[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Neben dem Aquaero könnte man die Zuleitung der Lüfter modden (passenden Widerstand in Serie reinlöten)
Wäre billiger, aber nicht weniger aufwändiger
Stecker hat den Test bestanden, einwandfrei! Die Backplate war das heißeste was ich gefühlt habe, Stecker hat Abstand zur Seitenwand, alles top !
Thema Melting beendet, und Gehäuse geschlossen:giggle:
Meine ASUS 4090 TUF ist heute aus Braunschweig zurück gekommen da diese am "send it in, get one free" Programm teilgenommen hat. https://www.alphacool.com/shopware.php?sViewport=ticket&sFid=141
Nach dem reverse-engineering dort hat man die TUF mit besserem Material und/oder handwerklich besser zusammen gebaut als ASUS ab Werk. Auf Rückfragen kam promt eine Antwort auf die sehr zusammen gerückten Temperaturen von GPU, Hotspot und Memory. Insbesondere der Speicher war vorher etwa 10°C wärmer.
Anhang anzeigen 820360 Anhang anzeigen 820359 Anhang anzeigen 820361
Bei meiner Karte sind die Vram Temps gut .
66•C war bisher das höchste der Gefühle im Alltags Gaming auch mit CP 2077 @ 420 Watt Verbrauch durchgehend .Die Pads liegen auch überall wohl sehr gut auf , wenn ich von der Seite schaue .
Ich mag nur das Delta zwischen GPU und Hotspot bei mir nicht .
Delta Werte: max Werte @ Hwinfo
IDLE : 9 Kelvin
Gaming BF2042 329 Watt : 12 Kelvin
Gaming CP 2077 420 Watt : 17 Kelvin
Timespy Extreme max OC 560 Watt : 20 Kelvin
Ich nominiere dich für den Kühlschrank Award!
Meine Gaming OC idled nach einer gewissen Zeit so zwischen 39° und 41° C. Aber ich habs auch eher warm in den Räumen. Ich schätze so 23-24° C. Ich müsste mal wieder die Batterie vom Raumthermometer laden.
Idle:
21c Raum
350rpm @ Noctuas
10min idle
33c 4090 FE
Erst Recht, wenn man das hier sieht... :oops:
🤔 Was denn?
Also die Karte als Asus Rog Strix LC ist ja wohl immer noch eine Wucht 🤯👏...
Hatte die als Asus Rog Strix RX 6900 XT LC Top mit dem XTXH Chip.
Da gab's nichts zu bemängeln, war top verarbeitet, hat sehr gut performt und sah wunderschön aus.
Ach so und war selbstverständlich schön teuer. Mit 1600€ zur beschissenen Zeit im Frühjahr war es sogar noch ein Schnäppchen... Letztens neu gerade mal die hälfte 😁
IDLE : 9 Kelvin
Welche Karte/Kühler hast du den aktuell im Einsatz? Temperaturen finde ich top, aber das Delta hätte mich schon etwas gestört.
Aktuelle Situation hier nach einer Viertelstunde FurMark. PL 75%. Alle drei Temperaturen rücken sehr nah zusammen. Ich hoffe mit dem Wasserkühler bekomme ich das auch so hin.
@pajonk Sehe ich ähnlich, aber es gibt auch wohl große Unterscheide in der Fertigung. Ab Werk in Taiwan werden die Karten im Akkord zusammen gekloppt. In meinem Fall hat ein Alphacool Mitarbeiter in Deutschland die Karte sorgfältig auseinander und mit eigenem Material wieder zusammengebaut. Ich mal er hatte viel mehr Zeit das sorgfältig zu machen und auch Zugriff auf bessere Pads/Paste. Das dürfte aber auch übertragbar sein auf Enthusiasten hier die Karten selbst, und sehr gewissenhaft umbauen.
Cool die haben dir bestimmt die Apex Soft 11W+ drauf gemacht !
Habe die TUF OC mit Luftkühler
Hier auch mal die IDLE Werte der Karte , weil das einige interessant finden .
Bei 55°C GPU Temp gehen die Lüfter an.
Bei BF ca. 60°C und bei CP 2077 65°C GPU Temp.
Hotsport Delta wie gesagt .
Kühler ist an für sich wirklich gut von der TUF.
Falls ich die Karte selbst Padde. Brauche ich da unterschiedlich dicke Thermalpads?
Gibt glaub ich Tear Down zur Tuf wo die die Pads gemessen haben!
Ich empfehle die Apex Soft 11W beste PL die noch stärkeren konnte kaum besser performen waren aber Mega teuer!
Die hier meine ich.
🤔 Was denn?
Ich wollte damit ausdrücken, dass diese Strix sehr günstig ist und die Preise der 4080 beschissen teuer
Falls ich meine Tuf behalte bekommt die auch einen Thermalpadmod. Die haben jetzt ulraweiche genomme. Ich hatte an harte gedacht da die doch angeblich besser leiten sollen? Am liebsten noch ein Coppermod für den VRAM.
... nur blöd, dass bei Ada niedrigere Speichertemperaturen Gift fürs OC sind :ROFLMAO:
Ich hab in Cyberpunk und wohl auch in The Ascent das Phänomen dass ich nicht über 400Watt gehen kann.
Das war schon mit der RTX3090 der Fall dachte erst es liegt an der. Jetzt habe ich das mit der 4090 aber auch.
Hat das Problem auch jemand?
Also man kann im PT eingeben was man will oder per curve er regelt immer bei ca. 400Watt runter
Echt ist das so? Dachte Kühler ist immer besser? Naja, ich bin eh der undervolter :-). Vielleicht lasse ich sie auch erstmal so. Aber wie es scheint kommt Asus nicht aus der Hufe. Seit 2 Tagen steht da Versand elektronisch angekündigt.
Welche Auflösung?
Welche Auflösung?
Glaub alle. Aber 4K weis ich das mit Sicherheit. DLSS ist bei mir immer off.
Hat wer seine 4090 schon auf EKWB umgebaut?
Block liegt noch hier.
Ich habe nur keinen Anreiz umzubauen weil die Karte halt unter Luft leise und kühl ist :d
Und die Garantie geht doch direkt flöten 🤔
Wollte ich erst auch aber lohnt sich ja nur wenn es Roman der Bauer persönlich oder ein anderer Profi mit Garantie macht.
-> meine Karte läuft seit dem 07.11. schon unter dem EKWB Vector FE Block :wink:
hier findest Du infos dazu:
@Grestorn
hier mal ein Paar Vergleichswerte falls Du den Thread nicht bereits kennst ;)
Wenn ich mir so die Temps angucke sind die ja im Hotspot bereich net wirklich besser oder irre ich mich da?
Ähnliche Themen
Antworten
6K
Aufrufe
353K
