[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Darf ich fragen, wieso deine Karte gerade bei Nvidia ist?
Eben genau wegen jener Lüfterproblematik. Also mir ist klar, dass ich wahrscheinlich entweder dieselbe Karte mit dem Vermerk "works as designed" oder eine neue mit dem gleichen Problem (Lüfterbrummen) bekomme, aber bei einer 2.000€ Karte wollte ich es wenigstens versuchen. Und da die RMA angekommen wurde, schien es denen ja auch nicht geheuer zu sein. Musste ein Video einschicken.
@*****, schon richtig. Aber FY NVidia, wenigstens nicht kampflos geschlagen geben ist hier das Motto. :d
Aber vielleicht verschiebe ich die Updates dazu eher in den Smalltalk Thread, soll ja kein Spam werden hier.
Weiß jmd nähere Infos zum Cold-Bug beim RAM?
Zb ob das nur einen bestimmten Temperatur-Bereich betrifft?
Denn offentlich gibt es ja ein paar User in der HoF, deren Karten mit -35°C (GPU) arbeiten
Dass die gleichzeitig den RAM warmhalten glaube ich eher nicht. Der extreme Temperaturunterschied auf so kleiner Fläche ist vielleicht nicht so "gesund" !?
Imho empfinde ich das nicht als “Bug”, das würde ja heißen, dass etwas kaputt oder unerwartet funktioniert. Ist ja hinlänglich bekannt, dass es Memory nicht zu kühl mag. Der 6X ist bei der 40er um Längen besser gekühlt als bei der 30er. Also 110C vs 50C unter Volllast.
Schau dir mal die Videos vom Bauer an. Da kommt ein LN2 Pod auf den GPU Die und der Memory wird nur mit einem Lüfter gekühlt. Dadurch bleibt das Memory in einer normaleren Temperaturrange und man kann richtig OCen.
Bei mir läuft das Memory bis zu +1600 und auch im TSE bei ~20C durch meinen Wasserblock.
Ich hatte mich schon bei Ampere geschlagen gegeben. Ich hatte 3 verschiedene 3080 ti und hatte mich dann am Ende für WK entschieden...
Also habs komplett aufgegeben und erwarte auch nichts mehr. Meine FE ist aktuell zum Testen noch mit Lüfter und vertikal und da rasselt der Lüfter. (ist wirklich der Lüfter. Wenn ich den mit der Hand stoppe, dann ist Ruhe)
Aber sonst eig so wie ich es von Ampere gewöhnt bin ^^
Nur 20°C RAM unter Last?
Selbst die 50°C oben unter Luft finde ich "wenig"
btw:
Links bei "Board Power Draw" von 400W unter Furmark @1920x1080 ohne AA und ohne OC sind es min. 70°C RAM mit dem TUF-Kühler
Rechts mit passivem MoRa @22°C Raumtemp. im Surfbetrieb
Doch gibt es, wurde ja auch hier im Forum bereits vorgestellt. Meine FE ist allerdings gerade bei NVidia, also muss warten bis sie zurück kommt, dann kann ich dieses Mod probieren.
Silent Mod 4090 / 80 FE
Aus gegebenen Anlass. gerade fertig gemacht.
Welche kostenlosen RT-Benches benutzt ihr?
Hab hier noch Niemand gesehen, der "Neon Noir" von Crytek gebencht hat
Vielleicht kann unser @Slipknot nochmal seine Hinweise auf andere Foren verlinken. Leider habe ich mir die Seiten auch nicht gemerkt. Daher bitte encore une fois :)
Ich habe keine Links für den Temperaturbereich um die -35°C.
Den Temperaturnormalbereich betreffend:
Cold memory bug bei ca 30-40°C und darunter. Tritt erst mit Waküs auf. Sweetspot eher bei 50-60°C.
Ich habe bei den pads der Wakü die Folie auf einer Seite belassen, die Temps steigen unter Last in den Bereich 50-60°C, vorher 36-40°C. Seitdem ist VRAM oc wieder stabil, davor instabil.
Ich werde wohl versuchen müssen das CableMod Kabel irgendwie zu stornieren/widerrufen, glaub nicht mehr dran, dass das ankommt.
Werden immer noch Daten "intern" ausgetauscht...
Bleibt halt der Dreizack an der Karte.
Das Teil wird schon ankommen. Habe auch mal irgendwas über Aliexpress bestellt und das Teil ging einen wirren Weg über Shicen City, blieb dann dort hängen und aufeinmal wars in Europa, glaube Rotterdam. Hat lange gedauert die Shice Lieferung.
Das heißt, man sollte die Kühlung des VRAM bewusst verschlechterten, damit dieser Cold-Bug bei einer Wasserkühlung nicht auftritt... ähm what an amazing piece of technology :wall: :stupid:💩
Ja. Vorgehensweise:
VRAM oc mit Lukü ausloten.
Wakü drauf.
Beobachten ob plötzlich blackscreens etc. auftauchen.
Wenn ja, dann Temp rauf, zB Folie drauf. Oder 200-300MHz reduzieren.
