[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann mom. auch höher stehen, weil sie aktuell nicht verfügbar ist. Ist ja nicht selten, dass die Preise dann seltsam hoch sind
Wie auch immer, trotz potentieller Fieporgie ein guter Preis. Zumindest geht es in die richtige Richtung.
Bin wirklich gespannt ob sich die Preise im Januar etwas niedriger angehen oder ob das stabil bleibt. Ich finde alle inkl der Strix müssten unter die 2000er Marke.
auch bei 1859€ ist die Rasselkiste zum Zocken nicht ihren Preis nicht wert :d man das sind Zeiten^^
Ich werde abwarten und Tee trinken .Jayz hat gestern auch nochmal ein schönes Video dazu gebracht, dass hat mich in meinem Denken bestätigt. Den Preis können nur die User drücken, indem Sie den Herstellern zeigen dass sie nicht alles mit sich machen lassen.
Klingt viel zu geil, aber wäre noch geiler, wenn das stimmt (der Cache - OMG) :-)
Bei 50Stück laut Angebots-Counter wohl eher unwahrscheinlich.;)
Naja, was manche Leute hier die letzen Monate für einen GPU-Umsatz hatten, würde mich das nicht wundern ;)
Bei einer einzelnen GPU würde man leichter einen Rückläufer vermuten, als bei 50 gesammelten Rückläufern, die auf einmal angeboten werden :d
Einschweiß-Geräte und Siegel kann man auch schnwll mal für 50 Kartons bedienen
Es gibt auch TUFs die nicht nicht singen... https://imgur.com/a/FY4LT1b
Zu dem Preis mit Abstand die beste 4090er.
Ja darum Wahrscheinlichkeit!
Aber wenn ich das lese wird mir bei dem Test auch schlecht!
75 % Power Limit, begrenzt auf 118 FPS
Die Tuf ist eine Rennmaschine wer macht den Bitte sowas
Wieso hat der nicht gleich den Netzstecker gezogen.
Mann hätte auch ein Spiel nehmen können was unter 120 FPS ohne Limiter läuft mit vernünftiger Last aber das ist ja komplett in die Richtung gedengelt damit nix fiept.
Jetzt auch schon länger zu haben bei Mediamarkt die Luft scheint raus zu sein!
Ich würde bei meiner 4090 auch das Power Limit auf 70-80% setzen, damit die keine 450W säuft!
Übrigens gutes Angebot die TUF für 2089 €. Ich verfolge das ja schon länger, Asus Shop hatte die Preise mal auf die neue UVP von 2078 Euro gesetzt, paar Tage danach auf 2299 zurück, und gestern gabs neue Ware, und die gammeln nun bei denen im Shop als Verfügbar.
Glauben die, die werden die zu dem Preis noch los? Gegenüber UVP von 1859 wären das 440 Euro Aufpreis, einfach Unverschämt^^
Das tut sie schon out of the Box nahe zu gar nicht ohne das ich da was Anfasse liegt die Karte oft ehr knapp an der 400W Marke klar gibt es Ausreißer nach oben aber auch nach unten.
Aber wen ich dir zeigen will ob meine Karte fiept dann dreh ich der nicht Komplet den Hals zu mit einem Limiter und dem Powerlimit .
Zu dem bekommt man noch mehr gespart wen man undervoltet.
450W ist die Spec und in der sollte sie halt nicht Singen drüber hinaus würde ich dann sagen okay .
[/URL]
Die 4090 TUF ist mit Abstand die beste Grafikkarte die ich je hatte. Der Kühler mit Vaporchamer kann bis 600Watt abführen, aber in der Praxis funktionieren diese Karten mit maximal 350-400W ganz hervorragend.
Wenn eine erwischt hat, die auch bei 100% TDP nicht fiept, dann hat man wirklich ein Einhorn und die beste 4090 erwischt.
Aber es ist nun mal so, dass die meisten fiepen und das sehr penetrant. Auch wenn sie in mein Case gepasst hätte, hätte ich sie deswegen nicht bestellt um mir eine Binning Orgie zu ersparen.
Die Karte ist Mega gut .
Nur man muss halt Glück haben eine zu bekommen die nicht singt!
