[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
1. Frage: Ryzen 2000 wird dann wohl nicht mehr so ausoptimiert sein oder Funktionen im UEFI wurden eingespart.
2. Frage: Evtl. wird der Macher von JZ was sagen koennen. Aber letzten Endes ist die Grundlage immer von AMD mit der AGESA. Ich habe das Gefuehl, dass erst mit der naechsten Generation der große Flashspeicher interessant wird. Letzten Endes hat man sich sicher fuer die Einbindung von B350/X370 entschieden bei den Combos, weil man die Verbreitung von Ryzen 3000 beschleunigen wollte im Retailmarkt. Ist natuerlich in gewisser Maßen ein Kompromiss. Es gibt ja auch Boards mit X470 von Biostar und Gigabyte mit nur 128 mbit CMOS. Auch beim X570 ging Gigabyte nur den 128 mbit Weg, aber die brauchen die Combos nicht. Vllt. werden manche X470 gar keine Unterstuetzung fuer Ryzeb 4000 bekommen und alle X370 fallen komplett heraus. Es ist alles nur Vermutung. Optimal ist das sicher alles nicht.
Als X470 Taichi Nutzer habe ich einige Fragen zu dem neuen 1.0.0.3ABB Bios.
Heißt das mit einem Ryzen 2000 läuft das Board dann garnicht mehr? Oder läuft es nur nicht optimal? Weil ich möchte schon gern ein aktuelles Bios benutzen bis mein Ryzen 3000 kommt.
Bis dein Ryzen 3000 kommt brauchst Du doch nicht updaten. Wenn Du ihn hast, das Update mit dem 2000er machen und danach CPU Wechsel.
Wäre reine Zeitverschwendung, das 1.0.0.3ABB Bios mit dem 2000er zu probieren.
Das alte AMD AGESA 1.0.0.6 bleibt das optimale für Ryzen 2000.
Kleiner Nachtrag: Interessant ist ja, dass MSI bei manchen B450/X470 die Speicherkapazitaet des CMOS verdoppelt. Ich weiß ehrlich gesagt echt nicht, in welche Richtung es geht.
Ich kann mich Ray666 nur anschließen. Ich habe es auch nicht getan.
BIOS für fatality ist draußen 5.80 mit neuen agesa am we kann ich den ryzen einbauen
Die alten Ryzen werden mit den neuen AGESA schon laufen. Sonst wirds mit dem Update schwierig...
Bitte berichtet wenn ihrs habt. Ich habe auch vor auf das x370 Taichi einen 3800x zu montieren.
Warum bietet man die Bios Dateien nicht getrennt für Ryzen-Generationen an ?
Weil die Matisse User alle nach Updates schreien, gibt es eben Bios Versionen ohne Empfehlung für die älteren CPUs, da wahrscheinlich nicht ausreichend getestet.
Ansonsten müssten die User noch länger warten...
Verstehe ich nicht. Eine Bios Datei die alle 3 unterstützt und ab da kann man auch für einzelne CPU Generationen getrennt machen. Keine Eigenentwicklung, sondern schlicht trennen. Parallel dazu normale Bios Versionen anbieten. Eine Bios Datei nach CPU Generationen zu trennen wird wohl keine Hexenkunst sein.
Das ist keine Hexenkunst, kostet aber vor allem Zeit (und somit Geld): Konfigurationsmanagement-, -Build, -Doku und Testaufwände für ca. 40 Oldgen Boards. Da kommt schnell der Rotstift.
schon wer das 5.80 auf dem Taichi probiert?
bei mir scheint PBO einen Absturz zu verursachen. 3700x
Ich habe ein Taichi aus den allerersten Anfängen - und ich würde gerne meine Neugier bez. der neuen CPUs (speziell 3900X) stillen.
1. Kann man die Kombination ohne größere Probleme laufen lassen?
2. Kann ich direkt auf das neueste BIOS flashen - oder brauche ich irgendwelche Zwischenschritte? CPU ist 1700.
Willkommen im Club, mein 3900X kommt die Tage, dann werde ich näheres wissen.
zu 1) frag doch mal bei _JZ nach, der hat das X370 wieder im Sortiment, vielleicht kann er da schon Auskunft zu geben. Ansonsten wird man hier fündig, wo einige auch den 3900X mit dem Taichi betreiben
zu 2) vom 4.60 (bei mir) kommend das 5.10 für AGESA 1.0.0.6 und für die 3xxx dann das neueste ROM flashen. _JZ hat mir folgenden Hinweis gegeben "Einfach mit der Serie2000 das P5.80 Updaten und wenn im BIOS gesagt wird "Neu Starten" dann dort einfach am Netzteil ausschalten. CPU 3900X rein und Netzteil wieder an" . Dürfte bei meinem 1700X aber genauso laufen
habe massive Probleme mit dem Taichi und 3700x
irgendwer sonst auch? Bios 5.80
Geht nicht um oc.
Alles Stock / Default und schmiert ohne bsod oder Fehlermeldung ab.
Stock und xmp 3200/CL 14 selbe.
Das merkwürdige.. passiert nur im idle sehr sporadisch.
Kann stundenlang zocken oder Benchen..nix. kurz surfen oder am Desktop kommt plötzlich der Absturz.
Kanns nicht nachvollziehen.
