[Sammelthread] Abit IP45-Pro / IP45-GT3/MAX / IX48 MAX (Intel P45 /X48)
Erste Bilder der P45 / X48 Boards
The model names are IP45-MAX, IP45 and IP43 Pro, and it gives away some information about what features the different models will have. Let's start from the bottom with the IP45, as this is a very basic P45 motherboard with a single x16 PCIe 2.0 slot, two PCIe x1 slots and three PCI slots. Around the back is a single PS/2 port, six USB 2.0 ports, a Gigabit Ethernet connector, 7.1-channel audio jacks with a coaxial S/PIDF out and a CMOS reset button.
This board is limited to DDR2 800 and 1,066MHz memory, according to the specs, and it also has six SATA ports and headers for a further six USB 2.0 ports. Depending on the market, Abit has three additional models of this board, one with 10/100Mbit Ethernet, one with 5.1-channel sound and one with both. This is what is commonly known as cost down.
Next up, we have the IP43 Pro, which appears to be a better motherboard than the IP45. It has the same slot layout and the same rear I/O layout, with the addition of an optical S/PDIF out. This board features Abit's micro Guru BIOS and silent OTES chipset cooling and supports DDR2 memory up to 1,200MHz.
The IP45-MAX has a pair of x16 PCIe 2.0 slots, two PCIe x1 slots and two PCI slots. Around the back you'll find a PS/2 port, eight USB 2.0 ports, FireWire, two eSATA, 7.1-channel audio with optical and coaxial S/PDIF out, Gigabit Ethernet and a CMOS reset button. This board also has six SATA connectors, headers for a further four USB 2.0 ports and, of course, silent OTES chipset cooling and micro Guru BIOS. Finally, this board has four DDR3 memory slots with support for 1,600MHz DDR3 memory.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=7579&Itemid=1
--------------------------------------- IP45 GT3 / MAX :---------------------------------------
Abit IP45 GT3: Intel P45 DDR3-1600, ATi CrossfireX Support.
The first abit's P45 motherboards that we saw is the IP45-MAX, which has four DDR3 DIMM slots (1600/1333MHz). The rest of the specifications look typical for a P45 board, with abit including only one Gigabit Ethernet unlike some other vendors. abit does include its own patented uGuru and Silent OTES technology. However, there is no exotic cooling solution for the board besides the now common heat pipe based cooler.
Specs des IP45 MAX :
------------------------------------------- IP45 Pro : -------------------------------------------
Similar to the MAX except for its use of DDR2 instead of DDR3 memory, the IP45 Pro has a more appealing color scheme in our opinion. The feature set remains however. LGA 775 , Intel® P45 , FSB 1600 , Dual DDR2 1200 , 2x PCI-E X16 (DualX8 CrossFire) , 2 x eSATA 3Gb/s , 6 x SATA 3Gb/s RAID , IEEE1394 , abit µGuru™ Technology , abit Silent OTES™ Technology ,100% Solid Solid Capacitors ,RoHS Compliant
------------------------------------------ IX48 MAX :------------------------------------------
While it has been available already, let's not forget the X48 chipsets amidst all the P45/43 releases. Here's abit's IX48-MAX, which supports up to 4 DIMM of DDR3 1600 memory and has 2 PCIe x 16 Gen 2 slots but no CrossFireX (no dual x8). It does have abit's proprietary uGuru and OTES technologies.​
Quelle : http://www.hardwarezone.com/articles/view.php?cid=18&id=2576
Dort heißt es: "...verfügbar im Zentrallager...". Das ist doch schon mal äußerst positiv. Dann kann man diesen Monat wohl wirklich noch mit dem IP45 Pro rechnen. Juhu! ;)
weis zufällig einer wann das GT3 kommt ?
schade hätte gern wieder nen Abit gehabt aber solang wart ich dann nicht.
Meinst du nicht, dass du mit deinem System noch warten kanns?
Ich hab auch keine Lust mehr zu warten , morgen wird zu 99% dann eben ein Asus P5Q Deluxe bestellt.