Wakü bringt diesmal bei VRAM oc gar nichts, man wird nicht mehr MHz rausholen im Vgl. zu Lukü.
Nochmals News zur Strix white edition
Der ist sehr gut. Karte wird unter Volllast nur 60°C warm.
Die Palit wird nur 60°C unter Volllast?
So also hier mal ein schneller erster Vergleich zwischen FE und PNY 4090
FE - PNY
Verbrauch idle: 6 bis 9W - 18 bis 22W
Temp GPU load: 65 bis 72° - 75 bis 80°
Temp Hotspot load: 75° - 85°
Temp mem load: 72° - 80°
stock Boost takt: 2715 - 2700
Lautstärke: Brumm brumm - super leise
Spulenfiepen: nicht wahrnehmbar - sehr leise, nicht störend (hab keine Games über 150 FPS)
Verarbeitung: super - naja, net so dolle
RGB mit Asus Aura einbindbar: ja - nein
Sag: nein - ja
Gehäuse geht zu: relativ einfach - Adapter muss stark geknickt werden
Alles in allem ist diese PNY etwas langsamer als meine FE, sie taktet ein wenig niedriger. Bin jetzt nicht so der Overclocker, silence is king. Was mich allerdings bei der PNY schon stark nervt ist der idle Verbrauch. @Foxel, kannst Du bitte einmal bei Dir schauen was Deine Karte sich auf dem Desktop nimmt? Dunkler Hintergrund. Die Differenz würde bei meinem User Profil und Strompreis ca 115€ pro Jahr ausmachen, das ist schon ne Menge.
Allerdings muss ich diese Karte zurück senden, denn anscheinend sollten sich alle drei Lüfter auch bei niedrigen Temps drehen. Wie schon angesprochen, gerade beim Wiederverkauf gibt es sonst Probleme. Aber auch die Temps sind so nicht ok. WÜRDEN sich alle drei Lüfter drehen und die Temps auf FE Niveau oder gar darunter sein, dann würde ich die PNY behalten. Eine RMA ist mir aber zu gefährlich, nachher drehen beim Ersatzmodell auch nicht alle drei Lüfter. Also Widerruf und neu bestellen. Es gibt bei Reddit auch etwas dazu und bei Amazon ein entsprechendes Review. Scheint also einige Karten zu betreffen. Wären die Temps ok hätte ich vielleicht noch gesagt egal, aber so... Mal schauen ob Amazon das ohne Murren mitmacht. Und bevor sich jetzt jemand beschwert, ja ich werde schreiben dass sich ein Lüfter nicht dreht. ;)
Ätzend. Also alles wieder einpacken und zu Amazon zuück. :(
Zum Thema Verbauch ist es bei der Gigaybte Master ähnlich.
FE idle 11W Master 20-30W (Browser aktuell 32W)
Warum zum Teufel sind die Custom da so verschwenderrisch? Ne Intel UHD 770 braucht 3W und ne Nvidia Custom einfach 10 Mal soviel.
Was ist eigentlich aus den 90° Angle Adaptern geworden?
Hört man garnichts mehr zu
btw:
Nicht unter Last.
Das sind die Max Wette, welche ich mir beim TSE unter Last aufgeschrieben habe (Fenster offen):
GPU Temp 44.4,
Hotspot 55.8
Mem: 28
Power: 580.7W
Water: 17.5
Ok, danke
Dürfte ein bisschen kürzer sein, dann wäre es perfekt. Oder noch besser - 90/180° am Kabel
Ja den link kenne ich aber man kann die ja nicht bestellen oder doch?
Nein... aber es steht alles da, bisher gibt es kein Update dazu.
Hör blos auf. Hab nen hals. Weiß nicht wie ich das rauskriegen soll. Wenn ich dort Bohre wird es echt eng bei 2mm :-(. Hast nen guten Tip?
Heißkleber o.ä. auf eine dünne "Stange" (Schraubendreher?) draufhalten trocknen lassen und rausdrehen vielleicht? :d
Gibt so Bohrer, die extra fürs links drehen gemacht sind, damit kann man es dann auch raus drehen. Aber keine Ahnung wie das bei so kleinen Gewinden möglich ist.
Die habe ich. Aber in der Minigröße nicht. 2mm ist echt eng. Selbst wenn ich mit 1-1,5mm ausbohre könnte ich das gewinde ankratzen. Das müsste man an einer Standbohrmaschine einspannen und bohren. werde wohl mal nach lust und laune zu meinem Ex Tischlerkollegen in die Werkstatt fahren.
heißkleber ist auf jeden Fall nix. Das Gewinde steckt fest drin. Hätte es mit einer mininuss anziehen sollen. aber die hatte ich nicht. 3 gingen leicht rein und die 4te wollte nicht ganz...
Aber unterm Strich läuft es...
Ich liebe diese Generation die PNY ist auch noch so unhörbar ich rendere die ganze zeit mit Blender und so sehen die Temperaturen aus, ein Traum 😍
Hat jemand bitte gerade mal dieses VRAM OC Stabilitytest Programm zur Hand? Wurde mal hier gelinkt aber finde es gerade nicht mehr.
Ähnliche Themen
