[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Ich gehe davon aus, dass die neue Generation auch mit dem X370 Board laufen wird.
kann ich auch trotz dieser t-topology auch einfach nur zwei ram riegel a 3200 einbauen, um die dann zu oc auf 3600 oder höher eventuell?
Was genau ist der unterschied zwischen x370 taichi gaming prof und gaming x?
Frage x570 boards, egal ob x570 taichi oder andere konsorten von asrock und hersteller. könnte es sein, das neben dem höheren preis und der etwas höhere preis doch etwas für x570 boards spricht? ich dachte da an folgendes:
besseres pcb, mehr lagen, elektisch stabiler dank besserer vrm und mosfets. bios aktueller mit mehr funktionen, gerade wenn es ans oc geht des rams zB.
mehrere m2 ssd, die mit voller geschwindigkeit laufen könnten zB. wenn man zwei oder drei verbaut und obendrein noch einen dvd toaster und 4 platten zB
schnelleres wlan und bluetooth an board hat zB
mehr usb schnuttstellen extern als auch intern, segment anzeige, toaster onboard und im ioshield, wie usb bios flashback, clearcmos usw.
Auch dachte ich das durch den x570 noch mehr lanes zur verfügung stehen, und auch die verbindung zum memory controller in der cpu als die ansteuerung derselbigen auch besser wäre, weil gerade state-of-art?
auch weiss ich nicht, weil ich keine ältere ryzen cpu habe, wo ich das dafür nötige richtige bios oder beta bios wie einzuspielen habe. ich habe auch berichte gelesen von usern von b450 boards die scheinbar grosse probleme hatten, neue cpus an laufen zu bekommen.
leider bin ich kein experte auf dem gebiet sondern suche mir das alles zusammen denn bevor ich viel geld ausgebe, möchte ich euch lieber dazu fragen.
Was meint ihr dazu? Welchen Hersteller neben Asrock würdet ihr weiter empehlen, eventuell auch Asus?
Ja, man kann zwei Riegel bei T-Topologie einbauen. Da kommt es wegen der Taktrate dann noch auf den Speichercontroller an und/oder Speicher mit Dual Rank.
Der Unterschied ist eher bei der Ausstattung und bei den Bauteilen zu suchen. Das Prof. Gaming ist natürlich mit besseren elektrischen Teilen wie VRM versehen worden.
Man kann bei den X570er eher davon ausgehen, man einen AMD-Chipsatz hat, evtl. stabilere USB-Ports. Da gibt es bei den X370 (wie mein Prof. Gaming) dann doch mal das ein oder andere Problem, dass die Verbindung verloren geht, wenn man Pech hat. PCI-E 4.0 ist natürlich dabei. Man bekommt natürlich kein Board, wo man sagt, dass es eher komplett schlecht ausgestattet ist.
Mir war bei der Auswahl des X570 wichtig, dass es von den VRMs schon besseres Mittelfeld darstellt, Daisy Chain (da ich grundsätzlich 2er-Bestücken einsetze) und ein CMOS eingesetzt wird, dass 32 MB groß ist. Da flog Gigabyte bei mir komplett heraus. Hersteller ist eine Ermessensfrage. Der Support der ASRock ist nicht von schlechten Eltern. Aber ich hätte von denen gerne mehr Daisy Chain. Wobei das bei den neuen Ryzen 3000 vllt. nicht mehr so sehr die Rolle spielt, wie man sagt. Das Steel Legend ist durchaus ausehenswert. Das Biostar X570GT8 ist ein Blick wert. Über ASUS kann ich nicht viel sagen. Aber der Lüfter sollter heruntergeregelt werden können. Bei Biostar kann ich es ganz gut.
Moin,
Hab auf meinen Taichi den Speicher vor kurzem von 2x16gb F4-3200C14D-32GTZR auf 4x16gb F4-3200C14Q-64GTZR aufgestockt. Da war mit dem 1700x natürlich nicht allzuviel zu erwarten.
Mit 2933mhz beim 5.10er Bios war ich da eigentlich ganz zufrieden, zumal die 2x16gb vor Urzeiten (Bios 3.30) zuletzt stabil auf 3200 liefen und seither auch nur mit viel Mühe auf 3066mhz (aus Zeitmangel dann die meiste Zeit doch eher mit 2933mhz).
