[Sammelthread] Abit IP45-Pro / IP45-GT3/MAX / IX48 MAX (Intel P45 /X48)
Erste Bilder der P45 / X48 Boards
The model names are IP45-MAX, IP45 and IP43 Pro, and it gives away some information about what features the different models will have. Let's start from the bottom with the IP45, as this is a very basic P45 motherboard with a single x16 PCIe 2.0 slot, two PCIe x1 slots and three PCI slots. Around the back is a single PS/2 port, six USB 2.0 ports, a Gigabit Ethernet connector, 7.1-channel audio jacks with a coaxial S/PIDF out and a CMOS reset button.
This board is limited to DDR2 800 and 1,066MHz memory, according to the specs, and it also has six SATA ports and headers for a further six USB 2.0 ports. Depending on the market, Abit has three additional models of this board, one with 10/100Mbit Ethernet, one with 5.1-channel sound and one with both. This is what is commonly known as cost down.
Next up, we have the IP43 Pro, which appears to be a better motherboard than the IP45. It has the same slot layout and the same rear I/O layout, with the addition of an optical S/PDIF out. This board features Abit's micro Guru BIOS and silent OTES chipset cooling and supports DDR2 memory up to 1,200MHz.
The IP45-MAX has a pair of x16 PCIe 2.0 slots, two PCIe x1 slots and two PCI slots. Around the back you'll find a PS/2 port, eight USB 2.0 ports, FireWire, two eSATA, 7.1-channel audio with optical and coaxial S/PDIF out, Gigabit Ethernet and a CMOS reset button. This board also has six SATA connectors, headers for a further four USB 2.0 ports and, of course, silent OTES chipset cooling and micro Guru BIOS. Finally, this board has four DDR3 memory slots with support for 1,600MHz DDR3 memory.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=7579&Itemid=1
--------------------------------------- IP45 GT3 / MAX :---------------------------------------
Abit IP45 GT3: Intel P45 DDR3-1600, ATi CrossfireX Support.
The first abit's P45 motherboards that we saw is the IP45-MAX, which has four DDR3 DIMM slots (1600/1333MHz). The rest of the specifications look typical for a P45 board, with abit including only one Gigabit Ethernet unlike some other vendors. abit does include its own patented uGuru and Silent OTES technology. However, there is no exotic cooling solution for the board besides the now common heat pipe based cooler.
Specs des IP45 MAX :
------------------------------------------- IP45 Pro : -------------------------------------------
Similar to the MAX except for its use of DDR2 instead of DDR3 memory, the IP45 Pro has a more appealing color scheme in our opinion. The feature set remains however. LGA 775 , Intel® P45 , FSB 1600 , Dual DDR2 1200 , 2x PCI-E X16 (DualX8 CrossFire) , 2 x eSATA 3Gb/s , 6 x SATA 3Gb/s RAID , IEEE1394 , abit µGuru™ Technology , abit Silent OTES™ Technology ,100% Solid Solid Capacitors ,RoHS Compliant
------------------------------------------ IX48 MAX :------------------------------------------
While it has been available already, let's not forget the X48 chipsets amidst all the P45/43 releases. Here's abit's IX48-MAX, which supports up to 4 DIMM of DDR3 1600 memory and has 2 PCIe x 16 Gen 2 slots but no CrossFireX (no dual x8). It does have abit's proprietary uGuru and OTES technologies.​
Quelle : http://www.hardwarezone.com/articles/view.php?cid=18&id=2576
Was wohl das IP 45 Pro kosten wird....
denke mal etwas mehr als das IP35 pro 120- 130€ vielleicht ?
mich interessiert der unterschied zwischen GT3 und Pro
Ob dann die "alten" X38 Boards günstiger werden? Das Abit IX38-QuadGT würde mir ja auch gut gefallen. Die Hauptsache ist DDR-2 läuft drauf.
gibts was neues zu den p45ern? Preise für mobos liefertermine etc??
hab mal bei Abit nachgefragt wann mit dem Abit ip45 zu rechnen ist. Als Aussage erhielt ich leider nur das es im 2. Quartal 08 auf den Markt kommen soll.
Michl
Sehr geehrter Herr ,
das IP45 Pro und IP45 sollte anfangs Juli im Laden verfügbar sein. Die DDR3 Variante (IP45 MAX) ein wenig später.
Kind regards
Mit freundlichem Gruss
Wouter Simon
Universal ABIT NL B.V.
Jan van Riebeeckweg 15, 5928 LG Venlo, The Netherlands
Irgendwie hat Abit nur einen Mann für deutschen Mail-Support. Seit 2002 antwortet mir immer der Wouter Simon :d
Das IP45 is zu 99% gekauft wenns zum OC taugt.
Das taugt bestimmt zum OC. Was soll denn da schon schief gehen, wenn das IP35 Pro schon eine Granate war?
Hat jemand Infos darüber, wo der Unterschied zwischen der GT3 und der MAX Version liegt?
Oder wurde da jetzt letzendlich bloß der Name geändert?
Oha, ein neuer Anwerter auf meiner Kaufliste, bin eh am überlegen soll ich mein Intel behalten und auf ein P45 uüdaten oder doch auf AMD wechseln, mhh
Hatte ich mir auch schon gedacht, hab ich auch nix dagegen einzuwenden.
Ich finde es furchtbar, wie einige Hersteller zig Versionen von einem Board rausbringen, wo jedes 2. im Prinzip dasselbe ist.
Vor allem bei Asus und Gigabyte hat man überhaupt keinen Durchblick mehr
Naja, die Boards sind bei Mix und Alternate schon seit mehreren Tagen gelistet, aber natürlich nicht verfügbar, daran ändert auch jetzt nichts der Eintrag bei Geizhals. Es wird aber jetzt langsam Zeit, mittlerweile haben wir die zweite Juliwoche!
ja abit wird leider immer langsamer .... sei es mit neuen boards oder bios support ....
Ich muss sagen mir reichts bald mitn warten und bin kurz davor ein Maximus 2 Formula zu bestellen.
Kostet zwar 60€ mehr und ich halt nicht viel von diesem ROG Zeug aber ich möchte endlich mal den neuen PC benutzen :hwluxx:
Bei xtremesystems stand sie hatten irgendwie Probleme mitn BIOS vom IP45 MAX.
Warum denn grad das Maximus? Ich warte noch die Woche und dann nehme ich das P5Q-E, was seit dem WE schonmal hier rumliegt.
Stimmt das enttäuscht mich zur Zeit auch. 190€ und dann auch net der Überflieger.
Aber von Abit immer noch nix aufn Markt :rolleyes:
Sollte aber doch wohl bald soweit sein. Ich habe beschlossen noch weiter zu warten. Wobei ich grad überlege, warum überhaupt...der wirklic Anreiz ist die uguru Software.
