[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
War gerade auf der Suche nach Retro-GPUs bzw. nach GPUs mit dem kindischten "Super-Duper"-Kühler und fand das... :oops:
Ist an mir vorbei gegangen - sieht aber spannend aus :d
Oh weh oh weh. Heulboje incoming
Das erinnert mich an die wilden Zeiten (Athlon XP und der Versuch möglichst hohe FSB Raten zu erreichen). Die Kühler nebst Lüfter waren klein, die Drehzahlen waren hoch. Und das galt nicht nur für die CPU sondern damals auch für Northbridge Kühler und GPU Kühler. Ich hatte da so einige Heulbojen. Mit Grausen erinnere ich mich noch an die Töne die damals YS-Tech 6 cm Lüfter hervorgebracht haben. Oder unvergessen auch der Aconto Noise Control Silverado mit doppel Radiallüfter.
Ich wette, dass ein Teil meines heutigen unterschwelligen Tinnitus daher kommt. Nebst Discos, Kopfhörern, Motorrädern und Kettensägen.
Ich weiß nichtmal was ich mit meinem gemacht habe. Sorry. Aber ich hatte so viele Dinge, die ich hätte aufheben sollen und die irgendwie verschwunden sind.
Auch alte Wasserkühler aus den Anfängen der wilden Zeiten.
Aber immerhin: ich war dabei und ich habs erlebt. Das nimmt mir keiner
btw: so gut hat er nicht gekühlt. Scheinbar ist Kupfer auch sinnvoller als Silber für den Wärmeübergang. War in jedem Fall mein letzter Kühler bevor ich auf Wakü umgestiegen bin - und seither auch nicht mehr zurück.
Moin zusammen. Ich stelle die Frage mal hier rein - ist hier noch jemand mit einem Thermal Grizzly Wireview im Dauereinsatz? Ist das bei dem Teil normal das es nach jedem PowerDown wieder mit der xxW - Anzeige startet und somit "vergisst" welches Menü man vorher eingestellt hatte? Bzw. das Timeout -> Cycle dann immer wieder neu konfiguriert werden muss? Oder sollten diese Einstellungen gespeichert bleiben?
Ja das ist bei mir genauso. Ärgert mich auch das er sich nicht merkt was man zuletzt eingestellt hat.
Das ärgert mich tatsächlich auch. Zumal Thermal Grizzly den Cycle-Modus in der Anleitung ja sogar explizit empfiehlt für OLED-Langlebigkeit. Warum ist dies also nicht direkt die Standardeinstellung? Man hat doch keine Lust andauernd das Glas-Seitenpanel abzunehmen um da das Knöpfen zu drücken.
Ja keine Ahnung was die sich dabei gedacht haben. Ist nicht so richtig durchdacht. Habe mich aber damit abgefunden.
Ja, wäre schön, wenn man das in der festen Programmierung des WireView ändern könnte. Ein ProgrammierPort ist ja auf jeden WireView schon vorhanden. Da wäre es für Thermal Grizzly ja relativ einfach, ein Programmierkabel und ne kleine Software als Zubehör für den WireView zusätzlich an zu bieten. Meiner Meinung nach gibt es auch noch ein paar andere Verbesserungen an dem WireView, um es auch für den Dauerbetrieb zu optimieren. Bis dahin bleibt halt nur ein DIY Umbau, um das zu beheben.
Ist beim Elmor PMD USB auch so...
Würde mir wünschen, dass man auch Elmor-Produkte in DE kaufen könnte (sind viel flexibler anwendbar und immer reparabel). Stände aber in direkter Konkurenz zum Wireview
Elmor PMD ist halt recht hässlich im Vergleich zu dem schnittigen WireView.
Gibt es nicht vielleicht bei GibHub ein Projekt, das sich mit der Programmierung des Thermal Grizzly WireView beschäftigt?
@Nastya
Bei sehr hoher Last (jenseits 600W), ist der Spannungsabfall, je nach Kabelpeitsche/-Adapter unterschiedlich stark (org. "Quadropus" von NV top - "Zweibeiner" von Corsair flop)
Wie ist das gemeint?
Habe mir jetzt extra das Corsair Kabel bestellt, bevor ich das Cablemod zerschnibbel.
Wird dich wahrscheinlich nicht betreffen. Hast also alles richtig gemacht (CableMod-Kacke zerstört) :fresse:
Wenn du Lasten weit über 600W fährst, ist der Spannungsabfall beim "Zweibeiner" recht stark. Worst case kackt der Bench ab...
Das ist nur das, was ich mit meinen bescheidenen Mitteln messen konnte. Der Drop geht kurzzeitig sicher noch weiter runter
Welchen Ini Tweak?
Dieses hier ?
Sind diese Tweaks mitttlerweile immer noch nötig oder wurde das gefixt?
@Dwayne_Johnson
Hab den Faden verloren auf was war das jetzt bezogen ?
Wegen R-Bar Starfield ?
Ich hab da selbst keine Antwort bekommen wen die Frage dahin ging.
Hattest du jeden der vier Stränge des Nvidia-Adapters individuell mit einem anderen 8-Pin Anschluss des Netzteils verbunden? Oder woran liegt es, dass der Corsair-Adapter hier so schlecht wegkommt?
Mein Corsair-NT versorgt je zwei der Nvidia-Adapterbuchsen pro 8-Pin, weil ich an die untere 8-Pin-Reihe am NT wegen einem Lüfter nicht rankomme. Dürfte aber laut Corsair kein Problem sein, da ein 8-Pin jeweils bis zu 300 W liefert.
Der 4er war an jeweils einer Buchse am NT. Beim Corsair reichen ja zwei...
"Schlecht wegkommen" tut das Corsair nur bei sehr hoher Last - also weit über 600W
Asus ROG 4090 Strix Evangelion Edition gelistet:
Ich glaube, ich muss mein Farbspektrum erweitern...
Preislich hatte ich die Karte die letzte Woche irgendwo kurz bei etwa 2.189 bis 2.3XX Euro gesehen. War - glaube ich - auch auf Amazon. Kann mich nicht mehr genau erinnern. Farblich übrigens nicht so mein Ding.
Hmm, dann wird es bei mir mit dem Corsair-Adapter effektiv wohl auch nicht anders sein, wenn ich jetzt schon nur zwei 8-Pins des NT verwende statt vier einzelne wie du.
Finde ich eigentlich ganz cool, ist mal was anderes. Der Preis aber auch.
Dann lieber eine Yeston Kawaii-Edition.
Wenn man so eine Karte verkauft, ist man quasi Kunsthändler. :d
Bei den Preisen ist das der Einstieg in den Kunstmarkt.
Warte eh schon die ganze Zeit darauf, dass uns einer hier eine an die Wand genagelte oder in Epoxidharz gegossene 4090 als modernes Kunstwerk anbietet... :fresse:
Wow +1.000€ mehr nur für rot :oops:
Farbe: Ölgemälde Wissen Blechschild 6 :fresse:
Ist eine Fälschung - da steht "02" :haha:
Ähnliche Themen