Das war schönes Plug&Play, 2933 xmp war aktiv, 2x16 raus, 4x16 rein, lüppt, schön.
Habe mir jetzt kurzentschlossen einen 3800x als Ersatz for den 1700x auf dem Taichi besorgt, weil die vielen guten Ergebisse der Matisse CPUs die Hoffnung geweckt hatten den schönen Speicher auch mal etwas fordern zu können.
Aber bisher bin ich da ziemlich enttäuscht :-[
Mit 4x16gb bekomme ich beim 5.80er Bios gerade mal 2933hmz stabil, 3200mhz postet mit Hand anlegen aber das wars dann auch :eek:
Dafür das wir hier von einem T-Topo Board reden ist das ganz schön deprimierend und spricht nicht gerade für das Bios.
Was man teilweise bei overclock.net im Taichi Thread liest in Bezug auf Bios Qualität und das möglicherweise das ABBA gar nicht kommt sondern dann erst ein ABBB macht einem nicht gerade Hoffnung.
Ich meine Boost ist mir Latte, aber zeitnah ein Bios was sauber funktioniert und anständigen XMP support bietet wäre eigentlich ganz schön.
Das Taichi ist ja eigentlich ein schönes Board und technisch super, nur steht und fällt das ganze leider mit dem Bios, und das hat sich gefühlt seit geraumer Zeit nicht zum Positiven entwickelt.
Hat hier sonst jemand 4x16Gb (oder zumindest 4x8Gb) auf dem Taichi mit 3000er Ryzen laufen?
Ähnliche oder andere Erfahrungen? Bin ich doch nur zu blöd die Custom Timings einzutackern? :hust:
4 x DR ist halt nicht so easy, auch nicht für Zen2 auf nem T-Topo board. Max. 2666mhz laut Spec kommt ja nicht von irgendwo her.
Aber der DRAM Calculator kann da schon helfen bei den Custom Timings und anderen Settings...
Ein 3900X für mein X370 ist unterwegs. Mal schauen, was dann so geht.
Da kannst du ja mal austesten, wie weit deine F4-3200C14D-32GTZ gehen. Meine gehen Riegel nur stabil bis DDR4-3400. DDR-3466 ist schon instabil und 3533 nur noch schwarzer Bildschirm.
Dram Calc nutze ich auch, habe auch schon diverse Settings probiert. Termination und CAD war mir bisher immer etwas fremd, aber da hab ich zumindest auch mal die Vorschläge ausm Calc probiert.
Allerdings ohne großen Erfolg. Muss ich aber nochmal ganz in Ruhe im Detail machen, zwischen Tür und Angel wird das nix.
Aber da ich gerade die Möglichkeit hatte, habe ich mal die 4x16gb auf 2 anderen Boards gegengetestet (nur auf die schnelle, kein Dauerstabitest).
Asrock X570 Pro 4 : XMP an, 3200 - lief nicht (Bluescreen beim Boot)
ASUS Prime X470-Pro : XMP an, 3600 & Main Timings auf 16,16,16,36 - lief (zumindest grob mal 15 min Prime)
2x16Gb hab ich neulich nur mal kurz versucht auf dem Taichi, bevor ich da was falsches behaupte lasse ich das erst nochmal laufen :)
Da bin ich mal gespannt :)
Also habe heute nochmal einiges probiert mit 2x16Gb (ob die aus dem F4-3200C14D-32GTZ Kit oder 2 aus dem F4-3200C14Q-64GTZ macht da keinen merklichen Unterschied, sind ja auch theroretisch Riegel mit derselben Spezifikation).
Da das Taichi wenn man XMP aktiviert nur die Werte aus dem SPD in die RAM Timings übernimmt und beim anpassen des Taktes so stehen lässt, habe ich die Subtimings zunächst bei 3200mhz mal alle auf "Auto" gesetzt.
Normal läuft der Takt ja, ich hätte jetzt eigentlich erwartet, daß das Board dann zu Takt und MainTimings (mehr oder weniger) passende Werte einstellt.
Zumindest hatte ich bei ASUS immer den Eindruck es wird entsprechend gehandhabt. Sollte das nicht so sein? Oder funktioniert das nur mit deaktiviertem XMP, das habe ich nicht getestet
Naja, zumindest bootet das Board dann nicht... also die Automatik funktioniert in dem Fall auf jeden Fall nicht.
