[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Seit gestern das 5.1 drauf. Keine Probleme beim Flashen. Vorher Cmos und zurücksetzen und nach dem Flashen das Komplette Programm mit Batterie raus etc.
XFR geht nun bei mir, keine Probleme bis jetzt beim Ram (Samsung B 3200@Fast) Für mehr muss ich wohl mal im Speicherthreat nachfragen, da alles höher als 3200 irgendwann in Karhu aussteigt..(War aber schon immer so)
Keine F9 Fehler beim Booten. Die letzten 2 Biose die ich genutzt hatte, waren Beta´s (3.20a und 4.81)
Manuelles CPU Oc funktioniert auch gut. Teste grad 4.2Ghz mit 1,319v (unter Last) Sieht aber gut bis jetzt aus.
Das erste offizielle Bios das mir gefällt. :)
hmm-- warum wird mein RAM im Bios als corsair venegance LPX erkannt und nicht als ballistix?? wenn ich das profil anklicke geht sogut wie nix...
wenn ich XFR aktiviere startet er nimmer...
bios default schon 3x gemacht..
Hmm, ich habe auch den FlareX Ram und auch bei mir wird dieses Profil angezeigt. ^^ Ist denke mal nicht so gewollt.
Nutze aber Dram Calc, 3200@fast.
Wenn du XFR aktivierst stell noch bei Spannung nen Offset von -0,0500 ein. Ich glaub der nimmt sonst automatisch -0,1000 . Das schafft meiner auch nicht.
LLC 4
@Jz
Bis jetzt Top. Danke :d
Irgendwie braucht mein 2700x nun weniger Saft. Bin nu bei zu testen 4.2Ghz mit 1.325 LLc3 ergibt 1.281-288v unter Last (prime 8k/1344k)
Gibts irgendwo ne Liste hex?code Spannung/Takt um das in CBS zu nutzen?
Danke für die Tabelle. Aber was wären die Hex für alles ab 4Ghz?
Grad als ich schreiben wollte gabs nen Freeze. Mal ne Spa stufe höher nehmen.
Dabei konnte ich aber gleich mal nen Foto machen von dem Ram Profile das angezeigt wird.
Normal hätte ich F4-3200C14D-16GFX
Was ist denn da unklar ? So sollte es sein, entweder als Auswahl das XMP Profil für spezielle Samsung Chips mit der Version 4.31 oder eben Auto für alle anderen Speicher ;)
Das dieses Ram Profile nicht passt ist mir auch klar. :)
Nur halt weil Reinhard schrieb das es nicht geht.
Ah, vielen Dank.
also ich finds verwirrend--sorry.
schreib doch einfach Samsung Speicher v4.31 da rein und nicht sowas. dann hätteich sofort bescheid gewußt,
woher soll man das wissen. hab echt gedacht das das board meinen ram verkehrt erkennt,oder ähnliches...
@ Devil THX für den tipp mit XFR Spannung. wird ich testen.
EDIT:
XFR funzt mit dem offset tipp :love:
Ist ja echt still hier.
Also nach ein paar tagen Test muss ich sagen das ich sehr zufrieden bin. Gibt aber bis jetzt 2 Sachen die mich Stören. Dazu Später
Ram oc ist mit dem 5.1 und dem AGESA1.0.0.6 top.
Bin Grad hier bei
Screenshot (115).png der 2700x läuft mit XFR und Ram 3533Mhz@cl14^^
Nun was mich stört
1.Kein Teiler vorhanden für 3533Mhz Ram
Daher musste ich das über den BCLK machen(102Mhz)
Da klafft ne Lücke zwischen 3466 und 3600Mhz
2.Wenn ich die CPU manuell übertakte (AMD CBS xxx auf manuell) und dann wieder zurück auf AMD CBS gehe behält er den Manuell eingegeben Takt bei. Ich muss erst in die Zen Optionen und STate 6 und 7?(weiß ich grad nicht aus dem Kopf) von Custum wieder auf Auto stellen.
Bei Manuell ändert er nämlich State 6 u 7 auf manuell mit den Werten.
