[Sammelthread] ASRock AB350 Fatal1ty K4 | AB350 Pro 4 | AB350M Pro 4 | (AMD B350)
Sammelthread für Asrock B350 Boards
(Fatal1ty K4 Gaming , AB350 Pro 4 , AB350M Pro 4 , AB350M , AB350M-HDV)
Bilder:
- Spezifikationen:
Code:
[LIST]
[*][COLOR=#FFFFFF]Gaming Armor[/COLOR]
[B]Memory
- 15μ Gold Contact in DIMM Slots
[B]Audio
- Creative Sound Blaster™ Cinema 3[/B][/B]
[*][COLOR=#FFFFFF][B]Unique Feature[/B][/COLOR]
[B]ASRock Super Alloy
- Premium Power Choke
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
[B]ASRock Steel Slots
[B]ASRock Ultra M.2 (PCIe Gen3 x4)
[B]ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
[B]ASRock Live Update & APP Shop[/B][/B][/B][/B][/B]
[*][COLOR=#FFFFFF][B]CPU[/B][/COLOR]
[B]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 9 Power Phase design
- Supports 95W Air Cooling[/B]
[*][COLOR=#FFFFFF][B]Chipset[/B][/COLOR]
[B]- AMD Promontory B350[/B]
[*][COLOR=#FFFFFF][B]Memory[/B][/COLOR]
[B]- Dual Channel DDR4 Memory Technology
- 4 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- AMD 7[SUP]th[/SUP] Gen A-Series APUs support DDR4 2133 ECC & non-ECC, un-buffered memory[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- Max. capacity of system memory: 64GB[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Please refer to Memory Support List on ASRock's website for more information.
Please refer to below table for DDR4 UDIMM maximum frequency support.
A-Series APUs:[TABLE="class: Table, width: 979"]
[TR]
[TH="colspan: 4, align: center"]UDIMM Memory Slot[/TH]
[TH="align: center"]Frequency(MHZ)[/TH]
[/TR]
[TR]
[TH]A1[/TH]
[TH="align: center"]A2[/TH]
[TH="width: 20%, align: center"]B1[/TH]
[TH="width: 20%, align: center"]B2[/TH]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]SR[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]DR[/TD]
[TD]2133[/TD]
[/TR]
[TR]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]1866[/TD]
[/TR]
[TR]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]1866[/TD]
[/TR]
[/TABLE]
Ryzen Series CPUs:[TABLE="class: Table, width: 979"]
[TR]
[/TR]
[TR]
[TH]A1[/TH]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]SR[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]DR[/TD]
[TD]2400-2667[/TD]
[/TR]
[TR]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]2133-2400[/TD]
[/TR]
[TR]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]1866-2133[/TD]
[/TR]
[/TABLE]
SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows[SUP]®[/SUP] 32-bit OS. For Windows[SUP]®[/SUP] 64-bit OS with 64-bit CPU, there is no such limitation.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]BIOS[/B][/COLOR]
[B]- 128Mb AMI UEFI Legal BIOS with multilingual GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- DRAM Voltage multi-adjustment[/B]
[*][COLOR=#FFFFFF][B]Graphics[/B][/COLOR]
[B]- Integrated AMD Radeon™ R7/R5 Series Graphics in A-series APU
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Three graphics output options: D-Sub, DVI-D and HDMI
- Supports Triple Monitor
- Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports DVI-D with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 1920x1200 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
- Supports HDCP with DVI-D and HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with DVI-D and HDMI Ports[/B]
[*][COLOR=#FFFFFF][B]Audio[/B][/COLOR]
[B]- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- Premium Blu-ray Audio support
- Supports Surge Protection
- ELNA Audio Caps
- PCB Isolate Shielding
- Individual PCB Layers for R/L Audio Channel
- Supports Creative Sound Blaster™ Cinema 3
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]To configure 7.1 CH HD Audio, it is required to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]LAN[/B][/COLOR]
[B]- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111GR
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/B]
[*][COLOR=#FFFFFF][B]Slots[/B][/COLOR]
[B]- 1 x PCI Express 3.0 x16 Slot (PCIE2: x16 mode)[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x PCI Express 3.0 x16 Slot (PCIE4: x4 mode)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 4 x PCI Express 2.0 x1 Slots
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Supports NVMe SSD as boot disks
AMD Ryzen series CPUs support PCIE2: x16 mode
AMD 7[SUP]th[/SUP] A-Series APUs support PCIE2: x8 mode
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]AMD Ryzen series CPUs support PCIE4: x4 mode
AMD 7[SUP]th[/SUP] A-Series APUs support PCIE4: x2 mode
If M2_1 is occupied, PCIE4 will be disabled.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Storage[/B][/COLOR]
[B]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]M2_2 and SATA3_3 share lanes. If either one of them is in use, the other one will be disabled.
