*********************** Log Started 2023-08-18T07:31:21Z ***********************
07:31:21:******************************* libFAH ********************************
07:31:21: Date: Oct 20 2020
07:31:21: Time: 13:36:55
07:31:21: Revision: 5ca109d295a6245e2a2f590b3d0085ad5e567aeb
07:31:21: Branch: master
07:31:21: Compiler: Visual C++ 2015
07:31:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:31:21: Platform: win32 10
07:31:21: Bits: 32
07:31:21: Mode: Release
07:31:21:****************************** FAHClient ******************************
07:31:21: Version: 7.6.21
07:31:21: Author: Joseph Coffland <
joseph@cauldrondevelopment.com>
07:31:21: Copyright: 2020 foldingathome.org
07:31:21: Homepage:
https://foldingathome.org/
07:31:21: Time: 13:41:04
07:31:21: Revision: 6efbf0e138e22d3963e6a291f78dcb9c6422a278
07:31:21: Bits: 32
07:31:21: Args: --open-web-control
07:31:21: Config: C:\ProgramData\FAHClient\config.xml
07:31:21:******************************** CBang ********************************
07:31:21: Time: 11:36:18
07:31:21: Revision: 7e4ce85225d7eaeb775e87c31740181ca603de60
07:31:21: Bits: 32
07:31:21:******************************* System ********************************
07:31:21: CPU: 13th Gen Intel(R) Core(TM) i5-13500
07:31:21: CPU ID: GenuineIntel Family 6 Model 191 Stepping 2
07:31:21: CPUs: 20
07:31:21: Memory: 31.74GiB
07:31:21: Free Memory: 28.19GiB
07:31:21: Threads: WINDOWS_THREADS
07:31:21: OS Version: 6.2
07:31:21: Has Battery: false
07:31:21: On Battery: false
07:31:21: UTC Offset: 2
07:31:21: PID: 2240
07:31:21: CWD: C:\ProgramData\FAHClient
07:31:21: Win32 Service: false
07:31:21: OS: Windows 10 Enterprise
07:31:21: OS Arch: AMD64
07:31:21: GPUs: 1
07:31:21: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:9 AD102 [GeForce RTX 4090]
07:31:21: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:8.9 Driver:12.2
07:31:21:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.0 Driver:536.99
07:31:21:***********************************************************************
07:31:21:<config>
07:31:21: <!-- Folding Slot Configuration -->
07:31:21: <cause v='ALZHEIMERS'/>
07:31:21:
07:31:21: <!-- Network -->
07:31:21: <proxy v=':8080'/>
07:31:21:
07:31:21: <!-- Slot Control -->
07:31:21: <power v='full'/>
07:31:21:
07:31:21: <!-- User Information -->
07:31:21: <passkey v='*****'/>
07:31:21: <team v='240890'/>
07:31:21: <user v='weizenleiche'/>
07:31:21:
07:31:21: <!-- Folding Slots -->
07:31:21: <slot id='1' type='GPU'>
07:31:21: <paused v='true'/>
07:31:21: <pci-bus v='1'/>
07:31:21: <pci-slot v='0'/>
07:31:21: </slot>
07:31:21:</config>
07:31:21:Trying to access database...
07:31:21:Successfully acquired database lock
07:31:21:FS01:Initialized folding slot 01: gpu:1:0 AD102 [GeForce RTX 4090]
07:31:22:4:127.0.0.1:New Web session
07:31:23:5:127.0.0.1:New Web session
07:31:33:FS01:Unpaused
07:31:33:WU00:FS01:Starting
07:31:33:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 2240 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:31:33:WU00:FS01:Started FahCore on PID 15232
07:31:34:WU00:FS01:Core PID:15224
07:31:34:WU00:FS01:FahCore 0x22 started
07:31:34:WU00:FS01:0x22:*********************** Log Started 2023-08-18T07:31:34Z ***********************
07:31:34:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:31:34:WU00:FS01:0x22: Core: Core22
07:31:34:WU00:FS01:0x22: Type: 0x22
07:31:34:WU00:FS01:0x22: Version: 0.0.20
07:31:34:WU00:FS01:0x22: Author: Joseph Coffland <
07:31:34:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
07:31:34:WU00:FS01:0x22: Homepage:
07:31:34:WU00:FS01:0x22: Date: Jan 20 2022
07:31:34:WU00:FS01:0x22: Time: 01:15:36
07:31:34:WU00:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:31:34:WU00:FS01:0x22: Branch: HEAD
07:31:34:WU00:FS01:0x22: Compiler: Visual C++
07:31:34:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:31:34:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
07:31:34:WU00:FS01:0x22: Platform: win32 10
07:31:34:WU00:FS01:0x22: Bits: 64
07:31:34:WU00:FS01:0x22: Mode: Release
07:31:34:WU00:FS01:0x22:Maintainers: John Chodera <
john.chodera@choderalab.org> and Peter Eastman