Grüße
So kann man es auch sehen. Dachte eher ruhig=Tot^^
@Devil
Was geht denn nicht ?
1.) Ram Multis sind in Arbeit
2.) F9 = Default
Nix=Tot ;)
Bin Grad hier bei
Anhang anzeigen 454702 der 2700x läuft mit XFR und Ram 3533Mhz@cl14^^
Nun was mich stört
Grüße
Hast du bei dir eigentlich bei XFR mit minus offset gearbeitet ?
Bei meinem x370 Professional Gaming haut das Board mal locker 1.48V auf die CPU weswegen ich lieber über P-Stats OC gehe.
Da mir nach einem halben Jahr die CPU kaputt gegangen ist nutze ich lieber wieder manuelles OC. Was nicht heißen soll das das Mainboard Schuld ist aber sicher ist sicher.
@Gumril
Ja hab ein -0.05 offset. Bin mir unschlüssig ob ich xfr an lasse oder manuell wieder auf 4.2Ghz gehe, lief ja mit moderater Spannung.
@JZ
Naja, default laden wäre übertrieben. Ist halt nur der Umstand das beim zurücksetzen von Manuell auf AMD CBS die gemachten Einstellungen nicht wieder auf Auto in den Zenstates setzt, sondern auf Custum lässt.
Mit den Ram multis wäre natürlich eine feine Sache. :) Schon einen Termin dafür? :d
Mit BCLK komm ich nicht klar. Oder besser gesagt irgendeine Komponente.
Also ist bis jetzt das letzte was ich stabil betreiben kann 3466Mhz. Trotsdem nen schönes Ergebniss.
Hallo zusammen!
Ich nutze jetzt seit ca. einer Woche ein ASRock x470 Taichi Mainboard, zusammen mit einem Ryzen 7 1800X und 16 GB PC3200 GSkill Flare X DDR4-RAM (Samsung B-Die Chips). Zuvor kam bereits seit 1,5 Jahren ein ASRock x370 Gaming K4 Mainboard zum Einsatz. Wechselgrund war die bestehende RAM-Poblematik bei diesem Board was Speicherfrequenzen oberhalb von 2933 MHz betrifft.
Da es für das x470 Tachi keinen eigenen Mainboard-Thread zu geben scheint (bis auf einen Test-Artikel) möchte ich hier kurz über vorhandene Fehler in der aktuellen UEFI-Version P2.00 (mit AMD AGESA Pinnacle-PI 1.0.0.6) berichten:
1. Die CPU LLC (Load Line Calibration) ist in der Standardeinstellung (Level 5) vermutlich fehlerhaft umgesetzt. Dies führt dazu, dass mein Ryzen 7 1800X unter Prime95-Dauerlast nicht mehr konstand auf 3,7 GHz taktet, sondern den Takt auf bis zu ca. 3,575 GHz absenkt. Mir ist dahingehend aufgefallen, dass die CPU VID dann fälschlicherweise mit 1,2750 Volt (anstatt richtigerweise 1,3500 Volt) eingestellt wird. Stelle ich dann händisch die CPU LLC auf Level 4 funktioniert wieder alles ordnungsgemäß. Dies sollte jedoch auch in der Standardeinstellung "Auto" richtig funktionieren.
2. In der Lüftersteuerung für den "CHA_Fan3" scheint die PWM-/DC-Erkennung fehlerhaft umgesetzt zu sein. Ich nutze insgesamt drei be quiet Silent Wings 3 Gehäuselüfter und einen NH-U14S CPU-Kühler von Noctua. Alle Lüfter sind PWM-gesteuert. Der an CHA_Fan3 angeschlossene Gehäuselüfter regelt jedoch in den Control Mode Einstellungen "Auto" und "PWM" auf volle Drehzahl hoch (allerdings erst nach Abschluss der UEFI-Initialisierung), obwohl ein benutzerdefiniertes Lüfterprofil einstellt worden ist. Stelle ich dann auf den eigentlich falschen DC-Modus um, scheint die Regelung soweit ordnungsgemäß zu funktionieren. Nach meinen Tests scheint dies auch bislang ausschließlich den CHA_Fan3-Anschluss zu betreffen.