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]If M2_1 is occupied, PCIE4 will be disabled.
Supports ASRock U.2 Kit[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Connector[/B][/COLOR]
[B]- 1 x COM Port Header
- 1 x TPM Header
- 1 x Power LED and Speaker Header
- 1 x RGB LED Header[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 3 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector
- 1 x Front Panel Audio Connector
- 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Supports up to 12V/3A, 36W LED Strip
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]CHA_FAN2 and CHA_FAN3 can auto detect if 3-pin or 4-pin fan is in use.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Rear Panel I/O[/B][/COLOR]
[B]- 1 x PS/2 Mouse/Keyboard Port
- 1 x D-Sub Port
- 1 x DVI-D Port
- 1 x HDMI Port
- 2 x USB 2.0 Ports (Supports ESD Protection)[COLOR=red][FONT=inherit]*[/FONT][/COLOR] 1 x Fatal1ty Mouse Port (USB 2.0) is included
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 5 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Line in / Front Speaker / Microphone[/B]
[*][COLOR=#FFFFFF][B]Software and UEFI[/B][/COLOR]
[B]Software
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[B]UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]These utilities can be downloaded from ASRock Live Update & APP Shop.[/COLOR]
[/B][/B]
[*][COLOR=#FFFFFF][B]Support CD[/B][/COLOR]
[B]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/B]
[*][COLOR=#FFFFFF][B]Accessories[/B][/COLOR]
[B]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x Screws for M.2 Sockets[/B]
[*][COLOR=#FFFFFF][B]Hardware Monitor[/B][/COLOR]
[B]- CPU/Chassis temperature sensing
- CPU/Chassis Fan Tachometer
- CPU/Chassis Quiet Fan
- CPU/Chassis Fan multi-speed control
- Voltage monitoring: +12V, +5V, +3.3V, Vcore[/B]
[*][COLOR=#FFFFFF][B]Form Factor[/B][/COLOR]
[B]- ATX Form Factor: 12.0-in x 8.8-in, 30.5 cm x 22.4 cm
- Solid Capacitor design[/B]
[/LIST]
CPU Kühler Kompatibilität:
RAM Kompatibilität:
Corsair CMK32GX4M2A2400C14 Vengeance LPX 32GB
- Corsair CMK16GX4M2B3000C15 Vengeance LPX 16GB
QVL Liste von Asrock
Link zur Hersteller Seite
Preise
BIOS Versionen:
3.20:
1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes.
2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
3.With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
PS1. Windows update is available for version P3.00 or later.
3.00:
Update AGESA to 1.0.0.6a
2.60: Update AGESA to 1.0.0.6.
2.50: Update Agesa Version string "SummitPI-AM4 1.0.0.4a"
2.22: Improve ASMedia SATA port compatibility for Windows 7. (BETA Version)
2.20 : 1.Ryzen 5 ready. 2.Support DDR4 Voltage control in Ryzen Master. 3.Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup.
1.44 : Add CPU Voltage item in BIOS setup. (BETA Version)
1.43 : 1.Add DRAM timing item in OC Tweaker. 2.Add CPU Voltage item in OC Tweaker. ( BETA Version )
1.42 : 1.Improve XMP DRAM compatibility. 2.Add Simultaneous Multi-Threading(SMT) item in BIOS setup. ( BETA Version )
1.41 : Add Enable RGB LED option. ( BETA Version )
1.40 : 1.Add Instant flash function. 2.Add "CPU Frequency Multiplier Change" item.
Danke nochmal für den Tipp mit dem CT2K16G4XFD824A von Crucial!
Der ist heute bei mir angekommen und läuft aktuell mit dem 1.40- Bios bei 1,3V auf 2933 MHz mit tCL 17, der Rest steht auf Auto. Bis jetzt scheint er völlig stabil zu sein. :) - (Edit: Ne, ist nur mit ECC komplett stabil. Habe auf CL19 angehoben.) Es sieht auch ziemlich danach aus, dass ECC aktiv ist, aber der Controller von den Tools noch nicht erkannt wird.
