lordberti
Experte
- AMD Ryzen 9 9950X3D
- ASUS ROG CROSSHAIR X670E EXTREME (Bios 2904)
- PHANTEKS Glacier One 360 T30 Gen2
- Corsair CMP64GX5M2B6000Z30
- ASUS TUF Gaming GeForce RTX 4090 OC
- LG OLED42C27LA
- WD SN850XBlack
- Phanteks NV7
- Seasonic PRIME TX-1600 ATX 3.1 Noctua Edition
- Windows 11 Pro Voll.
- Sonstiges
- TR AM5 Secure Frame Black
ASUS Pressemeldung: AEMP III Unterstützung für die Neuen Kingston 64GB DDR5 CUDIMM Module wenn 256 GB Installiert sind
edgeup.asus.com
Zudem:
AEMP III Unterstützung mit 256 GB für die ASUS Z890 Boards mit neuem Beta Bios 1401, jetzt auch über die jeweilige Produktseite des jeweiligen Mainboards.
rog.asus.com
AEMP III gives you a seamless experience with the new Kingston 64GB DDR5 memory modules - Edge Up
AEMP III makes sure that you can easily get Kingston's new 64GB DDR5 modules up and running -- and it provides a healthy speed boost, too.
Zudem:
1401 Beta Version
2025/01/10
Support up to 5600MT/s when running the maximum memory capacity of 256GB. The exclusive ""AEMP III"" option will appear when four Kingston RAM DDR5 6400MT/s 64GB CUDIMMs are installed.
ROG MAXIMUS Z890 HERO | Gaming motherboards|ROG - Republic of Gamers|ROG Global
The ROG Maximus Z890 Hero is ready for Advanced AI PCs. It makes builds soar with 22+1+2+2 power stages, hyper speed DDR5 support and the latest PCIe® 5.0 conne
