[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Gibt ja leider nach wie vor kein OCF für AM4 :motz:, also ist das Prof. Gaming für mich das Topmodell, was wäre es denn bei dir?
Ein fail hoch drei [emoji23]
Gesendet von meinem SM-G935F mit Tapatalk
Der Aufdruck Fatality war seit Beginn der kruden Reihe - egal um welchen Hardwaretyp oder anderen PC-Krempel ging einfach nur Marketingmüll in rot/schwarz. Mehr nicht.
So habe nun auch mal wieder Zeit ein paar Zeilen zu schreiben.
@STER187, 4Stroke & reinhardrudi
Es wäre nett, wenn ihr mir die Informationen, die ich auf der ersten Seite pflege, zukommen lassen würdet (Ram, Kühler, evtl. OC). Danke schon mal im Vorraus.
R6 1600x| reinhardrudi | 4,0Ghz | 1,376V| 3 | 3,20
Hersteller Modell @ Preisvergleich | Anzahl Module x Größe | Ranks | Quelle | kompatibel | Einschränkungen / Anmerkungen
Team Group Xtreem 2 x 8GB DDR4-3600 (TXD416G3600HC18ADC01) |2 x 8GB | SR | reinhardrudi| kompatibel | Bios 3,20 2933@18-20-20-39-58 (hier fehlt noch das fein tunning)
Hersteller Modell @ Preisvergleich | Quelle | kompatibel | Einschränkungen / Anmerkungen
Alphacool Eisblock XPX CPU Deep Blackl l reinhardrudi l kompatibel l AM4 mounting Kit included
Und das hat jetzt genau was mit meiner Frage zu tun? Welches Board ist deiner Meinung nach sonst das Topmodell?
@4Stroke & reinhardrudi
Danke euch beiden, habe ich eingetragen.
Für AM4 scheinbar das Asus CH6 wenn man bei den relativ guten Ergebnissen schaut, auch wenn die UEFIs echt langsam daherkommen.
Das Taichi ist gut, aber eben nicht das, was ich so erwartet habe bei dem Premiumpreis. Da hab ich mir in jeder Hinsicht bei OC und Ram etc. mehr erwartet. Auch beim UEFI erwarte ich da nach wie vor mehr.
Also Bootvoltage für den Ram, noch 3-4 Settings die das CH6 hat und die scheinbar echt was bringen. Da muss ich nochmal nachgucken was das alles war.
Mein absoluter Kritikpunkt am Taichi ist das UEFI und sein Layout selbst. Ich hab selten so eine zugemüllte Oberfläche gesehen die, nicht nur durch das Hintergrundbild in schwarz-weiss und ebenso schwarz-weisser Schrift, extrem unruhig und altbacken wirkt. Dazu verschachtelte Menüs die über mehrere Punkte zugänglich sind ( Ram Timings und paar andere ) - sowas geht einfach nicht. 1 (!) Anwahlpunkt für ein Menü und gut. Als Neuling oder Wechsler von Intel auf AM4 wundert man sich oft genug zu Beginn wo man gern testet und rumstellt, dass man in dem Menü doch schon war - zack ist man auf anderem Weg wieder dort.
Von allem Mainboard die ich bisher im Leben hatte, hat das Taichi echt das schlechteste und unintuitivste UEFI.
Rein technisch betrachtet scheint mir das Taichi dagegen das Topmodell zu sein - bisher 0 Probleme mit Agesa 1.0.0.6.
Dazu funktionieren auch alle anderen Sachen tadellos. Beim WLAN bin ich mir unsicher obs an der Karte oder hier am Haus liegt, aber da geht deutlich mehr mit potenteren Intel-WiFi-Modulen für den verwendeten Slot.
Die einzige Sache im die mir hart aufn Keks geht, ist der Umstand, dass ich bei absoluter Volllast auf einem Kern ( richtig 100% ) das ganze System für 1-2s komplett freezt mit weiterlaufendem Ton ( falls Musik oder Stream rennt ) und dann gehts weiter als wäre nichts. Das passiert genau ein Mal nach jedem Start / Neustart und dann im laufenden Betrieb nicht mehr. SSDs sind nicht das Problem, Ram auch nicht, GPU auch nicht. Kabel schon getauscht zwischen Taichi und SSDs etc. - selbst die alten Treiber nochmal getestet. Kam von heute auf morgen mal vor, seit dem hab ich das.
Das kenn ich von Intel einfach garnicht. Ich versteh auch nicht, was da passiert. Das Ereignislog etc. zeigt auch nichts an, HWiNFO auch nicht - keine WHEA Fehler oder was auch immer. Kurios.