Edit: Falls jemand die Messdaten(CPU- Temp etc.) unter Linux auslesen möchte: Dazu muss man nur das nct6775- Kernelmodul laden.
Hier ist meine /etc/modules - Datei:
Code:
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Generated by sensors-detect on Mon Mar 27 20:17:42 2017
# Chip drivers
nct6775
Nach einem Neustart müssten dann die Daten von den gängigen Tools erkannt werden. 100% darauf verlassen würde ich mich aber noch nicht ;). Die CPU- Temperatur scheint aber schon mal zu stimmen.
Code:
user@PC:~$ sensors
amdgpu-pci-0c00
Adapter: PCI adapter
fan1:        1021 RPM
temp1:        +30.0°C  (crit =  +0.0°C, hyst =  +0.0°C)
nct6779-isa-0290
Adapter: ISA adapter
Vcore:                  +0.73 V  (min =  +0.00 V, max =  +1.74 V)
in1:                    +1.29 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
AVCC:                   +3.36 V  (min =  +2.98 V, max =  +3.63 V)
+3.3V:                  +3.36 V  (min =  +2.98 V, max =  +3.63 V)
in4:                    +1.83 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in5:                    +0.95 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in6:                    +1.31 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
3VSB:                   +3.46 V  (min =  +2.98 V, max =  +3.63 V)
Vbat:                   +3.26 V  (min =  +2.70 V, max =  +3.63 V)
in9:                    +0.00 V  (min =  +0.00 V, max =  +0.00 V)
in10:                   +0.94 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in11:                   +1.07 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in12:                   +1.70 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in13:                   +0.27 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
in14:                   +1.85 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
fan1:                     0 RPM  (min =    0 RPM)
fan2:                  1967 RPM  (min =    0 RPM)
fan3:                     0 RPM  (min =    0 RPM)
fan4:                     0 RPM  (min =    0 RPM)
fan5:                     0 RPM  (min =    0 RPM)
SYSTIN:                 +29.0°C  (high =  +0.0°C, hyst =  +0.0°C)  ALARM  sensor = thermistor
CPUTIN:                 +30.5°C  (high = +80.0°C, hyst = +75.0°C)  sensor = thermistor
AUXTIN0:                +10.0°C    sensor = thermistor
AUXTIN1:                +29.0°C    sensor = thermistor
AUXTIN2:                +22.0°C    sensor = thermistor
AUXTIN3:                -28.0°C    sensor = thermistor
PCH_CHIP_CPU_MAX_TEMP:   +0.0°C
PCH_CHIP_TEMP:           +0.0°C
PCH_CPU_TEMP:            +0.0°C
PCH_MCH_TEMP:            +0.0°C
intrusion0:            OK
intrusion1:            ALARM
beep_enable:           disabled
Für das AB350 Pro4 gibt es Bios 2.2
ASRock > AB350 Pro4
1.Ryzen 5 ready.
Das Bios gefällt mir überhaupt nicht. Einige RAM- Optionen sind verschwunden und mein ECC funktioniert nicht mehr:
Code:
user@PC:~$ dmesg | grep EDAC
[    4.084818] EDAC MC: Ver: 3.0.0
[    4.090613] EDAC amd64: Node 0: DRAM ECC disabled.
Bin sofort wieder auf 1.4 zurück...
welche Optionen denn?
ECC ist mir nicht wichtig.
Die konnte ich nicht mehr finden:
Ohne ECC- Module ist das natürlich egal - aber damit wird/wurde geworben und deshalb habe ich mir das Board gekauft.
Na toll - 2.20 installiert und seitdem startet der Rechner nicht korrekt. Er startet kurz und schaltet sich dann wieder aus - in Endlosschleife. Hab auch schon CMOS-Reset versucht aber ohne Erfolg (was zu erwarten war, da das BIOS bisher nach Flash immer auf Defaults zurückgesetzt wurde, was so auch von Asrock beschrieben wird). Zum Glück kommt heute mein Taichi so dass die Ausfallzeit ziemlich gering bleibt.
Das hat mein Board bisher auch nach jedem BIOS Update gemacht. Das ging so fünf,sechs mal und dann ging der Start aber normal.
