[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe ne Strix 4090 OC. Meine Karte schafft ein unglaubliches Mem OC von +1700 Mhz und die GPU akzeptable +220 Mhz. Jedoch verstehe ich nicht wieso bei anderen Leuten mit ner Strix bei +220 Mhz GPU clock die RTX 4090 auf 3100 Mhz boostet und meine nur bei 3015 Mhz rumgurkt. Wie kann das?
Hast du auch +100% core voltage gegeben?
Setz mal in afterburner deine Kurve zurück und schau nach wieviel MHz für 1,05 und 1.1V hinterlegt sind.
Bei mir 1.1V => 2910Mhz. Daher erreiche ich mit +180Core auch 3090 Game Stable. Benchmarks gehen auch ab und zu 3150Mhz durch. Dies aber stark abhängig vom Benchmark.
edit: Rebar habe Ich noch im BIOS und nvinspector aktiviert, das hat 200-300 Punkte gebracht
konnte das tunen einfach nicht lassen :d
Platz #1 mit dem Ryzen 5800x3d und der ollen Palit Gamerock 4090 in DE:
Die Gamerock macht im Afterburner +2000 auf den Memory. Hatte mich gewundert ob evtl. noch mehr geht. Aber im AB ist der Regler am Limit.
Hatte es dann mit dem Asus Tweak Tool noch weiter schrauben können:
Das müssen so +2075 im AB sein auf den Memory. Dafür geht beim Core nicht viel.
Erstmal genung rumgespielt. Warten auf das CableMod Kabel ...
Nice. Und das mit der Ollen Palit :-)
Port Royal skaliert echt hart mit VRAM. Bei meiner Strix ist bei 1800 Schluss, dafür 3120 Takt im PR: 28896.
Klingt sehr gut. Ich habe mich auch in das erste Game relativ spät verliebt, hab es anfangs zu unrecht ignoriert bis ich mir das Gameplay angeschaut habe, hat mich direkt angesprochen und als ich es angefangen habe zu spielen war ich direkt gefangen! Echt ein richtig tolles Spiel mit einer sehr packenden Story! Der zweite Teil sollte Anreiz genug sein es mit meiner RTX 4090 zu genießen. Ist dort DLSS 3.0 schon fertiggestellt?
Ja läuft. Finde ihn auch abwechslungseicher als den ersten.
Moin, kannst du mal Timespy Extreme machen?
Bin da Platz #3 :) in DE
Musst du das immer neu einstellen? Dachte das bleibt gespeichert. Das mit NVinspector ist das gleiche wie "damals" bei den 30xx Karten oder ?
Wow, hätte nicht gedacht, dass ich die heute noch bekomme :hail:
Jetzt muss Hermes nur noch meine Haustür finden. 🙏
Gut, dass ich schon seit Wochen einen Cablemod 12VHPWR Adapter rumliegen habe.
Einfach mal 250€ über dem bisherigen Preis. Jetzt ergibt auch die Frostbite für 2399€ Sinn. Bist billiger dran :d
Hast du zufällig CP 2077 installiert ?
Mich würde bei deiner TUF interessieren wie das Delta zwischen GPU Temp und hotspot bei dir ist @ Stock
Habe UHD @ max. RT ULTRA DLSS Qualität 420 Watt Verbauch und habe max. 17 Kelvin Delta dazwischen.
Bin mir nicht sicher ob ich ggf. etwas den GPU kühler nachziehen muss wobei ich gute Vram Temps habe bis max. 68°C .
Eben nach dem Bench waren es 64°C GPU und 81°C Hotspot .
Ist fast 1 zu 1 identisch bei mir.
Interessant!
Warum geht meine Karte über Berlin obwohl ich auch aus Bayern bin!?
Wie soll sie denn sonst nach Bayern kommen? Auf dem Eselskarren durch den Harz? Berlin München ist die schnellste Nord-Süd Trasse.
Bezüglich Flightsimulator und Framegeneration....
Habe das Update heute Morgen gemacht und bin in positiv überrascht,
nach dem Framegenreration bei Requiem Artefakte bei schnellen Drehbewegungen geschmissen hat,
ist davon bisher hier nichts zu sehen.
Mein Testspielstand über RIO in 4K mit TAA ohne DLSS:
RTX 3080 Auflösungsskalierung =100 = 43FPS
RTX 4090 Auflösungsskalierung =100 = 78FPS
RTX 4090 Auflösungsskalierung =120 = 60FPS
RTX 4090 Auflösungsskalierung =120 + Framegeneration= 110FPS (CPU LIMIT)
RTX 4090 Auflösungsskalierung =150 + Framegeneration= 70FPS
CPU 7600x 5,5Ghz 1,27V Allcore OC @6200Mhz CL30 RAM
GPU UV 0,875V 2550MHz VRam +1000
Meine mal gelesen zu haben, dass Nürnberg auch in Bayern anzutreffen ist und zufällig auch auf deiner Nord-Süd Trasse liegt. (Ironie)
Ja und jetzt? Ändert ja nichts an meiner Aussage. Hamburg, Hannover etc. geht alles über Berlin in den Süden.
noice!
Hast du BCLK OC bei den X3d?Der macht 100mhz mehr als meiner. Und hast du den RAM auf CL16 oder CL14?
Ja, BCLK OC 1.0225 => +100Mhz
RAM ist offiziell 4000@CL18-22-22-22-59(?)
Und läuft mit 3750@16-21-21-20-38 und alle sekundär und tertiär Timings manuell eingestellt. Ist aber kein guter RAM, war halt 2020 schwierig und ich dachte IFCLK 2000 würde gehen…leider kam ich weder heim 5800X noch beim X3D über 1900 raus ohne WHEAs zu haben…
Interessant!
Muss das sein zum vollen Bilderquote noch seine eigene Sendungsverfolgung in voller Auflösung zu posten? 🙄
Wenn jetzt hier wieder alle anfangen Ihren Zustellverlauf bis ins kleinste Detail zu posten, was nebenbei bemerkt nichts mit dem Thema des Threads zu tun hat, wird es unübersichtlich.
Muss das sein zum Bilderquote noch seine eigene Sendungsverfolgung in voller Auflösung zu posten? 🙄
Ja sorry, bin am Handy und hab nur schnell einen Screenshot gemacht.
Kommt nicht wieder vor, versprochen!
Kannst du mir nochmal verzeihen?
Warum muss das überhaupt gesetzt werden. Nie von gehört? Ist doch im bios und gpuz aktiv?
du musst das nicht manuell setzen. Bei NVIDIA ist das so: NVIDIA erlaubt ReBar NUR wenn sie es PRO Spiel/Anwendung freigeben. Und das machen die technisch über die nvpanel Profile.
Änderst du das per nvprofileinspector für das globale Profil, ist rebar immer an, bei jedem Game. Das kann dir aber schon mal je nach Titel negative Performance einbringen :)
Da hier das Thema rBAR nun öfter angesprochen wurde habe ich mal bei mir aus Spass geschaut und es ist tatsächlich deaktiviert gewesen!
Bei meiner 3090 hatte ich es explizit aktiviert gehabt, mit Einbau der 4090 hat sich MB wohl auf default zurückgestellt? Strange auf jeden Fall...
PS: Strix hat der Postbote tatsächlich eben vorbeigebracht, Bestellung war gestern Mittag, wow.
Ähnliche Themen
