[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
schreibt euer Belangen im OLED-Thread weiter....
Ich finde meinen 42er auf dem Schreibtisch schon Grenzwertig und musste mich fast 2 Wochen an ihn gewöhnen (hatte am Anfang echt öfter Kopfschmerzen, trotz 1m Abstand).
Habe auch etwas bei 48CX gebraucht, aber Kopfschmerzen bekam ich keine. Mit wurde eher schwindelig beim Reiten in RDR2 :fresse:
Nackenschmerzen nach langem "statischen Zocken" mit X27 hatten nachgelassen, weil es ja nun "dynamisches Zocken" mit dem 48CX ist (Kopf geht in alle Richtungen) :d
Tja, es kommt nicht auf die Länge drauf an, sondern die Technik :bigok:
Ich habe hier von einem erfahrenen User im Forum eine 4090 gekauft, die wenige Wochen alt war und augenscheinlich ungenutzt war (alle Folien waren noch angebracht). Die Umverpackung und der Halter für die Karte haben gefehlt. Die Karte läuft wie erwartet.
Ich habe erst 1 Woche später bemerkt, dass wohl der Aufkleber für die Seriennummer entfernt wurde. Auf Nachfrage antwortet der User aktuell nicht.
Was würdet ihr denken, warum man die Seriennummer entfernt?
Die Geschichte kommt mir sehr bekannt vor 🤔
Es gibt mehrere Möglichkeiten:
- WLPaste ersetzt durch andere
- WLPads ersetzt durch andere
- Wasserblock installiert
- Aufkleber hat schon immer gefehlt
- Seriennummer unterschiedlich zur Verpackung
Bei dem Fall den ich kenne:
- Umverpackung nicht da (da würde die Seriennummer draufstehen).
- "innerer" Karton da, aber nachweislich nicht von der Karte sondern einem "kleineren" Modell der Reihe evtl. 4070 Ti.
- Aufkleber mit der Seriennummer von der Karte entfernt.
- Karte läuft aber problemlos
Kann auch Zufall sein :d
Edit: "Antworten" gab es aber
Klingt fast nach was anderes zurückschicken als man bestellt hat, oder wie?
Bei Punkt 1/2/3 entfernt man doch nicht die Seriennummer von der Backplate.
Zu Punkt 5: Die Umverpackung war nicht dabei, daher hätte man die nicht abgleichen können.
Ja, Rechnung von Amazon.
Warum?
Es könnte ja sein, dass darunter eine Schraube ist... ich kenne die Karte nicht.
Aber wenn ich darüber nachdenke, hast Du recht - meistens ist es ja dann eher ein Siegel.
Da wo die Seriennummer in der Regel aufgebracht ist, befindet sich keine Schraube (ist eine Asus 4090 Strix OC).
Der Kühler war auch noch nicht ab, wenn ich das richtig sehe. Eine Schraube hat ein Siegel.
Was ich bisher gelesen habe, gibt es keine Seriennr. bei Grafikkarten, abseits der Aufkleber.
Ich habe eine Nummer neben dem Stecker gefunden. Könnte das eine sein (die letzten 2 Zeichen habe ich unkenntlich gemacht)?
Also auch eine Strix, da ist normalerweise ein Aufkleber mit Seriennummer drauf unter dem weißen Asus Tek Aufkleber...
Kann die nächsten Stunden erstmal nicht antworten schau später nochmal rein.
was für ein Aufkleber auf der Backplate? Ich habe keinen. ....
Auf den Bildern die ich im Netz gefunden habe, war im markierten Bereich der Aufkleber mit der Seriennummer.
Wo ist der bei dir?
btw:
GPU + KI...
Würde mir wünschen, dass es mehr Standalone-Tools gibt. "Fotor" (leider web-basiert) hat eines der besten Face-Recoverys (ihr müsst "Face Unblur" wählen), welche mich teilweise echt schocken. Die 4090 könnte das locker. Manche, der Bilder sind mehr als 100 Jahre alt (links Original - rechts KI-generiert)
Nee, das hier ist die SN (langes, schwarzes Label) - Bild-Quelle "techpowerup"...
Wo ist der bei dir?
Genau da ;)
Und zur "Sicherheit" auch auf dem PCB
Sehr gut, danke für die Info.
Genau da ;)
Das ist das Bild aus dem Review oder? Leider passen die Nummern auf der Backplate und dem PCB da nicht zusammen, also entweder sind es Bilder unterschiedlicher Karten, oder das auf dem PCB ist eine andere Nummer...
PCB das sieht mir hinten eher nach der Produktnummer aus "90YV0ID0-M0NA00" (wenn auch nicht 100%) aber das müsste jemand mit einer Strix oder Strix OC bestätigen, dass sie sich unterscheiden.
Backplate:
Man kann es nicht super gut lesen, aber ich würde behaupten man erkennt, den Unterschied 😅
Abgesehen davon ist es nicht die feine Verkäuferart den Aufkleber abzuziehen und sie in einen Karton einer kleineren Karte zu quetschen, war das bei dir auch so @mospider ? (der 4090 "innen" Karton hat ein Fach unter der Karte)
Das Fach ist nicht vorhanden. Hat mich auch gewundert. Der Ausschnitt für die Karte aus Schaumstoff scheint aber original.
Auf dem inneren Karton steht auch Asus Strix und auf der Rückseite noch etwas was spanisch sein könnte.
Ja das ist wahrscheinlich der Karton einer 4070 Ti Strix (siehe Bild im Spoiler) und der Schaumstoff wurde halt mitgetauscht, damit die 4090 rein passt.... er ist auf jeden Fall zu klein :d (in der Höhe)
Ähnliche Themen