07:31:34:WU00:FS01:0x22: <
peastman@stanford.edu>
07:31:34:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 15232 -checkpoint 15
07:31:34:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:31:34:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
07:31:34:WU00:FS01:0x22:************************************ libFAH ************************************
07:31:34:WU00:FS01:0x22: Time: 01:14:17
07:31:34:WU00:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:31:34:WU00:FS01:0x22:************************************ CBang *************************************
07:31:34:WU00:FS01:0x22: Time: 01:13:20
07:31:34:WU00:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:31:34:WU00:FS01:0x22:************************************ System ************************************
07:31:34:WU00:FS01:0x22: CPU: 13th Gen Intel(R) Core(TM) i5-13500
07:31:34:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 191 Stepping 2
07:31:34:WU00:FS01:0x22: CPUs: 20
07:31:34:WU00:FS01:0x22: Memory: 31.74GiB
07:31:34:WU00:FS01:0x22:Free Memory: 28.01GiB
07:31:34:WU00:FS01:0x22: Threads: WINDOWS_THREADS
07:31:34:WU00:FS01:0x22: OS Version: 6.2
07:31:34:WU00:FS01:0x22:Has Battery: false
07:31:34:WU00:FS01:0x22: On Battery: false
07:31:34:WU00:FS01:0x22: UTC Offset: 2
07:31:34:WU00:FS01:0x22: PID: 15224
07:31:34:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
07:31:34:WU00:FS01:0x22:************************************ OpenMM ************************************
07:31:34:WU00:FS01:0x22: Version: 7.7.0
07:31:34:WU00:FS01:0x22:********************************************************************************
07:31:34:WU00:FS01:0x22:Project: 18449 (Run 3, Clone 443, Gen 1159)
igital signatures verified
07:31:34:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:31:34:WU00:FS01:0x22:Version 0.0.20
07:31:34:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (2%) [50 total]
07:31:34:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:31:34:WU00:FS01:0x22: XTC frame write interval: 2500000 steps (1e+02%) [1 total]
07:31:34:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
07:31:35:WU00:FS01:0x22:There are 4 platforms available.
07:31:35:WU00:FS01:0x22:Platform 0: Reference
07:31:35:WU00:FS01:0x22:Platform 1: CPU
07:31:35:WU00:FS01:0x22:Platform 2: OpenCL
07:31:35:WU00:FS01:0x22: opencl-device 0 specified
07:31:35:WU00:FS01:0x22:Platform 3: CUDA
07:31:35:WU00:FS01:0x22: cuda-device 0 specified
07:31:41:WU00:FS01:0x22:Attempting to create CUDA context:
07:31:41:WU00:FS01:0x22: Configuring platform CUDA
07:31:43:WU00:FS01:0x22: Using CUDA and gpu 0
07:31:43:WU00:FS01:0x22:Completed 100000 out of 2500000 steps (4%)
07:32:14:WU00:FS01:0x22:Completed 125000 out of 2500000 steps (5%)
07:32:22:Saving configuration to config.xml
07:32:22:<config>
07:32:22: <!-- Folding Slot Configuration -->
07:32:22: <cause v='ALZHEIMERS'/>
07:32:22:
07:32:22: <!-- Network -->
07:32:22: <proxy v=':8080'/>
07:32:22:
07:32:22: <!-- Slot Control -->
07:32:22: <power v='full'/>
07:32:22:
07:32:22: <!-- User Information -->
07:32:22: <passkey v='*****'/>
07:32:22: <team v='240890'/>
07:32:22: <user v='weizenleiche'/>
07:32:22:
07:32:22: <!-- Folding Slots -->
07:32:22: <slot id='1' type='GPU'>
07:32:22: <pci-bus v='1'/>
07:32:22: <pci-slot v='0'/>
07:32:22: </slot>
07:32:22:</config>
07:32:46:WU00:FS01:0x22:Completed 150000 out of 2500000 steps (6%)
07:32:47:WU00:FS01:0x22:Checkpoint completed at step 150000
07:33:19:WU00:FS01:0x22:Completed 175000 out of 2500000 steps (7%)
07:33:51:WU00:FS01:0x22:Completed 200000 out of 2500000 steps (8%)
07:33:52:WU00:FS01:0x22:Checkpoint completed at step 200000
07:34:23:WU00:FS01:0x22:Completed 225000 out of 2500000 steps (9%)
07:34:55:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
07:34:55:WU00:FS01:0x22:Checkpoint completed at step 250000
07:35:26:WU00:FS01:0x22:Completed 275000 out of 2500000 steps (11%)
07:35:49:WU00:FS01:0x22:An exception occurred at step 292470: Error invoking kernel: CUDA_ERROR_ILLEGAL_ADDRESS (700)
07:35:49:WU00:FS01:0x22:ERROR:98: Attempting to restart from last good checkpoint by restarting core.