Allgemein scheint mir die Lüftersteuerung auch nicht so umgesetzt wie beim ASRrock x370 Gaming K4 (mit gleicher AGESA Pinnacle-PI 1.0.0.6) bzw. der Regelbereich in irgendeinern Form eingeschränkt zu sein.
Beispiel: Mein benutzerdefiniertes Lüfterprofil sieht ab einer CPU-Temperatur (Tdie) von 70°C volle Drehzahl (ca. 1300 U/min) vor. Jetzt liegen aber max. ca. 900 U/min bei ca. 75°C (Tdie) CPU-Temp an. Und dies über einen längeren Zeitraum. Ich hatte zuerst den Verdacht, dass der Temp-Verlauf zur Lüftersteuerung in irgendeinerweise gemittelt bzw. geglättet wird.
3. Die jeweils eingestellte DRAM-Spannung wird immer um jeweils um 0,02 Volt zu hoch eingeregelt (ausgelsen mit AIDA64 und HWInfo64). Da ich meinen GSkill FlareX 3200 RAM nunmehr stabil mit 3400 Mhz DDR betreiben kann und hierbei eine tatsächliche Spannung von ca. 1,432 Volt anliegt (im UEFI-eingestellt sind: 1,415 Volt) wäre eine saubere Regelung bei einem absoluten High-End AM4-Premium Mainboard schon sehr wünschenswert.
4. Es handelt sich zwar nicht direkt um einen Fehler, aber die Bootzeiten sind bei diesem Board teilweise deutlich länger - ca. 4-5 Sekunden;) - wie bei meinem bisherigen x370 Gaming K4. Und ich habe bereits den WLan Controller im UEFI deaktiviert. Dies wurde auch bereits in dem hier von Hardwareluxx durchgeführten Testvergleich zwischen ASRock X470 Taichi und dem Taichi Ultimate bemängelt. Demnach war bei dem "einfacheren" Tachi eine ca. 3 Sekunden längere Bootzeit im Vergleich zum Taichi Ultimate zu beobachten. Bei meinem vorherigen ASRock Mobo hatte ich eine Bootzeit (Windows Task-Manger) von 5,9 Sekunden:love:, jetzt nurmehr ca. 10 Sekunden:( Es wäre doch sehr begrüßenswert, wenn ASrock dahingehend noch ein bisschen optimieren würde.
@JZ
Vielleicht könntest du die vorhandenen Fehler direkt auf dem kurzen Dienstweg an ASRock melden. Vielen Dank im Voraus!
StarTrokus
1. Höre ich das erste Mal von - CPU abhängig - eben dynamisch - stell doch nach Bedarf ein
2. Ist mir bekannt (siehe weiter unten)
3. Digital und analog - Man(n) muss Digitalschritte von 8 mit einbeziehen und die DRAM-Loadline - Siehe im BIOS bei H/W Monitor
4. BIOSe vom Taichi und Taichi Ultimate sind identisch - Puh, 10 Sek. ist doch viel Wartezeit - Das X370 Gaming K4 hat weniger inialisierbare Teile
There are totally 8 FAN Connector on this board, 2 CPU fan and 6 chassis fan.
But we mount two different super IO chip to monitor CPU temperature.
Base on super IO chip specification, each chip can only support 5 connector maximum.
So CPU fan1, fan2, chassis fan1~3 belongs to one chip; and chassis fan4~6 belongs to another.
However, due to the super IO chip temperature sensor is not reading the same location and also different method.
One is inside the CPU socket and reading PECI; but another one is in the back of the CPU and reading thermistor.
So the CPU temperature will not get the same value so that the fan speed will not be the same.
If customer would like to get the same fan speed, please install fan which belongs to the same super IO fan connector.
Hallo JZ,
ich möchte mich zunächst einmal für deine sehr schnelle Rückmeldung bedanken!