Die einzige Sache im die mir hart aufn Keks geht, ist der Umstand, dass ich bei absoluter Volllast auf einem Kern ( richtig 100% ) das ganze System für 1-2s komplett freezt mit weiterlaufendem Ton ( falls Musik oder Stream rennt ) und dann gehts weiter als wäre nichts. Das passiert genau ein Mal nach jedem Start / .
servus
das hatte ich auch- hat mich so tierisch genervt ,daß ich mein system neu auf eine andere SSD installierte- und siehe da-- alles gut!! warum?-- weiß ich nicht.
-- und das mit dem UEFI,da geb ich dir vollkommen recht.!
gruß
@ darkpope:
mein RAM: F4-3200C14D-16GTZSW (G.Skill Trident Z silber/weisterreich)
Grundsätzlich kompatibel - B-DIE / Single Side
@ ALL:
Irgendwie kommt es mir so vor als ob das Taichi noch grobe Probleme mit V.3.20 hat was RAM betrifft.
hier eine kurze Zusammenfassung.
- XMP lief ohne Probleme wenn Rest auf Default (Erstinstallation direkt mit Bios 3.20, Windows neu)
- bei den Versuchen die CPU zu übertakten auch wenn RAM auf Default kamen merkwürdige Fehlercodes (78 z.B.)
- Beim Herantasten an Max CPU Takt und RAM Takt kam ich auf einen gemeinsamen Nenner dachte ich. (CPU @ 3900 RAM 3200 XMP)
Dabei habe ich den CPU Takt erhöht bei Default Vcore / stable - danach den RAM -- war bei allen Stresstests stabil
- schon während des Test immer wieder den Cold-Boot bug gehabt (F9) und gedacht, dass ich nun einen stabilen OC habe
- der OC lief dann einige Tage bis die Cold-Boot Bugs mit F9 wieder auftraten
- das besondere dabei: Es war mir nicht mehr möglich @ Default und @ XMP den Fehler wegzubekommen, was eigentlich ja stabil war
- nun habe ich es wieder geschafft den CBB wegzubekommen...aber wer weiß wie lange
Also was das Brett beim Booten macht frage ich mich :fresse: einerseits glaube ich, dass das Brett bei Ramwerten die auf Default sind den größtmöglichen Blödsinn reinschreibt und beim Booten zu wenig Spannung ansetzt (welche ist nur die Frage)
Auch ist es ein Ding der Unmöglichkeit die XMP Werte manuell einzutragen und zu booten - F9
mit XMP geht es "meist"....bis eben mal wieder die Probleme auftauchen.
Was das Bios Layout betrifft stimm ich zu.. allein, dass man keine Multiplikatoren einträgt oder eben die Doppelte Ram Konfig-Seite
glaube mir hilft nur ein neues Bios sonst verliere ich noch die Nerven..
LG
Hallo darkpope,
die 4.099 GHz waren nur benchstable, hier noch was greifbares, alltagstaugliches mit Bios 3.1: (man verzeihe den Doppelpost)
Testrubrik | Kernanzahl
CPU Takt | V-Core | NB Takt | VDDSOC | V-Dimm | V-PLL | V-DDP | Stepping | reale Coretemp (ohne Offset) | Testzeit | CPU | Kühlung | Speichermenge | Rank | Speichername | Nickname | Verlinkung
Prime95 Large FFTs | Hexacore
3900.00 | 1.256 | 1666.3 | 1.0125 | 1.360 |1.833| 0.928 | UA 1723 PGT | 54° | >6h | R5 1600X | Lukü | 16GB | dual | G.Skill F4-3200CL14D-16GTZ | 4-Stroke | Link
Gruß Roland
@ 4Stroke: wie machst du das nur? unser Setup ist sehr ähnlich :wall:
Ich hab jetzt langsam die Schnauze voll von dem Board, jede Woche hab ich irgendeinen anderen Mist der nicht geht.
Von gestern auf heute hat mein Board jetzt beschlossen vor dem Windows Boot nicht mehr nötig zu haben jegliche Anschlüsse am I/O hinten oder vorne zu initialisieren --> komme nicht ins Bios.
In Windows selbst läuft dann alles problemlos, dann dachte ich mir ok, gehe ich über den erweiterten Start ins Bios, aber denkste: das Board springt da einfach drüber und bootet sofort wieder ins Windows.
CMOS Reset bringt nichts, ich könnt grad kotzen. Wenn das nicht besser wird schmeiß ich das Teil raus und kauf mir ein C6H, da gibts inzwischen anscheinend keine Probleme mehr mit sowas trivialem.
@immortuos
Das klingt nicht gerade positiv, aber auch negative Infos helfen weiter. ;)
Das C6H wird dich dann aber allein mit den einstell Möglichkeiten "erschlagen".
Wenn Englisch für dich kein Problem ist, sollte das kein Problem sein.
Ich habe die Sprache im UEFI auf Englisch, deutsch versteht da keine(r).