Auch schon mit und ohne pbo getestet.
Mit dem 1600x und BIOS 5.50 hatte ich die Probleme nicht
Geht nicht um oc.
Bei dem verlinkten Thread geht es vor allem meist darum, das RAM stabil mit gutem Takt betreiben zu können, insbesondere z.Z eben mit den neuen Ryzens.
Mehr Informationen zum 370er Taichi wirst Du kaum irgendwo finden.
Ansonsten: NEW!!! DRAM Calculator for Ryzenâ„¢ 1.6.0.3 (overclocking DRAM on AM4) + MEMbench 0.8 (DRAM bench) - Overclock.net - An Overclocking Community
Meine F4-3200C14D-32GTZ laufen mit dem XMP Profil ohne weitere Eingriffe auch nicht mit dem 1800X auf dem Fatal1ty-x370-pg
Man darf nicht vergessen, dass das Prof. Gaming nach T-Topologie gebaut worden ist. Ich hatte nie verstanden, warum z.B. MSI diese Taktraten erreicht hat, aber diese ASRock nicht. Daisychain scheint ganz einfach besser zu sein für unsere Bestückung mit DR und solchen Taktraten, die ja nicht umbedingt alltäglich sind mit den F4-3200C14D-32GTZ. Aber F4-3200C16D-32GTZA waren glaube problemloser bei 3200er Takt, so wie ich mich erinnern kann.
Aber ich hätte eigentlich gedacht, dass die neuen Ryzens mit dem Prof. Gaming weniger problematisch sind.
Ums nochmal kurz zu machen:
Es geht nicht um den RAM! Dieser lief bei mir mit seinen Angaben ohne Probleme!
ICH schreibe hier in den MOBO Thread weil ich glaube, dass das BIOS 5.80 für das Taichi X370 in Zusammenhang mit dem 3700x instabil ist!
(meine Vermutung liegt bei Stromsparmodi)
Falls du hierzu nichts sagen kannst, ok - aber verweise nicht dauernd auf OC Threads mit RAM Lösungen
Ich bin neu hier und lese schon lange Zeit mit,
bei mir läuft ein 3700x auf einem Asrock x370 Fatil1ty gaming Pro-
Erstmal möcht ich Danke sagen für die immer aktuellen Biosversionen von JZ-
Probleme wie du sie beschreibst habe ich nicht- Ich habe vom 2700x auf den 3700x umgerüstet, das ging plug n play,
auf dem Board ist eine CustomWakü- der Ram läuft dank Ramcalculator auf 3600- funktionierte vorher auch mit dem xmp- nur sind die timings jetzt schärfer.
Asrock gibt drei Jahre Herstellergarantie mit Abwicklung über den Händler.
Musste ich vor kurzem selbst in Anspruch nehmen, da mein altes X370 Taichi zum Verrecken nicht mit dem 3900X und verschiedenen RAM-Kits zusammenarbeiten wollte. Mit dem neuen Austauschboard läuft bislang Alles so wie es soll
Frage an die Taichi Besitzer, ich plane den Aufbau eines 3000'er System. Meint ihr es macht noch Sinn, auf ein x370 Taichi / Professional Gaming / Gaming X zu setzen?
Als CPU kommt entweder 37x, 38x oder wenn verfügbar eventuell auch ein 39x zum Einsatz. Und 32 GB Crucial Ballistix DDR4-3200 Sport LT zum Einsatz. Nur beim Mobo bin ich mir unsicher, ob
ich nicht doch lieber eines mit x570 verwenden sollte. Hier wäre mein Kandidat das Asus Crosshair Hero VIII.
Wenn du nicht unbedingt zwingend PCIe 4 benötigst spricht doch nichts gegen das X370 Taichi / ProfGam. Bei mir läuft die Kombo aus Taichi / 3900X / Ballistix Sport LT 4x8@3200 problemlos
Ach herrje, jetzt habe ich doch nicht den richtigen Ram ausgewählt. Müsste ich etwa diesen hier verbauen weil das Asrock nur 4 Riegel akzeptiert und diese besser ansteuern kann zum OC zB?
G.Skill Flare X schwarz DIMM Kit 32GB, DDR4-3200, CL14-14-14-34 (F4-3200C14Q-32GFX)
und wenn 2 Riegel reichen, was hälst du von diesen Modulen?
F4-3200C14D-32GTZR, Trident Z RGB
ein Freund hatte mir mal zu diesem hier geraten.
ASUS ROG Crosshair VIII Hero er meinte neue CPU braucht auch einen neuen Chipsatz. Ich bin total verwirrt.
Ich würde nur gerne wissen, ob eine neuere Plattform nicht eher Sinn machen würde? Ich kenne mich null aus mit den Boards von Asrock oder Asus. Ich habe seither immer nur Intel verwendet und würde gerne zwecks Neugier, Enthusiasmus von meiner 6700K Plattform aus auf die neuen Rizen upgraden.
aber brauch ich dann nicht unbedingt vier Riegel wegen dieser Topologie Geschichte?
Hallo. Ich interresiere mich auch für das x370 Taichi in Verbindung mit dem Ryzen 3600.
Bootet das Board bei euch zügig?
Hab derzei ein Asus x470 und das läuft erst kurz an geht aus und startet dann erst normal. Echt nervig.