Hab dann eben überall wo normalerweise die XMP Werte stehen alles per hand eingegeben. Die restlichen Werte werden dann auch angepasst
3600 lief aber partout nicht stabil, da hatte ich immer nach wenigen Minuten einen Fehler, egal was ich an Settings probiert habe
3533 hat aber immmerhin ne Stunde Karhu Ram Test ohne Fehler überstanden
Ich danke dir für den Einblick. Wir liegen ja nicht weit auseinander.
Ich war auch gespannt, jetzt nicht mehr:
Hatte ich schon in einem anderen Forum gepostet, in Englisch:
So, another Ryzen 3000 unsuccessfull try:
A got a 3900X the last days and because i didn't made a decision yet, which X570 board i should buy, i thougt to first try it with the X370 board.
First i saved current bios settings and a lot of bios screens to an USB stick.
Updated my Fatal1ty X370 Pro Gaming to Bios 5.80 and the good old R7 1800X did not care about that. It's running.
After swapping the CPUs, the first try to start ended in a 3..5 second loop with a short flashing of the Debug LED.
After 15 minutes i tried it with one RAM stick in A2. Now some states had been shown during the loop, but always ended in 65 or 66.
This is CPU DXE initialization (CPU module specific) from what i know.
After long time waiting without change i also tried it with removed M2 SSDs, but no change.
One stick Corsair CMK32GX4M2B3000C15 or G.Skill F4-3200C14-16GTZ, just the same.
I also have an unused 2700X CPU here, so i put that on the board and: Seems to be OK.
With the 2 F4-3200C14-16GTZ it is running with XMP3000, everything else default.
So i don't know what is going wrong with the 3900X, maybe the bequit!DarkPowerProP9 750W PSU.
Or i should give it another try after the warming up with the 2700X :drool:
Ich hab's tatsächlich nochmal versucht, aber keine Änderungen.
Ich denke, jetzt wird zuerst einmal der 2700X auf dem X370 Board bleiben und zur native Linux-Maschine werden.
Für den 3900X werde ich mir wahrscheinlich ein Gigabyte X570 Aorus Master holen, das gefällt mir nach dem overprized Aorus Xtreme immer noch am besten.
- Chipsatz/Lüfter nicht ganz so bescheuert platziert wie bei den anderen Boards
- M2 Plätze frei von irgendwelchen Komplett-Abdeckungen
Wie ich schon einmal angemerkt hatte, würden bei mir alle Gigabyte herausfallen. Siehe die Größe des Bausteins für das BIOS.
Hm ok, das ist ja unschön. An der CPU wirds ja kaum liegen, Netzteil sollte ja auch mehr als ausreichend sein (es sei denn, es hat einen wech).
Nach dem Wechsel vom 1700x auf den 3800x hat das Taichi bei mir auch ne gefühlte Ewigkeit gebraucht bis zum ersten Post, aber keine 15 min ^^
Ich kann später nochmal testweise nen 3900x aufs Taichi schnallen, aber würde mich sehr wundern wenn der nicht läuft.
Da wird das Board von der Güte her nicht so dolle sein und das deutigt sich erst richtig an, wenn eine Matisse eingesetzt wird. Hatte auch schon mal ein paar Ausreißer :/
- - - Updated - - -
Asrock gibt drei Jahre Herstellergarantie mit Abwicklung über den Händler.
Musste ich vor kurzem selbst in Anspruch nehmen, da mein altes X370 Taichi zum Verrecken nicht mit dem 3900X und verschiedenen RAM-Kits zusammenarbeiten wollte. Mit dem neuen Austauschboard läuft bislang Alles so wie es soll
Stimmt nicht ganz, es sind 3 Jahre ab Herstellungsdatum ;)
Erste TestBIOSe mit AGESA1004 sehen schon mal sehr gut aus, gerade das Bootverhalten hat sich drastisch verbessert ;)
Schreibe gerade unter Windows mit dem 3900X.
Meine Güte, äh Boards Güte! Ja, die Güte ist wohl nicht so gut.
Auf einem anderen Board läuft die CPU, auch mit meinem Netzteil und dem RAM.
Passt jetzt halt nicht mehr in diesen Thread... ;)
So, aber mit dem Bios 5.8 und dem 2700X läuft das Asrock recht gut (obwohl nur für Zen2 CPUs empfohlen).