Das testet anfangs den RAM. Wenn es aber keine stabilen Settings findet, könnte es schon sein, dass es damit nicht mehr aufhört... Mit 2.20 lief mein RAM auch erst auf CL 18 statt CL17 wie davor. Aber es könnte auch daran liegen, dass ich den CPU-Multiplikator gleichzeitig etwas angehoben hatte.
möchte mir auch einen Ryzen 1700+ /1800+, aber nur mit ECC-RAM fähigen Motherboad kaufen (habe z.Z. Asrock E3V5 mit i3-6100, 16 GB DDR4 2133 ECC-RAM Kingston) als kleine NAS mit OpenMediaVault 3. Könnte das bitte einer überprüfen auf einen B350:
The Low Down on High Tech: Enabling ECC memory in Linux without BIOS support
oder kurz:
% modprobe -v amd64_edac_mod ecc_enable_override=1
To verify that the ECC was turned on run
% dmesg | grep -i edac
Das ändert leider nichts bei mir, der Treiber wird schon vorher geladen, aber die Bänke sind alle mit 0MB angezeigt. Und auch sonst sieht es eher so aus, als ob kein ECC umgesetzt wird. (Also auch bei Bios 1.40 - zwischenzeitlich zweifle ich nämlich, ob es mit einem B350 überhaupt geht.) Bei ASRock schaut der Support aktuell nach dem Problem, mehr Rückmeldung habe ich zzt. nicht.
Mittlerweile habe ich eine Rückmeldung erhalten. ASRock hat ein Bios, womit ECC wieder bei mir geht, es wird dann denke ich bei der nächsten Version wieder laufen. Mittlerweile ist auch klar, dass diese 0MB, die angezeigt werden, nicht bedeuten, dass ECC nicht geht... Es wird nur falsch erkannt, im Hintergrund ist es aber lauffähig. Bin jetzt absolut zufrieden mit meinem AB350 Pro4.
Corsair LPX runter von der QVL
Hier: Corsair Vengeance LPX schwarz DIMM Kit 16GB, DDR4-3000, CL15-17-17-35 (CMK16GX4M2B3000C15) Preisvergleich Geizhals Deutschland
In der AB350 Pro4 - QVL Liste ist er wie folgt eingetragen: DDR4__3000__8GB__Corsair__CMK16GX4M2B3000C15__SS__2pcs
Ob er tatsächlich "ohne Murren" läuft weiß ich erst ab Mittwoch oder Donnerstag.
@ Mildseven
Welchen nutzt du denn?
Der LPX Speicher ist plötzlich von der QVL Liste verschwunden. Also mieser geht es wohl nicht mehr. Zuerst auf die Liste drauf, die Leute kaufen das Zeug und dann ohne Info einfach runter.
@Henniheine: läuft der LPX bei Dir trotzdem stabil?
Kann mir hier ggf. jemand sagen, wo man am AB350 Pro4 das LLC einstellen kann?
Gibt ein neues Beta Bios
ASRock > AB350 Pro4
Klingt uninteressant
meinst du den DDR4 3000 8GB Corsair CMK16GX4M2B3000C15 SS
also heute morgen war der jedenfalls in der qvl von asrock.
btw qvl: steht das "v" in der oc-spalte eig. für "verified"? - wobei ich 3000er ram nich auch noch oc´en muss :)
Ich hab ihn nicht finden können. Wäre ja bei ASRock nicht das erste Mal - für die Bulldozer PCs wurde die Kompatibilität bei manchen Mainboards auch nachträglich entfernt...
Hab gestern mein AB350M Pro4 bekommen. Backplate ist nicht verklebt.
Kriege meine G.Skill Ripjaws F4-3200C16D-16GVK nur auf 2666MHz :( muss mal heute abend noch etwas rum probieren..
Ist es bei eurer VCore auch so, dass im Idle +0,025V mehr anliegen als eingestellt? Unter Last passt es dann.. LLC gibt es ja nicht wirklich oder? Und was bedeuten die beiden Voltages unter der VDIMM? Einmal heißt die bloß "1,8 Voltage" und die andere glaub ich VDD bei rund 1,050V?