Sogar Asrock hat schon P45 Bords aufn Markt gebracht :wall:
Bist du dir mit dem Asus Board sicher? Ich habe jetzt schon etwas länger im P5Q-E Thread mitgelesen und so das gelbe vom Ei ist das Board nicht und da es ja schließlich der kleine Bruder vom Deluxe, würde ich vermuten, dass das Deluxe auch nicht so der Burner ist!
Wirklich überzeugen tut es mich auch nicht aber ich muss jetzt endlich bestellen. Der alte PC muss weg und notfalls gehts wieder zurück. DFI taugt auch noch nix, Gigabyte ist zu bunt, MSI aus Prinzip nicht mehr. Da bleibt nicht mehr viel...
Laut deiner Sig holst du es dir aber auch ?
Wieso, was ist mit meiner Sig? ;)
Ich hatte das P5Q-E hier liegen, habe es aber nicht eingebaut und nu isses wieder zurück zum Händler.
Ich hab mal bei Alternate angefragt und deren Lieferrant sagt das dauert noch ne weile.
Also mein ich mitte August ist realistich und so lang wart ich nicht.
soll ich evtl das ABIT/DFI X38 nehmen?
Habe ich Nachteile bzw Vorteile?
Willst du Crossfire nutzen ?
Ich würd nur noch X48 Bords kaufen, so groß ist der Preistunterschied nicht mehr.
Hab jetzt mal ein P5Q Deluxe bestellt.
ja .. habe nämlich auch gerade die Absage erhalten :(
Kein Plan wie lange das noch dauert, bis Abit mal was rausrückt
Also ich rate vom P5Q-E ab, auch mit neuem Bios ist nicht der bringer (vom übertaken her absolut nicht, 425 FSB ohne Spannungsanhebung ist ein Witz (machne kommen über 600 FSB, hohe Streuung), auf dem NEo 35 2 FR lief die CPu und der Rest 500 FSB), die Lüftersteurung ist kastriert etc. Da nimm lieber das MSI P45 Neo 2 oder schau mal sonst so rum. Das Asus ist echt nen schönfärber Bort, schaut man sich mal alle sin ruhe an, nö nicht kaufen. EPU ist für die KArtze, Xpress Gate auch (wer betreibt seine S-ata Platte schon im IDE Modus) Lüftersteuerung, CPU nur PWM und eine Steuerung für 3 Gehäuselüfter (mit nur 3 Einstellungen ) ist auch schrott. Ich denke die haben 2 Kanäle vom WinbondChip an zum Steuern an die Spawas geheftet und nennen das dann EPU-Chip.
Nö, ich würds nicht mehr kaufen (und ärgere mich darüber schon ein wenig das ich mich nicht 100% vorher darüber informiert habe). Mal sehen , vieleicht kommt ja bald dieses Abit rein oder das MSI.
Ja, ich habe deine Leidensgeschichte im P5Q Thread mitverfolgt. Ich habe auch lange überlegt, hatte das P5Q-E ja schon bei mir auf dem Schreibtisch (verpackt) liegen, habs aber dennoch zurückgeschickt und warte jetzt weiterhin auf das IP45 Pro. So eilig habe ich es nicht.
@Larkin: Das P5Q Deluxe hat aber einen P45 Chip und keinen X48!
@sgd02: Hast du wegem dem Pro oder dem GT3 gefragt?
Ich weiß mir reicht ein P45.
Mal gucken wie das P5Q Deluxe bei mir läuft (max FSB), notfalls gehts eben wieder zurück und ich hock wieder ohne Mainbord da :shake:
Und Abit ist schuld ;)
Wie sind die P45 Bords von Gigabyte so ? Les hier sehr wenig drüber...
So schlecht ?? Das konnte ja mein IC7-Max3 schon besser. Nach Belieben über Spannung und Temps einstellbar.
Jo wie gesagt ich denke es gibt bessere Bords für das Geld. Das P5W hatte ja noch eine vernüftigere Lüftersteuerung und zumindest mit SPeedfan konnte man gut regeln, bei weitem nicht vergleichbar die Bords.