Zu deinen Punkten möchte ich gerne noch folgendes ergänzen bzw. anmerken:
1. Als Workaround hatte ich bereits die CPU LLC auf Level 4 händisch eingestellt. Damit funktioniert auch alles soweit ordnungsgemäß. Allerdings liegt m. E. trotzdem ein Fehler bei der Erkennung vor. Beim x370 Gaming K4 hat es mit der Einstellung "auto" von Anfang an richtig funktioniert. Die CPU VID wurde beim Ryzen 7 1800X auf 1,3500 Volt und LLC auf Level 5 eingeregelt. Auch unterstelle ich jetzt mal, dass nicht jeder User die fachliche Expertise besitzt, um solche Workarounds durch langes Testen selber herauszufinden.
2. Ich habe gerade nochmals die Anzahl der entsprechenden Lüfteranschlüsse kontrolliert. Auf meinem x470 Taichi kann ich allerdings nur insgesamt 5 FAN-Anschlüsse finden. Mein CPU Lüfter hängt am CPU_FAN1 und die jeweiligen Gehäuselüfter an "CHA_FANs 1 bis 3". Nach deinen Informationen müsste das Taichi demnach eigentlich alle Lüfter korrekt einregeln, weil alle an dem gleichen IO-Chip hängen. Als halbwegs funktionierenden Workaround hatte ich bereits den "CHA_Fan3" auf den eigentlich falschen DC-Modus eingestellt. Damit weicht das Drehzahlsignal unter Last nurmehr ca. 100 U/min ab. Ist denn geplant den Fehler zu beheben?
3. Könntest du das Umrechungsprinzip digital - analog nochmals etwas verständlicher bzw. genauer erläutern?:) Auch kann ich im UEFI keine einstellbare DRAM LLC finden, noch scheint nach den Messergebnissen (AIDA64 und HWINFO64) die SOC LLC hierauf einfluss zu nehmen. Ich würde mir als User wünschen, dass die eingestellte Spannung immer der Zielvorgabe entspricht und die LLC nur dazu dienen mag, diese auch unter (OC-) Last stabil zu halten. Ich verstehe nicht ganz, warum ASRock das beim x470 Taichi so umsetzt. Beim x370 Gaming K4 entsprach die eingestellte Spannung ebenfalls der Zielvorgabe!
4. Gerade nochmals genau nachgeprüft: (Vorher) x370 Gaming K4 = 5,9 Senkunden. (Jetzt) x470 Tachi = 9,7 Sekunden. Wäre echt super, wenn hier nochmals Hand angelegt werden könnte. Allerding ist das schon wieder meckern auf sehr hohem Niveau. Fairerweise muss man aber auch sagen, dass es sich bei dem Taichi um ein absolutes Premium Mainboard unter den AM4-Boards handelt. Als Käufer erwarte ich mir dann auch einfach "mehr". Insbesondere wenn es bei preisgünstigeren Modellen halt auch deutlich schneller geht.
Nochmals vielen Dank für deinen sehr guten Support!
StarTrokus
Hi@All
Mit dem aktuellen BIOS 5.10 für das X370 Professionale Gaming immer wieder freez im IDLE und Black Screens beim Last Wechsel egal was ich einstelle im Bios, selbst in den Default Settings.
Mit dem Bios L4.81 Läuft wieder alles sauber ohne Probleme!
Kann es sein das im Bios 5.10 meine Corsair Vengeance RGB PRO 3200 nicht sauber erkannt werden?
PuMa
Stell doch mal das Corsair Zusatzprofil im BIOS ein und teste nochmal. Welche Chips bzw. Version ?
Also ich sehe jetzt zumindest erst einmal mit dem 5.10 keine Nachteile zum L4.81. Aber mal eine Frage zu den RAM-Profilen: Kommt da noch etwas oder war das bereits das einmalige ,,Weihnachtsgeschenk"? Oder kann ich zu Ostern noch etwas mehr erwarten?
Typisch deutsch... nur meckern :(
@CyLord
Was möchtest du denn für ein Ram-Profil haben ?