Der Kühler und Lautstärke im Silent Mode ist ein Traum.
Wen man aber das Glück nicht hat so eine Perle zu bekommen dann kann das rasselnde fiepen zur Hölle werden und den Top Kühler Komplet zu Nichte machen weil es laut wird.!
@Thunderburne Mir ist das echt ein Rätsel was du und der andere Tech Typ der schon 15 Karten ausprobiert hat eigentlich sucht? Bei 450-500 Watt luftgekühlt machen diese Karte alle etwas Lärm um die Abwärme weg zu schaufeln. Beste Karte und bester Luftkühler bei 500W klingt so: https://i.imgur.com/D2S6hW3.mp4 Wenn du die Karte forderst, wird es aufgrund der Lüfter immer lauter. Wobei ich echt mal ne Lanze für die TUF brechen muss, für 500W luftgekühlt ist dieser Kühler echt ein Brett.
Bei Cyperport gibts die NON OC für 2038 zum vorbestellen. Was haltet ihr davon. CP ist was das angeht ja eher unzuverlässig oder? ;)
Es waren 3 Master/ TUF /Strix von 15 Karten bin ich Meilen weit weg.
Die Master die am Anfang hatte bis 565 W nur mini mini gefiept aber auch nur mit dem Ohr auf der Karte zu hören und dann auch ganz leise.
Von daher ich weis das es auch ohne fiepen geht.
Da die Luft Steuerung aber Broke war hab ich sie wieder weg gegeben die konnte halt nicht das was die Strix oder Tuf konnte mit UV bei 1000RPM laufen .
Die Master hat mit 1500 RPM losgeballert was laut war.
Damals war ich noch nicht an dem Punkt gewesen wo ich bereit war auf die 2400 Euro noch einen EK für 265 Euro zu packen..
Im nach hinein hätte ich es tun sollen !
So hätte ich ruhe gehabt leider war ich zu diesem Zeitpunkt noch zu geizig da die Karte ja schon 2400 gekostet hat und ich mir gesagt habe alter sind die Luftkühler Stark wofür brauchst du da noch ne Wakü.
Ich glaube so beschreib ich das ganz gut warum es so gelaufen ist wie es ist.
Bin auch nicht der Typ der Bock hat auf Retouren aber bei diesen Preisen lasse ich mir nicht alles gefallen die TUF ging auch Direkt von Saturn zu ASUS zurück .
das ist schön für dich. ich brauch aber 120/144fps.
außerdem läuft die dx12 version des spielst OHNE RT schlechter als die DX11 version
in dx11 v1.32 habe ich die 144fps. in dx12 v4 aber nicht, bei gleichen settings und somit ohne RT.
Ja das stimmt, aber niemand zockt eigentlich ohne RT. Und 120 FPS bei Witcher 3 wohl auch nur sehr wenige. Obwohl ich einen 144 Hz Monitor habe sehe ich kein Grund bei Witcher 3 auf 144 FPS zu spielen und sinnloss Strom zu verbraten.
... denn die FE ist die Schönste, die Leiseste, die Wertstabilste, die Sparsamste und die Schnellste 4090 :o
(#insider)
Nö, die FE hat ein Jahr weniger Garantie als die meisten Customs und somit in 2 Jahren gar keine Garantie mehr. Das ist ein richtig fetter Nachteil aufm gebraucht Markt. Des Weiteren gibt es Hersteller mit z.B. mehr Anschlüssen 2xHdmi (und mehr Garantie). Auch die FE ist auch nicht die leisteste! Schnellste auch nicht...
Optik einer Graka ist 100 subjektiv und wird von jedem anders bewertet.
Immer dieses Verargumentieren der eigenen Käufe...
Ganz genau. Finde die FE ist die hässlichste Karte btw. ;)
Der größte Pluspunkt der FE ist der Preispunkt!
600W gutes PCB.
Kühler sind halt Geschmackssache!
Viele brauchen keine 600w Grill Funktion und sind mit der brachialen Leistung von 450w mehr als zufrieden
Bleibt einem dann halt überlassen in wie weit man das dann nutzt.
Dennoch der Preis ist halt heiß .
Ähnliche Themen
Antworten
6K
Aufrufe
392K
