[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
das gab es damals noch nicht bei resellern und auf die verfügbarkeits-mail von corsair warte ich bis heute.. naja.. auch nicht wirklich - hatte bis eben nichtmal mehr dran gedacht, dass ich mich da eingetragen hatte. das thema ist so alt wie die karte (12.10.22)..
tobi
Hatte mein Kabel 2 Tage vor 4090 release 😁.
Naja ist wie es ist .
Die "Premium" Version mit Strümpfen ist mechanisch, und somit auch elektronisch, mist. Weil die Kontakte im 12VHPwR Steckergehäuse durch die Strümpfe nicht mehr beweglich genug bleiben.
Wenn es dir um beste elektrische Funktion geht, würde ich auf jeden Fall das einfache Kabel ohne Strümpfe bevorzugen.
Den Einfluss auf den Kontaktwiderstand beim Wackeln am Stecker, kann man am besten im HWinfo Log mit kurzen Messinterval nachvollziehen. Selbst wenn die Grafikkarte dabei nicht in den FailsaveModus schaltet, sieht man trotzdem beim Benchmarken die Schwankungen der 12V Grafikkarten-Stromversorgung-Spannung.
Aktuelle Curve Setting sind bei mir 0.950v, Core Clock im Spiel 2800 MHz verbrauch 340 Watt im Spiel max. 65 Grad in TD2
Schaut rein optisch schon richtig gut aus, die Matrix Platinum.
Allerdings ist mir ehrlich gesagt eine Karte mit Luftkühlung lieber. Das ist später leichter verkaufbar, weil die AIO Versionen doch erstmal in ein Gehäuse passen müssen (Radiator). Aber wenns passt, ists bestimmt eine tolle Karte.
Bei Asus im eBay-Shop gäbe es aktuell die TUF OC für 1.599,99 Euro im Angebot...
Das wären 200 Euro weniger als das derzeit günstigste Angebot auf Geizhals.
12VHPWR Stecker funktionieren nur nonSleeved und ohne "Knickschutz" oder Kabelabdeckung vernünftig!
Der Außendurchmesser eines AWG18 Kabels ist gegeben, und beträgt abhängig von der Oberflächestrucktur und Dicke der PVC Isolierung 1.25-1.6mm. Ein sleeved AWG18 Kabel hat mindestens 2.2mm Außendurchmesser. Und das ist in einem 12VHPWR Stecker zu viel Kabeldurchmesser, damit die BuchsenKontakte im 12VHPwR Steckergehäuse beweglich gunug bleiben. Den die BuchsenKontakte sind nicht ohne Grund etwas beweglich im Steckergehäuse gelagert. Das wird halt gern mal übersehen, weil in den größern PCIe 8pin Steckern, auch für dickere sleeved AWG18 Kabel immer noch genug Platz war.
Bei NonSleeved 12VHPwR Kabeln ohne Knickschutz und, lassen sich die Kabel auch problemlos direkt hinter dem Steckergehäuse 90° abwinkeln, ohne das die Beweglichkeit der Buchsenkontakte eingeschränkt wird. Man muss sie halt nur schon vor der Montage gewissenhaft Abwinkeln. Selbst bei den nonsleeved SeasonicKabel, mit ihrer relativ dicken PVCisolierung, braucht das Abwinkeln nichtmal 10mm Radius. Und ich kenne kaum eine Kombination(Grafikkarte/PC-Gehäuse) wo weniger als 15mm Abstand zwischen Steckergehäuse und PC-Seitenwand vorhanden ist.
Was hältst du eigentlich von:
Hab jetzt hier noch nicht allzu viel davon gelesen.
1 jahr nach release. stramm
Naja, nachdem eine 5090 noch auf sich warten lässt wie man so liest, ist der Zeitpunkt eigentlich super. Wer bisher noch nicht überzeugt ist wird vielleicht bei dem Ding zugreifen(?) Die Stückzahl müsste halt begrenzt sein.
Freu mich immer wieder wie cool die gpu mit über 3000mhz zusammen mit dem 7950x3d läuft. 100 fps lock in starfield in 2k ohne probleme.
Hab zurzeit das Gehäuse offen
Ja, wie bei meiner ARES II damals, im Alu-Koffer ... war allerdings dann auch ein Rohr bzw. Pumpenkrepierer, also wahrlich eine Limited (lifetime) Edition. :LOL:
tobi
Das echt schade hab schon 3 von Corsair gekauft zuerst zwei Schwarze und dann ein weiß gesleevtes.
Das eine hat mein Bruder bekommen für seine 4080 .
Ein schwarzes hab ich jetzt noch alles Ersatz liegen sollte Mal was sein.
Bin top zufrieden mit den Corsair Kabeln.
Hier bei CB habe ich mal einen kleinen Artikel verfasst.
Eventuell hilft es ja dem ein oder anderen beim Betrieb der Karte.
Und räumt hoffentlich mal mit dem Gerücht auf, dass PT zu senken gleich viel bewirkt wie manuelles OC/UV
Es gibt 12VHPwR Kabel mit AWG18(Standard)oder mit dickerem AWG16(OC) Kabelquerschnitt. Leider steht der verwendete Kabelquerschnitt nicht immer dabei, und Angaben über die Kupferqualität die eigentlichen Kupferlitzen findet man noch seltener. Kabellänge sollte man auch nicht ganz vernachlässigen(nicht länger als nötig ,für eine bequeme Verlegung). Daher würde ich immer nur MarkenKabel von großen NT-Herstellern kaufen. Da kann man dann auch relativ sicher sein, das die Kabelitzen einen vernünftigen Reinkupferanteil haben, und Angaben zum Kabelquerschnitt sowie Kabellänge werden idR auch veröffentlicht.
Das Kabel aus deinem Link, scheint ein NoName Kabel zu sein. Zumindest kann ich unter der angegebenen SKu:# keine eindeutigen Angaben zum Kabelquerschnitt, Länge oder Hersteller finden.
Ich benutze momentan noch den Nvidia-Pigtail-Adapter mit meinem Corsair-NT, habe aber schon das reguläre 12VHPWR-Kabel hier. Würde sich die Spannung verbessern, wenn ich das tausche? Läuft nun schon einige Monate ohne Probleme, Minimalspannung bisher knapp unter 12 V (11,8 V).
@Nastya
Kommt darauf an, was du machen willst...
Bei sehr hoher Last (jenseits 600W), ist der Spannungsabfall, je nach Kabelpeitsche/-Adapter unterschiedlich stark (org. "Quadropus" von NV top - "Zweibeiner" von Corsair flop)
Dass bei Gaming die Spannung so tief bei dir fällt, ist eher unwahrscheinlich
Bald kommt die 4090 super ti mega
Das finde ich doch ziemlich "würzig". Scheinbar gibt es bei der 301-Dievariante doch tiefgreifendere Änderungen, die insgesamt zu einer schlechteren Performance führen sollen.
Das lässt mich im Hinblick auf die Matrix etwas ins Grübeln geraten. :unsure:
@Holzmann
Ach, da musst Dir keinen Kopf machen. Der effektive Takt wird doch in GPU-Z gar nicht angezeigt.;)
Ähnliche Themen