Ich kann Dein Genöle über das ASUS P5Q-E nicht mehr lesen :-(
Welches Board ist denn besser für den Preis von 110Euro?
Das P5W-DH habe ich noch in richtig schlechter Erinnerung. Die Lüftersteuerung ist umfangreich und gut - das muss ich zugeben, aber die BIOS-Macken des Boards die ASUS nie beseitigt hat sind einfach eine Frechheit für ein 180Euro Board (z.B. dass es Minuten dauern kann, bis man im BIOS an die Lüftersteuerung kommt, oder dass nur bei 2 meiner 5 SpeicherKits die Timings manuell eingestellt werden dürfen).
Ich musste ne Weile rumprobieren, bis das P5Q-E vernünftig lief (WD-Problem), aber wie man auch bei vielen anderen sehen kann ist es TOP für 45nm dual und quadcore oc.
Der SPD Bug kam bei hohem FSB zum Tragen der Weit über den Specs lag, ab ca 360 FSB und das Bord ging aber trotzdem noch weiter und wenn man den Sammelthreat richtig gelesen hätte, wüste man auch das die lange Bootzeit sich durch das umstellen der Lüfterüberwachung auf "ignore" hätte beseitigen können. Stand ganz klar auf Seite eins und war mit einem Handgriff zu beseitigen. Stand alles im Sammelthreat und nicht erst im dritten, den ich gemacht hatte. Ein besseres Bord für 110 Euro, kann man nicht sagen, wenn man keine anderen getestet hat. Ich sag nur ich hätte für 110 Euro mehr erwartet.
Ich habe die Sammelthreads aufmerksam verfolgt und kenne den "ignore-Trick".
Allerdings sind beide angesprochenen Probleme trotz jahrelangen BIOS-Updates nie gefixt worden. IMHO ist das P5W-DH zu dem Preis absolut überhypt gewesen.
Ich bin jedenfalls auf das ABIT P45 DDR2 Board mit µGuru gespannt (deshalb lese ich hier ja mit). Hoffentlich blamiert sich ABIT nicht wieder so mit den BIOSsen...
Wieso hat Abit sich denn blamiert?
Hah, es geht aufwärts, jetzt haben die nächsten Shop das IP45 Pro gelistet und der Preis ist auch akzeptabler geworden (113,22€).
Bei der letzten Board-Generation (P35) dauerte es Monate bis die BIOSse vernünftig liefen. IIRC gab es massive Probleme mit Quad Core CPUs.
Nö, nicht wirklich. Einizges Problem bei den QCs waren die Spawas, die sehr heiß wurden. Das schränkte das OC Potenzial ein. Ansonsten gabs BIOS bedingt nur Probleme beim Umstieg auf die 45nm CPUs, die mittlerweile aber auch behoeben sind.
Ich denke, das war aber sicherlich nicht nur eine BIOS Problem. Mit der 8-phasigen Spannungsversorgung beim IP45 Pro sollten die Problem aber sicherlich nicht auftreten.
Vor allen Dingen hoffe ich, dass endlich die niedrigere VCore einstellbar sind, als beim IP35 Pro. Ich glaub, nach BIOS-Update waren es immer 1.2xx V.
neues von ABIT:
Sehr geehrter herr x,
Soweit wie ich im moment weiss werden die boards mit P45 und p43 chipsatzen in woche 34 auf dem markt erscheinen.
Danke. / Thank You / Bedankt.
please reply with former messages included,
Bitte Antworten sie mit vollem Inhalt vorheriger Nachrichten,
Met vriendelijke groet,
Mit freundlichen Grüßen,
Best Regards,
Technical Support Europe.
Das ist eine Mail direk von Abit? Und der gute Herr kann dir das nur "soweit wie er weiß" sagen, wann die Boards erscheinen?
KW 34?! *schluck* Das ist ja erst Ende August. Es war mal die Rede von KW28! Was machen die bloß so lange?
Weil ich es eigentlich einbauen wollte und mich dann aber um- bzw. gegen das P5Q entschieden hatte.
