[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der ist es auch nicht, dafür ist die Karte zu teuer... 😅 Hast PM den Namen will ich (noch) nicht erwähnen...
@***** Ne, der ist das nicht. Mit "erfahren" meine ich, schon länger hier im Forum und hat viel verkauft, mit positiven Bewertungen.
@hwk Weißt du mehr, was du mir evtl. auch per PM mitteilen kannst? Das mit deinem letztem Bild mit dem Karton von der 4070 könnte passen.
@Dwayne_Johnson ROG Strix RTX 4090 OC direkt bei ARLT gekauft im Laden.
Also bevor hier spekuliert wird, das Entfernen des Aufklebers mit der S/N wurde bestätigt auf Rückfrage... es ist also nicht "normal" oder ähnliches.
Man könnte die Theorie prüfen. Auf Amazon ist gerade eine Rückläufer 4090 Strix kaufbar... Wenn da dann eine 4070 TI oder sowas drin ist... Aber das kriegst Amazon nicht erklärt. Also nicht machen.
Falls es um eine Strix geht, das habe ich auch gemacht. Einfach weil der Sticker so angebracht ist, dass er sich nach einigen Stunden unter Last von selbst "aufrollt" und das einfach Scheisse aussieht. Bzw. fällt der im vertikalen Einbau auch einfach ab. Da hat Asus bei der Strix n sehr schlechten Kleber genommen. Davon ab ist mir sowieso nicht klar wieso solche Sticker nicht generell auf der Unterseite der Karte angebracht werden.
Möchte nur sagen dass das nicht aus niederen Absichten passiert sein muss.
Die Karte war "Neu" und der Sticker wurde entfernt "weil man sie ursprünglich behalten wollte" und es ist ja jetzt offensichtlich nicht nur bei einer Karte so.
Außerdem fehlt die "Umverpackung" auf der die S/N ja auch nochmal steht sicher nicht zufällig und auch der "Innenkarton" ist sicher nicht zufällig so gewählt ("ja den Original Karton habe ich weggeworfen").
Außerdem fehlt die "Umverpackung" auf der die S/N ja auch nochmal steht sicher nicht zufällig.
Ok hatte nicht den gesamten Strang gelesen, dachte es ging um eine gebrauchte Karte. Hatte ja einige Strix und bei allen war der S/N Sticker beim ersten Auspacken an derselben Stelle.
Das ist eine Möglichkeit. Ich habe kein gutes Gefühl, zumal es sein kann, dass ich die Karte irgendwann hier im Forum weiterverkaufen möchte.
Ich weiß gerade nicht wie ich damit umgehen soll, da der Verkäufer sich nicht mehr meldet.
Wie gesagt, gehen bei der Strix auch gerne von selbst ab. Mindestens innerhalb der ersten beiden Jahre.
Aber ja, wegschmeißen sollte man ihn nicht, bei der RMA muss der wieder drauf.
Schon sehr abenteuerlich was man hier so liest, "neue" Karte ohne OVP und Seriennummer.....
Kein normaler Mensch entfernt den Aufkleber mit der SN innerhalb der Garantie, vorallem nicht bei ner fast 2000€ GPU. :fresse:
Also Lederjacke höchstpersönlich hat auf meiner FE den S/N-Kleber entfernt bevor er ihn in den Karton gepackt hat, da war einfach nie einer drauf. :unsure:
Bei der FE steht sie auf dem Karton, und der Slotblende :P
Aja k, Slotblende (was irgendwo in der Wohnung rumliegt :o), dann hat man Lederjacke einen Stein in den Weg gelegt und er kann da nicht ran. (y)
Sorry, aber das kann ich so nicht bestätigen...
Meine Strix wird von Anfang an vertikal im Benchtable, mehrmals mit bis zu 1.000W betrieben. Die BP wurde da schon mal recht warm, aber da hat sich nicht mal ansatzweise das Label abgelöst ;)
Meine wage Theorie...
Das Label wurde mal entfernt, und evtl. gegen ein "anderes" (?) Label ersetzt. Ohne "Nachhilfe" (extra Kleber drunter) kann sich so ein Label wieder ablösen. Das ist meine persönliche Erfahrung mit irgenwelchen Labels
Oder... ASUS nutzt andere Labels, die nicht so lange halten...? :unsure:
Musst Du ja auch nicht. Bei mir war es, mit mehreren Karten. ;)
Also der Kollege, der auch eine Strix ohne Seriennummer beim gleichen Verkäufer wie @mospider gekauft hat, hat zumindest sein Geld jetzt wieder bekommen, macht es zwar nur bedingt besser, weil der ganze Vorgang einfach sehr shady ist, aber immerhin...
@Dwayne_Johnson bei der MSI 4090 geh ich von nicht ordentlich gestützt und durchgehangen aus. Allein das verdrehte PCB und dazu noch die abgerissenen Pads. Das passiert doch nicht einfach so
Nichts gegen die tollen UE-Demos, aber Free-View könnte realistischer sein (wie zb in "Unrecord")
Hiervon sind wir auch noch weit entfernt :cry:
Sowas noch in UHD-VR - das wär´s...
Das N1 ist eig. ein NAS-Case...
Und coole Idee mit dem Monoblock für CPU und GPU
Das Problem mit dieser realistischen UE5 Grafik ist halt, dass Kleinigkeiten, die nicht ganz so realistisch sind, viel mehr hervorstechen. Auch weil man dazu neigt mehr nach Fehlern zu suchen. Zum Beispiel wenn die Regentropfen auf die Steinlaterne fallen, da sieht man klar ein nicht so gut animiertes Decal oder die Holzplanken, die ineinander clippen. Je höher die Immersion in der Optik, desto leichter ist sie zu brechen. Ist wohl einer der Gründe wieso man sei 2015 kaum noch was von "Präsenz" bei VR hört, weil da langsam erkannt wurde, dass das noch ein sehr langer Weg bis dahin ist und mit aktueller VR Technik nicht erreichbar ist. :d
Zum letzten Video, richtig schön kompakt und ich glaub ich muss mir doch mal Gedanken um Custom Wasserkühlung machen, wenn ich neben der 4090 noch eine zweite Karte in mein System kriegen will, was damit viel leicht realisierbar ist. Die Dicke des Luftkühlers der 4090 ist einfach Irrsinn. XD
Die Idee mit dem Monoblock ist zwar nicht neu, aber in der Kombi hab ich das, glaube ich, noch nicht gesehen
Da hätte ich auch richtig Bock drauf. Aber mit nem X3D... :)
Anscheinend will "Billet Labs" ein eigenes Case, mit dem gleichen Layout, des N1 bauen, Bin gespannt...
OMG - 834€ !!! :oops:
Linus und Jay hatte den vor paar Wochen/Monaten...
@Hoto
Was hast du mit 2x 4090 vor?
Ne, die 2. Karte wäre eine kleinere mit 16GB VRAM, ist aber nur ne Idee. KI Kram. Würde gerne den Herika Mod für Skyrim lokal laufen lassen... damit kriegt man gut VRAM weg. XD
Ähnliche Themen
Antworten
6K
Aufrufe
392K