Hat jetzt aber schon die zwei NVMEs für das neue Board opfern müssen und jetzt kommt auch noch der Kühler dran, denn der Boxed-Kühler ist schon sehr laut, wenn die CPU mal was tun muss. Das Asrock muss jetzt zuerst mal pausieren.
Ich kümmere mich gerade darum, dass bei den X370 Taichi bald das AGESA 1004 fertig wird ;)
Zurzeit sind bzw. waren in TW einige National-Feiertage und hoffe, dass es Montag wieder los geht :(
Habe leider meine M2 Schrauben verbummelt, oder es waren keine dabei? Kann mir jemand sagen welche Schrauben ich benötige und falls bekannt, wo ich diese bekommen kann?
Vielen Dank!
Kann man die neuen AGESA 1.0.0.4 TestBiose empfehlen? Oder sind die noch zu instabil?
x370 Taichi, wechsel von 5.8 auf 5.91
Boot:
Meinen Empfinden nach die wichtigste Baustelle. Das Update bringt die angedeutete Verbesserung mit sich. Deaktivierung von CSM lässt das 3x "Screen refreshing"(/geblinke) vom Monitor beim betreten des UEFIs verschwinden und die Option "Ultra Fast Boot" ist wieder eine korrekte Betitelung.
Boost:
Kann ich nichts zu sagen.
RAM:
Bei exakt gleichen Haupt- sowie Subtimings habe ich eine deutliche Verbesserung der Latenz von gut und gerne 3-4ns. Diese war allerdings zuvor auch ungewöhnlich hoch im Vergleich zu Ergebnissen von anderen mit ähnlichen Takt und Timings. Die Riegel scheinen sich dafür einen kleinen Schluck Saft mehr zu genehmigen.
clDO VDDG Voltage:
Ob so gewollt oder ein Bug vorliegt, sie lässt sich nicht mehr unter einen Wert von 1.000 setzen.
Stabilität
Heutzutage mache ich nur noch Kurztests und den Rest erledigt der Alltag. Erstere hat auch diese Version bestanden.
So hab auf mein X470 Taichi jetzt das 3.71 Testbios mit AGESA 1.0.0.4 geflasht. Läuft eigentlich ganz gut bis auf meine M.2 SATA SSD welche mit dem neuen Bios nicht mehr erkannt wird. Ist das ein bekanntes Problem?
CMOS gecleared, mehrmals defaults geladen, M.2 Sata SSD wird noch immer nicht erkannt. Ich denke dass es an dem Testbios liegt und das nächste Final das Problem nicht mehr hat.
Werde die Tage wieder auf ein 1.0.0.3er Bios zurückflashen und auf ein finales 1.0.0.4 warten.
Immer diese M2 SATA SSDs :/
Ist die Firmware dort aktuell ?
- - - Updated - - -
In welchem M2 Slot ist die SATA M2 drin ?
Die Firmware meiner WDS200T2B0B ist noch die Originale von 2018.
Die SSD steckt im oberen Slot, der untere kann laut X470 Taichi Produktwebseite nur PCIe SSDs.
Edit: Hab jetzt wieder auf Bios 3.60 downgegraded und meine SSD ist wieder da.
Ich habe seit 3 Wochen das Asrock X370 Taichi mit einem Ryzen 5 3600 am laufen. Heute abend habe ich von die Bios Version von 5.60 auf 5.80 aktualisiert. Das Gehäuse war die ganze Zeit offen.
Seit dem Update auf 5.80 höre ich immer ein Zirpen, welches von unter dem CPU Kühler kommt. Bei last ist es weg. Wenn ich auf dem Desktop bin oder surfe zirpt es leicht. Dies war vor dem Update definitiv nicht der Fall.
Auch kam ich nach dem Update das erste Mal nicht ist Bios und der Bildschirm blieb schwarz. Nach dem Hard reset ist der Rechner nach einigen Minuten auf dem Desktop abgestürzt.
Was kann dieses Verhalten und nun dieses nervie Zirpen bedeuten?
Ist etwas kaputt?
Wenn ja kann ich das Mainboard noch innerhalb einer Woche umtauschen. Auf eine Wochenlange Reparatur hätte ich keine Lust.