Die Möglichkeiten im ASRock UEFI sind auch nicht übersichtlicher. Wie HW-Mann schon beschrieben hat ist das das reinste Labyrinth. Auch die Zeit bis zum POST ist nach wie vor eine riesige Baustelle, in der Zeit hat mein olles 2600k System schon längst ins Windows gebootet, da ist mein AM4 System noch nichtmal beim POST fertig.
Naja für mich sinds auch die Kleinigkeiten und sowas eben, weshalb ich gerade ersthaft überlege das alte i5 3570k System wieder ins Leben zu holen und zu schauen obs bei 1:1 Vergleichen brauchbar ist.
Allein die Freezes nerven hart - allein deswegen würde ich das Ding versetzen.
Im UEFI gibt es im Reiter "Systemstart" die Option "CSM Kompatibilitätsunterstützung".
Sofern ihr zumindest Win10 habt...deaktiviert den Mist!! System startet viel schneller, und es staretet überhaubt! Die Option unwissend auf "aktiviert" war bei mir Ursache für extem merkwürdiges, oc-instabiles und willkürliches Verhalten wie von einem Start auf den anderen ohne andere settings dann Boot-Schleife, gar nicht booten mit Black Screen, usw..
ash
Stop stop stop!
Mit CSM auf AUS startet das System teilweise garnicht, weils die Hardware nicht hergibts.
CSM hat auch keine Auswirkung auf OC - wieso auch.
1. Muss man CSM vor der Win 10 Installation auf DISABLED stellen - nachträglich geht das nicht. Dann bootet da garnichts mehr.
2. Kommts wie gesagt auf die Resthardware an. Schalte ich CSM aus, bekomme ich nichtmal mehr ein Bild.
Woran das liegt? Weil die meisten Grafikkarten IMMERNOCH kein UEFI GOP unterstützen und somit "ultrafast boot" nicht funktioniert.
Heißt also:
1. GPU beherrscht kein UEFI GOP -> kein ultrafast boot -> kein CSM disabled sinnvoll / nutzbar
2. GPU beherrscht UEFI GOP -> ultrafast boot nutzbar, WENN -> VOR der Win 10 Installation CSM disabled gesetzt wird, dann Windows auf eine bestimmte Art und Weise installiert wird - nicht Standard!
Desweitere -> Win 10 -> Task Manager -> AUTOSTART Tab -> oben rechts steht die Bios Time -> Was steht da bei euch?
Bei mir cremige 12s. Ich hab 14-15s vom Startknopf bis Windows im Loginscreen ist. Passt. Und nehme ich Memory Training raus, bin ich noch weiter drunter.
Danke für den Hinweis, werde ich morgen gleich mal anschauen.
Nach wie vor fehlt mir eine ausführlichere Dokumentation zum AM4 Bios von ASRock, zu 95% der Einstellungen gibt es keine (ausreichende) Erklärung, da könnte man sie sich gleich sparen. Ziemlich schade dass da auch knapp 8 Monate nach Release immer noch nichts voran geht, man kommt sich als AM4 Käufer doch leicht verarscht vor.
Die Frage verstehe ich jetzt nicht ganz, ich stell was ein und lote die Grenzen aus bis er crasht, dann gibts wieder ein weng mehr Futter so dass die Kiste den Anforderungen genügt. Vom 3.20er Bios bin ich zurück auf 3.10 (ursprünglich 2.20 glaub ich) das scheint mir weniger Coldbootprobleme zu bereiten als das 3.20er, kann aber auch sein dass sich meine B-Dies mit 60Ohm wohler fühlen wie mit den empfohlenen 53.3Ohm. Allerdings zickt das 3.10er mehr mit den Lüftern rum, vor allem wenn man sie mit A-Tuning einstellt, vornehmlich die ohne PWM und das sind die 200ter bzw 230er die jetzt per Silentkabel ruhig gestellt wurden. Vielleicht und hoffentlich vereint das nächste Bios das beste aus zwei Welten :rolleyes:
ps:
Bios Zeit 12.4s
@ 4Stroke: genau solche Details wollte ich hören ;)
Daher hast du den Widerstand beim RAM extra eingestellt. -> das könnte ich auch testen
Oder eben Bios 3.10 probieren. (da alles mit Wasser gekühlt wird sind mir die Lüfterregelungen über das Brett egal ;) )
Denn wie du meinen Posts vielleicht entnimmst, komme ich auf keinen grünen Zweig wenn es um OC bei AM4 geht.
Der RAM ist zu 99% Schuld bei mir und ich bin noch nicht drauf gekommen wie ich ihn stabil bekomme.
(btw. gecrashed is sogar bei allen meinen Stresstests nichts - nur beim Booten scheißts mir rein mit F9)
LG
Wenn ich das mache bekomme ich in Windows reproduzierbar alle paar Minuten/halbe Stunde nen blauen mit "unexpected kernel mode trap".