Und wie heiß werden eure VRMs bzw. liest bei euch HWinfo dort korrekte Werte aus ? Bei mir wird immer 97 °C angezeigt.. mein Temperatursensor vom Aquaero 5 hat bei 3,9GHz@1,375V beim Primen in Large 95 °C angezeigt ?! Beim RUN mit 4GHz@1,425V hatte ich vergessen zu schauen, da ist Prime aber nach 10 min mit Blackscreen gecrasht.. da liefen aber auch nicht alle Lüfter auf voller Pulle.. denke das mir da die VRMs nen Strich durch die Rechnung machen :/
Bei mir liest die HW Info konstant 29°C aus. Wert ändert sich nicht, trotz Prime95. Scheint bei mir nicht richtig auszulesen...
Bezgl. VCore und IDLE muss ich mal im Bios nachschauen, vielleicht liegts aber auch daran:
Ryzen CPU Voltage explanation
Edit: Hat jemand eine Einstellung um den Bus Speed von 100MHz anzuheben. Kann im Bios (2.20) das nicht finden ....
Hängt wohl stark vom verwendeten RAM ab.. du hast da ja Corsair verlinkt..
Moin, moin.
Wollte/ will jetzt endlich zuschlagen, habe keine Lust mehr zu warten.
Könnt ihr mir sagen ob ich bedenkenlos das AB 350 Pro4 kaufen kann. Habe auch den berühmten Corsair Vengeance LPX schwarz DIMM Kit 16GB, DDR4-3000, CL15-17-17-35 (CMK16GX4M2B3000C15) Preisvergleich Geizhals Deutschland Corsair Speicher (16GB; ver 5.30).
Dazu wollte ich mir den R5 1600X besorgen. Bzgl. Overclocking habe ich wenig Ahnung und würde mich da langsam reinfuchsen, sobald ich alles hier habe - Rekorde werde ich aber keine aufstellen wollen ;P
Habe mit ASRock gute Erfahrungen gemacht und würde gerne dabei bleiben.
Kühler habe ich einen Noctua NH-U14S (noch ohne AM4-Montage-Kit).
Danke schon mal :)
Danke, auf den letzten Seiten war es für mich ein wenig undurchsichtig - den Ryzen habe ich gerade bestellt. Board bestell ich dann wohl heute Nacht bei Mindfactory.
Die Bastelwut ist einfach nicht mehr zu ertragen gewesen :fresse:
Halli hallo,
ich bin auf der Suche nach Leuten mit gleicher/ähnlicher Konfiguration auf diesen Thread gestoßen.
Ich und habe seit gestern einen R5 1600X, ASRock AB350 Pro und 2x8GB GSkill RAM. (F4-3200C16D-16GVKB Kit)
Aktuelles 2.20 Bios ist drauf, ich habe den RAM nach langem Probieren endlich auf 2400MHz bekommen bei CL16. -.-
Dass das XMP Profil noch nicht läuft war mir klar aber mit 2666MHz habe ich eigentlich gerechnet.
Habt ihr da Tipps oder ist einfach warten angesagt?
CL16 ist ja die Standardlatenz. Du könntest mal bis 20 oder höher probieren. Bei 1,3V brauche ich auch CL18 für 2933MHz. Da bei Dir schon 1,35V drauf sind, geht der Speicher eventuell nicht ganz so gut, aber irgendwie sollte man doch den Takt noch ein wenig steigern können, wenn aktuell die Latenz noch so niedrig ist...
Schori:
Laut G.Skill
Series Ripjaws V
Memory Type DDR4
Capacity 16GB (8GBx2)
Multi-Channel Kit Dual Channel Kit
Tested Speed 3200MHz
Tested Latency 16-18-18-38-2N
Stimmen die Timmings im Bios vom XMP ? Werte manuell mal eingestellt ? RAM Slote A2 + B2 benutzt, siehe Asrock ?
Ich habe die Timimgs auch schon auf 20 getestet allerdings nur mit 1.25V evtl. mal mehr Spannung.
@oooverclocker. Welche Timings hast du bei 2933MHz eingestellt?
@Roadi. Ja das passt. Ich kann die Command Rate allerdings nicht verstellen, die ist fest auf 1T.
Das XMP lädt er überhaupt nicht auch nicht mit anderen Taktraten.
wenn du den Speicher online gekauft hast, dann sende ihn doch zurück und kaufe einen anderen.... bevor du dich ewig damit beschäftigst. Scheint ja irgendwie nicht ok zu sein der Speicher ...