07:35:49:WU00:FS01:0x22:Folding@home Core Shutdown: CORE_RESTART
07:35:52:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
07:35:52:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
07:35:52:WU00:FS01:Starting
07:35:52:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/win/64bit/22-0.0.20/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 706 -lifeline 2240 -checkpoint 15 -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor nvidia -gpu 0 -gpu-usage 100
07:35:52:WU00:FS01:Started FahCore on PID 7956
07:35:52:WU00:FS01:Core PID:9828
07:35:52:WU00:FS01:FahCore 0x22 started
07:35:53:WU00:FS01:0x22:*********************** Log Started 2023-08-18T07:35:52Z ***********************
07:35:53:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:35:53:WU00:FS01:0x22: Core: Core22
07:35:53:WU00:FS01:0x22: Type: 0x22
07:35:53:WU00:FS01:0x22: Version: 0.0.20
07:35:53:WU00:FS01:0x22: Author: Joseph Coffland <
07:35:53:WU00:FS01:0x22: Copyright: 2020 foldingathome.org
07:35:53:WU00:FS01:0x22: Homepage:
07:35:53:WU00:FS01:0x22: Date: Jan 20 2022
07:35:53:WU00:FS01:0x22: Time: 01:15:36
07:35:53:WU00:FS01:0x22: Revision: 3f211b8a4346514edbff34e3cb1c0e0ec951373c
07:35:53:WU00:FS01:0x22: Branch: HEAD
07:35:53:WU00:FS01:0x22: Compiler: Visual C++
07:35:53:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /O2 /Zc:throwingNew /MT
07:35:53:WU00:FS01:0x22: -DOPENMM_VERSION="\"7.7.0\""
07:35:53:WU00:FS01:0x22: Platform: win32 10
07:35:53:WU00:FS01:0x22: Bits: 64
07:35:53:WU00:FS01:0x22: Mode: Release
07:35:53:WU00:FS01:0x22:Maintainers: John Chodera <
07:35:53:WU00:FS01:0x22: <
07:35:53:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 706 -lifeline 7956 -checkpoint 15
07:35:53:WU00:FS01:0x22: -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu-vendor
07:35:53:WU00:FS01:0x22: nvidia -gpu 0 -gpu-usage 100
07:35:53:WU00:FS01:0x22:************************************ libFAH ************************************
07:35:53:WU00:FS01:0x22: Time: 01:14:17
07:35:53:WU00:FS01:0x22: Revision: 9f4ad694e75c2350d4bb6b8b5b769ba27e483a2f
07:35:53:WU00:FS01:0x22:************************************ CBang *************************************
07:35:53:WU00:FS01:0x22: Time: 01:13:20
07:35:53:WU00:FS01:0x22: Revision: ab023d155b446906d55b0f6c9a1eedeea04f7a1a
07:35:53:WU00:FS01:0x22:************************************ System ************************************
07:35:53:WU00:FS01:0x22: CPU: 13th Gen Intel(R) Core(TM) i5-13500
07:35:53:WU00:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 191 Stepping 2
07:35:53:WU00:FS01:0x22: CPUs: 20
07:35:53:WU00:FS01:0x22: Memory: 31.74GiB
07:35:53:WU00:FS01:0x22:Free Memory: 27.69GiB
07:35:53:WU00:FS01:0x22: Threads: WINDOWS_THREADS
07:35:53:WU00:FS01:0x22: OS Version: 6.2
07:35:53:WU00:FS01:0x22:Has Battery: false
07:35:53:WU00:FS01:0x22: On Battery: false
07:35:53:WU00:FS01:0x22: UTC Offset: 2
07:35:53:WU00:FS01:0x22: PID: 9828
07:35:53:WU00:FS01:0x22: CWD: C:\ProgramData\FAHClient\work
07:35:53:WU00:FS01:0x22:************************************ OpenMM ************************************
07:35:53:WU00:FS01:0x22: Version: 7.7.0
07:35:53:WU00:FS01:0x22:********************************************************************************
07:35:53:WU00:FS01:0x22:Project: 18449 (Run 3, Clone 443, Gen 1159)
07:35:53:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:35:53:WU00:FS01:0x22:Version 0.0.20
07:35:53:WU00:FS01:0x22: Checkpoint write interval: 50000 steps (2%) [50 total]
07:35:53:WU00:FS01:0x22: JSON viewer frame write interval: 25000 steps (1%) [100 total]
07:35:53:WU00:FS01:0x22: XTC frame write interval: 2500000 steps (1e+02%) [1 total]
07:35:53:WU00:FS01:0x22: Global context and integrator variables write interval: disabled
07:35:53:WU00:FS01:0x22:There are 4 platforms available.
07:35:53:WU00:FS01:0x22:Platform 0: Reference
07:35:53:WU00:FS01:0x22:Platform 1: CPU
07:35:53:WU00:FS01:0x22:Platform 2: OpenCL
07:35:53:WU00:FS01:0x22: opencl-device 0 specified
07:35:53:WU00:FS01:0x22:Platform 3: CUDA
07:35:53:WU00:FS01:0x22: cuda-device 0 specified
07:36:00:WU00:FS01:0x22:Attempting to create CUDA context:
07:36:00:WU00:FS01:0x22: Configuring platform CUDA
07:36:03:WU00:FS01:0x22: Using CUDA and gpu 0
07:36:03:WU00:FS01:0x22:Completed 250000 out of 2500000 steps (10%)
