unsäglich lauter Rasselei der Spulen per "Tor's Hammer Luftpost" wieder in die NBB Zentrale gepfeffert wurde, nach dem Motto, diesmal nicht Nvidia, behaltet euer Rasselkonzert! Die Kühlung bzw. die Lüftergeräusche der TUF sind bedeutend besser und angenehmer. Die TUF hat natürlich auch Spulengeräusche, hier ist es aber mehr ein Zirpen und buzzing, von der Frequenz her für mich persönlich aber angenehmer als die der FE und auch nicht so laut, hatte aber evtl. auch nur Pech mit der FE, also was die Spulen angeht, obwohl ich das nicht wirklich glaube. Von der Wertigkeit her tun sich aber beide nichts, das Design ist mir recht egal, kommt eh Wakü drauf, das VRM bzw. die hier verwendeten Bauteile sind mir viel wichtiger als Led Quatsch und Design, diese 14 Spulen VRMs sind wirklich sagen wir etwas günstig designt, die Gründe zu erklären spare ich mir, da kommt man hier in diesem Thread eh nicht weiter, nur so viel, bei manchen 2000,- Karten ne echte Frechheit. ;)
mein ziel war es gar nicht die karte voll zu nutzen sondern sie eben nicht am anschlag laufen zu lassen damit ich in ruhe zocken kann ;)
Ich kenne 50 jährige die Superhelden absolut feiern. Dafür gibt es kein Alter :)
Ich feier die auch aber ich muss das nicht mehr unbedingt spielen.
Früher waren das auch meine Helden, heute sind meine Helden Leute wie Carsten Stahl oder Sarah Wagenknecht!
Eine fe zur wasserkühlung zu zerlegen ist schon blasphemie. 😀 also hat dich nur das spulenfiepen gestört... danke
Plague of tale, spiderman, uncharted z.b. mein geheimtipp quantum break.
Ja das sind gute Spiele, ich liebe A Plague Tale!
Erst mal bin ich mir God of War Ragnaroek beschäftigt, da ich die PS5 nur geliehen habe solange mein Kumpel in Thailand Urlaub macht.
Direkt danach kommt A Plague Tale Requiem dran 👍
Microsoft Flight Simulator yo Patch ist raus, mit DLSS 3.0. Can den Shice jemand hier testen und berichten?
Wobei die FE da schon besser ist als die TUF.
Also Spannungsversorgung und auch teils die Bauteile . Die FE ist schon hochwertig .
Die TUF ist da im guten Mittelfeld . Lüftkühler wahrscheinlich mit der Strix am besten .
Bei den anderen Karten wurde immer was bemängelt wegen den Kühler oder Lüfter , aber ist in deinem Fall uninteressant .
Positiv zu sehen ist der Umbau der Karte sehr easy bei der TUF .
Durchaus, am VRM der FE gibt es bis auf die Geräuschentwicklung der Spulen nichts auszusetzen - die ganzen 14 Spulen Karten sind jedoch unter der TUF anzusiedeln und das sind einige, zumal die TUF ja auch "nur" 1949,- kostet. Die 600 Watt Karten sind hier Bauteil mäßig eben doch im Vorteil, was nicht heißt, dass die anderen nicht auch ihren Job machen.
Glaub @Felix the Cat ist der einzige, die Kühler sind ja fast alle noch in Vorbestellung. Ich warte auf den EK, soll Ende des Monats kommen.
Hat jemand seine Suprim hier schon unter Wasser?? :unsure:
Jap, wie @L0rd_Helmchen sagt, habe ich heute den Phanteks-Kühler auf meiner SuprimX verbaut. Aber im Kreislauf kommt sie wohl erst Montag, warte noch auf eine zweite D5, die ich im gleichen Atemzug verbauen will.
Hast du zufällig CP 2077 installiert ?
Mich würde bei deiner TUF interessieren wie das Delta zwischen GPU Temp und hotspot bei dir ist @ Stock
Habe UHD @ max. RT ULTRA DLSS Qualität 420 Watt Verbauch und habe max. 17 Kelvin Delta dazwischen.
