[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe heute in der Pause mal mein System auf Default, OC und Undervolting getestet mit Stromanzeige in W mit voller Gaminglast in 4K mit RT.
OC:
13900KF mit 5,8GHZ all core, All Limits Removed 398W
4090 Frostbite mit max OC und max Voltage 450W
Total aus der Dose vom Rechner = Knapp 872W
105% Leistung
Default:
13900KF Stock = 290W
4090 Frostbite default ohne Voltageerhöhung = 424W
Total aus der Dose vom Rechner = Knapp 731W
Maßstab 100% Leistung
Undervolting:
13900KF mit 1,32v im Bios. Das sind 1.137V unter Last mit LCC4 in Windows = 211W
4090 Frostbite 70% undervolting = 320W
Total aus der Dose vom Rechner = Knapp 551W
92% Leistung
Von OC bis Undervolting verliere ich in etwa nur 13% Leistung, aber ich habe 37% weniger Stromvebrauch. Es bleibt noch zu erwähnen, dass die CPU ca. 15 grad kälter ist und die Karte auch 5-6 Grad weniger hat.
Ich empfehle dir, Hyper Threading zu deaktivieren, diese unechten künstlichen Kerne braucht man nicht. 24 echte Kerne reichen locker.
Hyper Threading kann auch einige Probleme machen beim zocken
Das ist aber gar nicht so verkehrt. Die Karte wartet ab ob die Karte die Temperatur senkt und schaltet erst dann die Lüfter ab. Hast Du jetzt ein Lite Game laufen und die Lüfter würden ausgehen würde die Temperatur langsam steigen. Dann würden die Lüfter wieder anspringen um sie runterzukühlen... dann wieder ausgehen.... und das immer wieder... Von daher lässt sie die Lüfter auf 30% laufen und wartet bis sie sicher ist, dass die Temperatur abfällt. Und wenn sie einmal auf 30% laufen hört man sie ja kaum. Besser als an aus...
Tja, wenn der Scheiss Propeller dabei leise wäre, hätte ich damit auch kein Problem. :d
Dann nenn mal ein Beispiel wo es Probleme macht? Habe da schon mehrmals recherchiert. Am Ende kam immer raus, dass es egal ist ob beim Gamen HT an oder aus ist. Es gabe ein zwei games wo es vllt. mal 3-5% Leistung gekostet hat. Hast Du Beispiele für aktuelle Games?
Noch kein Fliess und Doppelklebeband besorgt? :-)
Weil die 3090TI Suprim zu groß war und ich keine vernünftige Stelle für den Halter an der Graka gefunden habe. :fresse:
Die 1100U/min Lüfter der FE sind mit Abstand das lauteste in meinem System.
750U/min würden locker langen.
Ja das geht Gurkengräber und mir genau so. Und wenn ich das jetzt wieder höre überdenke ich schon wieder ob ich sie gegen eine andere tauschen soll. Aber mit leisem Spielsound sind die 30% noch erträglich.
War eh nur ein Beispiel, der PC ist weg und der Käufer hat eh n anderen Stand benutzt.
Sag ich doch. die Thermalpads der Tuf sind teilweise zu klein und decken nicht die ganze VRAM Fläche ab. Falls ich meine Tuf behalte bekommt die auch einen Thermalpadmod. Die haben jetzt ulraweiche genomme. Ich hatte an harte gedacht da die doch angeblich besser leiten sollen? Am liebsten noch ein Coppermod für den VRAM. Lächerlich was die Fachfabriken da bei 2000 Euro zusammenklatschen. Irgendwie denkt keiner mehr langfristig an seinen Ruf sondern nur noch an den schnellen Profit.
