[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab jetzt nur mal schnell auf deren Seite nach einem anderen 4090 Review geschaut. Bei der MSI sagen sie
Also vielleicht messen die anders. In jedem Fall zieht die FE weniger. Die PNY haben sie anscheinend nicht getestet, aber daran sieht man ja, dass insgesamt der Unterschied schon da ist.
Edit: Hier noch die Zotac:
Also komm, lass gut sein. Die FE ist die Beste und Basta. Was erlauben Strunz! ;)
Und bei der MSI sagen sie
… und bei der 4080 zieht dann die PNY sogar gemessen weniger als die FE, trotz gleichen Bauteilen.
Die Debatte ist sinnlos und dreht sich im Kreis, das einzige was sich deutlich zeigt, ist der Fakt das Messungen der idle Verbrauchs wohl recht sinnlos und nicht besonders konsistent sind.
Ok ich geb's auf. Es geht um das Verhältnis des Verbrauches zu einander, nicht die Schwankungen oder die absolute Zahl. Und das Verhältnis kann man sehr wohl vergleichen, wenn die Messmethode und das restliche Setup identisch sind. Aber ok. Deine heilige Kuh PNY 4090 wurde hier zwar nachweislich geschlachtet aber wenn Du das anders siehst, ist das natürlich Dein gutes Recht. Jedem das Seine. :bigok:
Es geht doch gar nicht um die PNY, du kannst jede beliebige 4090 nehmen. Du hast im Idle nicht so massive Unterschiede. Das ist meine Aussage, ist mir egal ob ne PNY, Gigabyte, MSI oder wer auch immer.
Die PNY ist ne rein vom PCB eine absolute Dreckkarte, da braucht man auch nichts beschönigen, lediglich der Kühler ist wirklich solide.
Aber sich irgendwie einzurden die 4090 würde im idle 6W ziehen ist einfach sehr weit von der Realität, das ist der Punkt um den es mir im Kern geht. Und nur weil HWInfo das anzeigt ist es nicht richtig, wei gesagt, selbst bei meiner Dreck PNY habe ich schon 6,xx W gesehen. Du hast hier sogar 2 Screenshots von unterschiedlichen usern wo 11,xxxW zu sehen sind.
Ergbeniss: Entweder ist HWInfo nicht zuverlässig, oder du hast ne God Tier FE und eine unterirdische PNY ^^ Ist ja nicht so, dass ich nicht auch eine FE da hatte ^^
Igor hat übrigens auch 35W idle gemessen, aber was wissen die alle schon wenn doch HWInfo was anderes sagt. Wenn die 6-11W idle die auch meine PNY anzeigt stimmen, dann gehen die restlichen 59W sicher einfach für den 13700k, 3 SSDs und 7 Lüfter drauf 😂
Ich verstehe auch nicht warum Leute das als PNY vs. FE auffassen… eine FE zieht einfach Idle keine 6W und ist nicht 3-4x so effizient wie andere Karten rein über den VRM. Die MSI Suprim hatte übrigens die selben Bauteile wie die FE, nur nochmal mehr davon. Man wird ja wohl noch sachlich hinterfragen dürfen.
sie kommt doch....
Also meine Phantom hat im Idle mit 2 Monitoren: UWQHD 144Hz QHD 144Hz 25-29W. Da ich wahrscheinlich bald auf eine FE umsteige kann ich ja den direkten Vergleich nochmal hier posten :d
Ich bekomme die Tage auch ne FE da werde ich es auch Testen.
Auch Multimonitor Setup
FE hier 17W mit 2 Monitoren.
3440x1440 144Hz
1920x480 60Hz
meine tuf mit dem galaxy bios idled bei ca. 18w mit 2 Monitoren (4k 120hz + 4k 160hz)
Also spinnt HW Info nur bei der FE, ja? Und bei allen anderen Karten liest es richtig aus? Denn meine PNY ist nie unter 20W. Die FE aber permanent unter 10.
3440x1440 144hz TUF
Nein, eben nicht. Wie gesagt, ich habe auch häufiger 6W als Minimum stehen, ich nehme es nur eben nicht ernst.
Hat jemand ne Idee, wieso mein Idle Verbauch so exorbitant hoch ist?
Läuft auf einem OLED UHD 120Hz 48 Zoll.
78W komplettes System oder net?
Und das ist nie weniger? :oops:
Mal im BIOS/UEFI auf default-Settings gestellt?
Müsste ich mal schauen.
An der Karte hängt sonst nur der OLED?
Mal einen anderen Moni angeschlossen?
Doch, hab noch einen 32 Zoll Samsung als Moni dran. Der ist aber die meiste Zeit aus und wird nur ab und an für Office Sachen verwendet. Kann doch aber nicht sein, dass dieser hohe Verbrauch durch den 2. Moni, der sich im Standby befindet, entsteht.
sind bestimmt die LEDs der GameRock :) :) :)
Stecker raus an der Karte und nochmal schauen
Klingt so als wäre sie im Low Power 3d Mode, kommt hin vom Verbrauch. Mal Treiber per DDU runter und neuinstalliert?
Hast du irgendwelche Live Wallpaper o.ä. am laufen?
Ich seh gerade, dass die Lüfter der Karte ständig auf ca. 1150 RPM drehen. Hä, wieso greift denn nicht meine Lüfterkurve?
Hab eigentlich bis 40° auf 0 RPM stehen im Afterburner🤔
Keine Live-, nur wechselnde Wallpaper.
Ähnliche Themen
Antworten
6K
Aufrufe
397K