Momentan hab ich zu meiner großen Freude das Problem mit der Unmöglichkeit des Bios Starts gelöst (und habe dazu genau nichts getan, ging einfach von gestern auf heute, so wie es von vorgestern auf gestern nicht ging :stupid:), jetzt habe ich dafür wieder Spaß mit der bescheuerten Lüftersteuerung.
Permanent 100% auf beiden 800 rpm Eloops, ignoriert sämtliche Einstellungen, scheißegal ob ich auf DC oder PWM schalte, ob 50% oder 100%, ob silent oder Standard, einfach stur 100%.
Ich liebe dieses Board, das teuerste und mit Abstand das zickigste das ich je hatte :wut:
Edit: grade mal mit der Hoffnung auf Besserung Fan Tuning für die beiden Eloops durchlaufen lassen. Ergebnis:
2 baugleiche Lüfter, beide laufen bei ~350 rpm an. Was sagt das Board? Fan1: braucht 26% zum Start, Fan2: 65% für den Start. Dankeschön für diesen Bullshit.
Hallo darkpope,
Gruß Roland
Danke Roland, habe ich nachgebessert.
Ein habe ähnliches Problem mit beiden CPU-Lüftern, der eine dreht minimal 1000Rpm, derander passt sich der Temperatur an, und das obwohl beide gleich sind.
LG
Ram Einstellungen sind ziemlich zeitintensiv wenn man so wie ich anfangs ziemlich planlos rangeht und auch das Board zumindest fragwürdige Timings einstellt.
Was mir geholfen hat ist z.B. Ryzen DRAM Calculator da hat man schon mal ne brauchbare Basis um auch an den anderen Schrauben drehen zu können. Ein bisschen mehr Soc bzw Pll-Spannung soll auch den Coldstartbug etwas mildern.
hier mal ein Srceen mit Ryzen Dram Calculator und Timing Checker mit meinen momentan "coldbootfesten" settings, fast so schnell wie mäßig optimierte 3466er, die allerdings sehr viel mehr Saft brauchen:
@ 4Stroke: danke für den Tipp mit dem Calculator!
Muss ich mir noch ansehen, kann aber bestimmt jeder hier brauchen.
hatte an dem Tag von meinem Post mit den Ohm getestet... tada rennt ;) wär ich nie draufgekommen..
Denk mit dem Calculator komm ich noch weiter..
zur Zeit 3.95 GHz @ ca. load 1.37 / RAM @ 3200 16/15/15/15/39 1T; 1,35; 60 Ohm
daher großen Dank an dich! an dem Tag hatte ich auch meinen ersten Blauen :drool: (wie ich mich gefreut hatte über einen interpretierbaren Error)
LG
Crucial CT16G4WFD824A | 1 x 16GB ECC | DR | Bios 3.10 | @2400 CL17
übertakten nicht getestet. System läuft mit vier Einzelmodulen davon (seitdem ich mal wegen einem defekten Modul das komplette Kit wegen Garantie einschicken durfte und ohne Ram dastand, kaufe ich keine Ram-Kits mehr)
das wird auch das Beste sein, wenn mann hier so mitliest.
Kauft euch Speicher, die für AMD freigegeben sind und denkt daran, dass nicht immer das Board schuld hat, sondern auch vieles gütenmäßig von der CPU im OC her kommt oder einiges falsch oder übertrieben eingestellt wird :/
Ich kann diese Probleme einiger nicht nachvollziehen und ich mache nicht wenige OC-Kits ;)
Was den ,,Cold-Bug" stark reduzieren kann, wenn man die ProcODT selber festlegt. Seitdem laufen DDR-3200 im DR sehr gut und es startet endlich ohne Probleme. Okay, der Austauschprozessor brauchte auch Vorteile.
Tjoar ... mit der neuen CPU ists dann aber wieder unklar, obs an der CPU maßgeblich lag oder an der ProcODT.
Diese von AUTO 53,3 Ohm auf manuelle 53,3 Ohm zu stellen, bewirkt bei mir garnichts.
Nur langsam nerven die Systemfreezes hart.
Die 53.3Ohm ProcODT sind bei den B-dies wie mir scheint auch nicht in Stein gemeißelt, der Autor von Ryzen Dram Calculator empfieht alternativ 48 oder 60 Ohm, ich erweitere (für mich) sogar auf 68.3 Ohm die es momentan tun.
Auch im Termination (RTT_PARK) bzw CAD_Busblock gibt es noch einige zig Variationen zum testen. Freezes sind mir fremd, wenns beim Boot keinen BS gibt läuft er auch zu 90% stabil, die restlichen 10% wenn AIDA64 oder Prime95 noch ein Quentchen Saft fehlt.