Leiten besser, ja - geben aber schlechter nach, dass du worst case schlechtere GPU-Temps hast (Igor hatte dazu mal einen Test mit zu harten Pads gemacht)
Daher wird bei vielen Pad-Mods eher zu GELID Extreme statt zu GELID Ultimate geraten. Die GELID Extreme sind mit den "Rise Ultra Soft" vergleichbar (geben gut nach)
Hab die "Rise Ultra Soft" seit mehr als einem Jahr im Einsatz und bin sehr zufrieden. Ich finde sie etwas besser, als die GELID Extreme (Obwohl die Extreme 12W/mK haben)
Auf diesen Wert alleine kommt es jedoch nicht an (hatte Igor damals auch gut erklärt)
Ein Copper-Plate-Mod ist natürlich am Besten, aber der Aufwand ist sehr hoch
Und Finger weg von EC360-Pads!!!
Kannn es aber auch sein, dass deine karte nun kühler ist weil der fussboden nun jetzt auch winterlicher ist?
Die Wärmeübertragung hängt ja nicht nur am Wärmeübertragungskoeffizient. Die dicke ist auch wichtig bzw. sogar deutlich wichtiger. Bei gleicher dicke wirst du mir besseren Wärmeübertragungskoeffizient besser sein, aber gewöhnlich sind härtere Pads/Pasten auch dicker unter Kompression.
Weil ich den Haltewinkel der Gigabyte Gaming OC nutze. Stabiler und eleganter geht's nicht
Doch einfach eine Karte haben die gar keine Stütze braucht und trotzdem nicht hängt…. Schleichwerbung für die PNY hier einfügen 😜
Klar, deshalb würde ich ja ein härteres Pad nehmen welches nur so dick ist wie die zusammengedrückte Stelle des weichen Pads.
@pajonk
Schau mal...
Keine "Rise" aber auch Ultra Soft
Ultra-softe Pads nicht nicht diese "Schaum-Pads", die gerne verbaut werden (Hatte meine 3090 Strix OC). Die Pads sind eher wie Knetmasse. Wenn man zb 3mm Pads hat, man aber 1mm braucht - kann man diese auf 1mm vorpressen ;)
@pajonk
Schau mal...
Dem Fazit nach müsste man es also selbst probieren. Ob weich oder hart hat jeweils vor.- nachteile. Danke für den Artikel.
Ich würds nicht machen. Aber Freiwillige vor ;)
Wenn du das genaue Maß hinbekommst - Respekt
Ich kann dir nur sagen, dass ich damals die FE zig mal zerlegen und die ultra-soften Pads merhfach nachpressen musste, bis die GPU-Temp wieder ok war (da war ich nicht der Einzige)
Bei härten Pads will ich mir das garnicht vorstellen und ich kenne auch Keinen, der das mit härteren Pads probiert hat. Außer Jemanden, der es vielleicht probieren will :d
Bei dem Aufwand (zig-maliges Zerlegen) hätte ich mir auch gleich Kupferplättchen zurecht feilen können :rolleyes2:
So habe jetzt endlich auch mein bequiet Kabel, ziemlich steif das Teil wie soll ich das nicht knicken/biegen. ^^
Das ist die Frage ?, habe deswegen Panel offen. Überlege ein weiches Kabel von Kable Mod zu bestellen..., oder abziehen, brutal knicken un wieder gerade aufstecken
Sag mal kriegst du von PNY Cashback für die Dauerwerbung? Ist ja echt heftig. :d
Ne, aber es ist einfach echt krass wie viel Unterschiede und Mängel es auch zwischen den Herstellern gibt…
Eigentlich ist es einfach nur traurig, dass man bei 2000€ nicht mal ein einwandfreies Produkt bekommt. Jede hat irgendwie ihre Macken, vor paar Jahren waren die Karten günstiger und weitestgehend alle kompromisslos gut und es gab einige wenige welche absolut problemlos waren.
Gefühlt ist es bei den 40ern ja sogar so, dass es mehr Probleme gibt, desto teurer die Karte ist 🤣
Bei mir auch. Die Geräusche bei 30% sind absolut inakzeptabel.
Ähnliche Themen