Bin mir nicht sicher ob ich ggf. etwas den GPU kühler nachziehen muss wobei ich gute Vram Temps habe bis max. 68°C .
Eben nach dem Bench waren es 64°C GPU und 81°C Hotspot .
Ich habe vorher noch ein bisschen gezockt, so dass die Karte warm war.
Somit ging der Kühler relativ leicht ab.
Wichtig ist, dass eine Schraube noch unter der Backplate ist, die mit dem Kühler auf der Vorderseite verschraubt ist. Die darf man nicht vergessen. ;)
@Holzmann
Jein, da ich unter Luft die Karte nur Stock betrieben habe und ich keinen Vergleich habe.
Was genau willst du wissen? Kurz mit dem Fenix getestet läuft butterweich. 8-)
Als ich dachte plague wäre jetzt zu ende gings erstmsl richtig ab. Bis auf hugos synchro wars geil. Krasses ende
Klingt sehr gut. Ich habe mich auch in das erste Game relativ spät verliebt, hab es anfangs zu unrecht ignoriert bis ich mir das Gameplay angeschaut habe, hat mich direkt angesprochen und als ich es angefangen habe zu spielen war ich direkt gefangen! Echt ein richtig tolles Spiel mit einer sehr packenden Story! Der zweite Teil sollte Anreiz genug sein es mit meiner RTX 4090 zu genießen. Ist dort DLSS 3.0 schon fertiggestellt?
Kurze Frage an Euch...hat jemand zufällig diesen Kabelsatz schon ausprobiert und kann was dazu sagen?
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin (12+4) 12VHPWR Anschluss für RTX 3090 Ti 4080 4090 | 3x8pin (6+2) PCI-e Stecker kompatibel für ASUS EVGA Seasonic Modular Netzteil https://amzn.eu/d/ijTCiHx
Wenn ich diese verkohlten Adapter sehe bekomm ich das...
CableMod da wart ich schon aber anscheinend kommt das auch aus China...weiß diesbezüglich auch jemand mehr?
Danke und viele Grüße.
Ein paar fps. Vgl DLSSon und DLSSoff, und wie sehen die fps in den dicken Städten aus? Ist auch frame generation dabei?
Fallen Artefakte auf?
Morgen sollte die FE bei mir eintrudeln. Kleine Frage, nutzt ihr eine GPU Stütze oder funzt es auch so?
FE hier ohne Stütze. Ist stabil genug als ganzes Teil.
Ich habe die FE etwas "höher" angeschraubt. Also die Karte etwas hochgedrückt und die Daumenschraube beim Slotblech ans Gehäuse geschraubt.
Sowas wollte ich hören, danke dir!
Ich habe ne Strix 4090 OC. Meine Karte schafft ein unglaubliches Mem OC von +1700 Mhz und die GPU akzeptable +220 Mhz. Jedoch verstehe ich nicht wieso bei anderen Leuten mit ner Strix bei +220 Mhz GPU clock die RTX 4090 auf 3100 Mhz boostet und meine nur bei 3015 Mhz rumgurkt. Wie kann das?
Schlechte Bin erwischt RAM ist zwar gut … GPU leider nicht … gibt eher weniger Strix die Stabil 3100+ Machen … die meisten die ich kenne ist bei 3030 bis 3090 Schluss je nach Benchmark.
Vielleicht hat Sie ja immerhin kein Spulenfiepen dann kannst du dich glücklich schätzen.
konnte das tunen einfach nicht lassen :d
Platz #1 mit dem Ryzen 5800x3d und der ollen Palit Gamerock 4090 in DE:
Die Gamerock macht im Afterburner +2000 auf den Memory. Hatte mich gewundert ob evtl. noch mehr geht. Aber im AB ist der Regler am Limit.
Hatte es dann mit dem Asus Tweak Tool noch weiter schrauben können:
Das müssen so +2075 im AB sein auf den Memory. Dafür geht beim Core nicht viel.
Erstmal genung rumgespielt. Warten auf das CableMod Kabel ...
Ähnliche Themen
Antworten
6K
Aufrufe
353K
