$ffffffffff ----------------------------------------------------------------
$ffffffffff Northbridge information
$0400000000 Description : VIA KT400/600 series
$0400000001 Vendor ID : 1106 (VIA)
$0400000002 Device ID : 3189
$0400000003 AGP bus : revision 3.0
$0400000004 AGP status : enabled
$0400000005 AGP rate : 4x 8x supported, 8x selected
$0400000006 AGP SBA : hardwired, enabled
$0400000007 AGP FW : supported, enabled
$ffffffffff Display adapter information
$0000000000 Description : NVIDIA GeForce 6800 LE
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0042
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : AGP revision 3.0
$0000000005 AGP status : enabled
$0000000006 AGP rate : 4x 8x supported, 8x selected
$0000000007 AGP SBA : hardwired, enabled
$0000000008 AGP FW : supported, enabled
$0000000009 Base address 0 : de000000 (memory range)
$000000000a Base address 1 : d0000000 (memory range)
$000000000b Base address 2 : dd000000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : none
$000000000e Base address 5 : none
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : NV40 revision A1 (16x1,6vp)
$0100000001 Hardwired ID : 0042 (ROM strapped to 0042)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR (RAM configuration 06)
$0100000004 Memory amount : 131072KB
$0100000005 Core clock : 299.250MHz
$0100000006 Memory clock : 351.000MHz (702.000MHz effective)
$0100000007 Reference clock : 27.000MHz
$010000000b HW masked units : pixel 1100b, vertex 001100b
